    2. dihe85
    D
    • Posts 19
    dihe85
    @dihe85
    19
    dihe85 Follow
    Latest posts made by dihe85
    • RE: Update von admin fehlgeschlagen! Admin startet nicht mehr
      ne wieso sollte ich noch root sein?
      Ich hab mich als root vorhin eingeloggt für die ganzen systemupdates und so
      (bin zu Faul immer Sudo zu schreiben)
      Dirk
      posted in Installation
      D
      dihe85
      Homeserv:/opt/iobroker# iobroker status
      Objects type: file
      States  type: file
      Homeserv:/opt/iobroker# iobroker update
      Used repository: stable
      hash unchanged, use cached sources
      update done
      Adapter    "backitup"      : 2.4.10   , installed 2.4.9 [Updateable]
      Adapter    "daswetter"     : 3.1.2    , installed 3.1.2
      Adapter    "discovery"     : 3.0.5    , installed 3.0.3 [Updateable]
      Adapter    "dwd"           : 2.8.3    , installed 2.8.3
      Adapter    "fhem"          : 1.6.3    , installed 1.6.3
      Adapter    "history"       : 2.2.0    , installed 1.11.1 [Updateable]
      Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "info"          : 1.9.19   , installed 1.9.19
      Adapter    "javascript"    : 6.0.0    , installed 5.7.0 [Updateable]
      Controller "js-controller" : 4.0.23   , installed 3.3.22 [Updateable]
      Adapter    "musiccast"     : 0.1.5    , installed 0.1.5
      Adapter    "ping"          : 1.5.3    , installed 1.5.3
      Adapter    "simple-api"    : 2.7.0    , installed 2.7.0
      Adapter    "socketio"      : 4.2.0    , installed 4.2.0
      Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
      Adapter    "vis"           : 1.4.15   , installed 1.4.15
      Adapter    "vis-hqwidgets" : 1.2.0    , installed 1.2.0
      Adapter    "vis-inventwo"  : 3.3.1    , installed 3.3.1
      Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
      Adapter    "vis-weather"   : 2.5.5    , installed 2.5.5
      Adapter    "weatherunderground": 3.4.2   , installed 3.4.2
      Adapter    "web"           : 4.3.0    , installed 4.3.0
      Adapter    "ws"            : 1.3.0    , installed 1.3.0
      Homeserv:/opt/iobroker# iobroker list instances
        system.adapter.admin.0                  : admin                 : Homeserv                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : Homeserv                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : Homeserv                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : Homeserv                                 -  enabled
      + system.adapter.fhem.0                   : fhem                  : Homeserv                                 -  enabled, port: 7072
      + system.adapter.history.0                : history               : Homeserv                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Homeserv                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Homeserv                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Homeserv                                 -  enabled
      + system.adapter.info.0                   : info                  : Homeserv                                 -  enabled
      + system.adapter.javascript.0             : javascript            : Homeserv                                 -  enabled
      + system.adapter.javascript.1             : javascript            : Homeserv                                 -  enabled
      + system.adapter.musiccast.0              : musiccast             : Homeserv                                 -  enabled
      + system.adapter.ping.0                   : ping                  : Homeserv                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : Homeserv                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : Homeserv                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : Homeserv                                 -  enabled
      + system.adapter.tr-064.1                 : tr-064                : Homeserv                                 -  enabled
      + system.adapter.tr-064.2                 : tr-064                : Homeserv                                 -  enabled
      + system.adapter.tr-064.3                 : tr-064                : Homeserv                                 -  enabled
      + system.adapter.tr-064.4                 : tr-064                : Homeserv                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Homeserv                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : Homeserv                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : Homeserv                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : Homeserv                                 -  enabled
        system.adapter.vis.0                    : vis                   : Homeserv                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : Homeserv                                 -  enabled
      + system.adapter.web.0                    : web                   : Homeserv                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      Dirk
      D
      dihe85
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      spuckt das aus
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      root
      /opt/iobroker
      OK:1 http://phoscon.de/apt/deconz bullseye InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      Paketlisten werden gelesen… Fertig
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           16.17.0-deb-1nodesource1
        Installationskandidat: 16.17.0-deb-1nodesource1
        Versionstabelle:
       *** 16.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u1 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      Dirk
      D
      dihe85
    • Update von admin fehlgeschlagen! Admin startet nicht mehr
      Ich wollte vorhin die Adapter nach längerem mal wieder Updaten.
      Bei dem Update vom Admin hat sich aller aufgehangen und ist eingefrohren.
      Nach 30 min musste ich den Stecker ziehen.
      Jetzt startet Admin nicht mehr.
      node node_modules/iobroker.admin/admin.js --logs
      Führt zu
      node:internal/modules/cjs/loader:959
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.admin/admin.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
          at Function.Module._load (node:internal/modules/cjs/loader:804:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      kann mir einer sagen wie ich das wieder gefixt bekomme?
      Dirk
      D
      dihe85
    • RE: String mit zeige auf View
      Was auch gehen würde einen Navigation button auf trasparent oder die hintergrundfarbe zu stellen.
      Aber auch das bekomm ich irgendwie nicht hin.
      D
      dihe85
      @sigi234
      View in Widget macht doch nen container zu ner anderen View auf.
      Wie bekommen ich denn dann auf den String den View wechsel?
      D
      dihe85
    • String mit zeige auf View
      Hallo zusammen.
      Ich baue mir gerade meine erste Vis zusammen.
      Auf der Startseite möchte ich auch eine Wettervorhersage implementieren.
      Soweit steht das auch schon.
      Aus Platzmangel kann ich aber nur die Vorhersage je Tag darstellen.
      Beispiel: Freitag Regen 4L/m² 10-20°C
      Jetzt würde ich aber gerne auch die deteils sehen können wenn ich z.B. auf den Wochentag klicke.
      5:00 Trocken 0l/m² 8:00 Regen 2l/m² 11:00 Regen 2l/m² .....
      Die Anzeigefelder sind ja nur Strings. Kann ich da irgendwie einen Button draus machen der auf einen neuen View zeigt?
      Dirk
      D
      dihe85
    • RE: [Gelöst]Vis 1.2.4 läuft nicht. Erster start
      @crunchip
      Witzig nach dem "weg werfen" hat er mir wieder die falsche version installiert.
      Diesmal konnte ich aber nachträglich die version downgraden.
      Vielen Dank an alle die geholfen haben und sich die Zeit für mich genommen haben ohne mich zu zerfleischen😉
      Dirk
      D
      dihe85
      @crunchip
      vom API hab ich den runter setzten können bei dem Socket.IO ist der Punkt nicht da
      Bild Text
      Wie bekomme ich den dann jetzt auf 3.0.9 runter?
      Dirk
      D
      dihe85
      Nachtrags
      socket auf 3.0.9
      API auf 2.4.6
      Dirk
      D
      dihe85
