    2. matyi
    • Posts 2
    matyi
    @matyi
    matyi Follow
    Latest posts made by matyi
    • RE: Neuinstall, Adapter lassen sich nicht installieren
      @Linedancer said in Neuinstall, Adapter lassen sich nicht installieren:
      Kaum macht mal es richtig, geht's. Ich hatte die falsche Debian Version erwischt. Hatte zuerst die i386. Die hat die oben beschriebenen Fehler verursacht. Hab jetzt die amd64 verwendet.
      Ich scheine eine sehr/ähnliche Fehlermeldung zu bekommen, wie du eingangs beschrieben hast und wollte nachfragen warum das von der Architektur des Betriebssystems abhängig ist, ob ich einen Adapter installieren kann oder nicht. Das du unabhängig dessen deine volle 16 GB RAM nutzen möchtest, verstehe ich nat. 🙂
      matyi
    • Installation issues due to npm node.js version compatibility
      Hello all,
      I started using ioBroker yesterday and it took me till today to get it started. I guess it's good to share the experience to improve the scripts/workflow/documentation. I was going through the following while until setting up ioBorder successfully (roughly reproduced):
      1. trial:
      • setting up a VM with Debian Buster including updating the system.
      • First I was following the instructions using this guide: https://www.iobroker.net/docu/index-15.htm?page_id=8323&lang=de
        I googled for the current node.js version and installed version 10.x intuitively. Axecuting the following command indicated my main issue already
      node -v
      nodejs -v
      npm -v
      the command npm couln'd be found! I simply ignored this issueand installted ioBroker. I couldn't load the ioBroker configuration page.
      1. trial:
      • uninstalled all packages by using:
      update-rc.d iobroker.sh remove
      sudo apt-get remove nodejs
      sudo apt-get remove npm
      • Subsequently, I used the following instructions to install your software: https://www.iobroker.net/#de/download
      • some warnings appeared during installation including that npm is not compatible with the installed nodejs version. I couldn't load the ioBroker configuration page again.
      • I tried to fix this issue by using this troubleshooting instruchtions https://www.iobroker.net/docu/index-26.htm?page_id=3928&lang=de and installing the recent version of npm:
      curl https://www.npmjs.com/install.sh | sudo sh
      from here: https://github.com/nodejs/help/issues/1877
      however no success again
      1. trial
      • since I lost the overview of installed software I reseted the VM to the point after updating the operating system.
      • Again I tried to use the instructions from here: https://www.iobroker.net/#de/download without success.
      • After reseting again I used the following sequence of commands:
      curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
      sudo apt-get install -y nodejs
      curl -sL https://iobroker.net/install.sh | bash -
      With success!!! Now I'm happy to be able to load the web interface of ioBroker. 😊
      I'm curious to learn how it works 😀
      Cheers,
      Matyi
      Systemdata
      Hardwaresystem: Virtual Box
      Arbeitsspeicher: 1GB
      Festplattenart: 8 GB
      Betriebssystem: Debian Buster with Raspberry Pi Desktop
      Node-Version: 10.15.2
      Nodejs-Version: 10.15.2
      NPM-Version: 6.13.7
      Installationsart: Skript
      Image genutzt: Nein
      aguilared created this issue in nodejs/help
      closed npm does not support Node.js v10.15.2 #1877
      matyi
