    2. Schaimania
    • Posts 2
    Schaimania
    @Schaimania
    25
    Schaimania Follow
    Latest posts made by Schaimania
    • RE: [Frage] analoge Temperatursensoren über I2C auslesen
      Hallo paul53, vielen Dankf ür die schnelle Antwort. Sobald wir das Programm installieren, kommt eine Fehlermeldung.
      Hier einmal der Errorlog:
      root@Heizung:~# cd /opt/iobroker
      root@Heizung:/opt/iobroker# npm install nodejs-adcpi
      i2c@0.2.1 install /opt/iobroker/node_modules/nodejs-adcpi/node_modules/i2c
      node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/nodejs-adcpi/node_modules/i2c/build'
      CXX(target) Release/obj.target/i2c/src/i2c.o
      ../src/i2c.cc: In function ‘void ReadBlock(const v8::FunctionCallbackInfov8::value&)’:
      ../src/i2c.cc:162:47: error: no matching function for call to ‘New(int32_t&)’ Local <object>buffer = node::Buffer::New(len);
      ../src/i2c.cc:162:47: note: candidates are:
      In file included from ../src/i2c.cc:2:0:
      /root/.node-gyp/4.8.3/include/node/node_buffer.h:31:40: note: v8::MaybeLocal v8::objectnode::Buffer::New(v8::Isolate*, size_t)
      NODE_EXTERN v8::MaybeLocal v8::objectNew(v8::Isolate* isolate, size_t length);
      /root/.node-gyp/4.8.3/include/node/node_buffer.h:31:40: note: candidate expects 2 arguments, 1 provided
      /root/.node-gyp/4.8.3/include/node/node_buffer.h:34:40: note: v8::MaybeLocal v8::objectnode::Buffer::New(v8::Isolate*, v8::Localv8::string, node::encoding)
      /root/.node-gyp/4.8.3/include/node/node_buffer.h:34:40: note: candidate expects 3 arguments, 1 provided
      /root/.node-gyp/4.8.3/include/node/node_buffer.h:39:40: note: v8::MaybeLocal v8::objectnode::Buffer::New(v8::Isolate*, char*, size_t, node::Buffer::FreeCallback, void*)
      /root/.node-gyp/4.8.3/include/node/node_buffer.h:39:40: note: candidate expects 5 arguments, 1 provided
      /root/.node-gyp/4.8.3/include/node/node_buffer.h:46:40: note: v8::MaybeLocal v8::objectnode::Buffer::New(v8::Isolate*, char*, size_t)
      /root/.node-gyp/4.8.3/include/node/node_buffer.h:46:40: note: candidate expects 3 arguments, 1 provided
      i2c.target.mk:92: recipe for target 'Release/obj.target/i2c/src/i2c.o' failedmake: *** [Release/obj.target/i2c/src/i2c.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/nodejs-adcpi/node_modules/i2c/build'
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack at emitTwo (events.js:87:13)
      gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      gyp ERR! System Linux 4.4.50-v7+
      gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/nodejs-adcpi/node_modules/i2c
      gyp ERR! node -v v4.8.3
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      npm ERR! Linux 4.4.50-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "nodejs-adcpi"
      npm ERR! node v4.8.3
      npm ERR! npm v2.15.11
      npm ERR! code ELIFECYCLE
      npm ERR! i2c@0.2.1 install: node-gyp rebuild
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the i2c@0.2.1 install script 'node-gyp rebuild'.
      npm ERR! This is most likely a problem with the i2c package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node-gyp rebuild
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs i2c
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR! npm owner ls i2c
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR! /opt/iobroker/npm-debug.log
      Vielen Dank für die Hilfe im Voraus</v8::object></v8::object></v8::object></v8::object></v8::object></v8::string></v8::object></v8::object></v8::object></object></v8::value>
      Schaimania
    • [Frage] analoge Temperatursensoren über I2C auslesen
      MOD-Edit by eric2905; 09.05.2017 / 10:15; Betreff geändert
      Hallo Zusammen,
      wir möchten unsere alte Heizungssteuerung rausschmeißen und die Heizung über einen Raspberry Pi steuern.
      Da wir aber die alten PT1000 Temperatursensoren nicht rausschmeißen wollen, wollen wir die Werte der PT1000 über den IO Broker auswerten.
      Die PT1000 werden über ADC Pi + eingelesen und sollen im IO Broker ausgewertet werden.
      Die ADC Pi + Platine wird über I2C angebunden.
      <u>Hier haben wir folgendes Problem:</u>
      Wie können wir I2C Werte über den IO Broker einlesen?
      Vielen Dank im Voraus.
      Schaimania
