  2. English
  4. Mac OS: adapter installation error
    apollon77A
2 Beiträge 2 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • K
    K
    Kositch
    Hello, I have installed latest ioBroker on Mac OS Sonoma (Mac Mini M1) and I receive error as shown in log example during installation of any adapter, when I repeat the installation the adapter seems to be installed, it can create instances, which works, but when I reboot OS and ioBroker is realaunched, all adapters are missing and it tries to install them again which failes with same error. When I reinstall them manually, it works again. Any help appreciated. Thanks!
    host.unifi
    2025-02-22 16:39:10.294	info	iobroker npm-install: exit 25
    host.unifi
    2025-02-22 16:39:09.274	error	iobroker npm-install: host.unifi Cannot install iobroker.mqtt@6.1.2: 243
    host.unifi
    2025-02-22 16:39:09.274	error	iobroker npm-install: npm error code EACCESnpm error syscall opennpm error path /usr/local/iobroker/package.jsonnpm error errno -13npm error Error: EACCES: permission denied, open '/usr/local/iobroker/package.json'npm error at async open (node:internal/fs/promises:639:25)npm error at async writeFile (node:internal/fs/promises:1212:14)npm error at async PackageJson.save (/usr/local/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:250:14)npm error at async [saveIdealTree] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1512:9)npm error at async Arborist.reify (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:148:5)npm error at async Install.exec (/usr/local/lib/node_modules/npm/lib/commands/install.js:150:5)npm error at async Npm.exec (/usr/local/lib/node_modules/npm/lib/npm.js:207:9)npm error at async module.exports (/usr/local/lib/node_modules/npm/lib/cli/entry.js:74:5) {npm error errno: -13,npm error code: 'EACCES',npm error syscall: 'open',npm error path: '/usr/local/iobroker/package.json'npm error }npm errornpm error The operation was rejected by your operating system.npm error It is likely you do not have the permissions to access this file as the current usernpm errornpm error If you believe this might be a permissions issue, please double-check thenpm error permissions of the file and its containing directories, or try runningnpm error the command again as root/Administrator.npm error A complete log of this run can be found in: /Users/michal/.npm/_logs/2025-02-22T15_39_06_838Z-debug-0.log
    host.unifi
    2025-02-22 16:39:06.764	info	iobroker npm-install: Installing iobroker.mqtt@6.1.2... (System call)
    host.unifi
    2025-02-22 16:39:06.764	info	iobroker npm-install: NPM version: 10.8.2
    host.unifi
    2025-02-22 16:39:06.106	info	iobroker install mqtt@6.1.2 using installedVersion
    host.unifi
    2025-02-22 16:39:06.105	warn	startInstance cannot find adapter "mqtt@6.1.2". Try to install it... 2 attempt
    host.unifi
    2025-02-22 16:39:05.097	info	iobroker npm-install: exit 25
    host.unifi
    2025-02-22 16:39:04.080	error	iobroker npm-install: host.unifi Cannot install iobroker.vw-connect@0.6.1: 243
    host.unifi
    2025-02-22 16:39:04.080	error	iobroker npm-install: npm error code EACCESnpm error syscall opennpm error path /usr/local/iobroker/package.jsonnpm error errno -13npm error Error: EACCES: permission denied, open '/usr/local/iobroker/package.json'npm error at async open (node:internal/fs/promises:639:25)npm error at async writeFile (node:internal/fs/promises:1212:14)npm error at async PackageJson.save (/usr/local/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:250:14)npm error at async [saveIdealTree] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1512:9)npm error at async Arborist.reify (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:148:5)npm error at async Install.exec (/usr/local/lib/node_modules/npm/lib/commands/install.js:150:5)npm error at async Npm.exec (/usr/local/lib/node_modules/npm/lib/npm.js:207:9)npm error at async module.exports (/usr/local/lib/node_modules/npm/lib/cli/entry.js:74:5) {npm error errno: -13,npm error code: 'EACCES',npm error syscall: 'open',npm error path: '/usr/local/iobroker/package.json'npm error }npm errornpm error The operation was rejected by your operating system.npm error It is likely you do not have the permissions to access this file as the current usernpm errornpm error If you believe this might be a permissions issue, please double-check thenpm error permissions of the file and its containing directories, or try runningnpm error the command again as root/Administrator.npm error A complete log of this run can be found in: /Users/michal/.npm/_logs/2025-02-22T15_38_58_539Z-debug-0.log
    host.unifi
    2025-02-22 16:38:58.419	info	iobroker npm-install: Installing iobroker.vw-connect@0.6.1... (System call)
    host.unifi
    2025-02-22 16:38:58.418	info	iobroker npm-install: NPM version: 10.8.2
    host.unifi
    2025-02-22 16:38:57.326	info	iobroker install vw-connect@0.6.1 using installedVersion
    host.unifi
    2025-02-22 16:38:57.325	warn	startInstance cannot find adapter "vw-connect@0.6.1". Try to install it... 1 attempt
    Systemdata Bitte Ausfüllen
    Adaptername: All Adapters
    js-controller Version: v20.17.0
    Admin Version: 7.4.10
    Hardwaresystem: Mac Mini M1
    Arbeitsspeicher: 8 GB
    Festplattenart: 256 GB SSD
    Betriebssystem: Mac OS Sonoma
    Nodejs-Version: v20.17.0
    NPM-Version: 10.8.2
    Installationsart: Skript from official website - finished without any issues
    Image / Docker genutzt: No
    • K Kositch
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      host.unifi
      NPM-Version: 10.8.2
      mcm1957M
      mcm1957M
      mcm1957
      @kositch
      I would suggest to run iob fix
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      84.1k
      1.4m
