  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Управление GPIO в orange pi zero
    5.9k
2 Beiträge 2 Kommentatoren 2.1k Aufrufe
  • L Offline
    leikocid
    Доброго дня, подскажите кто знает при помощи чего можно реализовать управление GPIO orange pi zero к которой будут подключены релейные модули для управления светом, спасибо
      Alekseym6
      ! var gpio = require("gpio");
      ! var gpioSensDoor = 87;
      ! var gpioRelLamp1 = 88;
      ! var gpioSensMotion = 89;
      ! var gpioRelLamp2 = 94;
      ! createState('SensDoor','',{type:'boolean',role:'indicator.state',read:true});
      ! createState('RelLamp1','',{type:'boolean',role:'indicator.state',read:true});
      ! createState('RelLamp2','',{type:'boolean',role:'indicator.state',read:true});
      ! createState('SensMotionVestibul','',{type:'boolean',role:'indicator.state',read:true});
      ! var gpioObjsCount1, gpioObjsCount2, gpioObjsCount3, gpioObjsCount4, gpioObjsCount5, gpioObjsCount6,
      ! gpioObjsCount7, gpioObjsCount8, gpioObjsCount9, gpioObjsCount10, gpioObjsCount11, gpioObjsCount12,
      ! gpioObjsCount13, gpioObjsCount14, gpioObjsCount15, gpioObjsCount16, gpioObjsCount17;
      ! // Calling export with a pin number will export that header and return a gpio header instance
      ! var gpio87 = gpio.export(gpioSensDoor, {
      ! // When you export a pin, the default direction is out. This allows you to set
      ! // the pin value to either LOW or HIGH (3.3V) from your program.
      ! direction: 'in',
      ! // set the time interval (ms) between each read when watching for value changes
      ! // note: this is default to 100, setting value too low will cause high CPU usage
      ! interval: 100,
      ! // Due to the asynchronous nature of exporting a header, you may not be able to
      ! // read or write to the header right away. Place your logic in this ready
      ! // function to guarantee everything will get fired properly
      ! ready: function() {
      ! var gpio88 = gpio.export(gpioRelLamp1, {
      ! direction: 'out',
      ! var gpio89 = gpio.export(gpioSensMotion, {
      ! direction: 'in',
      ! var gpio94 = gpio.export(gpioRelLamp2, {
      ! direction: 'out',
      ! // bind to the "change" event
      ! gpio87.on("change", function(val) {
      ! // value will report either 1 or 0 (number) when the value changes
      ! if ( val == 1 ) {
      ! setState('SensDoor', true, true);
      ! } else {
      ! setState('SensDoor', false, true);
      ! gpio89.on("change", function(val) {
      ! if ( val == 1 ) {
      ! setState('SensMotionVestibul', true, true);
      ! } else {
      ! setState('SensMotionVestibul', false, true);
      ! on("RelLamp1", function (obj) {
      ! if ( obj.newState.val == 1 ) {
      ! gpio88.set();
      ! } else {
      ! gpio88.set(0);
      ! on("RelLamp2", function (obj) {
      ! gpio94.set();
      ! } else {
      ! gpio94.set(0);
