  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Ошибки при установке контроллера и драйверов
    5.4k
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
4 Beiträge 3 Kommentatoren 4.1k Aufrufe
  • V Offline
    V Offline
    vladragor
    При установке iobroker выдает такие ошибки
    Вроде и админка и web запускаются …но все ж ..
    первая установка ..
    Есть идеи как это лечить?
    устанавливал на ubuntu server 16.04
    root@isua:/opt/iobroker# sudo npm install iobroker --unsafe-perm
    ! > iobroker@0.9.0 install /opt/iobroker/node_modules/iobroker
    node lib/setup.js
    ! npm install iobroker.js-controller --production --prefix /opt/iobroker
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.j son'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    npm install iobroker.admin --production --prefix /opt/iobroker
    npm install iobroker.discovery --production --prefix /opt/iobroker
    In file included from ../src/dns_sd.cpp:1:0:
    ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Нет такого файла или каталога
    compilation terminated.
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Ошибка 1
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_m odules/node-gyp/lib/build.js:285:23)
    gyp ERR! stack at emitTwo (events.js:106:13)
    gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_proces s.js:215:12)
    gyp ERR! System Linux 4.4.0-78-generic
    gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/ node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns
    gyp ERR! node -v v6.10.3
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    npm WARN optional dep failed, continuing mdns@2.3.3
    Write "./iobroker start" to start the ioBroker
    /usr/bin/env: «node\r»: Нет такого файла или каталога
    Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable aut o-start
    iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
    /opt/iobroker
    └─┬ iobroker@0.9.0
    └─┬ yargs@7.1.0
    ├── camelcase@3.0.0
    ├─┬ cliui@3.2.0
    │ ├─┬ strip-ansi@3.0.1
    │ │ └── ansi-regex@2.1.1
    │ └── wrap-ansi@2.1.0
    ├── decamelize@1.2.0
    ├── get-caller-file@1.0.2
    ├─┬ os-locale@1.4.0
    │ └─┬ lcid@1.0.0
    │ └── invert-kv@1.0.0
    ├─┬ read-pkg-up@1.0.1
    │ ├─┬ find-up@1.1.2
    │ │ ├── path-exists@2.1.0
    │ │ └─┬ pinkie-promise@2.0.1
    │ │ └── pinkie@2.0.4
    │ └─┬ read-pkg@1.1.0
    │ ├─┬ load-json-file@1.1.0
    │ │ ├── graceful-fs@4.1.11
    │ │ ├─┬ parse-json@2.2.0
    │ │ │ └─┬ error-ex@1.3.1
    │ │ │ └── is-arrayish@0.2.1
    │ │ ├── pify@2.3.0
    │ │ └─┬ strip-bom@2.0.0
    │ │ └── is-utf8@0.2.1
    │ ├─┬ normalize-package-data@2.3.8
    │ │ ├── hosted-git-info@2.4.2
    │ │ ├─┬ is-builtin-module@1.0.0
    │ │ │ └── builtin-modules@1.1.1
    │ │ ├── semver@5.3.0
    │ │ └─┬ validate-npm-package-license@3.0.1
    │ │ ├─┬ spdx-correct@1.0.2
    │ │ │ └── spdx-license-ids@1.2.2
    │ │ └── spdx-expression-parse@1.0.4
    │ └── path-type@1.1.0
    ├── require-directory@2.1.1
    ├── require-main-filename@1.0.1
    ├── set-blocking@2.0.0
    ├─┬ string-width@1.0.2
    │ ├── code-point-at@1.1.0
    │ └─┬ is-fullwidth-code-point@1.0.0
    │ └── number-is-nan@1.0.1
    ├── which-module@1.0.0
    ├── y18n@3.2.1
    └── yargs-parser@5.0.0
    ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.j son'
    • BluefoxB Offline
      BluefoxB Offline
      Это не страшно. Но можно сделать так
      sudo apt-get install build-essential libavahi-compat-libdnssd-dev
      • V Offline
        V Offline
        vladragor
        Ну да вообщем все работает…но как то привык что лучше сразу устранить даже мелкие ошибки...
        Переустановил брокера
        ! root@isua:/opt/iobroker# node -v
        ! v7.10.0
        ! root@isua:/opt/iobroker# npm -v
        ! 4.2.0
        все равно есть несколько вопросов…
        в установке iobrokera инструкции последним пунктом стоит
        sudo unit 6
        У меня ubuntu 16.04 server ругается
        sudo: unit: команда не найдена
        ну и вроде установка прошла лучше благодаря
        но все равно отсутствующие директории
        ! root@isua:/opt/iobroker# sudo npm install iobroker –unsafe-perm
        ! > iobroker@1.0.0 install /opt/iobroker/node_modules/iobroker
        ! > node lib/setup.js
        ! npm install iobroker.discovery --production --prefix /opt/iobroker
        ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
        ! npm WARN iobroker No description
        ! npm WARN iobroker No repository field.
        ! npm WARN iobroker No README data
        ! npm WARN iobroker No license field.
        ! npm install iobroker.admin --production --prefix /opt/iobroker
        ! npm WARN iobroker No license field.npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
        ! Write "./iobroker start" to start the ioBroker
        ! /usr/bin/env: «node\r»: Нет такого файла или каталога
        ! Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
        ! iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
        ! /opt/iobroker
        ! └─┬ iobroker@1.0.0
        ! └─┬ yargs@7.1.0
        ! ├── camelcase@3.0.0
        ! ├─┬ cliui@3.2.0
        ! │ ├─┬ strip-ansi@3.0.1
        ! │ │ └── ansi-regex@2.1.1
        ! │ └── wrap-ansi@2.1.0
        ! ├── decamelize@1.2.0
        ! ├── get-caller-file@1.0.2
        ! ├─┬ os-locale@1.4.0
        ! │ └─┬ lcid@1.0.0
        ! │ └── invert-kv@1.0.0
        ! ├─┬ read-pkg-up@1.0.1
        ! │ ├─┬ find-up@1.1.2
        ! │ │ ├── path-exists@2.1.0
        ! │ │ └─┬ pinkie-promise@2.0.1
        ! │ │ └── pinkie@2.0.4
        ! │ └─┬ read-pkg@1.1.0
        ! │ ├─┬ load-json-file@1.1.0
        ! │ │ ├── graceful-fs@4.1.11
        ! │ │ ├─┬ parse-json@2.2.0
        ! │ │ │ └─┬ error-ex@1.3.1
        ! │ │ │ └── is-arrayish@0.2.1
        ! │ │ ├── pify@2.3.0
        ! │ │ └─┬ strip-bom@2.0.0
        ! │ │ └── is-utf8@0.2.1
        ! │ ├─┬ normalize-package-data@2.3.8
        ! │ │ ├── hosted-git-info@2.4.2
        ! │ │ ├─┬ is-builtin-module@1.0.0
        ! │ │ │ └── builtin-modules@1.1.1
        ! │ │ ├── semver@5.3.0
        ! │ │ └─┬ validate-npm-package-license@3.0.1
        ! │ │ ├─┬ spdx-correct@1.0.2
        ! │ │ │ └── spdx-license-ids@1.2.2
        ! │ │ └── spdx-expression-parse@1.0.4
        ! │ └── path-type@1.1.0
        ! ├── require-directory@2.1.1
        ! ├── require-main-filename@1.0.1
        ! ├── set-blocking@2.0.0
        ! ├─┬ string-width@1.0.2
        ! │ ├── code-point-at@1.1.0
        ! │ └─┬ is-fullwidth-code-point@1.0.0
        ! │ └── number-is-nan@1.0.1
        ! ├── which-module@1.0.0
        ! ├── y18n@3.2.1
        ! └── yargs-parser@5.0.0
        ! root@isua:/opt/iobroker# sudo unit 6
        ! sudo: unit: команда не найдена
        беспокоят…и устранимо ли это...
        заранее спасибо..
          spectrekr
          @vladragor:
          ! v7.10.0
          ! 4.2.0
          sudo unit 6
          ! /opt/iobroker
          ! └─┬ yargs@7.1.0
          ! ├─┬ cliui@3.2.0
          ! │ └─┬ lcid@1.0.0
          ! ├── y18n@3.2.1
          заранее спасибо.. `
          Там должна быть команда
          sudo init 6
          видно опечатка, еще можно
          sudo reboot
