  2. Русский
  3. ioBroker
  4. Скрипты
  5. ioBroker скрипты
  6. Управление GPIO
    2.8k
    4.8k
    4.0k
Управление GPIO
Geplant Angeheftet Gesperrt Verschoben ioBroker скрипты
4 Beiträge 3 Kommentatoren 2.3k Aufrufe
    Alekseym6
    пример рабочего скрипта
    var gpio = require("gpio");
    var gpioSensDoor = 87;
    var gpioRelLamp1 = 88;
    var gpioSensMotion = 89;
    var gpioRelLamp2 = 94;
    createState('SensDoor','',{type:'boolean',role:'indicator.state',read:true});
    createState('RelLamp1','',{type:'boolean',role:'indicator.state',read:true});
    createState('RelLamp2','',{type:'boolean',role:'indicator.state',read:true});
    createState('SensMotionVestibul','',{type:'boolean',role:'indicator.state',read:true});
    // Calling export with a pin number will export that header and return a gpio header instance
    var gpio87 = gpio.export(gpioSensDoor, {
    // When you export a pin, the default direction is out. This allows you to set
    // the pin value to either LOW or HIGH (3.3V) from your program.
    direction: 'in',
    // set the time interval (ms) between each read when watching for value changes
    // note: this is default to 100, setting value too low will cause high CPU usage
    interval: 100,
    // Due to the asynchronous nature of exporting a header, you may not be able to
    // read or write to the header right away. Place your logic in this ready
    // function to guarantee everything will get fired properly
    ready: function() {
    var gpio88 = gpio.export(gpioRelLamp1, {
    direction: 'out',
    ready: function() {
    var gpio89 = gpio.export(gpioSensMotion, {
    direction: 'in',
    ready: function() {
    var gpio94 = gpio.export(gpioRelLamp2, {
    direction: 'out',
    ready: function() {
    // bind to the "change" event
    gpio87.on("change", function(val) {
    // value will report either 1 or 0 (number) when the value changes
    if ( val == 1 ) {
    setState('SensDoor', true, true);
    } else {
    setState('SensDoor', false, true);
    gpio89.on("change", function(val) {
    if ( val == 1 ) {
    setState('SensMotionVestibul', true, true);
    } else {
    setState('SensMotionVestibul', false, true);
    on("RelLamp1", function (obj) {
    if ( obj.newState.val == 1 ) {
    gpio88.set();
    } else {
    gpio88.set(0);
    on("RelLamp2", function (obj) {
    gpio94.set();
    } else {
    gpio94.set(0);
    • V Offline
      V Offline
      vtec
      Управление gpio это хорошо, но может плату укажите какой управляете?
        spectrekr
        Угу, а еще желательно от какого пользователя работает IOBroker, и если не от root, то как организовали доступ пользователю к параметрам GPIO.
          Alekseym6
          сечас работает на ODROID X2 и C1+, раньше запускал на Raspberry PI2, Cubieboard. работает от user(не root).
          нужно добавить user в группу gpio
