  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Homekit
    5.9k
Homekit
3 Beiträge 2 Kommentatoren 1.4k Aufrufe
  • Z Offline
    Z Offline
    znammut
    Здравствуйте, не получается установить Homekit:
    ./iobroker add homekit
    npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call)
    In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
    #include <dns_sd.h>
    ! compilation terminated.
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
    gyp
    ERR! build error
    gyp ERR! stack
    Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    gyp
    ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)gyp
    ERR! System Linux 3.4.112-sun8igyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR!
    cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdnsgyp ERR! node -v v4.4.7
    gyp ERR! node-gyp -v v3.3.1
    gyp ERR! not ok
    ! npm
    ERR! Linux 3.4.112-sun8i
    npm ERR! argv
    "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.4.7
    npm ERR! npm v2.15.8
    ! npm ERR! code ELIFECYCLE
    npm ERR! mdns@2.2.11 install: node-gyp rebuild
    npm ERR! Exit status 1
    npm
    ERR! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
    npm ERR! This is most likely a problem with the mdns package,
    npm
    ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR!
    You can get information on how to open an issue for this project with:npm ERR! npm bugs mdns
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR!
    npm owner ls mdnsnpm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    ! ERROR: host.orangepipc-1 Cannot install iobroker.homekit: 1
    ERROR: process exited with code 25</dns_sd.h>
    Armbian ставил по инструкции с вашего сайта. Опыт работы с Юникс системами есть, с Node нет. Как починить?
    С уважением Дмитрий
    • BluefoxB Offline
      BluefoxB Offline
      Вроде бы нужна версия node.js 4.xx
      и
      ` > Note: one some systems additional package is required
      sudo apt-get install libavahi-compat-libdnssd-dev
      • Z Offline
        Z Offline
        znammut
        Спасибо получилось, надо было раньше спросить.
