  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. FreeBSD
    5.4k
FreeBSD
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
7 Beiträge 2 Kommentatoren 2.8k Aufrufe
    boba
    ставлю по инструкции отсюда http://forum.iobroker.net/viewtopic.php … sd.#p22467
    (там неточность небольшая "sudo chmod 777 /opt/iobroker/. -R" ключ после команды должен быть)
    все встает без ошибок и запускается.
    а дальше:
    root /opt/iobroker # iobroker add vis        11:23
    npm install iobroker.vis --production --prefix "/opt/iobroker" (System call)
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    host.home.su install adapter vis
    npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
    npm ERR! FreeBSD 10.2-RELEASE
    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.vis"
    npm ERR! node v6.1.0
    npm ERR! npm  v3.8.8
    npm ERR! path /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
    npm ERR! code ENOENT
    npm ERR! errno -2
    npm ERR! syscall rename
    npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
    npm ERR! enoent This is most likely not a problem with npm itself
    npm ERR! enoent and is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log
    Cannot install iobroker.vis: 254
    root /opt/iobroker # uname -a
    FreeBSD home.su 10.2-RELEASE FreeBSD 10.2-RELEASE #0 r286835: Mon Aug 17 10:34:15 YEKT 2015     root@home.su:/usr/obj/usr/src/sys/MYKERNEL9  amd64
    root /opt/iobroker # node -v
    v6.1.0
    root /opt/iobroker # npm -v
    3.8.8
    ! root /opt/iobroker # cat /opt/iobroker/npm-debug.log 11:40
    ! 0 info it worked if it ends with ok
    ! 1 verbose cli [ '/usr/local/bin/node',
    ! 1 verbose cli '/usr/local/bin/npm',
    ! 1 verbose cli 'install',
    ! 1 verbose cli '–production',
    ! 1 verbose cli '--prefix',
    ! 1 verbose cli '/opt/iobroker/node_modules/iobroker.vis' ]
    ! 2 info using npm@3.8.8
    ! 3 info using node@v6.1.0
    ! 4 silly loadCurrentTree Starting
    ! 5 silly install loadCurrentTree
    ! 6 silly install readLocalPackageData
    ! 7 silly install normalizeTree
    ! 8 silly loadCurrentTree Finishing
    ! 9 silly loadIdealTree Starting
    ! 10 silly install loadIdealTree
    ! 11 silly cloneCurrentTree Starting
    ! 12 silly install cloneCurrentTreeToIdealTree
    ! 13 silly cloneCurrentTree Finishing
    ! 14 silly loadShrinkwrap Starting
    ! 15 silly install loadShrinkwrap
    ! 16 silly loadShrinkwrap Finishing
    ! 17 silly loadAllDepsIntoIdealTree Starting
    ! 18 silly install loadAllDepsIntoIdealTree
    ! 19 silly loadAllDepsIntoIdealTree Finishing
    ! 20 silly idealTree:prePrune iobroker.vis@0.9.4
    ! 21 silly loadIdealTree Finishing
    ! 22 silly currentTree iobroker.vis@0.9.4
    ! 23 silly idealTree iobroker.vis@0.9.4
    ! 24 silly generateActionsToTake Starting
    ! 25 silly install generateActionsToTake
    ! 26 silly generateActionsToTake Finishing
    ! 27 silly diffTrees action count 1
    ! 28 silly diffTrees update iobroker.vis@0.9.4
    ! 29 silly decomposeActions action count 8
    ! 30 silly decomposeActions fetch iobroker.vis@0.9.4
    ! 31 silly decomposeActions extract iobroker.vis@0.9.4
    ! 32 silly decomposeActions test iobroker.vis@0.9.4
    ! 33 silly decomposeActions preinstall iobroker.vis@0.9.4
    ! 34 silly decomposeActions build iobroker.vis@0.9.4
    ! 35 silly decomposeActions install iobroker.vis@0.9.4
    ! 36 silly decomposeActions postinstall iobroker.vis@0.9.4
    ! 37 silly decomposeActions finalize iobroker.vis@0.9.4
    ! 38 silly executeActions Starting
    ! 39 silly install executeActions
    ! 40 silly doSerial global-install 0
    ! 41 silly doParallel fetch 1
    ! 42 verbose correctMkdir /root/.npm/_locks correctMkdir not in flight; initializing
    ! 43 verbose lock using /root/.npm/_locks/staging-40fe0fc83e86560c.lock for /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging
    ! 44 silly doParallel extract 1
    ! 45 silly extract iobroker.vis@0.9.4
    ! 46 verbose unbuild node_modules/.staging/iobroker.vis-c6a771c0
    ! 47 silly gentlyRm /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0 is being purged from base /opt/iobroker/node_modules/iobroker.vis
    ! 48 verbose gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
    ! 49 verbose tar unpack /root/.npm/iobroker.vis/0.9.4/package.tgz
    ! 50 verbose tar unpacking to /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
    ! 51 silly gentlyRm /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0 is being purged
    ! 52 verbose gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
    ! 53 silly gunzTarPerm modes [ '755', '644' ]
    ! 54 silly gunzTarPerm extractEntry package.json
    ! 55 silly gunzTarPerm modified mode [ 'package.json', 438, 420 ]
    ! 56 silly gunzTarPerm extractEntry .npmignore
    ! 57 silly gunzTarPerm modified mode [ '.npmignore', 438, 420 ]
    ! 58 silly gunzTarPerm extractEntry README.md
    ! 59 silly gunzTarPerm modified mode [ 'README.md', 438, 420 ]
    ! 60 silly gunzTarPerm extractEntry LICENSE
    ! 61 silly gunzTarPerm modified mode [ 'LICENSE', 438, 420 ]
    ! 62 silly gunzTarPerm extractEntry main.js
    ! 63 silly gunzTarPerm modified mode [ 'main.js', 438, 420 ]
    ! 64 silly gunzTarPerm extractEntry ROADMAP.md
    ! 65 silly gunzTarPerm modified mode [ 'ROADMAP.md', 438, 420 ]
    ! 66 silly gunzTarPerm extractEntry admin/index.html
    ! 67 silly gunzTarPerm modified mode [ 'admin/index.html', 438, 420 ]
    ! 68 silly gunzTarPerm extractEntry admin/vis.png
    ! 69 silly gunzTarPerm modified mode [ 'admin/vis.png', 438, 420 ]
    ! 70 silly gunzTarPerm extractEntry io-package.json
    ! 71 silly gunzTarPerm modified mode [ 'io-package.json', 438, 420 ]
    ! 72 silly gunzTarPerm extractEntry lib/install.js
    ! 73 silly gunzTarPerm modified mode [ 'lib/install.js', 438, 420 ]
    ! 74 silly gunzTarPerm extractEntry lib/utils.js
    ! 75 silly gunzTarPerm modified mode [ 'lib/utils.js', 438, 420 ]
    ! 76 silly gunzTarPerm extractEntry www/cordova.js
    ! 77 silly gunzTarPerm modified mode [ 'www/cordova.js', 438, 420 ]
    ! 78 silly gunzTarPerm extractEntry www/img/editmode-pattern.png
    ! 79 silly gunzTarPerm modified mode [ 'www/img/editmode-pattern.png', 438, 420 ]
    ! 80 silly gunzTarPerm extractEntry www/img/Heating.png
    ! 81 silly gunzTarPerm modified mode [ 'www/img/Heating.png', 438, 420 ]
    ! 82 silly gunzTarPerm extractEntry www/img/OutsideTemp.png
    ! 83 silly gunzTarPerm modified mode [ 'www/img/OutsideTemp.png', 438, 420 ]
    ! 84 silly gunzTarPerm extractEntry www/img/Window.png
    ! 85 silly gunzTarPerm modified mode [ 'www/img/Window.png', 438, 420 ]
    ! 86 silly gunzTarPerm extractEntry www/img/back/box-radial.png
    ! 87 silly gunzTarPerm modified mode [ 'www/img/back/box-radial.png', 438, 420 ]
    ! 88 silly gunzTarPerm extractEntry www/img/back/flowers.jpg
    ! 89 silly gunzTarPerm modified mode [ 'www/img/back/flowers.jpg', 438, 420 ]
    ! 90 silly gunzTarPerm extractEntry www/img/back/oblique-line-bk.png
    ! 91 silly gunzTarPerm modified mode [ 'www/img/back/oblique-line-bk.png', 438, 420 ]
    ! 92 silly gunzTarPerm extractEntry www/img/bulb_off.png
    ! 93 silly gunzTarPerm modified mode [ 'www/img/bulb_off.png', 438, 420 ]
    ! 94 silly gunzTarPerm extractEntry www/img/bulb_on.png
    ! 95 silly gunzTarPerm modified mode [ 'www/img/bulb_on.png', 438, 420 ]
    ! 96 silly gunzTarPerm extractEntry www/img/camera.png
    ! 97 silly gunzTarPerm modified mode [ 'www/img/camera.png', 438, 420 ]
    ! 98 silly gunzTarPerm extractEntry www/img/cc-nc-by.png
    ! 99 silly gunzTarPerm modified mode [ 'www/img/cc-nc-by.png', 438, 420 ]
    ! 100 silly gunzTarPerm extractEntry www/img/disconnect.png
    ! 101 silly gunzTarPerm modified mode [ 'www/img/disconnect.png', 438, 420 ]
    ! 102 silly gunzTarPerm extractEntry www/img/door-bell.mp3
    ! 103 silly gunzTarPerm modified mode [ 'www/img/door-bell.mp3', 438, 420 ]
    ! 104 silly gunzTarPerm extractEntry www/img/Lamp.png
    ! 105 silly gunzTarPerm modified mode [ 'www/img/Lamp.png', 438, 420 ]
    ! 106 silly gunzTarPerm extractEntry www/img/eg_trans.png
    ! 107 silly gunzTarPerm modified mode [ 'www/img/eg_trans.png', 438, 420 ]
    ! 108 silly gunzTarPerm extractEntry www/img/favicon.png
    ! 109 silly gunzTarPerm modified mode [ 'www/img/favicon.png', 438, 420 ]
    ! 110 silly gunzTarPerm extractEntry www/img/faviconEdit.png
    ! 111 silly gunzTarPerm modified mode [ 'www/img/faviconEdit.png', 438, 420 ]
    ! 112 silly gunzTarPerm extractEntry www/img/garage-door-closed.png
    ! 113 silly gunzTarPerm modified mode [ 'www/img/garage-door-closed.png', 438, 420 ]
    ! 114 silly gunzTarPerm extractEntry www/img/garage-door-opened.png
    ! 115 silly gunzTarPerm modified mode [ 'www/img/garage-door-opened.png', 438, 420 ]
    ! 116 silly gunzTarPerm extractEntry www/img/gear-icon-md.png
    ! 117 silly gunzTarPerm modified mode [ 'www/img/gear-icon-md.png', 438, 420 ]
    ! 118 silly gunzTarPerm extractEntry www/img/hexabump.png
    ! 119 silly gunzTarPerm modified mode [ 'www/img/hexabump.png', 438, 420 ]
    ! 120 silly gunzTarPerm extractEntry www/img/kde_folder.png
    ! 121 silly gunzTarPerm modified mode [ 'www/img/kde_folder.png', 438, 420 ]
    ! 122 silly gunzTarPerm extractEntry www/img/no_filter.png
    ! 123 silly gunzTarPerm modified mode [ 'www/img/no_filter.png', 438, 420 ]
    ! 124 silly gunzTarPerm extractEntry www/img/sound.png
    ! 125 silly gunzTarPerm modified mode [ 'www/img/sound.png', 438, 420 ]
    ! 126 silly gunzTarPerm extractEntry www/img/tank.png
    ! 127 silly gunzTarPerm modified mode [ 'www/img/tank.png', 438, 420 ]
    ! 128 silly gunzTarPerm extractEntry www/css/add_kian.css
    ! 129 silly gunzTarPerm modified mode [ 'www/css/add_kian.css', 438, 420 ]
    ! 130 silly gunzTarPerm extractEntry www/css/backgrounds.css
    ! 131 silly gunzTarPerm modified mode [ 'www/css/backgrounds.css', 438, 420 ]
    ! 132 silly gunzTarPerm extractEntry www/css/doc.css
    ! 133 silly gunzTarPerm modified mode [ 'www/css/doc.css', 438, 420 ]
    ! 134 silly gunzTarPerm extractEntry www/css/vis.css
    ! 135 silly gunzTarPerm modified mode [ 'www/css/vis.css', 438, 420 ]
    ! 136 silly gunzTarPerm extractEntry www/css/vis_editor.css
    ! 137 silly gunzTarPerm modified mode [ 'www/css/vis_editor.css', 438, 420 ]
    ! 138 silly gunzTarPerm extractEntry www/edit.html
    ! 139 silly gunzTarPerm modified mode [ 'www/edit.html', 438, 420 ]
    ! 140 silly gunzTarPerm extractEntry www/icon/cancel.png
    ! 141 silly gunzTarPerm modified mode [ 'www/icon/cancel.png', 438, 420 ]
    ! 142 silly gunzTarPerm extractEntry www/icon/add.png
    ! 143 silly gunzTarPerm modified mode [ 'www/icon/add.png', 438, 420 ]
    ! 144 silly gunzTarPerm extractEntry www/icon/align-horizontal-center-2.png
    ! 145 silly gunzTarPerm modified mode [ 'www/icon/align-horizontal-center-2.png', 438, 420 ]
    ! 146 silly gunzTarPerm extractEntry www/icon/align-horizontal-left.png
    ! 147 silly gunzTarPerm modified mode [ 'www/icon/align-horizontal-left.png', 438, 420 ]
    ! 148 silly gunzTarPerm extractEntry www/icon/align-horizontal-right-2.png
    ! 149 silly gunzTarPerm modified mode [ 'www/icon/align-horizontal-right-2.png', 438, 420 ]
    ! 150 silly gunzTarPerm extractEntry www/icon/align-vertical-bottom-2.png
    ! 151 silly gunzTarPerm modified mode [ 'www/icon/align-vertical-bottom-2.png', 438, 420 ]
    ! 152 silly gunzTarPerm extractEntry www/icon/align-vertical-center-2.png
    ! 153 silly gunzTarPerm modified mode [ 'www/icon/align-vertical-center-2.png', 438, 420 ]
    ! 154 silly gunzTarPerm extractEntry www/icon/align-vertical-top-2.png
    ! 155 silly gunzTarPerm modified mode [ 'www/icon/align-vertical-top-2.png', 438, 420 ]
    ! 156 silly gunzTarPerm extractEntry www/icon/align-width.png
    ! 157 silly gunzTarPerm modified mode [ 'www/icon/align-width.png', 438, 420 ]
    ! 158 silly gunzTarPerm extractEntry www/icon/align-height.png
    ! 159 silly gunzTarPerm modified mode [ 'www/icon/align-height.png', 438, 420 ]
    ! 160 silly gunzTarPerm extractEntry www/icon/copy.png
    ! 161 silly gunzTarPerm modified mode [ 'www/icon/copy.png', 438, 420 ]
    ! 162 silly gunzTarPerm extractEntry www/icon/delete.png
    ! 163 silly gunzTarPerm modified mode [ 'www/icon/delete.png', 438, 420 ]
    ! 164 silly gunzTarPerm extractEntry www/icon/distribute-horizontal-equal.png
    ! 165 silly gunzTarPerm modified mode [ 'www/icon/distribute-horizontal-equal.png', 438, 420 ]
    ! 166 silly gunzTarPerm extractEntry www/icon/distribute-vertical-equal.png
    ! 167 silly gunzTarPerm modified mode [ 'www/icon/distribute-vertical-equal.png', 438, 420 ]
    ! 168 silly gunzTarPerm extractEntry www/icon/info.png
    ! 169 silly gunzTarPerm modified mode [ 'www/icon/info.png', 438, 420 ]
    ! 170 silly gunzTarPerm extractEntry www/icon/lock.png
    ! 171 silly gunzTarPerm modified mode [ 'www/icon/lock.png', 438, 420 ]
    ! 172 silly gunzTarPerm extractEntry www/icon/ok.png
    ! 173 silly gunzTarPerm modified mode [ 'www/icon/ok.png', 438, 420 ]
    ! 174 silly gunzTarPerm extractEntry www/icon/refresh-4.png
    ! 175 silly gunzTarPerm modified mode [ 'www/icon/refresh-4.png', 438, 420 ]
    ! 176 silly gunzTarPerm extractEntry www/icon/rename.png
    ! 177 silly gunzTarPerm modified mode [ 'www/icon/rename.png', 438, 420 ]
    ! 178 silly gunzTarPerm extractEntry www/cache.manifest
    ! 179 silly gunzTarPerm modified mode [ 'www/cache.manifest', 438, 420 ]
    ! 180 silly gunzTarPerm extractEntry www/index.html
    ! 181 silly gunzTarPerm modified mode [ 'www/index.html', 438, 420 ]
    ! 182 silly gunzTarPerm extractEntry www/js/app.js
    ! 183 silly gunzTarPerm modified mode [ 'www/js/app.js', 438, 420 ]
    ! 184 silly gunzTarPerm extractEntry www/js/conn.js
    ! 185 silly gunzTarPerm modified mode [ 'www/js/conn.js', 438, 420 ]
    ! 186 silly gunzTarPerm extractEntry www/js/connSignalR.js
    ! 187 silly gunzTarPerm modified mode [ 'www/js/connSignalR.js', 438, 420 ]
    ! 188 silly gunzTarPerm extractEntry www/js/visLang.js
    ! 189 silly gunzTarPerm modified mode [ 'www/js/visLang.js', 438, 420 ]
    ! 190 silly gunzTarPerm extractEntry www/js/vis.js
    ! 191 silly gunzTarPerm modified mode [ 'www/js/vis.js', 438, 420 ]
    ! 192 silly gunzTarPerm extractEntry www/js/config.js
    ! 193 silly gunzTarPerm modified mode [ 'www/js/config.js', 438, 420 ]
    ! 194 silly gunzTarPerm extractEntry www/js/visEdit.js
    ! 195 silly gunzTarPerm modified mode [ 'www/js/visEdit.js', 438, 420 ]
    ! 196 silly gunzTarPerm extractEntry www/js/visEditExt.js
    ! 197 silly gunzTarPerm modified mode [ 'www/js/visEditExt.js', 438, 420 ]
    ! 198 silly gunzTarPerm extractEntry www/js/visEditInspect.js
    ! 199 silly gunzTarPerm modified mode [ 'www/js/visEditInspect.js', 438, 420 ]
    ! 200 silly gunzTarPerm extractEntry www/js/visEditWelcome.js
    ! 201 silly gunzTarPerm modified mode [ 'www/js/visEditWelcome.js', 438, 420 ]
    ! 202 silly gunzTarPerm extractEntry www/js/visWizard.js
    ! 203 silly gunzTarPerm modified mode [ 'www/js/visWizard.js', 438, 420 ]
    ! 204 silly gunzTarPerm extractEntry www/js/visAbout.js
    ! 205 silly gunzTarPerm modified mode [ 'www/js/visAbout.js', 438, 420 ]
    ! 206 silly gunzTarPerm extractEntry www/js/fm/fileManager.js
    ! 207 silly gunzTarPerm modified mode [ 'www/js/fm/fileManager.js', 438, 420 ]
    ! 208 silly gunzTarPerm extractEntry www/js/fm/fileManager.css
    ! 209 silly gunzTarPerm modified mode [ 'www/js/fm/fileManager.css', 438, 420 ]
    ! 210 silly gunzTarPerm extractEntry www/js/fm/icon/actions/folder-new.png
    ! 211 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/folder-new.png', 438, 420 ]
    ! 212 silly gunzTarPerm extractEntry www/js/fm/icon/actions/add.png
    ! 213 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/add.png', 438, 420 ]
    ! 214 silly gunzTarPerm extractEntry www/js/fm/icon/actions/delete.png
    ! 215 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/delete.png', 438, 420 ]
    ! 216 silly gunzTarPerm extractEntry www/js/fm/icon/actions/down.png
    ! 217 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/down.png', 438, 420 ]
    ! 218 silly gunzTarPerm extractEntry www/js/fm/icon/actions/edit-rename.png
    ! 219 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/edit-rename.png', 438, 420 ]
    ! 220 silly gunzTarPerm extractEntry www/js/fm/icon/actions/folder-new-7.png
    ! 221 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/folder-new-7.png', 438, 420 ]
    ! 222 silly gunzTarPerm extractEntry www/js/fm/icon/actions/back.png
    ! 223 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/back.png', 438, 420 ]
    ! 224 silly gunzTarPerm extractEntry www/js/fm/icon/actions/icons.png
    ! 225 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/icons.png', 438, 420 ]
    ! 226 silly gunzTarPerm extractEntry www/js/fm/icon/actions/list.png
    ! 227 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/list.png', 438, 420 ]
    ! 228 silly gunzTarPerm extractEntry www/js/fm/icon/actions/play.png
    ! 229 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/play.png', 438, 420 ]
    ! 230 silly gunzTarPerm extractEntry www/js/fm/icon/actions/refresh.png
    ! 231 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/refresh.png', 438, 420 ]
    ! 232 silly gunzTarPerm extractEntry www/js/fm/icon/actions/stop.png
    ! 233 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/stop.png', 438, 420 ]
    ! 234 silly gunzTarPerm extractEntry www/js/fm/icon/actions/up.png
    ! 235 silly gunzTarPerm modified mode [ 'www/js/fm/icon/actions/up.png', 438, 420 ]
    ! 236 silly gunzTarPerm extractEntry www/js/fm/icon/circleLeftIcon.png
    ! 237 silly gunzTarPerm modified mode [ 'www/js/fm/icon/circleLeftIcon.png', 438, 420 ]
    ! 238 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/jpg.png
    ! 239 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/jpg.png', 438, 420 ]
    ! 240 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/JS.png
    ! 241 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/JS.png', 438, 420 ]
    ! 242 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/css.png
    ! 243 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/css.png', 438, 420 ]
    ! 244 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/folder-blue.png
    ! 245 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/folder-blue.png', 438, 420 ]
    ! 246 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/folder-brown.png
    ! 247 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/folder-brown.png', 438, 420 ]
    ! 248 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/folder-green.png
    ! 249 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/folder-green.png', 438, 420 ]
    ! 250 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/gif.png
    ! 251 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/gif.png', 438, 420 ]
    ! 252 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/img2.png
    ! 253 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/img2.png', 438, 420 ]
    ! 254 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/bmp.png
    ! 255 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/bmp.png', 438, 420 ]
    ! 256 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/misc.png
    ! 257 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/misc.png', 438, 420 ]
    ! 258 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/mp3.png
    ! 259 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/mp3.png', 438, 420 ]
    ! 260 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/png.png
    ! 261 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/png.png', 438, 420 ]
    ! 262 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/prg.png
    ! 263 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/prg.png', 438, 420 ]
    ! 264 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/svg.png
    ! 265 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/svg.png', 438, 420 ]
    ! 266 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/undef.png
    ! 267 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/undef.png', 438, 420 ]
    ! 268 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/wav.png
    ! 269 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/wav.png', 438, 420 ]
    ! 270 silly gunzTarPerm extractEntry www/js/fm/icon/mine/128/zip.png
    ! 271 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/128/zip.png', 438, 420 ]
    ! 272 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/js.png
    ! 273 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/js.png', 438, 420 ]
    ! 274 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/bmp.png
    ! 275 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/bmp.png', 438, 420 ]
    ! 276 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/folder-blue.png
    ! 277 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/folder-blue.png', 438, 420 ]
    ! 278 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/folder-brown.png
    ! 279 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/folder-brown.png', 438, 420 ]
    ! 280 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/folder-green.png
    ! 281 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/folder-green.png', 438, 420 ]
    ! 282 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/gif.png
    ! 283 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/gif.png', 438, 420 ]
    ! 284 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/img2.png
    ! 285 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/img2.png', 438, 420 ]
    ! 286 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/jpg.png
    ! 287 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/jpg.png', 438, 420 ]
    ! 288 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/css.png
    ! 289 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/css.png', 438, 420 ]
    ! 290 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/misc.png
    ! 291 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/misc.png', 438, 420 ]
    ! 292 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/mp3.png
    ! 293 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/mp3.png', 438, 420 ]
    ! 294 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/png.png
    ! 295 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/png.png', 438, 420 ]
    ! 296 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/prg.png
    ! 297 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/prg.png', 438, 420 ]
    ! 298 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/svg.png
    ! 299 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/svg.png', 438, 420 ]
    ! 300 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/undef.png
    ! 301 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/undef.png', 438, 420 ]
    ! 302 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/wav.png
    ! 303 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/wav.png', 438, 420 ]
    ! 304 silly gunzTarPerm extractEntry www/js/fm/icon/mine/24/zip.png
    ! 305 silly gunzTarPerm modified mode [ 'www/js/fm/icon/mine/24/zip.png', 438, 420 ]
    ! 306 silly gunzTarPerm extractEntry www/lib/ace/ace.js
    ! 307 silly gunzTarPerm modified mode [ 'www/lib/ace/ace.js', 438, 420 ]
    ! 308 silly gunzTarPerm extractEntry www/lib/ace/ext-language_tools.js
    ! 309 silly gunzTarPerm modified mode [ 'www/lib/ace/ext-language_tools.js', 438, 420 ]
    ! 310 silly gunzTarPerm extractEntry www/lib/ace/ext-searchbox.js
    ! 311 silly gunzTarPerm modified mode [ 'www/lib/ace/ext-searchbox.js', 438, 420 ]
    ! 312 silly gunzTarPerm extractEntry www/lib/ace/mode-css.js
    ! 313 silly gunzTarPerm modified mode [ 'www/lib/ace/mode-css.js', 438, 420 ]
    ! 314 silly gunzTarPerm extractEntry www/lib/ace/mode-html.js
    ! 315 silly gunzTarPerm modified mode [ 'www/lib/ace/mode-html.js', 438, 420 ]
    ! 316 silly gunzTarPerm extractEntry www/lib/ace/worker-css.js
    ! 317 silly gunzTarPerm modified mode [ 'www/lib/ace/worker-css.js', 438, 420 ]
    ! 318 silly gunzTarPerm extractEntry www/lib/ace/worker-html.js
    ! 319 silly gunzTarPerm modified mode [ 'www/lib/ace/worker-html.js', 438, 420 ]
    ! 320 silly gunzTarPerm extractEntry www/lib/css/add2home-2.0.8.css
    ! 321 silly gunzTarPerm modified mode [ 'www/lib/css/add2home-2.0.8.css', 438, 420 ]
    ! 322 silly gunzTarPerm extractEntry www/lib/css/fancytree/channel.png
    ! 323 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/channel.png', 438, 420 ]
    ! 324 silly gunzTarPerm extractEntry www/lib/css/fancytree/device.png
    ! 325 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/device.png', 438, 420 ]
    ! 326 silly gunzTarPerm extractEntry www/lib/css/fancytree/icons.gif
    ! 327 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/icons.gif', 438, 420 ]
    ! 328 silly gunzTarPerm extractEntry www/lib/css/fancytree/loading.gif
    ! 329 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/loading.gif', 438, 420 ]
    ! 330 silly gunzTarPerm extractEntry www/lib/css/fancytree/state.png
    ! 331 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/state.png', 438, 420 ]
    ! 332 silly gunzTarPerm extractEntry www/lib/css/fancytree/ui.fancytree.jquery.min.css
    ! 333 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/ui.fancytree.jquery.min.css', 438, 420 ]
    ! 334 silly gunzTarPerm extractEntry www/lib/css/fancytree/ui.fancytree.min.css
    ! 335 silly gunzTarPerm modified mode [ 'www/lib/css/fancytree/ui.fancytree.min.css', 438, 420 ]
    ! 336 silly gunzTarPerm extractEntry www/lib/css/farbtastic.css
    ! 337 silly gunzTarPerm modified mode [ 'www/lib/css/farbtastic.css', 438, 420 ]
    ! 338 silly gunzTarPerm extractEntry www/lib/css/jquery-ui-timepicker-addon-1.2.2.css
    ! 339 silly gunzTarPerm modified mode [ 'www/lib/css/jquery-ui-timepicker-addon-1.2.2.css', 438, 420 ]
    ! 340 silly gunzTarPerm extractEntry www/lib/css/jquery.jgrowl.min.css
    ! 341 silly gunzTarPerm modified mode [ 'www/lib/css/jquery.jgrowl.min.css', 438, 420 ]
    ! 342 silly gunzTarPerm extractEntry www/lib/css/jquery.multiselect-1.13.css
    ! 343 silly gunzTarPerm modified mode [ 'www/lib/css/jquery.multiselect-1.13.css', 438, 420 ]
    ! 344 silly gunzTarPerm extractEntry www/lib/css/jquery.multiselect.filter.css
    ! 345 silly gunzTarPerm modified mode [ 'www/lib/css/jquery.multiselect.filter.css', 438, 420 ]
    ! 346 silly gunzTarPerm extractEntry www/lib/css/superfish/megafish.css
    ! 347 silly gunzTarPerm modified mode [ 'www/lib/css/superfish/megafish.css', 438, 420 ]
    ! 348 silly gunzTarPerm extractEntry www/lib/css/superfish/superfish-navbar.css
    ! 349 silly gunzTarPerm modified mode [ 'www/lib/css/superfish/superfish-navbar.css', 438, 420 ]
    ! 350 silly gunzTarPerm extractEntry www/lib/css/superfish/superfish-vertical.css
    ! 351 silly gunzTarPerm modified mode [ 'www/lib/css/superfish/superfish-vertical.css', 438, 420 ]
    ! 352 silly gunzTarPerm extractEntry www/lib/css/superfish/superfish.css
    ! 353 silly gunzTarPerm modified mode [ 'www/lib/css/superfish/superfish.css', 438, 420 ]
    ! 354 silly gunzTarPerm extractEntry www/lib/img/delete.png
    ! 355 silly gunzTarPerm modified mode [ 'www/lib/img/delete.png', 438, 420 ]
    ! 356 silly gunzTarPerm extractEntry www/lib/img/edit-undo-8.png
    ! 357 silly gunzTarPerm modified mode [ 'www/lib/img/edit-undo-8.png', 438, 420 ]
    ! 358 silly gunzTarPerm extractEntry www/lib/img/logout.png
    ! 359 silly gunzTarPerm modified mode [ 'www/lib/img/logout.png', 438, 420 ]
    ! 360 silly gunzTarPerm extractEntry www/lib/img/marker.png
    ! 361 silly gunzTarPerm modified mode [ 'www/lib/img/marker.png', 438, 420 ]
    ! 362 silly gunzTarPerm extractEntry www/lib/img/mask.png
    ! 363 silly gunzTarPerm modified mode [ 'www/lib/img/mask.png', 438, 420 ]
    ! 364 silly gunzTarPerm extractEntry www/lib/img/shape_align_bottom.png
    ! 365 silly gunzTarPerm modified mode [ 'www/lib/img/shape_align_bottom.png', 438, 420 ]
    ! 366 silly gunzTarPerm extractEntry www/lib/img/shape_align_left.png
    ! 367 silly gunzTarPerm modified mode [ 'www/lib/img/shape_align_left.png', 438, 420 ]
    ! 368 silly gunzTarPerm extractEntry www/lib/img/shape_align_right.png
    ! 369 silly gunzTarPerm modified mode [ 'www/lib/img/shape_align_right.png', 438, 420 ]
    ! 370 silly gunzTarPerm extractEntry www/lib/img/shape_align_top.png
    ! 371 silly gunzTarPerm modified mode [ 'www/lib/img/shape_align_top.png', 438, 420 ]
    ! 372 silly gunzTarPerm extractEntry www/lib/img/wheel.png
    ! 373 silly gunzTarPerm modified mode [ 'www/lib/img/wheel.png', 438, 420 ]
    ! 374 silly gunzTarPerm extractEntry www/lib/js/add2home-2.0.8.js
    ! 375 silly gunzTarPerm modified mode [ 'www/lib/js/add2home-2.0.8.js', 438, 420 ]
    ! 376 silly gunzTarPerm extractEntry www/lib/js/jquery.ba-resize.min.js
    ! 377 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.ba-resize.min.js', 438, 420 ]
    ! 378 silly gunzTarPerm extractEntry www/lib/js/jquery.base64.min.js
    ! 379 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.base64.min.js', 438, 420 ]
    ! 380 silly gunzTarPerm extractEntry www/lib/js/jquery.fancytree-all.min.js
    ! 381 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.fancytree-all.min.js', 438, 420 ]
    ! 382 silly gunzTarPerm extractEntry www/lib/js/jquery.inputmask.bundle.min.js
    ! 383 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.inputmask.bundle.min.js', 438, 420 ]
    ! 384 silly gunzTarPerm extractEntry www/lib/js/jquery-ui-timepicker-addon-1.2.2.js
    ! 385 silly gunzTarPerm modified mode [ 'www/lib/js/jquery-ui-timepicker-addon-1.2.2.js', 438, 420 ]
    ! 386 silly gunzTarPerm extractEntry www/lib/js/jquery.jgrowl.min.js
    ! 387 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.jgrowl.min.js', 438, 420 ]
    ! 388 silly gunzTarPerm extractEntry www/lib/js/jquery.multiselect-1.13.min.js
    ! 389 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.multiselect-1.13.min.js', 438, 420 ]
    ! 390 silly gunzTarPerm extractEntry www/lib/js/jquery.multiselect.filter-1.5pre.js
    ! 391 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.multiselect.filter-1.5pre.js', 438, 420 ]
    ! 392 silly gunzTarPerm extractEntry www/lib/js/jquery.ui.datepicker.min.js
    ! 393 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.ui.datepicker.min.js', 438, 420 ]
    ! 394 silly gunzTarPerm extractEntry www/lib/js/jquery.ui.touch-punch.min.js
    ! 395 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.ui.touch-punch.min.js', 438, 420 ]
    ! 396 silly gunzTarPerm extractEntry www/lib/js/jquery-ui-1.10.3.dragdropsort.min.js
    ! 397 silly gunzTarPerm modified mode [ 'www/lib/js/jquery-ui-1.10.3.dragdropsort.min.js', 438, 420 ]
    ! 398 silly gunzTarPerm extractEntry www/lib/js/jquery.wakeup.js
    ! 399 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.wakeup.js', 438, 420 ]
    ! 400 silly gunzTarPerm extractEntry www/lib/js/html2canvas.min.js
    ! 401 silly gunzTarPerm modified mode [ 'www/lib/js/html2canvas.min.js', 438, 420 ]
    ! 402 silly gunzTarPerm extractEntry www/lib/js/jqueryui.selectmenu.js
    ! 403 silly gunzTarPerm modified mode [ 'www/lib/js/jqueryui.selectmenu.js', 438, 420 ]
    ! 404 silly gunzTarPerm extractEntry www/lib/js/farbtastic.js
    ! 405 silly gunzTarPerm modified mode [ 'www/lib/js/farbtastic.js', 438, 420 ]
    ! 406 silly gunzTarPerm extractEntry www/lib/js/loStorage.js
    ! 407 silly gunzTarPerm modified mode [ 'www/lib/js/loStorage.js', 438, 420 ]
    ! 408 silly gunzTarPerm extractEntry www/lib/js/dropzone.js
    ! 409 silly gunzTarPerm modified mode [ 'www/lib/js/dropzone.js', 438, 420 ]
    ! 410 silly gunzTarPerm extractEntry www/lib/js/quo.standalone.js
    ! 411 silly gunzTarPerm modified mode [ 'www/lib/js/quo.standalone.js', 438, 420 ]
    ! 412 silly gunzTarPerm extractEntry www/lib/js/colResizable-1.5.min.js
    ! 413 silly gunzTarPerm modified mode [ 'www/lib/js/colResizable-1.5.min.js', 438, 420 ]
    ! 414 silly gunzTarPerm extractEntry www/lib/js/superclick.js
    ! 415 silly gunzTarPerm modified mode [ 'www/lib/js/superclick.js', 438, 420 ]
    ! 416 silly gunzTarPerm extractEntry www/lib/js/can.2.2.4.custom.min.js
    ! 417 silly gunzTarPerm modified mode [ 'www/lib/js/can.2.2.4.custom.min.js', 438, 420 ]
    ! 418 silly gunzTarPerm extractEntry www/lib/js/translate.js
    ! 419 silly gunzTarPerm modified mode [ 'www/lib/js/translate.js', 438, 420 ]
    ! 420 silly gunzTarPerm extractEntry www/lib/js/jquery.jgrowl.map
    ! 421 silly gunzTarPerm modified mode [ 'www/lib/js/jquery.jgrowl.map', 438, 420 ]
    ! 422 silly gunzTarPerm extractEntry www/offline.html
    ! 423 silly gunzTarPerm modified mode [ 'www/offline.html', 438, 420 ]
    ! 424 silly gunzTarPerm extractEntry www/widgets/jqui.html
    ! 425 silly gunzTarPerm modified mode [ 'www/widgets/jqui.html', 438, 420 ]
    ! 426 silly gunzTarPerm extractEntry www/widgets/basic/css/table.css
    ! 427 silly gunzTarPerm modified mode [ 'www/widgets/basic/css/table.css', 438, 420 ]
    ! 428 silly gunzTarPerm extractEntry www/widgets/basic/doc.html
    ! 429 silly gunzTarPerm modified mode [ 'www/widgets/basic/doc.html', 438, 420 ]
    ! 430 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueBool.png
    ! 431 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueBool.png', 438, 420 ]
    ! 432 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_AckBool.png
    ! 433 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_AckBool.png', 438, 420 ]
    ! 434 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ContainerView.png
    ! 435 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ContainerView.png', 438, 420 ]
    ! 436 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_HTML.png
    ! 437 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_HTML.png', 438, 420 ]
    ! 438 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_HTMLnavigation.png
    ! 439 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_HTMLnavigation.png', 438, 420 ]
    ! 440 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_Image.png
    ! 441 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_Image.png', 438, 420 ]
    ! 442 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_StatefulContainerView8.png
    ! 443 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_StatefulContainerView8.png',
    ! 443 silly gunzTarPerm 438,
    ! 443 silly gunzTarPerm 420 ]
    ! 444 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_StatefulIFrame8.png
    ! 445 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_StatefulIFrame8.png', 438, 420 ]
    ! 446 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_StatefulImage.png
    ! 447 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_StatefulImage.png', 438, 420 ]
    ! 448 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_BasicState.png
    ! 449 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_BasicState.png', 438, 420 ]
    ! 450 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueBoolCtrl.png
    ! 451 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueBoolCtrl.png', 438, 420 ]
    ! 452 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueList.png
    ! 453 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueList.png', 438, 420 ]
    ! 454 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueListHtml.png
    ! 455 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueListHtml.png', 438, 420 ]
    ! 456 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueListHtml8.png
    ! 457 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueListHtml8.png', 438, 420 ]
    ! 458 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_ValueStringImg.png
    ! 459 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_ValueStringImg.png', 438, 420 ]
    ! 460 silly gunzTarPerm extractEntry www/widgets/basic/img/Prev_iFrame.png
    ! 461 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/Prev_iFrame.png', 438, 420 ]
    ! 462 silly gunzTarPerm extractEntry www/widgets/basic/img/doc_example_hm_val_number.png
    ! 463 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/doc_example_hm_val_number.png',
    ! 463 silly gunzTarPerm 438,
    ! 463 silly gunzTarPerm 420 ]
    ! 464 silly gunzTarPerm extractEntry www/widgets/basic/img/pin_red5.svg
    ! 465 silly gunzTarPerm modified mode [ 'www/widgets/basic/img/pin_red5.svg', 438, 420 ]
    ! 466 silly gunzTarPerm extractEntry www/widgets/basic/js/table.js
    ! 467 silly gunzTarPerm modified mode [ 'www/widgets/basic/js/table.js', 438, 420 ]
    ! 468 silly gunzTarPerm extractEntry www/widgets/jqplot/css/jquery.jqplot.min.css
    ! 469 silly gunzTarPerm modified mode [ 'www/widgets/jqplot/css/jquery.jqplot.min.css', 438, 420 ]
    ! 470 silly gunzTarPerm extractEntry www/widgets/jqplot/doc.html
    ! 471 silly gunzTarPerm modified mode [ 'www/widgets/jqplot/doc.html', 438, 420 ]
    ! 472 silly gunzTarPerm extractEntry www/widgets/jqplot/img/Prev_MeterGauge.png
    ! 473 silly gunzTarPerm modified mode [ 'www/widgets/jqplot/img/Prev_MeterGauge.png', 438, 420 ]
    ! 474 silly gunzTarPerm extractEntry www/widgets/jqplot/js/jquery.jqplot.min.js
    ! 475 silly gunzTarPerm modified mode [ 'www/widgets/jqplot/js/jquery.jqplot.min.js', 438, 420 ]
    ! 476 silly gunzTarPerm extractEntry www/widgets/jqplot.html
    ! 477 silly gunzTarPerm modified mode [ 'www/widgets/jqplot.html', 438, 420 ]
    ! 478 silly gunzTarPerm extractEntry www/widgets/jqui/doc.html
    ! 479 silly gunzTarPerm modified mode [ 'www/widgets/jqui/doc.html', 438, 420 ]
    ! 480 silly gunzTarPerm extractEntry www/widgets/jqui/img/ct.png
    ! 481 silly gunzTarPerm modified mode [ 'www/widgets/jqui/img/ct.png', 438, 420 ]
    ! 482 silly gunzTarPerm extractEntry www/widgets/jqui/img/hue.png
    ! 483 silly gunzTarPerm modified mode [ 'www/widgets/jqui/img/hue.png', 438, 420 ]
    ! 484 silly gunzTarPerm extractEntry www/widgets/jqui/img/internet-web-browser-2.png
    ! 485 silly gunzTarPerm modified mode [ 'www/widgets/jqui/img/internet-web-browser-2.png', 438, 420 ]
    ! 486 silly gunzTarPerm extractEntry www/widgets/basic.html
    ! 487 silly gunzTarPerm modified mode [ 'www/widgets/basic.html', 438, 420 ]
    ! 488 silly gunzTarPerm extractEntry www/widgets/swipe/css/swipe.css
    ! 489 silly gunzTarPerm modified mode [ 'www/widgets/swipe/css/swipe.css', 438, 420 ]
    ! 490 silly gunzTarPerm extractEntry www/widgets/swipe/doc.html
    ! 491 silly gunzTarPerm modified mode [ 'www/widgets/swipe/doc.html', 438, 420 ]
    ! 492 silly gunzTarPerm extractEntry www/widgets/swipe/img/noSwipe.jpg
    ! 493 silly gunzTarPerm modified mode [ 'www/widgets/swipe/img/noSwipe.jpg', 438, 420 ]
    ! 494 silly gunzTarPerm extractEntry www/widgets/swipe/js/jquery.roundabout-shapes.js
    ! 495 silly gunzTarPerm modified mode [ 'www/widgets/swipe/js/jquery.roundabout-shapes.js', 438, 420 ]
    ! 496 silly gunzTarPerm extractEntry www/widgets/swipe/js/jquery.roundabout.min.js
    ! 497 silly gunzTarPerm modified mode [ 'www/widgets/swipe/js/jquery.roundabout.min.js', 438, 420 ]
    ! 498 silly gunzTarPerm extractEntry www/widgets/swipe/js/jquery.touchSwipe.min.js
    ! 499 silly gunzTarPerm modified mode [ 'www/widgets/swipe/js/jquery.touchSwipe.min.js', 438, 420 ]
    ! 500 silly gunzTarPerm extractEntry www/widgets/tabs/jquery.sliderTabs.js
    ! 501 silly gunzTarPerm modified mode [ 'www/widgets/tabs/jquery.sliderTabs.js', 438, 420 ]
    ! 502 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/indicator.png
    ! 503 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/indicator.png', 438, 420 ]
    ! 504 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/indicatorActive.png
    ! 505 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/indicatorActive.png',
    ! 505 silly gunzTarPerm 438,
    ! 505 silly gunzTarPerm 420 ]
    ! 506 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/leftArrow.png
    ! 507 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/leftArrow.png', 438, 420 ]
    ! 508 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/leftPanelArrow.png
    ! 509 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/leftPanelArrow.png', 438, 420 ]
    ! 510 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/rightArrow.png
    ! 511 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/rightArrow.png', 438, 420 ]
    ! 512 silly gunzTarPerm extractEntry www/widgets/tabs/styles/images/rightPanelArrow.png
    ! 513 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/images/rightPanelArrow.png',
    ! 513 silly gunzTarPerm 438,
    ! 513 silly gunzTarPerm 420 ]
    ! 514 silly gunzTarPerm extractEntry www/widgets/tabs/styles/jquery.sliderTabs.css
    ! 515 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/jquery.sliderTabs.css', 438, 420 ]
    ! 516 silly gunzTarPerm extractEntry www/widgets/tabs/styles/jquery.sliderTabs.css.orig
    ! 517 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/jquery.sliderTabs.css.orig',
    ! 517 silly gunzTarPerm 438,
    ! 517 silly gunzTarPerm 420 ]
    ! 518 silly gunzTarPerm extractEntry www/widgets/tabs/styles/jquery.sliderTabs.min.css
    ! 519 silly gunzTarPerm modified mode [ 'www/widgets/tabs/styles/jquery.sliderTabs.min.css', 438, 420 ]
    ! 520 silly gunzTarPerm extractEntry www/widgets/tabs.html
    ! 521 silly gunzTarPerm modified mode [ 'www/widgets/tabs.html', 438, 420 ]
    ! 522 silly gunzTarPerm extractEntry www/widgets/todo/dev.html
    ! 523 silly gunzTarPerm modified mode [ 'www/widgets/todo/dev.html', 438, 420 ]
    ! 524 silly gunzTarPerm extractEntry www/widgets/todo/homematic.html
    ! 525 silly gunzTarPerm modified mode [ 'www/widgets/todo/homematic.html', 438, 420 ]
    ! 526 silly gunzTarPerm extractEntry www/widgets/todo/special.html
    ! 527 silly gunzTarPerm modified mode [ 'www/widgets/todo/special.html', 438, 420 ]
    ! 528 silly gunzTarPerm extractEntry www/widgets/todo/swipe.html
    ! 529 silly gunzTarPerm modified mode [ 'www/widgets/todo/swipe.html', 438, 420 ]
    ! 530 silly gunzTarPerm extractEntry www/widgets/todo/weather.html
    ! 531 silly gunzTarPerm modified mode [ 'www/widgets/todo/weather.html', 438, 420 ]
    ! 532 silly gunzTarPerm extractEntry www/widgets/weather-adapter.html
    ! 533 silly gunzTarPerm modified mode [ 'www/widgets/weather-adapter.html', 438, 420 ]
    ! 534 silly gentlyRm /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0/node_modules is being purged
    ! 535 verbose gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0/node_modules
    ! 536 silly doParallel preinstall 1
    ! 537 silly preinstall iobroker.vis@0.9.4 /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
    ! 538 info lifecycle iobroker.vis@0.9.4~preinstall: iobroker.vis@0.9.4
    ! 539 silly lifecycle iobroker.vis@0.9.4~preinstall: no script for preinstall, continuing
    ! 540 silly doReverseSerial remove 0
    ! 541 silly doSerial move 0
    ! 542 silly doSerial finalize 1
    ! 543 silly finalize /opt/iobroker/node_modules/iobroker.vis
    ! 544 verbose unlock done using /root/.npm/_locks/staging-40fe0fc83e86560c.lock for /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging
    ! 545 silly rollbackFailedOptional Starting
    ! 546 silly rollbackFailedOptional Finishing
    ! 547 silly runTopLevelLifecycles Starting
    ! 548 silly runTopLevelLifecycles Finishing
    ! 549 silly install printInstalled
    ! 550 verbose stack Error: ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
    ! 550 verbose stack at whenOldMovedAway (/usr/local/lib/node_modules/npm/lib/install/action/finalize.js:43:5)
    ! 550 verbose stack at /usr/local/lib/node_modules/npm/lib/utils/rename.js:13:14
    ! 550 verbose stack at FSReqWrap.oncomplete (fs.js:117:15)
    ! 550 verbose stack
    ! 550 verbose stack at Error (native)
    ! 551 verbose cwd /opt/iobroker
    ! 552 error FreeBSD 10.2-RELEASE
    ! 553 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "–production" "--prefix" "/opt/iobroker/node_modules/iobroker.vis"
    ! 554 error node v6.1.0
    ! 555 error npm v3.8.8
    ! 556 error path /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
    ! 557 error code ENOENT
    ! 558 error errno -2
    ! 559 error syscall rename
    ! 560 error enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
    ! 561 error enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
    ! 561 error enoent This is most likely not a problem with npm itself
    ! 561 error enoent and is related to npm not being able to find a file.
    ! 562 verbose exit [ -2, true ]
    • BluefoxB Offline
      BluefoxB Offline
      Можешь поставить node 4.x ?
        boba
        все тоже самое
        ! root /opt/iobroker # iobroker add vis 0:23
        ! npm install iobroker.vis –production --prefix "/opt/iobroker" (System call)
        ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
        ! npm WARN iobroker No description
        ! npm WARN iobroker No repository field.
        ! npm WARN iobroker No README data
        ! npm WARN iobroker No license field.
        ! host.home.su install adapter vis
        ! npm install --production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
        ! npm ERR! FreeBSD 10.2-RELEASE
        ! npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.vis"
        ! npm ERR! node v4.4.4
        ! npm ERR! npm v3.8.8
        ! npm ERR! path /opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0
        ! npm ERR! code ENOENT
        ! npm ERR! errno -2
        ! npm ERR! syscall rename
        ! npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.vis/node_modules/.staging/iobroker.vis-c6a771c0' -> '/opt/iobroker/node_modules/iobroker.vis'
        ! npm ERR! enoent This is most likely not a problem with npm itself
        ! npm ERR! enoent and is related to npm not being able to find a file.
        ! npm ERR! enoent
        ! npm ERR! Please include the following file with any support request:
        ! npm ERR! /opt/iobroker/npm-debug.log
        ! Cannot install iobroker.vis: 254
        • BluefoxB Offline
          BluefoxB Offline
          А можешь поставить Npm попроще?
          npm install -g npm@2.15.5
            boba
            заработало.
            спасибо!
            • BluefoxB Offline
              BluefoxB Offline
              @boba:
              (там неточность небольшая "sudo chmod 777 /opt/iobroker/. -R" ключ после команды должен быть) `
              3 раза прочитал. Так и не понял, что за ключ :?
                boba
                boba ~ % sudo chmod 777 /opt/iobroker/*.* -R
                chmod: -R: No such file or directory
                boba ~ % man chmod
                CHMOD(1)                FreeBSD General Commands Manual               CHMOD(1)
                NAME
                     chmod — change file modes
                SYNOPSIS
                     chmod [-fhv] [-R [-H | -L | -P]] mode file ...
                правильно "sudo chmod -R 777 /opt/iobroker"
                на счет "." я тоже не уверен, ибо это сменит права только двум скриптам в корне iobroker
