  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Ошибки при установке Homekit
    5.9k
1 Beiträge 1 Kommentatoren 366 Aufrufe
    avtomat78
    Здравствуйте, помогите кто в курсе, бьюсь неделю ничего не получается, отказывается устанавливаться Homekit, Виндовс 7, в логе установки пишет
    ! $ ./iobroker add yahka –host Andrey-PC
    ! NPM version: 6.4.1
    ! npm install iobroker.yahka --production --save --prefix "D:/Program Files/ioBroker" (System call)
    ! gyp
    ! ERR! configure error gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
    ! gyp ERR! stack at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
    ! gyp ERR!
    ! stack at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
    ! gyp ERR! stack at FSReqWrap.oncomplete (fs.js:154:21)
    ! gyp ERR! System Windows_NT 6.1.7601
    ! gyp ERR! command
    ! "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"gyp ERR!
    ! cwd
    ! D:\Program Files\ioBroker\node_modules\iobroker.yahka\node_modules\curve25519-ngyp ERR! node -v v10.13.0
    ! gyp ERR! node-gyp -v
    ! v3.8.0gyp ERR! not ok
    ! npm
    ! ERR! code ELIFECYCLEnpm ERR! errno
    ! 1
    ! npm
    ! ERR!
    ! curve25519-n@1.4.0 install: node-gyp rebuild
    ! npm
    ! ERR!
    ! Exit status 1
    ! npm
    ! ERR!
    ! npm
    ! ERR!
    ! Failed at the curve25519-n@1.4.0 install script.
    ! npm
    ! ERR!
    ! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-02-02T20_27_53_094Z-debug.log
    ! host.Andrey-PC install adapter yahka
    ! gyp
    ! gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR!
    ! stack at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)gyp ERR! stack at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
    ! gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
    ! gyp ERR! stack
    ! at FSReqWrap.oncomplete (fs.js:154:21)
    ! gyp ERR!
    ! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"gyp ERR! cwd D:\Program Files\ioBroker\node_modules\iobroker.yahka\node_modules\curve25519-n
    ! gyp ERR! node -v v10.13.0gyp
    ! ERR! node-gyp -v v3.8.0gyp ERR! not ok
    ! npm
    ! ERR! code ELIFECYCLEnpm ERR! errno 1
    ! npm ERR! curve25519-n@1.4.0 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the curve25519-n@1.4.0 install script.
    ! npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-02-02T20_28_01_959Z-debug.log
    ! gyp
    ! gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
    ! gyp ERR! stack at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
    ! gyp ERR! System Windows_NT 6.1.7601gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
    ! gyp ERR! cwd D:\Program Files\ioBroker\node_modules\iobroker.yahka\node_modules\curve25519-n
    ! gyp ERR! node-gyp -v v3.8.0
    ! gyp
    ! ERR! not ok
    ! npm
    ! 1
    ! ERR! Exit status 1npm ERR!
    ! npm
    ! ERR! Failed at the curve25519-n@1.4.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    ! npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-02-02T20_28_09_016Z-debug.log
    ! ERROR: host.Andrey-PC Cannot install yahka
    ! ERROR: process exited with code 13</anonymous></anonymous></anonymous>
