  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Web
    5.9k
Web
3 Beiträge 3 Kommentatoren 2.0k Aufrufe
  • aurodionovA Offline
    aurodionovA Offline
    aurodionov
    Продолжаю бороться с нескладушками. При установке виз падает в ошибку, оказалось не ставится web
    root@SmartHome:/opt/iobroker# iobroker install web
    ! /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:77
    if (arr.rows[id].value.common.enabled) {
    TypeError: Cannot read property 'enabled' of undefined
    at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:77:54)
    at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
    at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
    at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
    at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
    at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
    root@SmartHome:/opt/iobroker#</anonymous></anonymous></anonymous>
    root@SmartHome:/opt/iobroker# iobroker add web
    Пишу с пульта….
    • E Offline
      electric
      Текущая версия 1.4.6.
      Не устанавливается ни через админку ни через консоль.
      В лог сыплет ошибки:
      ! npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json !
      В админке один раз и выходит из установки с ошибкой.
      update: починили))
        dimonchik88
        Если в Лог такая ошибка:
        host.raspberrypi instance system.adapter.web.0 terminated with code 1 ()
        то удаляем через командную строку:
        ****cd /opt/iobroker
        ./iobroker del web****
        и после этого устанавливаем заново через графику или
        ./iobroker add web
