  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер KODI
    5.3k
Драйвер KODI
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
41 Beiträge 7 Kommentatoren 11.6k Aufrufe
  • V Offline
    V Offline
    vtec
    Если я не ошибаюсь, kodi может работать на ws. Тогда для начала сделать пульт управления через ws .
    А как максимум так: https://github.com/Jalle19/xbmc-video-server :)
    • aurodionovA Offline
      aurodionovA Offline
      aurodionov
      ставится с варнингами и ошибками
      ! iobroker 2016-04-24 11:02:56 info exit 0
      ! iobroker 2016-04-24 11:02:56 info upload [0] kodi /opt/iobroker/node_modules/iobroker.kodi/www/README.md README.md text/x-markdown
      ! iobroker 2016-04-24 11:02:56 info upload [1] kodi /opt/iobroker/node_modules/iobroker.kodi/www/index.html index.html text/html
      ! iobroker 2016-04-24 11:02:56 info upload [2] kodi /opt/iobroker/node_modules/iobroker.kodi/www/kodi.png kodi.png image/png
      ! iobroker 2016-04-24 11:02:56 info Adapter "system.adapter.vis.0" restarted.got /opt/iobroker/node_modules/iobroker.kodi/www
      ! host-SmartHome 2016-04-24 11:02:56 info "system.adapter.vis.0" enabled
      ! host-SmartHome 2016-04-24 11:02:56 info object change system.adapter.vis.0
      ! host-SmartHome 2016-04-24 11:02:56 info "system.adapter.vis.0" disabled
      ! iobroker 2016-04-24 11:02:56 info upload [0] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/index.html index.html text/html
      ! Cannot 2016-04-24 11:02:56 error write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi.admin/: EISDIR: illegal operation on a directory, open '/opt/iobroker/node_modules/iobr
      ! iobroker 2016-04-24 11:02:56 info upload [1] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/iobroker.kodi.png image/png
      ! iobroker 2016-04-24 11:02:55 info upload [2] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/kodi.png kodi.png image/png
      ! iobroker 2016-04-24 11:02:55 info got /opt/iobroker/node_modules/iobroker.kodi/admin
      ! iobroker 2016-04-24 11:02:55 info iobroker.kodi@0.0.2 ../opt/iobroker/node_modules/iobroker.kodi└── kodi-ws@2.4.0 (has-value@0.2.1, set-value@0.2.0, jrpc-schema@2.0.0, ws@0.7.2, eslint@2.2.0, babel-eslint@5.0.4)
      ! iobroker 2016-04-24 11:02:02 info npm WARN optional dep failed, continuing bufferutil@1.1.0
      ! iobroker 2016-04-24 11:02:02 info npm WARN optional dep failed, continuing utf-8-validate@1.1.0
      ! iobroker 2016-04-24 11:02:02 info gyp ERR! not ok
      ! iobroker 2016-04-24 11:02:02 info gyp ERR! node -v v4.4.3gyp ERR! node-gyp -v v3.3.1
      ! iobroker 2016-04-24 11:02:02 info gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/w
      ! iobroker 2016-04-24 11:02:02 info gyp ERR! System Linux 3.16.0-4-686-pae
      ! iobroker 2016-04-24 11:02:02 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
      ! iobroker 2016-04-24 11:02:02 info gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      ! iobroker 2016-04-24 11:02:02 info gyp ERR! stack at emitTwo (events.js:87:13)
      ! iobroker 2016-04-24 11:02:02 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! iobroker 2016-04-24 11:02:02 info ERR! build error
      ! iobroker 2016-04-24 11:02:02 info make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Ошибка 1
      ! iobroker 2016-04-24 11:02:02 info bufferutil.target.mk:90: ошибка выполнения рецепта для цели «Release/obj.target/bufferutil/src/bufferutil.o»make: выход из каталога «/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node
      ! iobroker 2016-04-24 11:02:01 info ^
      ! iobroker 2016-04-24 11:02:01 info return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h: In function ‘v8::Local NanBufferUse(char*, uint32_t)’:
      ! iobroker 2016-04-24 11:02:01 info return node::Buffer::New(v8::Isolate::GetCurrent(), size);
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocal’ to ‘v8::Local’
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(uint32_t)’:
      ! iobroker 2016-04-24 11:02:01 info In file included from ../src/bufferutil.cc:16:0:
      ! iobroker 2016-04-24 11:02:01 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’
      ! iobroker 2016-04-24 11:02:01 info NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
      ! iobroker 2016-04-24 11:02:01 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, char*, size_t)
      ! iobroker 2016-04-24 11:02:01 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’
      ! iobroker 2016-04-24 11:02:01 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, v8::Local, node::encoding)
      ! iobroker 2016-04-24 11:02:01 info In file included from ../src/bufferutil.cc:10:0:
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:672:67: note: candidates are:
      ! iobroker 2016-04-24 11:02:01 info return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(const char*, uint32_t)’:
      ! iobroker 2016-04-24 11:02:01 info v8::Isolate::GetCurrent(), data, length, callback, hint);
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘…’ before ‘callback’ , node::smalloc::FreeCallback callback
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback
      ! iobroker 2016-04-24 11:02:01 info ../node_modules/nan/nan.h:256:25: note: ‘template v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
      ! iobroker 2016-04-24 11:02:01 info NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
      ! iobroker 2016-04-24 11:02:01 info In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template v8::Local _NanEnsureLocal(v8::Local)’
      ! iobroker 2016-04-24 11:01:59 info CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
      ! iobroker 2016-04-24 11:01:59 info make: вход в каталог «/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/bufferutil/build»
      ! iobroker 2016-04-24 11:01:55 info > node-gyp rebuild
      ! iobroker 2016-04-24 11:01:55 info > bufferutil@1.1.0 install /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/bufferutil
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! not ok
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! node-gyp -v v3.3.1
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! node -v v4.4.3
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validate
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! System Linux 3.16.0-4-686-pae
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! iobroker 2016-04-24 11:01:55 info gyp ERR! build error
      ! iobroker 2016-04-24 11:01:55 info make: *** [Release/obj.target/validation/src/validation.o] Ошибка 1
      ! iobroker 2016-04-24 11:01:55 info validation.target.mk:90: ошибка выполнения рецепта для цели «Release/obj.target/validation/src/validation.o»make: выход из каталога «/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node
      ! iobroker 2016-04-24 11:01:55 info ^
      ! iobroker 2016-04-24 11:01:55 info return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h: In function ‘v8::Local NanBufferUse(char*, uint32_t)’:
      ! iobroker 2016-04-24 11:01:55 info return node::Buffer::New(v8::Isolate::GetCurrent(), size);
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocal’ to ‘v8::Local’
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(uint32_t)’:
      ! iobroker 2016-04-24 11:01:55 info In file included from ../src/validation.cc:15:0:
      ! iobroker 2016-04-24 11:01:55 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’
      ! iobroker 2016-04-24 11:01:55 info NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
      ! iobroker 2016-04-24 11:01:55 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, char*, size_t)
      ! iobroker 2016-04-24 11:01:55 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’
      ! iobroker 2016-04-24 11:01:55 info /root/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, v8::Local, node::encoding)
      ! iobroker 2016-04-24 11:01:55 info In file included from ../src/validation.cc:10:0:
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:672:67: note: candidates are:
      ! iobroker 2016-04-24 11:01:55 info return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(const char*, uint32_t)’:
      ! iobroker 2016-04-24 11:01:55 info v8::Isolate::GetCurrent(), data, length, callback, hint);
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘…’ before ‘callback’ , node::smalloc::FreeCallback callback
      ! iobroker 2016-04-24 11:01:55 info ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback
      ! iobroker 2016-04-24 11:01:54 info ^
      ! iobroker 2016-04-24 11:01:54 info ../node_modules/nan/nan.h:256:25: note: ‘template v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
      ! iobroker 2016-04-24 11:01:54 info NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
      ! iobroker 2016-04-24 11:01:54 info In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template v8::Local _NanEnsureLocal(v8::Local)’
      ! iobroker 2016-04-24 11:01:52 info CXX(target) Release/obj.target/validation/src/validation.o
      ! iobroker 2016-04-24 11:01:52 info make: вход в каталог «/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validate/build»
      ! iobroker 2016-04-24 11:01:37 info > node-gyp rebuild
      ! iobroker 2016-04-24 11:01:37 info > utf-8-validate@1.1.0 install /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validate
      ! iobroker 2016-04-24 11:01:31 info npm WARN peerDependencies longer be automatically installed to fulfill the peerDependency npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly.
      ! iobroker 2016-04-24 11:01:31 info WARN peerDependencies The peer dependency eslint@<2.3.0 included from babel-eslint will no
      ! iobroker 2016-04-24 11:01:06 info npm install https://github.com/instalator/iobroker. ... all/master --production --prefix "/opt/iobroker" (System call)
      ! iobroker 2016-04-24 11:01:06 info install https://github.com/instalator/iobroker. ... all/master
      ! iobroker 2016-04-24 11:01:05 info url "https://github.com/instalator/iobroker.kodi" --debug
      Пишу с пульта….
        aurodionovA Offline
        aurodionov
        добавить в уведомления - адрес иконки для отображения в уведомлении,
        например http://server.lan/%D0%BA%D0%B0%D1%80%D1%82%D0%B8%D0%BD%D0%BA%D0%B0.jpg или vis/путь.картинка.jpg
        Пишу с пульта….
        • I Offline
          I Offline
          instalator
          @aurodionov:
          например http://server.lan/%D0%BA%D0%B0%D1%80%D1%82%D0%B8%D0%BD%D0%BA%D0%B0.jpg или vis/путь.картинка.jpg `
          А пример можно как там можно отобразить картинку?
          Высокий уровень Децибел вреден для здоровья!
          http://blog.instalator.ru/
            aurodionovA Offline
            aurodionov
            На смежном сайте тоже пилят драйвер
            http://majordomo.smartliving.ru/forum/v … f=5&t=2893
            возможно у них подсмотреть
            Пишу с пульта….
            • I Offline
              I Offline
              instalator
              @aurodionov:
              возможно у них подсмотреть `
              Вспомнил что я делал так, хотел жипег с камеры отображать, но картинка уменьшается до размера иконки. т.е. там можно задать свою иконку просто.
                aurodionovA Offline
                aurodionov
                ясно , иконка уже не плохо
                можно от разных девайсов месоги быстро различать визуально а не только аларм,инфо
                хотя для камеры снапшот это было бы круто, вопрос с размером
                Пишу с пульта….
                • I Offline
                  I Offline
                  instalator
                  Если закрыть Коди, то драйвер падает с непонятной ошибкой
                  Server-PC 2016-04-27 21:39:57 info host.Server-PC instance system.adapter.kodi.0 started with pid 2692
                  Server-PC 2016-04-27 21:39:27 info host.Server-PC Restart adapter system.adapter.kodi.0 because enabled
                  Server-PC 2016-04-27 21:39:27 error host.Server-PC instance system.adapter.kodi.0 terminated with code 0 (OK)
                  kodi.0 2016-04-27 21:39:26 debug kodi.0 Response GetPlayerId [[],{"muted":false,"volume":100}]
                  Из-за чего происходит ошибка непонятно, как можно выловить эти ошибки и отработать? Может возможно подписаться на 'error' модуля kodi-ws?
                  у него есть self.emit но я так понимаю чтобы подписаться на них в самом драйвере нужно как то их сделать видимыми в самом драйвере.
                  • I Offline
                    I Offline
                    instalator
                    Виджеты для КОДИ:
                    [{"tpl":"tplkodiProgressBar","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid":"kodi.0.playing_time","oid_curtime":"kodi.0.playing_time","oid_curtimetotal":"kodi.0.playing_time_total","oid_seek":"kodi.0.seek"},"style":{"left":"93px","top":"436px","width":"514px","height":"12px","color":"","background-color":"#a50d0d"},"widgetSet":"kodi"},{"tpl":"tplkodiPlaylist","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_playlist":"kodi.0.playlist","oid_goto":"kodi.0.GoTo","oid_position":"kodi.0.position"},"style":{"left":"91px","top":"186px","width":"511px","height":"241px","color":"#2d8f39","background-color":"#0f0505","border-radius":"5px","border-style":"groove","border-color":"#0a8aeb","padding-left":"","box-shadow":"","font-size":"x-small"},"widgetSet":"kodi"},{"tpl":"tplkodiButton","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_play":"kodi.0.play","oid_speed":"kodi.0.speed","oid_prev":"kodi.0.previous","oid_next":"kodi.0.next","oid_stop":"kodi.0.stop","oid_mute":"kodi.0.mute","oid_rpt":"kodi.0.repeat","oid_shf":"kodi.0.shuffle","oid_seek":"kodi.0.seek"},"style":{"left":"88px","top":"458px","width":"400px","height":"50px"},"widgetSet":"kodi"},{"tpl":"tplJquiSlider","data":{"oid":"kodi.0.volume","visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"min":"0","max":"100","step":"1"},"style":{"left":"490px","top":"469px","width":"102px","height":"23px"},"widgetSet":"jqui"},{"tpl":"tplkodiCodec","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_codec":"kodi.0.codec"},"style":{"left":"96px","top":"520px","width":"50px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiAspect","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_aspect":"kodi.0.info.video_aspect"},"style":{"left":"272px","top":"520px","width":"36px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiResolut","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_resolut":"kodi.0.info.video_height"},"style":{"left":"232px","top":"520px","width":"35px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiChannel","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_channel":"kodi.0.channels"},"style":{"left":"150px","top":"520px","width":"28px","height":"25px"},"widgetSet":"kodi"},{"tpl":"tplkodiVideoCodec","data":{"visibility-cond":"==","visibility-val":1,"gestures-offsetX":0,"gestures-offsetY":0,"oid_videocodec":"kodi.0.info.video_codec"},"style":{"left":"183px","top":"520px","width":"46px","height":"25px"},"widgetSet":"kodi"}]
                    • BluefoxB Offline
                      BluefoxB Offline
                      Запости скрины для затравки ;)
                      • I Offline
                        I Offline
                        instalator
                        @Bluefox:
                        Запости скрины для затравки ;) `
                        • I Offline
                          I Offline
                          instalator
                          @Bluefox:
                          Немогу победить почему драйвер падает при закрытии КОДИ, причем он падает даже если вызов всех функции в main закоментить кроме getConnection.
                          Получается какой то встроенный модуль дает исключение. Может посмотреть?
                          • BluefoxB Offline
                            BluefoxB Offline
                            BTW: https://github.com/ioBroker/ioBroker/wi … connection
                            Проблема с падением ещё есть?
                            • I Offline
                              I Offline
                              instalator
                              @Bluefox:
                              Проблема с падением ещё есть? `
                              Да есть, по ссылке не понял смысла. Должны создать переменную для драйвера? Но драйвер сваливается с ошибкой если коди вырубить
                              • BluefoxB Offline
                                BluefoxB Offline
                                @instalator:
                                @Bluefox:
                                Проблема с падением ещё есть? Да есть, по ссылке не понял смысла. Должны создать переменную для драйвера? Но драйвер сваливается с ошибкой если коди вырубить
                                У меня нет KODI. С какой ошибкой сваливается и где?
                                Создай переменную info.connection вместо KODI_connected и статус соединения будет показываться в admin.
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  Ты не можешь создать все переменные, как info.connection в io-package.json?
                                  А то при установке значения ты всегда создаёшь (или перезаписываешь) объект.
                                  function setObject(name, val, type){
                                  if (type){
                                  name = type +'.'+ name;
                                  object = {
                                  type: 'state',
                                  common: {
                                  role: 'media',
                                  type: typeof val
                                  native: {}
                                  adapter.setObject(name, object, function (err, obj) {
                                  adapter.setState(name, {val: val, ack: true});
                                  Это ненужная нагрузка на систему. И в будущем (а оно, я уверен, наступит), когда будет CouchDb, каждый раз будет создаваться история объекта.
                                  Вот этого я тоже не пойму..
                                  [https://github.com/instalator/iobroker. … di.js#L255](https://github.com/instalator/iobroker.kodi/blob/master/kodi.js#L255)
                                  • I Offline
                                    I Offline
                                    instalator
                                    @Bluefox:
                                    Это ненужная нагрузка на систему. И в будущем (а оно, я уверен, наступит), когда будет CouchDb, каждый раз будет создаваться история объекта. `
                                    Это переделаю.
                                    @Bluefox:
                                    https://github.com/instalator/iobroker. … di.js#L255 `
                                    Если этой строки не добавить, то драйвер не реагирует на message. И только после того как из самого драйвера отправишь сообщение то начинает работать и из драйвера JS. Поэтому сделал пока так и хотел тебя спросить по этому вопросу.
                                    • I Offline
                                      I Offline
                                      instalator
                                      @Bluefox:
                                      @instalator:
                                      @Bluefox:
                                      Создай переменную info.connection вместо KODI_connected и статус соединения будет показываться в admin. `
                                      info.connection добавил, интересная штука, только сейчас увидел ее в работе)
                                      А вот по падению не понятно.
                                      Если в драйвере оставляю в main только этот код:
                                      getConnection(function (err, _connection) {
                                      if (_connection){
                                      стартануть драйвер, а потом закрыть программу КОДИ, то драйвер просто падает.
                                      Из лога ошибка не ясна.
                                      host-Server-PC	2016-05-04 19:39:14	info	Restart adapter system.adapter.kodi.0 because enabled
                                      host-Server-PC	2016-05-04 19:39:14	error	instance system.adapter.kodi.0 terminated with code 0 (OK)
                                      kodi-0	2016-05-04 19:39:12	debug	Response GetPlayerId [[],{"muted":false,"volume":100}]
                                      • I Offline
                                        I Offline
                                        instalator
                                        Вот просто свалился и все, сам не перезапускается.
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          @instalator:
                                          Вот просто свалился и все, сам не перезапускается. `
                                          Я бы мог сегодня посмотреть по teamViewer
