  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер Ping
    5.9k
Драйвер Ping
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
15 Beiträge 4 Kommentatoren 4.7k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    @electric69:
    Пытаюсь заставить работать драйвер PING.
    Железо - BananaPI (не pro, обычная)
    ОС - http://www.igorpecovnik.com/2014/09/07/banana-pi-debian-sd-image/
    Версия ioBroker.js-controller - 0.4.1.
    Устанавливаю драйвер. через веб-интерфейс на вкладке "Драйвера" в строке "PING" справа нажимаю кнопку "+" (добавить экземпляр).
    Содержимое вкладки "Лог":
    ! system.adapter.ping.0 2015-01-13 19:54:32 error invalid mode
    ! host.bananapi 2015-01-13 19:54:32 info object change system.adapter.ping.0
    ! system.adapter.ping.0 2015-01-13 19:53:51 error invalid mode
    ! host.bananapi 2015-01-13 19:53:51 info object change system.adapter.ping.0
    ! host.bananapi 2015-01-13 19:53:32 info object change system.adapter.ping.0
    ! iobroker 2015-01-13 19:53:12 info exit 0
    ! iobroker 2015-01-13 19:53:12 info object system.adapter.ping.0 created
    ! host.bananapi 2015-01-13 19:53:11 info object change system.adapter.ping.0
    ! iobroker 2015-01-13 19:53:11 info object system.adapter.ping.0.alive created
    ! iobroker 2015-01-13 19:53:11 info object system.adapter.ping.0.connected created
    ! iobroker 2015-01-13 19:53:11 info object system.adapter.ping.0.memHeapUsed created
    ! iobroker 2015-01-13 19:53:11 info object system.adapter.ping.0.memHeapTotal created
    ! iobroker 2015-01-13 19:53:11 info object system.adapter.ping.0.memRss created
    ! iobroker 2015-01-13 19:53:11 info object system.adapter.ping.0.uptime created
    ! iobroker 2015-01-13 19:53:11 info create instance ping
    ! iobroker 2015-01-13 19:53:11 info object system.adapter.ping created
    ! iobroker 2015-01-13 19:53:11 info upload ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html
    ! iobroker 2015-01-13 19:53:11 info upload ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
    ! iobroker 2015-01-13 19:53:11 info got /opt/iobroker/node_modules/iobroker.ping/admin
    ! iobroker 2015-01-13 19:53:11 info install adapter ping
    ! iobroker 2015-01-13 19:52:54 info WARN package.json daemonize2@0.4.2 No repository field.
    ! iobroker 2015-01-13 19:52:54 info npm
    ! iobroker 2015-01-13 19:52:50 info npm install iobroker.ping –production [/opt/iobroker/lib]
    ! iobroker 2015-01-13 19:52:46 info add ping
    Перемещаюсь на вкладку "Настройка драйверов", нажимаю кнопку "редактировать", ставлю галочку "активно".
    Нажимаю кнопку "настроить" - хммм… а где кнопачка "добавить хост"?
    Видимо что то пошло не так? `
    Это хорошо, что ты попробовал ping. При переводе на русский я забыл обновить одну ссылку.
    Можешь сам заменить файл ioBroker/node_modules/iobroker.ping/admin/index.html на:
    ! ### PING adapter settings
    ! #### Ping settings
    ! | Interval[ms]: | |
    ! #### Ping addresses после этого вызвать в ioBroker директории.
    node iobroker upload ping
    Ну или дождаться вечера и я исправлю ошибку.
    Спасибо.
    • E Offline
      electric69
      @Bluefox:
      Спасибо.
      Все сделал, кнопочка добавления хоста появилась. Добавил ардуинку, перезапустил драйвер несколько раз, но он не стартует.
      На вкладке "Лог" ошибки:
      ! system.adapter.ping.0 2015-01-14 18:57:40 error invalid mode
      ! host.bananapi 2015-01-14 18:57:40 info object change system.adapter.ping.0
      ! system.adapter.ping.0 2015-01-14 18:57:03 error invalid mode
      ! host.bananapi 2015-01-14 18:57:03 info object change system.adapter.ping.0
      ! system.adapter.ping.0 2015-01-14 18:54:43 error invalid mode
      ! host.bananapi 2015-01-14 18:54:43 info object change system.adapter.ping.0 `
      • BluefoxB Offline
        BluefoxB Offline
        @electric69:
        @Bluefox:
        Спасибо.
        Тоже ошибка перевода. Пофиксю ;)
        • BluefoxB Offline
          BluefoxB Offline
          @Bluefox:
          @electric69:
          @Bluefox:
          Спасибо.
          Нужно ещё раз деактивировать ping и снова активирвать через админку. (Просто перезапуск не поможет) `
          • E Offline
            electric69
            Установил драйвер, перешел на вкладку драйверов, добавил хосты, нажал сохранить и выйти, в логe:
            ! ping.0 2015-01-22 19:41:22 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.ping
            ! host.bananapi 2015-01-22 19:41:19 info instance system.adapter.ping.0 started with pid 3496
            ! host.bananapi 2015-01-22 19:41:17 info instance system.adapter.ping.0 terminated with code 0 (OK)
            ! ping.0 2015-01-22 19:41:17 info terminating
            ! host.bananapi 2015-01-22 19:41:17 info stopInstance system.adapter.ping.0 killing pid 2293
            ! host.bananapi 2015-01-22 19:41:17 info object change system.adapter.ping.0
            Вроде все хорошо.
            Затем опять зашел в настройки драйвера, в одином из хостов поменял название и IP-адрес (даже если только адрес), сохранить и выйти, в логе пошли ошибки:
            ! bananapi 2015-01-22 19:49:15 info host.bananapi Restart adapter system.adapter.ping.0 because enabled
            ! bananapi 2015-01-22 19:49:15 error host.bananapi instance system.adapter.ping.0 terminated with code 6 (uncaught exception)
            ! ping.0 2015-01-22 19:49:15 error TypeError: Cannot call method 'replace' of undefined at /opt/iobroker/node_modules/iobroker.ping/main.js:195:43 at Socket. (/opt/iobroker/lib/adapter.js:989:44) at Socket.onack
            ! ping.0 2015-01-22 19:49:15 error uncaught exception: Cannot call method 'replace' of undefined
            ! ping.0 2015-01-22 19:49:15 info ping.0 starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.ping
            ! bananapi 2015-01-22 19:49:11 info host.bananapi instance system.adapter.ping.0 started with pid 5744
            ! host.bananapi 2015-01-22 19:48:41 info Restart adapter system.adapter.ping.0 because enabled
            ! host.bananapi 2015-01-22 19:48:41 error instance system.adapter.ping.0 terminated with code 6 (uncaught exception)
            ! TypeError: 2015-01-22 19:48:41 error at Decoder.add (/opt/iobroker/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
            ! TypeError: 2015-01-22 19:48:41 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:48:41 error at Decoder. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:48:41 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:274:8)
            ! TypeError: 2015-01-22 19:48:41 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:48:41 error at Manager. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:48:41 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:219:12)
            ! TypeError: 2015-01-22 19:48:41 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:294:6)
            ! TypeError: 2015-01-22 19:48:41 error at Socket. (/opt/iobroker/lib/adapter.js:989:44)
            ! TypeError: 2015-01-22 19:48:41 error at /opt/iobroker/node_modules/iobroker.ping/main.js:195:43
            ! TypeError: 2015-01-22 19:48:41 error Cannot call method 'replace' of undefined
            ! uncaught 2015-01-22 19:48:41 error exception: Cannot call method 'replace' of undefined
            ! ping.0 2015-01-22 19:48:40 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.ping
            ! host.bananapi 2015-01-22 19:48:37 info instance system.adapter.ping.0 started with pid 5577
            ! host.bananapi 2015-01-22 19:48:07 info Restart adapter system.adapter.ping.0 because enabled
            ! host.bananapi 2015-01-22 19:48:07 error instance system.adapter.ping.0 terminated with code 6 (uncaught exception)
            ! TypeError: 2015-01-22 19:48:07 error at Decoder.add (/opt/iobroker/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
            ! TypeError: 2015-01-22 19:48:07 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:48:07 error at Decoder. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:48:07 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:274:8)
            ! TypeError: 2015-01-22 19:48:07 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:48:07 error at Manager. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:48:07 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:219:12)
            ! TypeError: 2015-01-22 19:48:07 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:294:6)
            ! TypeError: 2015-01-22 19:48:07 error at Socket. (/opt/iobroker/lib/adapter.js:989:44)
            ! TypeError: 2015-01-22 19:48:07 error at /opt/iobroker/node_modules/iobroker.ping/main.js:195:43
            ! TypeError: 2015-01-22 19:48:07 error Cannot call method 'replace' of undefined
            ! uncaught 2015-01-22 19:48:07 error exception: Cannot call method 'replace' of undefined
            ! ping.0 2015-01-22 19:48:06 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.ping
            ! host.bananapi 2015-01-22 19:48:03 info instance system.adapter.ping.0 started with pid 5410
            ! host.bananapi 2015-01-22 19:47:33 info Restart adapter system.adapter.ping.0 because enabled
            ! host.bananapi 2015-01-22 19:47:33 error instance system.adapter.ping.0 terminated with code 6 (uncaught exception)
            ! TypeError: 2015-01-22 19:47:33 error at Decoder.add (/opt/iobroker/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
            ! TypeError: 2015-01-22 19:47:33 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:47:33 error at Decoder. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:47:33 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:274:8)
            ! TypeError: 2015-01-22 19:47:33 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:47:33 error at Manager. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:47:33 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:219:12)
            ! TypeError: 2015-01-22 19:47:33 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:294:6)
            ! TypeError: 2015-01-22 19:47:33 error at Socket. (/opt/iobroker/lib/adapter.js:989:44)
            ! TypeError: 2015-01-22 19:47:33 error at /opt/iobroker/node_modules/iobroker.ping/main.js:195:43
            ! TypeError: 2015-01-22 19:47:33 error Cannot call method 'replace' of undefined
            ! uncaught 2015-01-22 19:47:33 error exception: Cannot call method 'replace' of undefined
            ! ping.0 2015-01-22 19:47:32 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.ping
            ! host.bananapi 2015-01-22 19:47:29 info instance system.adapter.ping.0 started with pid 5244
            ! host.bananapi 2015-01-22 19:46:59 info Restart adapter system.adapter.ping.0 because enabled
            ! host.bananapi 2015-01-22 19:46:59 error instance system.adapter.ping.0 terminated with code 6 (uncaught exception)
            ! TypeError: 2015-01-22 19:46:58 error at Decoder.add (/opt/iobroker/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
            ! TypeError: 2015-01-22 19:46:58 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:46:58 error at Decoder. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:46:58 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:274:8)
            ! TypeError: 2015-01-22 19:46:58 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:46:58 error at Manager. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:46:58 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:219:12)
            ! TypeError: 2015-01-22 19:46:58 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:294:6)
            ! TypeError: 2015-01-22 19:46:58 error at Socket. (/opt/iobroker/lib/adapter.js:989:44)
            ! TypeError: 2015-01-22 19:46:58 error at /opt/iobroker/node_modules/iobroker.ping/main.js:195:43
            ! TypeError: 2015-01-22 19:46:58 error Cannot call method 'replace' of undefined
            ! uncaught 2015-01-22 19:46:58 error exception: Cannot call method 'replace' of undefined
            ! ping.0 2015-01-22 19:46:58 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.ping
            ! host.bananapi 2015-01-22 19:46:55 info instance system.adapter.ping.0 started with pid 5078
            ! host.bananapi 2015-01-22 19:46:25 info Restart adapter system.adapter.ping.0 because enabled
            ! host.bananapi 2015-01-22 19:46:25 error instance system.adapter.ping.0 terminated with code 6 (uncaught exception)
            ! TypeError: 2015-01-22 19:46:24 error at Decoder.add (/opt/iobroker/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
            ! TypeError: 2015-01-22 19:46:24 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:46:24 error at Decoder. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:46:24 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:274:8)
            ! TypeError: 2015-01-22 19:46:24 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
            ! TypeError: 2015-01-22 19:46:24 error at Manager. (/opt/iobroker/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            ! TypeError: 2015-01-22 19:46:24 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:219:12)
            ! TypeError: 2015-01-22 19:46:24 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:294:6)
            ! TypeError: 2015-01-22 19:46:24 error at Socket. (/opt/iobroker/lib/adapter.js:989:44)
            ! TypeError: 2015-01-22 19:46:24 error at /opt/iobroker/node_modules/iobroker.ping/main.js:195:43
            ! TypeError: 2015-01-22 19:46:24 error Cannot call method 'replace' of undefined
            ! uncaught 2015-01-22 19:46:24 error exception: Cannot call method 'replace' of undefined
            ! ping.0 2015-01-22 19:46:24 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.ping
            ! host.bananapi 2015-01-22 19:46:21 info instance system.adapter.ping.0 started with pid 4912
            ! host.bananapi 2015-01-22 19:46:19 info instance system.adapter.ping.0 terminated with code 0 (OK)
            ! ping.0 2015-01-22 19:46:19 info terminating
            ! host.bananapi 2015-01-22 19:46:18 info stopInstance system.adapter.ping.0 killing pid 4265
            ! host.bananapi 2015-01-22 19:46:18 info object change system.adapter.ping.0
            Редактирование хоста со старыми настройками (вернуть значения) не помогает, перезагрузка драйвера не помогает. Только полная очистка настроек, потом удаление объекта "bananapi" из папки "ping.0" на вкладке "Объекты" и полная перезагрузка сервера. Затем добавление нужных хостов для сканирования в драйвер и его запуск - так срабатывает…
            • BluefoxB Offline
              BluefoxB Offline
              @electric69:
              Вроде все хорошо.
              Редактирование хоста со старыми настройками (вернуть значения) не помогает, перезагрузка драйвера не помогает. Только полная очистка настроек, потом удаление объекта "bananapi" из папки "ping.0" на вкладке "Объекты" и полная перезагрузка сервера. Затем добавление нужных хостов для сканирования в драйвер и его запуск - так срабатывает… `
              В новой версии должно работать. 0.1.3
              • V Offline
                V Offline
                vtec
                Bluefox, подскажи, что должно происходить если хост перестал пинговаться?
                Или это я сам должен в виде скрипта сделать, то что мне нужно?
                • E Offline
                  electric69
                  @vtec:
                  Или это я сам должен в виде скрипта сделать, то что мне нужно? `
                  Если хост перестал пинговаться, то значение переменной станет false и все.
                  Реакция может быть как графическая - просто фигура/текст/картинка - зеленый/красный/путь_к_картинке, так и через скрипт. В скрипте либо "подписаться" на изменение переменной, либо по таймеру проверять состояние (как в CCU.IO сейчас).
                  • V Offline
                    V Offline
                    vtec
                    electric69, спасибо.
                    • V Offline
                      V Offline
                      vtec
                      А есть возможность получить массив и его проверить на значение false? Чтобы каждое устройство не проверять.
                      И у кого какая реакция настроена на отсутствие ping'а?
                      • BluefoxB Offline
                        BluefoxB Offline
                        @vtec:
                        А есть возможность получить массив и его проверить на значение false? Чтобы каждое устройство не проверять. `
                        Возможности нет. Но мысли есть.
                        Какой use-case?
                        Показывать в vis, мониторить по IP телефонов присутствие домочадцев дома. Рассылка для особо критичных устройств email. Например если NAS не пингуется.
