  2. Русский
  3. ioBroker
  4. Скрипты
  5. ioBroker скрипты
  6. Скрипт для датчика CO2 MH-Z14 (MH-Z19)
    1.7k
Geplant Angeheftet Gesperrt Verschoben ioBroker скрипты
16 Beiträge 2 Kommentatoren 3.4k Aufrufe
    andrey99986
    Датчик:
    https://ru.aliexpress.com/item/Free-shi … 6141ebe467
    Адаптер:
    https://ru.aliexpress.com/item/FT232RL- ... 0.0.DBxfZO
    var device_port = '/dev/ttyUSB2';
    var buflen = 64;
    var sleep_time = 200; // Sleep time between request and wait for response.
    var SerialPort = require('serialport');
    var ByteLength = SerialPort.parsers.ByteLength;
    var ppm;
    var cmd_init = new Buffer ([0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79]);
    var cmd_set_zero = new Buffer ([0xFF, 0x01, 0x87, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78]);
    function toHexString(byteArray) {
      return Array.from(byteArray, function(byte) {
        return ('0' + (byte & 0xFF).toString(16)).slice(-2);
      }).join('');
    function co2_gd(cmd,buflen,callback)
        var port = new SerialPort(device_port,{
        baudrate: 9600,
        dataBits: 8,
        parity: 'none'
        const parser = port.pipe(new ByteLength({length: buflen}));
        port.pipe(parser);
        port.write(cmd);
        setTimeout(readport, sleep_time);
        function readport () {
            parser.on ('data', function (result) {
                   ppm = null;
                   var CRC_calc=0;
                    var b2 = parseInt(toHexString(result.slice(3,4)),16);
                    var b3 = parseInt(toHexString(result.slice(5,6)),16);
                    var b4 = parseInt(toHexString(result.slice(7,8)),16);
                    var b5 = parseInt(toHexString(result.slice(9,10)),16);
                    var b6 = parseInt(toHexString(result.slice(11,12)),16);
                    var b7 = parseInt(toHexString(result.slice(13,14)),16);
                    var b8 = parseInt(toHexString(result.slice(15,16)),16);
                    var CRC_get = parseInt(toHexString(result.slice(17,18)),16);
                    CRC_calc = (255 - (b2 + b3 + b4 + b5 + b6 + b7 + b8) % 256) + 1;
                    if (CRC_get != CRC_calc)
                        console.log ('CRC ERROR');
                        console.log ('result='+JSON.stringify(result));
                        console.log('b='+b2+' '+b3+' '+b4+' '+b5+' '+b6+' '+b7+' '+b8 );
                        console.log('CRC_get='+(CRC_get));
                        console.log('CRC_calc='+(CRC_calc));
                    else
                        //console.log ('CRC CO2 is  OK');
                        //console.log ('result='+JSON.stringify(result));
                        //console.log('b='+b2+' '+b3+' '+b4+' '+b5+' '+b6+' '+b7+' '+b8 );
                        //console.log('CRC_get='+(CRC_get));
                        //console.log('CRC_calc='+(CRC_calc));
                        var Hibyte = toHexString(result.slice(5,6));
                        var Lowbyte = toHexString(result.slice(7,8));
                        ppm = parseInt(Hibyte,16)*256+parseInt(Lowbyte,16);
                        //console.log('Hibyte='+Hibyte);
                        //console.log('Lowbyte='+Hibyte);
                        //console.log('ppm='+ppm);
                        if (ppm> 5000 )
                                console.log ('CRC OK');
                                ppm = null;
                    if (callback && typeof(callback) === "function") {
                    callback(ppm);
            }); //parser.on
            port.pause();
            port.close();
            return (ppm);
    }  //end function co2_gd
    //co2_gd(cmd_set_zero,18, function(data) {} ); //Set CO2 level as zero  (400 ppm)
    schedule("* * * * *", function () {
        co2_gd(cmd_init,18, function(data) {
            //console.log('CO2 ppm='+data);
            setState("javascript.0.CO2_1f_uart",data);
      artko
      Не работает.
      8:10:37.273 [info] javascript.0 Start javascript script.js.common.co2_mh_z19
      18:10:37.274 [info] javascript.0 script.js.common.co2_mh_z19: registered 0 subscriptions and 1 schedule
      18:11:00.281 [info] javascript.0 script.js.common.co2_mh_z19: request={"type":"Buffer","data":[255,1,134,0,0,0,0,0,121]}
      18:11:00.508 [info] javascript.0 script.js.common.co2_mh_z19: –-----------------
      18:11:00.509 [info] javascript.0 script.js.common.co2_mh_z19: CRC ERROR
      18:11:00.510 [info] javascript.0 script.js.common.co2_mh_z19: result={"type":"Buffer","data":[255,255,134,2,142,86,134,2,142,86,4,4,58,58,137,137,205,205]}
      18:11:00.510 [info] javascript.0 script.js.common.co2_mh_z19: b=2 86 2 86 4 58 137
      18:11:00.510 [info] javascript.0 script.js.common.co2_mh_z19: CRC_get=205
      18:11:00.511 [info] javascript.0 script.js.common.co2_mh_z19: CRC_calc=137
      Добавлял отладочный вывод запросов - такое впечатление, что отсылается команда чтения два раза и потом в буфере приемном все перемешано, вот и лажа.
        artko
        А никому не приходилось бороться со странными зависами при setTimeout в скриптах?
        Переделал скрипт из темы, несколько раз получил результаты и теперь мертвые висы.
          console.log('wait response');
                    setTimeout(readport, 200);
                    function readport() {
                                                console.log('readport enter');
        в логе вижу первый вывод в консоль - и все, глухой вис. в top висит процесс iobroker.javascript с 100% загрузкой, драйвер javascript в панели тоже останавливается. Приходится вручную процесс убивать.
        Иногда по непонятной причине - проходит, результат получается нормально.
          andrey99986
          @artko:
          Не работает.
          CRC ERROR
          Добавлял отладочный вывод запросов - такое впечатление, что отсылается команда чтения два раза и потом в буфере приемном все перемешано, вот и лажа. `
          Дело в том что мне попадались 2 типа USB-Uart адаптера.
          В первом случае ответы дублируются побайтно, а во втором - ответ дублируется целиком.
          При чём у разных адаптеров разный % CRC Error.
          В вашем случае побайтный дубль (как у меня) и видно - что идёт сбой ответа - не все байты попарно одинаковы.
          Длина кабеля?
          Уверены что нет просадки напряжения на самом датчике в моменты ИК-свечения (ток вроде 300мА)?
          Какой у вас адаптер?
          В первые пару минут - CRC error это нормально.
          Попробуйте другой адаптер.
          У меня на таком FTDI_FT232R_USB_UART_AH05SK6S CRC ошибок менее ~3 %
          P.S.Мой скрипт написан для MH-Z14, на MH-Z19 ещё не проверял. Скоро проверю, сам датчик уже есть. Судя по документации логика абсолютно одинаковая.
            andrey99986
            @artko:
            Иногда по непонятной причине - проходит, результат получается нормально. `
            Какая OS?
            Сколько свободной памяти показывает iobroker?
              artko
              @andrey99986:
              Длина кабеля?
              P.S.Мой скрипт написан для MH-Z14, на MH-Z19 ещё не проверял. Скоро проверю, сам датчик уже есть. Судя по документации логика абсолютно одинаковая. `
              адаптер прямо в порту торчит. чип CP2102. датчик - проводочки сантиметров пять. Просадку не смотрел. Два разных адаптера (одинаковых, впрочем, по чипу и схеме).
              Скрипт на питоне - работает как из пушки. Ни одной ошибки.
              import MySQLdb
              import string
              import time
              import serial
              from datetime import datetime
              ser = serial.Serial('/dev/ttyUSB0',
                                    baudrate=9600,
                                    bytesize=serial.EIGHTBITS,
                                    parity=serial.PARITY_NONE,
                                    stopbits=serial.STOPBITS_ONE,
                                    timeout=1.0)
              result=ser.write("\xff\x01\x86\x00\x00\x00\x00\x00\x79")
              s=ser.read(9)
              if s[0] == "\xff" and s[1] == "\x86":
                co2 = ord(s[2])*256 + ord(s[3])
              print "co2=", co2
              ts = time.time()
              ts1 = int(ts * 1000)
              print "ts=", ts1
              db = MySQLdb.connect(host="localhost", user="xxxx", passwd="xxxxx", db="iobroker", charset="utf8")
              cursor = db.cursor()
              sql = """insert iobroker.ts_number(id, ts, val, ack, _from, q) values (12,%(ts)s,%(val)s,0,2,0) """ %{"ts":ts1, "val":co2}
              print "sql=", sql
              cursor.execute(sql)
              db.commit()
              db.close()
                artko
                @andrey99986:
                Какая OS?
                Сколько свободной памяти показывает iobroker? `
                Ubuntu 16.04LTS.
                Всего RAM - Используется: 325 Мб / Свободно: 176 Мб (9%) [Сервер: atom-nb - 9 процессов]
                %Cpu(s): 8,0 us, 2,0 sy, 0,0 ni, 87,0 id, 3,0 wa, 0,0 hi, 0,0 si, 0,0 st
                КиБ Mem : 2050484 total, 179628 free, 520800 used, 1350056 buff/cache
                КиБ Swap: 8269820 total, 8203072 free, 66748 used. 1233352 avail Mem
                  andrey99986
                  @artko:
                  @andrey99986:
                  Какая OS?
                  Ubuntu 16.04LTS.
                  КиБ Swap: 8269820 total, 8203072 free, 66748 used. 1233352 avail Mem `
                  У меня драйвер javascript при работе с ком-портами периодически самоперегружается, поэтому я скрипты работающие с ком-портами запускаю в дополнительной инстанции, чтобы сбой не повлиял на работу других скриптов. Причина где то в недрах библиотеки serialport nodejs. По идее надо дебажить и создавать issue на https://github.com/node-serialport/node … ort/issues
                    andrey99986
                    @artko:
                    Скрипт на питоне - работает как из пушки. Ни одной ошибки. `
                    Попробуй поменять в коде на````
                    var buflen = 9;
                    Ещё вероятно причина в драйвере serialport. Видно же что ответ ненормальный идёт. Сделайте дебаг вывод ответа питона и сравните с nodejs.
                    С питоном также дублированы байты ответа?
                    Когда работает с портом iobroker (nodejs) - другие скрипты на уровне OS (питон) с этим портом не работают?
                      artko
                      12:25:19.724 [info] javascript.0 script.js.common.Скрипт1: registered 0 subscriptions and 1 schedule
                      12:26:00.729 [error] javascript.0 at co2_gd (script.js.common.Скрипт1:20:16)
                      12:26:00.730 [error] javascript.0 at Object. (script.js.common.Скрипт1:93:5)
                      20 var port = new SerialPort(device_port,{
                      93 co2_gd(cmd_init,18, function(data) {
                      с питоном ничего не дублируется, с терминалкой тоже все ок. никаких других скриптов кроме этого вообще нет. питон на время экспериментов остановил.
                      похоже, что-то в недрах nodejs.serialport очень странно работает.
                        andrey99986
                        @artko:
                        похоже, что-то в недрах nodejs.serialport очень странно работает. `
                        Посмотреть кто занял порт:
                         fuser /dev/ttyUSB1
                        Иногда javascript driver надо перезапустить чтобы порт освободить.
                        Это не помогло?
                        var buflen = 9;
                          artko
                          @andrey99986:
                           fuser /dev/ttyUSB1
                          Иногда javascript driver надо перезапустить чтобы порт освободить. `
                          никто не занимает, ну и проверяю в процессах - уже вижу, если висит io.javascript c 100% загрузкой ядра - то ой. почему-то вешается именно при ожидании данных.
                          сделал себе вот такой вариант скрипта для проверки по этапам:
                          `createState('CO2_UART');
                          var device_port = '/dev/ttyUSB0';
                          var buflen = 64;
                          var ppm;
                          //var cmd_abc_off = new Buffer ([0xFF, 0x01, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x86]);
                          //var cmd_abc_on= new Buffer ([0xFF, 0x01, 0x79, 0xA0, 0x00, 0x00, 0x00, 0x00, 0xE6]);
                              baudRate: 9600,
                              dataBits: 8,
                              parity: 'none',
                              autoOpen: false
                              port.open(function (err) {
                                  if (err) {
                                      return console.log('Error opening port: ', err.message);
                                  console.log('port opened');
                                  console.log ('request='+JSON.stringify(cmd));
                                  port.pipe(parser);
                                  port.write(cmd, function(err) {
                                      if (err) {
                                          return console.log('Error on write: ', err.message);
                                      console.log('message written');
                                      port.pipe(parser);
        var i = 0;
        while (i < 18)
                                            if (result[i] == result[i+1])
                                                i += 2;
                                            else
                                                if ((i + 2) < 18)
                                                    if (result[i] == result[i+2])
                                                        console.log ('fix data at position ' + i);
                                                        result[i+2] = result[i+1];
                                                        result[i+1] = result[i];
                                                        i += 2;
                                           console.log('fix cycle ' + i);
        ppm = null;
        var CRC_calc=0;
        var CRC_get = result[16];
        CRC_calc = (255 - (result[2] + result[4] + result[6] + result[8] + result[10] + result[12] + result[14]) % 256) + 1;
        else
                                                      ppm = result[4] * 256 + result[6];
                                                      if (ppm> 5000 )
                                                          ppm = null;
        callback(ppm);
        port.pause();
        port.close();
        return (ppm);
                          schedule("*/15 * * * * *", function () {
                              console.log('co2 request');
                                  setState("CO2_UART",data);
                          ~~[quote]~~
                          Это не помогло?
                          `~~[code]~~var buflen = 9;[/code]` `  `
                          неа, в таком виде как скрипт из первого сообщения - вообще не хочет работать. с ошибками.[/i][/i][/i]
                            andrey99986
                            @artko:
                            Что-то не видно проверки CRC на питоне. Понятно что без проверки ошибок нет :)
                              artko
                              @andrey99986:
                              @artko:
                              Скрипт на питоне - работает как из пушки. Ни одной ошибки. Что-то не видно проверки CRC на питоне. Понятно что без проверки ошибок нет :)
                              то был первый вариант :) питон принимает строго нужное количество байт, crc совпадает :)
                                andrey99986
                                @artko:
                                то был первый вариант :) питон принимает строго нужное количество байт, crc совпадает :) `
                                CRC вычисляется в именно в строгом количестве байт, смотрите даташит на датчик. В вашем коде на питоне проверки CRC нет.
                                  artko
                                  @andrey99986:
                                  @artko:
                                  то был первый вариант :) питон принимает строго нужное количество байт, crc совпадает :) CRC вычисляется в именно в строгом количестве байт, смотрите даташит на датчик. В вашем коде на питоне проверки CRC нет.
                                  я же написал, то был первый вариант….
                                  import MySQLdb
                                  import string
                                  import time
                                  import serial
                                                        baudrate=9600,
                                                        timeout=1.0)
                                  s=ser.read(9)
                                  str = ""
                                  for ch in s:
                                  	str += hex(ord(ch))+ " "
                                  print str
                                  crc_get = ord(s[8])
                                  crc_calc = (255 - (ord(s[1]) + ord(s[2]) + ord(s[3]) + ord(s[4]) + ord(s[5]) + ord(s[6]) + ord(s[7]))) % 256 + 1
                                  print "crc calc=" + hex(crc_calc) + " crc get=" + hex(crc_calc)
                                  if s[0] == "\xff" and s[1] == "\x86" and crc_calc == crc_get:
                                     print "crc ok"
                                  else:
                                     co2 = 0
                                     print "crc error"
                                  print "co2=", co2
                                  ts = time.time()
                                  print "ts=", ts1
                                  db = MySQLdb.connect(host="localhost", user="xxxxxxx", passwd="xxxxxxx", db="iobroker", charset="utf8")
                                  print "sql=", sql
                                  cursor.execute(sql)
                                  db.commit()
                                  db.close()
                                  вывод исполнения
                                  0xff 0x86 0x1 0xca 0x57 0x40 0x28 0x58 0x98
                                  crc calc=0x98 crc get=0x98
                                  crc ok
                                  co2= 458
                                  ts= 1514450008318
                                  sql= insert iobroker.ts_number(id, ts, val, ack, _from, q) values (12,1514450008318,458,0,2,0)
