  4. SQL Adapter Fehlermeldung
14 Beiträge 4 Kommentatoren 3.6k Aufrufe
  • L Offline
    Loomii
    Bekomme seit gestern eine Fehlermeldung vom SQL Adapter
    ! sql.0 2016-11-16 18:39:06.276 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! socketio.0 2016-11-16 18:39:05.719 info 2016-11-16T17:39:05.719Z Connected system.user.admin
    ! sql.0 2016-11-16 18:39:03.513 info No Data
    ! sql.0 2016-11-16 18:38:54.902 warn No connection to SQL-DB
    ! sql.0 2016-11-16 18:38:36.260 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! hm-rpc.1 2016-11-16 18:38:30.121 info Connected
    ! hm-rpc.1 2016-11-16 18:38:29.003 info binrpc -> listDevices 54
    ! hm-rpc.1 2016-11-16 18:38:28.337 info Disconnected
    ! sql.0 2016-11-16 18:38:06.238 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! sql.0 2016-11-16 18:37:36.200 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! sql.0 2016-11-16 18:37:06.187 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! sql.0 2016-11-16 18:36:36.164 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! sql.0 2016-11-16 18:36:06.144 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! sql.0 2016-11-16 18:35:53.271 warn No connection to SQL-DB
    ! sql.0 2016-11-16 18:35:53.255 warn No connection to SQL-DB
    ! sql.0 2016-11-16 18:35:36.119 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! hm-rpc.1 2016-11-16 18:35:28.295 info Connected
    ! hm-rpc.1 2016-11-16 18:35:27.204 info binrpc -> listDevices 54
    ! hm-rpc.1 2016-11-16 18:35:26.553 info Disconnected
    ! sql.0 2016-11-16 18:35:06.083 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! host.Iobroker-Server 2016-11-16 18:35:03.506 info instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
    ! tvspielfilm.0 2016-11-16 18:35:02.952 info objects written
    ! tvspielfilm.0 2016-11-16 18:35:02.905 info starting. Version 0.2.2 in D:/Iobroker/node_modules/iobroker.tvspielfilm, node: v4.6.1
    ! host.Iobroker-Server 2016-11-16 18:35:00.574 info instance system.adapter.tvspielfilm.0 started with pid 1140
    ! sql.0 2016-11-16 18:34:36.101 info enabled logging of hm-rpc.0.NEQ0194533.1.STATE
    ! sql.0 2016-11-16 18:34:36.101 info enabled logging of hm-rpc.0.MEQ0800610.4.VALVE_STATE
    ! sql.0 2016-11-16 18:34:36.101 info enabled logging of hm-rpc.0.MEQ0800610.4.SET_TEMPERATURE
    ! sql.0 2016-11-16 18:34:36.101 info enabled logging of hm-rpc.0.MEQ0800610.4.ACTUAL_TEMPERATURE
    ! sql.0 2016-11-16 18:34:36.079 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
    ! sql.0 2016-11-16 18:34:36.048 info starting. Version 1.3.0 in D:/Iobroker/node_modules/iobroker.sql, node: v4.6.1
    Wenn ich im Adapter auf Verbindung testen gehe kommt dieses:
    ! TypeError: SQL[clients[msg.message.config.dbtype].name] is not a function
    Und die Daten löschen bekomme ich das:
    ! TypeError: Cannot read property 'borrow' of undefined
    Adapter gelöscht und neu installiert habe ich auch schon versucht,ohne Erfolg.
    Node 4.6.1 und Adapter aktuelle 1.3.0
    Mfg
    Sven
    Debian Buster ,Node v12.19.0 NPM 6.14.8
    Billig Tablet an der Wand Android 4.4 und VIS App
    :mrgreen:
    • apollon77A Offline
      Gestern irgendwas am System gemacht? Irgendein Update?
      • L Offline
        Loomii
        Ne zumindest nicht den Tag davor. Hatte am Wochende die Updates gemacht aber da war noch kein
        Fehler da.
        Gruß Sven
        :mrgreen:
        • L Offline
          Loomii
          So habe jetzt das System komplett neu gemacht und nur den SQL Adapter installiert und der wirft mir gleich
          diese Fehlermeldung wieder raus!! :(
          ! sql.0 2016-11-22 17:32:44.916 error TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
          ! sql.0 2016-11-22 17:32:44.884 info starting. Version 1.3.2 in d:/ioBroker/node_modules/iobroker.sql, node: v4.5.0
          ! iobroker 2016-11-22 17:32:42.447 info exit 0
          ! iobroker 2016-11-22 17:32:42.416 info host.Iobroker-Server object system.adapter.sql.0 created
          Hab es mit Node 4.6.1 , 6.9.1 und jetzt mit 4.5.0 das mit dem Installer geliefert wird und bei allen das gleiche!? :?
          Wann soll er denn die SQlite Datei anlegen,wenn der Adapter installiert wird oder erst wenn Daten vorhanden sind?
          Das ganze läuft auf einen Win10 Rechner!!
          Einer ne Idee? Sonst muss ich mal anderen Adapter zum Loggen nehmen
          Mfg
          Sven
          :mrgreen:
            Was hast du denn in den Settings eingestellt? Zeig mal.
            Ansonsten mal versuchen: Settings -> irgendwas ändern und zurück das die Buttons aktiviert werden und so Settings neu schreiben. Gehts dann?
            • L Offline
              Loomii
              Hallo Apollon,
              Sind die standard Einstellungen wie es auch vorher gelaufen ist
              Habe jetzt mal kurz was zum loggen eingestellt und dann gleich ne latte an Meldungen.
              ! TypeError: 2016-11-22 18:56:58.473 error at Socket.onevent (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:270:10)
              ! TypeError: 2016-11-22 18:56:58.473 error at Socket.Emitter.emit (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
              ! TypeError: 2016-11-22 18:56:58.473 error at Socket. (D:\ioBroker\node_modules\iobroker.js-controller\lib\states\statesInMemClient.js:45:30)
              ! TypeError: 2016-11-22 18:56:58.473 error at Object.that.states.States.change (D:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:2169:34)
              ! TypeError: 2016-11-22 18:56:58.473 error at Adapter.emit (events.js:169:7)
              ! TypeError: 2016-11-22 18:56:58.473 error at emitOne (events.js:77:13)
              ! TypeError: 2016-11-22 18:56:58.473 error at Adapter. (D:\ioBroker\node_modules\iobroker.sql\main.js:106:5)
              ! TypeError: 2016-11-22 18:56:58.473 error at processMessage (D:\ioBroker\node_modules\iobroker.sql\main.js:484:9)
              ! TypeError: 2016-11-22 18:56:58.473 error at getHistory (D:\ioBroker\node_modules\iobroker.sql\main.js:1161:16)
              ! TypeError: 2016-11-22 18:56:58.473 error at getId (D:\ioBroker\node_modules\iobroker.sql\main.js:951:15)
              ! TypeError: 2016-11-22 18:56:58.473 error Cannot read property 'borrow' of undefined
              ! message 2016-11-22 18:56:58.457 error messagebox.system.adapter.sql.0 [object Object] Cannot read property 'borrow' of undefined
              ! sql.0 2016-11-22 18:56:51.357 info enabled logging of system.adapter.web.0.memHeapTotal
              Mfg
              Sven
              :mrgreen:
              • BluefoxB Offline
                BluefoxB Offline
                Sqlite wird als Binary übersetzt. Das heißt bei dir gibt es keine Pakete, dass die Übersetzung möglich ist.
                cd C:\iobroker
                npm install –global --production windows-build-tools
                npm install iobroker.sql --production
                • L Offline
                  Loomii
                  Hallo Bluefox
                  Habe es so gemacht wie du geschrieben hast aber immer noch die gleiche Meldung.
                  Was ich bloß nicht verstehe ist, das sich am System nichts geändert hat.
                  Oder hat sich der Adapter geändert das der jetzt dieses Dateien brauch?
                  Habe ihn jetzt erstmal deaktiviert der Rest läuft ja richtig gut.
                  Ich werde morgen nochmal sehen,reicht für heut :D
                  Vielen Dank erstmal Bluefox
                  Mfg
                  Sven
                  :mrgreen:
                    Die Konsolenausgaben von den beiden npm Befehlen wäre interessant …
                    • L Offline
                      Loomii
                      Moin,
                      Hier erstmal die Ausgaben vom Installer
                      ! Downloaded python-2.7.11.msi. Saved to C:\Users\Loom.windows-build-tools\python-2.7.11.msi.
                      ! Starting installation…
                      ! Launched installers, now waiting for them to finish.
                      ! This will likely take some time - please be patient!
                      ! Waiting for installers... -Successfully installed Python 2.7
                      ! Waiting for installers... \Successfully installed Visual Studio Build Tools.
                      ! windows-build-tools@0.6.1 C:\Users\Loom\AppData\Roaming\npm\node_modules\windows-build-tools
                      ! +-- cli-spinner@0.2.5
                      ! +-- debug@2.3.3 (ms@0.7.2)
                      ! +-- chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, has-ansi@2.0.0, strip-ansi@3.0.1)
                      ! +-- fs-extra@1.0.0 (jsonfile@2.4.0, graceful-fs@4.1.11, klaw@1.3.1)
                      ! +-- nugget@2.0.1 (throttleit@0.0.2, minimist@1.2.0, single-line-log@1.1.2, progress-stream@1.2.0, pretty-bytes@1.0.4, request@2.79.0)
                      ! PS D:\iobroker>
                      ! PS D:\iobroker> npm install iobroker.sql --production
                      ! npm WARN deprecated node-uuid@1.4.7: use uuid module instead
                      ! > sqlite3@3.1.8 install D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3
                      ! > node-pre-gyp install --fallback-to-build
                      ! node-pre-gyp ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws ... a32.tar.gz
                      ! node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@4.6.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                      ! D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" clean ) else (node "" clean )
                      ! D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" configure --fallback-to-build --module=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32\node_sqlite3.node --module_name=node_sqlite3 --module_path=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32 --python=C:\Users\Loom.windows-build-tools\python27\python.exe --msvs_version=2015 ) else (node "" configure --fallback-to-build --module=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32\node_sqlite3.node --module_name=node_sqlite3 --module_path=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32 --python=C:\Users\Loom.windows-build-tools\python27\python.exe --msvs_version=2015 )
                      ! gyp WARN install got an error, rolling back install
                      ! gyp ERR! configure error
                      ! gyp ERR! stack Error: ENOENT: no such file or directory, open 'D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\undefined'
                      ! gyp ERR! stack at Error (native)
                      ! gyp ERR! stack at Object.fs.openSync (fs.js:549:18)
                      ! gyp ERR! stack at Object.fs.readFileSync (fs.js:397:15)
                      ! gyp ERR! stack at readCAFile (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\install.js:466:15)
                      ! gyp ERR! stack at download (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\install.js:438:22)
                      ! gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\install.js:185:19
                      ! gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\mkdirp\index.js:30:20
                      ! gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
                      ! gyp ERR! System Windows_NT 10.0.10240
                      ! gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "configure" "--fallback-to-build" "--module=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32\node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32" "--python=C:\Users\Loom\.windows-build-tools\python27\python.exe" "--msvs_version=2015"
                      ! gyp ERR! cwd D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3
                      ! gyp ERR! node -v v4.6.1
                      ! gyp ERR! node-gyp -v v3.4.0
                      ! gyp ERR! not ok
                      ! node-pre-gyp ERR! build error
                      ! node-pre-gyp ERR! stack Error: Failed to execute 'node-gyp.cmd configure --fallback-to-build --module=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32\node_sqlite3.node --module_name=node_sqlite3 --module_path=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32 --python=C:\Users\Loom.windows-build-tools\python27\python.exe --msvs_version=2015' (1)
                      ! node-pre-gyp ERR! stack at ChildProcess. <anonymous>(D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
                      ! node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
                      ! node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                      ! node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:829:16)
                      ! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
                      ! node-pre-gyp ERR! System Windows_NT 10.0.10240
                      ! node-pre-gyp ERR! command "C:\Program Files\nodejs\node.exe" "D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
                      ! node-pre-gyp ERR! cwd D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3
                      ! node-pre-gyp ERR! node -v v4.6.1
                      ! node-pre-gyp ERR! node-pre-gyp -v v0.6.31
                      ! node-pre-gyp ERR! not ok
                      ! Failed to execute 'node-gyp.cmd configure --fallback-to-build --module=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32\node_sqlite3.node --module_name=node_sqlite3 --module_path=D:\iobroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32 --python=C:\Users\Loom.windows-build-tools\python27\python.exe --msvs_version=2015' (1)
                      ! npm WARN optional dep failed, continuing sqlite3@3.1.8
                      ! iobroker.sql@1.3.2 node_modules\iobroker.sql
                      ! +-- mysql@2.12.0 (sqlstring@2.2.0, bignumber.js@2.4.0, readable-stream@1.1.14)
                      ! +-- pg@6.1.0 (packet-reader@0.2.0, pg-connection-string@0.1.3, buffer-writer@1.0.1, semver@4.3.2, pg-pool@1.5.0, pg-types@1.11.0, pgpass@1.0.1)
                      ! +-- sql-client@0.7.0 (argf@0.0.1, optimist@0.6.1, inote-util@0.8.1)
                      ! +-- mssql@3.3.0 (generic-pool@2.5.0, promise@7.1.1, tedious@1.14.0)
                      ! PS D:\iobroker></anonymous>
                      So habe das ganze mal auf meinen Laptop mit frischen Win10 Pro 64bit installiert und lief gleich ohne irgendwelche Fehlermeldung.
                      Da habe ich das System vom Server neu aufgesetzt mit Win10 Pro 32bit(anderes geht nicht) und alles neu Installiert.
                      Wieder diese fehlermeldung.
                      Also da ganze nochmal mit Bluefox Ratschlag probiert und auch hier wiedr ohne Erfolg.Weiß nicht was es ist aber da System lief so ganze 9 Monate einwandfrei bis zum besagten Tag. :?
                      Mfg
                      Sven
                      :mrgreen:
                        Am besten reporte es mit allen infos mal beim Entwickler (https://github.com/mapbox/node-sqlite3) … vllt haben die ja ne Idee ...
                        • L Offline
                          Loomii
                          Hallo ,
                          So habe jetzt alles wieder rückgängig gemacht und mal das neue Node 0.7.2 installiert und mit
                          dieser Version funktioniert es wieder :D
                          Und alles ohne die build-tools.
                          Bis jetzt funktioniert auch alles so wie es soll.
                          Vielen Dank nochmal an die ,die versucht haben mit mir das Problem zu lösen.
                          Mfg
                          Sven
                          :mrgreen:
                            @Loomii:
                            dieser Version funktioniert es wieder `
                            nicht ganz so gut:
                            @fsjoke in einem anderen Thread:
                            Eine Übersicht was unterstützt wird in welcher nodejs-Version gibt's auf: http://node.green/
                            Übrigens, alle ungeraden Versionen (5.x.x, 7.x.x) sind nur Entwicklerversionen und bekommen keinen long time support (werden mehr als ein Jahr upgedated). Also wenn du nicht selbst an nodejs mitschraubst dann die Finger weg davon. `
                            Rainer
                            • L Offline
                              Loomii
                              Moin Homoran,
                              Danke für den Tip. Das mit den graden und ungraden wußte ich nicht 😢
                              Dachte hätte es einfach gelöst :mrgreen:
                              Denn werde ich noch weiter auf Fehlersuche gehen aber solange bleibt die Version erstmal :D
                              Danke euch.
                              Mfg
                              Sven
                              :mrgreen:
