  4. [gelöst] Hilfe: ich kriege IOBroker NICHT installiert
40 Beiträge 8 Kommentatoren 8.0k Aufrufe
    skorpil
    auf meinem neuen Raspi 3 versuche ich, iobroker nach dem Rezept unter
    http://www.iobroker.net/?page_id=5106&lang=de
    zu installieren. Aber es klappt nicht. Alles funktioniert. node.js ist drauf. Und dann bricht die Installation bei
    "sudo npm install iobroker –unsafe-perm"
    ab. Hier die Fehlermeldung:
    0 info it worked if it ends with ok
    1 verbose cli [ '/usr/bin/nodejs',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker --unsafe-perm' ]
    2 info using npm@2.15.11
    3 info using node@v4.7.2
    4 verbose install initial load of /opt/iobroker/package.json
    5 verbose installManyTop reading scoped package data from /opt/iobroker/node_modules/iobroker/package.json
    6 verbose readDependencies loading dependencies from /opt/iobroker/package.json
    7 silly cache add args [ 'iobroker --unsafe-perm', null ]
    8 verbose cache add spec iobroker --unsafe-perm
    9 silly cache add parsed spec Result {
    9 silly cache add   raw: 'iobroker --unsafe-perm',
    9 silly cache add   scope: null,
    9 silly cache add   name: null,
    9 silly cache add   rawSpec: 'iobroker --unsafe-perm',
    9 silly cache add   spec: '/opt/iobroker/iobroker --unsafe-perm',
    9 silly cache add   type: 'local' }
    10 error addLocal Could not install /opt/iobroker/iobroker --unsafe-perm
    11 verbose stack Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker --unsafe-perm'
    11 verbose stack     at Error (native)
    12 verbose cwd /opt/iobroker
    13 error Linux 4.4.38-v7+
    14 error argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker --unsafe-perm"
    15 error node v4.7.2
    16 error npm  v2.15.11
    17 error path /opt/iobroker/iobroker --unsafe-perm
    18 error code ENOENT
    19 error errno -2
    20 error syscall open
    21 error enoent ENOENT: no such file or directory, open '/opt/iobroker/iobroker --unsafe-perm'
    21 error enoent This is most likely not a problem with npm itself
    21 error enoent and is related to npm not being able to find a file.
    22 verbose exit [ -2, true ]
    Was mache ich falsch? Was ist zu tun?
    Danke für Euere Hilfe!
    • eric2905E Offline
      eric2905E Offline
      eric2905
      welche Antwort kommt bei
      node -v
      npm -v
      Du hast diese Schritte aus der Anleitung in dieser Reihenfolge ausgeführt?
      > Die alten node & node.js Versionen deinstallieren (bei Jessie Light nicht notwendig)
      apt-get --purge remove node
      apt-get --purge remove nodejs
      apt-get autoremove
      reboot
      > Node.js neu installieren für Raspbery 2/3
      curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
      sudo apt-get install -y build-essential python nodejs
      reboot
      > ioBroker installieren
      sudo mkdir /opt/iobroker
      sudo chmod 777 /opt/iobroker
      cd /opt/iobroker
      sudo npm install iobroker --unsafe-perm
      Gruß,
      Eric
        skorpil
        Erstmal, Danke.
        node -v
        npm -v
        Das:
        root@raspberrypi-3:~# node -v v4.7.2
        root@raspberrypi-3:~# npm -v 2.15.11
        Ja, exakt!
        apt-get autoremove
        reboot
        Ja
        reboot
        Ja
        cd /opt/iobroker
        Genau hier````
        Bernd
        • BluefoxB Offline
          BluefoxB Offline
          Schreib mal per hand "npm i iobroker –unsafe-perm"
          npm denkt, dass dein Verzeichnis '/opt/iobroker/iobroker –unsafe-perm' heißt.
          Warum auch immer.
            skorpil
            Hallo bluefox,
            Kann ich erst gleich testen. Bin nicht zu hause. Aber wo ist der Unterschied zwischen
            und
            npm i iobroker --unsafe-perm
            Sicher soll ich doch auch sudo und install anfügen. Oder?
            Bin nicht der Linux Crack. Daher bitte noch einmal Hilfe.
            Liebe Grüße
            Bernd
            • BluefoxB Offline
              BluefoxB Offline
              @skorpil:
              Hallo bluefox,
              und
              Liebe Grüße
              Bernd `
              Es gibt kein Unterschied. Ich vermute, dass du beim Kopieren vom Kommando irgendein Zeichen mitkopierst, was falsch interpretiert wird.
                skorpil
                Das war es! Vielen Dank. Die manuelle Eingabe hat funktioniert. Auf der Website scheint es irgendein unsichtbares Zeichen zu geben, das den Fehler verursacht! Ich hatte ganz brav copy and paste gemacht. Und es kam zu dem Fehler.
                  @skorpil:
                  Auf der Website scheint es irgendein unsichtbares Zeichen zu geben, das den Fehler verursacht! `
                  WO?
                  Rainer
                    skorpil
                    Ich vermute,in diesem Ausdruck
                    Denn da ist die Installation abgebrochen. Bluefox hatte den richtigen Verdacht.
                      @skorpil:
                      Ich vermute,in diesem Ausdruck `
                      Klar doch :)
                      Aber wo muss ich die Website korrigieren?
                      Rainer
                        skorpil
                        Schau mal: im ersten Post hatte ich die in Rede stehende Website gepostet. Hilft das?
                          Danke, seh ich mir an!
                          • G Offline
                            galferiz
                            Moin nochmal.
                            wo liegt jetzt hier die Lösung?
                            Hab das selbe Problem:
                            Er schreibt:
                            root@raspberrypi:/opt/iobroker# npm i iobroker –unsafe-perm
                            -bash: npm: command not found
                            Ist alles per Hand eingegben?!
                            Danke und Gruß
                            PS: install geht auch nicht
                            Nach Weihnachten ist vor Weihnachten
                              skorpil
                              Galferiz, schreib mal genau das, was ich in Post 9 geschrieben habe. Ganz genau. Und: schreiben, nicht kopieren. Dann geht es!
                                skorpil
                                Also: das hier "sudo npm install iobroker –unsafe-perm"
                                • G Offline
                                  galferiz
                                  root@raspberrypi:/opt/iobroker# sudo npm install iobroker –unsafe-perm
                                  sudo: npm: command not found
                                  emm - nope ;-)
                                  läuft nicht
                                    skorpil
                                    Du hast auch insatll geschrieben. Und nicht install. Versuch nochmal.
                                    • G Offline
                                      galferiz
                                      alles probiert - 3. versuch,
                                      immer der selbe Fehler
                                        @galferiz:
                                        sudo: npm: command not found `
                                        Hast du denn nodejs incl. npm installiert?
                                        was sagt
                                        nodejs -v
                                        node -v
                                        npm -v
                                        Rainer
                                        • G Offline
                                          galferiz
                                          root@raspberrypi:/opt/iobroker# nodejs -v
                                          v0.10.29
                                          root@raspberrypi:/opt/iobroker# node -v
                                          -bash: node: command not found
                                          root@raspberrypi:/opt/iobroker# npm -v
                                          node - v hat er schon nicht bei der installation genommen
                                          82.8k
