    2. hoschiman0
    H
    • Topics 15
    • Posts 43
    hoschiman0
    @hoschiman0
    34
    43
    hoschiman0 Follow
    Best posts made by hoschiman0
    • Fehler nach Update iobroker
      Moin,
      Ich habe heute mein iobroker ( Admin )ein update verpasst.
      Nun bekomme ich den nicht mehr zum laufen und folgende Meldung.
      internal/modules/cjs/loader.js:905
      throw err;
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
      at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
      Kann mir jemand helfen wo der Fehler liegt?
      Vielen Dank
      H
      hoschiman0
    Latest posts made by hoschiman0
    • RE: Fehler nach Update iobroker
      @crunchip das sind die Meldungen
      pi@iobroker-pi:~ $ cd /opt/iobroker
      pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      node lib/preinstallCheck.js
      NPM version: 6.14.16
      iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
      node iobroker.js setup first
      No connection to databases possible ...
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
      npm ERR! code ELIFECYCLE
      npm ERR! errno 22
      npm ERR! iobroker.js-controller@4.0.21 install: node iobroker.js setup first
      npm ERR! Exit status 22
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! /home/iobroker/.npm/_logs/2022-05-01T20_04_42_209Z-debug.log
      pi@iobroker-pi:/opt/iobroker $ iobroker stop
      pi@iobroker-pi:/opt/iobroker $ iobroker fix
      library: loaded
      Library version=2022-02-10
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      pi@iobroker-pi:/opt/iobroker $ iobroker start
      pi@iobroker-pi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      pi@iobroker-pi:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.0
      v14.19.0
      6.14.16
      pi
      /opt/iobroker
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
      Reading package lists... Done
      Building dependency tree
      All packages are up to date.
      nodejs:
      Installed: 14.19.0-deb-1nodesource1
      Candidate: 14.19.0-deb-1nodesource1
      Version table:
      *** 14.19.0-deb-1nodesource1 100
      100 /var/lib/dpkg/status
      10.24.1-1nodesource1 500
      500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
      10.24.0~dfsg-1~deb10u1 500
      pi@iobroker-pi:/opt/iobroker $ reboot
      H
      hoschiman0
      Moin,
      throw err;
      requireStack: []
      Vielen Dank
      H
      hoschiman0
    • RE: error: datapoint "ham.0.Window" not found
      @hoschiman0 Vielen Dank für eure Hilfe bis da hin. Melde mich morgen mal ob das mit dem Zigbee Adapter klappt.
      H
      hoschiman0
      Der ist das.
      Den Zigbee versuche ich mal. Den Sonoff habe ich verwechselt sorry
      H
      hoschiman0
      @bahnuhr ne da müssen die Geräte geflasht werden. Den habe ich aber auch. Der ist aber immer gelb mit dem Dreieck.2EF9C026-58F1-4EE9-B780-7E83FE3B132D.jpeg
      H
      hoschiman0
      @bahnuhr der ist für Zigbee Geräte ohne sie mit Thosmata oder wie das heisst Flaschen zu müssen.
      H
      hoschiman0
      @homoran kann man die / in der ID ändern. Wenn ich auf den Stift rechts klicke öffnet sich ja ein Fenster wo das Objekt bearbeiten kann. Oder darf das nicht?
      Nicht wundern das ich sowas frage aber bin völlig Ahnungslos 😧 😊22B35697-8F8B-4316-84BE-BE44ADE87151.jpeg
      H
      hoschiman0
      @homoran und was stattdessen?
      Der Punkt ging ja auch nicht
      H
      hoschiman0
      @bahnuhr aber das gibt er mir doch vor wenn ich die ID kopiere (wenn ich auf das kopier Zeichen drücke und dann einfüge)
      H
      hoschiman0
      @homoran das hat er ja geändert, weil @SBorg dachte das sei ein Trenner
      und so wird es wahrscheinlich auch interpretiert.
      Genau
      H
      hoschiman0
