  4. Bitte um Test js-controller 0.13.0
56 Beiträge 15 Kommentatoren 9.3k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    Muss einfach funktionieren.
    # 0.13.0 (2016-10-21)
    * (bluefox) fix letsencrypt to use fullchain.pem
    * (bluefox) fix error with emitter
    * (bluefox) fix formatDate for russian month
    * (bluefox) backup letsencrypt files too
    * (bluefox) install missing adapters one after other and not parallel.
    * (bluefox) let remove UUID to prepare images with ioBroker
    * (bluefox) using peerDependencies
    * (bluefox) rename host automatically if singlehost
    * (bluefox) add write/read properties to alive variable
    * (bluefox) fix creation of package.json for npm 3
    * (bluefox) try catch for parse of states
    * (appolon77) add possibility to send messages with json
    * (bluefox) updates some packages
    * (bluefox) print node.js version at start
    * (bluefox) force logger to use local time
    * (appolon77) fix multi instance messaging
    * (bluefox) update artnet
    * (bluefox) add vis-canvas-gauges
    * (bluefox) add rflink
    * (bluefox) add foobar2000
    * (bluefox) add mqtt client
    * (bluefox) add lgtv
    * (bluefox) add pushsafer
    • rantanplanR Offline
      rantanplanR Offline
      rantanplan
      Habe mal das update durchgeführt, obwohl nichts dabei war mich interessierte.
      Angezeigt wird jetzt die 3.1.0.
      Diese Meldungen habe ich bekommen.
      ! host-xyz 2016-10-22 02:22:50.493 info Update repository "online" under "https://raw.githubusercontent.com/ioBro … -dist.json"
      ! iobroker 2016-10-22 02:22:49.915 info exit 0
      ! iobroker 2016-10-22 02:20:33.851 info ursa@0.9.4
      ! iobroker 2016-10-22 02:20:33.851 info optional dep failed, continuing
      ! iobroker 2016-10-22 02:20:33.851 info WARN
      ! iobroker 2016-10-22 02:20:33.836 info npm
      ! iobroker 2016-10-22 02:20:33.648 info
      ! iobroker 2016-10-22 02:20:33.648 info not ok
      ! iobroker 2016-10-22 02:20:33.648 info ERR!
      ! iobroker 2016-10-22 02:20:33.632 info gyp
      ! iobroker 2016-10-22 02:20:33.632 info v3.0.3
      ! iobroker 2016-10-22 02:20:33.632 info node-gyp -v
      ! iobroker 2016-10-22 02:20:33.632 info ERR!
      ! iobroker 2016-10-22 02:20:33.617 info v4.3.1
      ! iobroker 2016-10-22 02:20:33.617 info node -v
      ! iobroker 2016-10-22 02:20:33.617 info ERR!
      ! iobroker 2016-10-22 02:20:33.617 info gyp
      ! iobroker 2016-10-22 02:20:33.617 info C:\ioBroker\node_modules\iobroker.js-controller\node_modules\letsencrypt\node_modules\rsa-compat\node_modules\ursa
      ! iobroker 2016-10-22 02:20:33.601 info cwd
      ! iobroker 2016-10-22 02:20:33.601 info ERR!
      ! iobroker 2016-10-22 02:20:33.601 info gyp
      ! iobroker 2016-10-22 02:20:33.601 info "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
      ! iobroker 2016-10-22 02:20:33.586 info command
      ! iobroker 2016-10-22 02:20:33.586 info ERR!
      ! iobroker 2016-10-22 02:20:33.586 info gyp
      ! iobroker 2016-10-22 02:20:33.586 info Windows_NT 10.0.14393
      ! iobroker 2016-10-22 02:20:33.570 info System
      ! iobroker 2016-10-22 02:20:33.570 info ERR!
      ! iobroker 2016-10-22 02:20:33.570 info gyp
      ! iobroker 2016-10-22 02:20:33.570 info at FSReqWrap.oncomplete (fs.js:82:15)
      ! iobroker 2016-10-22 02:20:33.554 info stack
      ! iobroker 2016-10-22 02:20:33.539 info ERR!
      ! iobroker 2016-10-22 02:20:33.539 info gyp
      ! iobroker 2016-10-22 02:20:33.523 info at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:71:11
      ! iobroker 2016-10-22 02:20:33.523 info stack
      ! iobroker 2016-10-22 02:20:33.523 info ERR!
      ! iobroker 2016-10-22 02:20:33.523 info gyp
      ! iobroker 2016-10-22 02:20:33.523 info at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:116:14)
      ! iobroker 2016-10-22 02:20:33.508 info stack
      ! iobroker 2016-10-22 02:20:33.508 info ERR!
      ! iobroker 2016-10-22 02:20:33.492 info gyp
      ! iobroker 2016-10-22 02:20:33.476 info Error: Can't find Python executable "python", you can set the PYTHON env variable.
      ! iobroker 2016-10-22 02:20:33.476 info stack
      ! iobroker 2016-10-22 02:20:33.476 info ERR!
      ! iobroker 2016-10-22 02:20:33.476 info gyp
      ! iobroker 2016-10-22 02:20:33.461 info configure error
      ! iobroker 2016-10-22 02:20:33.461 info ERR!
      ! iobroker 2016-10-22 02:20:33.382 info gyp
      ! iobroker 2016-10-22 02:19:04.554 info in npm 3+. Your application will need to depend on it explicitly.
      ! iobroker 2016-10-22 02:19:04.554 info peerDependencies
      ! iobroker 2016-10-22 02:19:04.554 info WARN
      ! iobroker 2016-10-22 02:19:04.554 info npm
      ! iobroker 2016-10-22 02:19:04.554 info longer be automatically installed to fulfill the peerDependency
      ! iobroker 2016-10-22 02:19:04.539 info
      ! iobroker 2016-10-22 02:19:04.539 info WARN
      ! iobroker 2016-10-22 02:19:04.539 info npm
      ! iobroker 2016-10-22 02:19:04.539 info The peer dependency socket.io@^1.5.0 included from iobroker.js-controller will no
      ! iobroker 2016-10-22 02:19:04.539 info peerDependencies
      ! iobroker 2016-10-22 02:19:04.523 info in npm 3+. Your application will need to depend on it explicitly.
      ! iobroker 2016-10-22 02:19:04.523 info peerDependencies
      ! iobroker 2016-10-22 02:19:04.523 info WARN
      ! iobroker 2016-10-22 02:19:04.523 info npm
      ! iobroker 2016-10-22 02:19:04.507 info longer be automatically installed to fulfill the peerDependency
      ! iobroker 2016-10-22 02:19:04.507 info peerDependencies
      ! iobroker 2016-10-22 02:19:04.507 info WARN
      ! iobroker 2016-10-22 02:19:04.507 info npm
      ! iobroker 2016-10-22 02:19:04.507 info The peer dependency request@^2.75.0 included from iobroker.js-controller will no
      ! iobroker 2016-10-22 02:19:04.492 info WARN
      ! iobroker 2016-10-22 02:19:04.492 info npm
      ! iobroker 2016-10-22 02:18:16.899 info npm install https://github.com/ioBroker/ioBroker.js ... all/master --production --prefix "C:/ioBroker" (System call)
      ! iobroker 2016-10-22 02:18:16.618 info install https://github.com/ioBroker/ioBroker.js ... all/master
      ! iobroker 2016-10-22 02:18:14.055 info url "https://github.com/ioBroker/ioBroker.js ... all/master" js-controller
      Setze sicherheitshalber meine VM wieder zurück.
      Grüße
      Rantanplan
      • BluefoxB Offline
        BluefoxB Offline
        @rantanplan:
        Grüße `
        Ist nicht schlimm. Da wird versucht letsencrypt zu übersetzen. Aber es ist optional.
        • H Offline
          Heinzelmaennchen
          Hi BF,
          ich habe gestern früh den neuen Controller installiert. Es gab einen Abbruch / Fehler mit dem Hinweis auf eine falsche (zu alte Version) von socket.io.
          Nach kurzem googlen habe ich dann auf der Ebene /opt/ioBroker "npm install socket.io" ausgeführt. Es wurde die neueste Version 1.4.5 fehlerfrei installiert. Danach nochmal das Update des js-controllers angestossen. Seitdem läuft alles reibungslos.
          Perfekt.
          Bernhard
          263 Kanäle in 91 Geräten
          3x Sonos Play:1, 1x Sonos:Amp, 1x Sonos Playbar
          4x Hue E27, 21xHue GU10, 1x Lightify RGB Stripe, 1x Lightify E27 TW
            RS_Tobi
            hi,
            habe aus git den js-contoller installiert.
            System:
            RPi 2 mit jessie lite und IOBROKER
            diverse Adapter ALLES AUF AKTUELLEN stand laut Admin.
            node & nodejs 4.5.0
            direkt danach reboot und iobroker tot.
            beim versuch
            root@raspberrypi:/opt/iobroker# iobroker start
            module.js:327
                throw err;
            Error: Cannot find module 'is-arrayish'
                at Function.Module._resolveFilename (module.js:325:15)
                at Function.Module._load (module.js:276:25)
                at Module.require (module.js:353:17)
                at require (internal/module.js:12:17)
                at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/node_modules/read-pkg-up/node_modules/read-pkg/node_modules/load-json-file/node_modules/parse-json/node_modules/error-ex/index.js:4:18)
                at Module._compile (module.js:409:26)
                at Object.Module._extensions..js (module.js:416:10)
                at Module.load (module.js:343:32)
                at Function.Module._load (module.js:300:12)
                at Module.require (module.js:353:17)</anonymous>
            werde jetzt wieder letzten Stand "darüber bügeln" oder brauchst du noch infos?
            grüße Tobi
            • BluefoxB Offline
              BluefoxB Offline
              Hm… Kann mir den Fehler nicht erklären, aber es gefällt mir nicht, was ich da sehe.
              Hast du Broker gestoppt? Wie war update Befehl?
                RS_Tobi
                es war "on the run" installiert.
                also über git-Button aus dem Admin im laufenden system heraus installiert.
                war das falsch?
                soll ich was anderes nochmal testen?
                tobi
                  rantanplanR Offline
                  rantanplan
                  Hallo Bluefox
                  Hier den, aus dem anderen Thread, gewünschte Protokollauszug.
                  ! 2016-10-25 08:48:01.783 - [32minfo[39m: iobroker url "https://github.com/ioBroker/ioBroker.js … all/master" js-controller
                  ! 2016-10-25 08:48:02.892 - [32minfo[39m: iobroker install https://github.com/ioBroker/ioBroker.js ... all/master
                  ! 2016-10-25 08:48:03.111 - [32minfo[39m: iobroker npm install https://github.com/ioBroker/ioBroker.js ... all/master --production --prefix "C:/ioBroker" (System call)
                  ! 2016-10-25 08:48:37.908 - [32minfo[39m: iobroker npm
                  ! 2016-10-25 08:48:37.908 - [32minfo[39m: iobroker WARN
                  ! 2016-10-25 08:48:37.908 - [32minfo[39m: iobroker peerDependencies
                  ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker The peer dependency request@^2.75.0 included from iobroker.js-controller will no
                  ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker npm
                  ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker WARN
                  ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker peerDependencies
                  ! 2016-10-25 08:48:37.923 - [32minfo[39m: iobroker longer be automatically installed to fulfill the peerDependency
                  ! 2016-10-25 08:48:37.939 - [32minfo[39m: iobroker npm
                  ! 2016-10-25 08:48:37.939 - [32minfo[39m: iobroker WARN
                  ! 2016-10-25 08:48:37.939 - [32minfo[39m: iobroker peerDependencies
                  ! 2016-10-25 08:48:37.939 - [32minfo[39m: iobroker in npm 3+. Your application will need to depend on it explicitly.
                  ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker
                  ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker WARN
                  ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker peerDependencies
                  ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker The peer dependency socket.io@^1.5.0 included from iobroker.js-controller will no
                  ! 2016-10-25 08:48:37.955 - [32minfo[39m: iobroker npm
                  ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker longer be automatically installed to fulfill the peerDependency
                  ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker npm
                  ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker WARN
                  ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker peerDependencies
                  ! 2016-10-25 08:48:37.970 - [32minfo[39m: iobroker in npm 3+. Your application will need to depend on it explicitly.
                  ! 2016-10-25 08:49:44.548 - [32minfo[39m: iobroker gyp
                  ! 2016-10-25 08:49:44.564 - [32minfo[39m: iobroker
                  ! 2016-10-25 08:49:44.564 - [32minfo[39m: iobroker ERR!
                  ! 2016-10-25 08:49:44.564 - [32minfo[39m: iobroker configure error
                  ! 2016-10-25 08:49:44.564 - [32minfo[39m: iobroker gyp
                  ! 2016-10-25 08:49:44.580 - [32minfo[39m: iobroker ERR!
                  ! 2016-10-25 08:49:44.580 - [32minfo[39m: iobroker stack
                  ! 2016-10-25 08:49:44.580 - [32minfo[39m: iobroker Error: Can't find Python executable "python", you can set the PYTHON env variable.
                  ! 2016-10-25 08:49:44.580 - [32minfo[39m: iobroker gyp
                  ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker stack
                  ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:116:14)
                  ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker gyp
                  ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker ERR!
                  ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:71:11
                  ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker at FSReqWrap.oncomplete (fs.js:82:15)
                  ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker System
                  ! 2016-10-25 08:49:44.611 - [32minfo[39m: iobroker Windows_NT 10.0.14393
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker gyp
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker ERR!
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker command
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker cwd
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker C:\ioBroker\node_modules\iobroker.js-controller\node_modules\letsencrypt\node_modules\rsa-compat\node_modules\ursa
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker node -v
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker v4.3.1
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker node-gyp -v
                  ! 2016-10-25 08:49:44.627 - [32minfo[39m: iobroker v3.0.3
                  ! 2016-10-25 08:49:44.642 - [32minfo[39m: iobroker
                  ! 2016-10-25 08:49:44.642 - [32minfo[39m: iobroker ERR!
                  ! 2016-10-25 08:49:44.642 - [32minfo[39m: iobroker not ok
                  ! 2016-10-25 08:49:44.798 - [32minfo[39m: iobroker npm
                  ! 2016-10-25 08:49:44.814 - [32minfo[39m: iobroker
                  ! 2016-10-25 08:49:44.814 - [32minfo[39m: iobroker WARN
                  ! 2016-10-25 08:49:44.814 - [32minfo[39m: iobroker optional dep failed, continuing
                  ! 2016-10-25 08:49:44.814 - [32minfo[39m: iobroker ursa@0.9.4
                  ! 2016-10-25 08:51:43.128 - [32minfo[39m: iobroker exit 0
                  ! 2016-10-25 08:51:43.393 - [32minfo[39m: host.host-pc-xyz Update repository "online" under "https://raw.githubusercontent.com/ioBro ... -dist.json"
                  ! 2016-10-25 08:58:52.921 - [31merror[39m: host.host-pc-xyz instance system.adapter.admin.0 terminated with code 4294967295 ()
                  ! 2016-10-25 08:58:52.921 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.admin.0 because enabled
                  ! 2016-10-25 08:58:53.077 - [31merror[39m: host.host-pc-xyz instance system.adapter.hm-rpc.0 terminated with code 4294967295 ()
                  ! 2016-10-25 08:58:53.077 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.hm-rpc.0 because enabled
                  ! 2016-10-25 08:58:53.249 - [31merror[39m: host.host-pc-xyz instance system.adapter.hm-rega.0 terminated with code 4294967295 ()
                  ! 2016-10-25 08:58:53.249 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.hm-rega.0 because enabled
                  ! 2016-10-25 08:58:53.405 - [31merror[39m: host.host-pc-xyz instance system.adapter.web.0 terminated with code 4294967295 ()
                  ! 2016-10-25 08:58:53.405 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.web.0 because enabled
                  ! 2016-10-25 08:58:53.561 - [31merror[39m: host.host-pc-xyz instance system.adapter.javascript.0 terminated with code 4294967295 ()
                  ! 2016-10-25 08:58:53.561 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.javascript.0 because enabled
                  ! 2016-10-25 08:58:53.702 - [31merror[39m: host.host-pc-xyz instance system.adapter.pushover.0 terminated with code 4294967295 ()
                  ! 2016-10-25 08:58:53.702 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.pushover.0 because enabled
                  ! 2016-10-25 08:58:53.874 - [31merror[39m: host.host-pc-xyz instance system.adapter.javascript.1 terminated with code 4294967295 ()
                  ! 2016-10-25 08:58:53.874 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.javascript.1 because enabled
                  ! 2016-10-25 08:58:54.014 - [31merror[39m: host.host-pc-xyz instance system.adapter.scenes.0 terminated with code 4294967295 ()
                  ! 2016-10-25 08:58:54.014 - [32minfo[39m: host.host-pc-xyz Restart adapter system.adapter.scenes.0 because enabled
                  ! 2016-10-25 08:58:57.983 - [32minfo[39m: host.host-pc-xyz iobroker.js-controller version 0.13.0 js-controller starting
                  ! 2016-10-25 08:58:57.983 - [32minfo[39m: host.host-pc-xyz Copyright (c) 2014-2016 bluefox, hobbyquaker
                  ! 2016-10-25 08:58:57.983 - [32minfo[39m: host.host-pc-xyz hostname: host-pc-xyz, node: v4.3.1
                  ! 2016-10-25 08:58:57.983 - [32minfo[39m: host.host-pc-xyz ip addresses: xxx.xxx.xxx.xxx
                  ! 2016-10-25 08:58:58.123 - [32minfo[39m: inMem-states listening on port 9000
                  ! 2016-10-25 08:58:58.264 - [32minfo[39m: inMem-objects listening on port 9001
                  ! 2016-10-25 08:58:58.264 - [32minfo[39m: host.host-pc-xyz InMemoryDB connected
                  ! 2016-10-25 08:58:58.279 - [32minfo[39m: host.host-pc-xyz 32 instances found
                  ! 2016-10-25 08:58:58.295 - [32minfo[39m: host.host-pc-xyz starting 21 instances
                  ! 2016-10-25 08:58:58.326 - [32minfo[39m: host.host-pc-xyz instance system.adapter.admin.0 started with pid 7892
                  ! 2016-10-25 08:59:02.295 - [32minfo[39m: host.host-pc-xyz instance system.adapter.hm-rpc.0 started with pid 8232
                  ! 2016-10-25 08:59:02.279 - [32minfo[39m: admin.0 starting. Version 1.6.4 in C:/ioBroker/node_modules/iobroker.admin, node: v4.3.1
                  ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 requesting all states
                  ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 requesting all objects
                  ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 Request actual repository...
                  ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 http server listening on port 8081
                  ! 2016-10-25 08:59:02.310 - [32minfo[39m: admin.0 Use link "http://localhost:8081" to configure.
                  ! 2016-10-25 08:59:04.060 - [32minfo[39m: admin.0 received all states
                  ! 2016-10-25 08:59:04.638 - [32minfo[39m: admin.0 received all objects
                  ! 2016-10-25 08:59:04.826 - [32minfo[39m: host.host-pc-xyz Update repository "online" under "https://raw.githubusercontent.com/ioBro ... -dist.json"
                  ! 2016-10-25 08:59:05.482 - [32minfo[39m: hm-rpc.0 starting. Version 1.3.3 in C:/ioBroker/node_modules/iobroker.hm-rpc, node: v4.3.1
                  ! 2016-10-25 08:59:05.889 - [32minfo[39m: hm-rpc.0 binrpc server is trying to listen on xxx.xxx.xxx.xxx:2001
                  ! 2016-10-25 08:59:05.904 - [32minfo[39m: hm-rpc.0 binrpc client is trying to connect to xxx.xxx.xxx.xxx:2001 with ["xmlrpc_bin://xxx.xxx.xxx.xxx:2001","hm-rpc.0"]
                  ! 2016-10-25 08:59:06.686 - [32minfo[39m: host.host-pc-xyz instance system.adapter.hm-rega.0 started with pid 5212
                  ! 2016-10-25 08:59:09.170 - [32minfo[39m: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
                  ! 2016-10-25 08:59:09.186 - [32minfo[39m: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
                  ! 2016-10-25 08:59:09.264 - [32minfo[39m: hm-rpc.0 binrpc -> 348 devices
                  ! 2016-10-25 08:59:10.248 - [32minfo[39m: hm-rpc.0 Connected
                  ! 2016-10-25 08:59:10.295 - [32minfo[39m: host.host-pc-xyz instance system.adapter.web.0 started with pid 1656
                  ! 2016-10-25 08:59:09.014 - [32minfo[39m: hm-rega.0 starting. Version 1.3.0 in C:/ioBroker/node_modules/iobroker.hm-rega, node: v4.3.1
                  ! 2016-10-25 08:59:09.014 - [32minfo[39m: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                  ! 2016-10-25 08:59:12.654 - [32minfo[39m: hm-rega.0 ReGaHSS xxx.xxx.xxx.xxx up
                  ! 2016-10-25 08:59:12.685 - [32minfo[39m: hm-rega.0 time difference local-ccu -39s
                  ! 2016-10-25 08:59:12.779 - [32minfo[39m: hm-rega.0 added/updated 2 favorites to enum.favorites
                  ! 2016-10-25 08:59:13.045 - [32minfo[39m: hm-rega.0 added/updated functions to enum.functions
                  ! 2016-10-25 08:59:13.951 - [32minfo[39m: hm-rega.0 added/updated rooms to enum.rooms
                  ! 2016-10-25 08:59:14.670 - [32minfo[39m: hm-rega.0 got 26 programs
                  ! 2016-10-25 08:59:14.764 - [32minfo[39m: hm-rega.0 added/updated 26 programs
                  ! 2016-10-25 08:59:14.764 - [32minfo[39m: hm-rega.0 deleted 0 programs
                  ! 2016-10-25 08:59:15.295 - [32minfo[39m: hm-rega.0 got 113 variables
                  ! 2016-10-25 08:59:15.935 - [32minfo[39m: hm-rega.0 added/updated 113 variables
                  ! 2016-10-25 08:59:15.935 - [32minfo[39m: hm-rega.0 deleted 0 variables
                  ! 2016-10-25 08:59:15.935 - [32minfo[39m: hm-rega.0 request state values
                  ! 2016-10-25 08:59:13.732 - [32minfo[39m: web.0 starting. Version 1.7.2 in C:/ioBroker/node_modules/iobroker.web, node: v4.3.1
                  ! 2016-10-25 08:59:16.747 - [32minfo[39m: web.0 socket.io server listening on port 8082
                  ! 2016-10-25 08:59:16.747 - [32minfo[39m: web.0 http server listening on port 8082
                  ! 2016-10-25 08:59:22.310 - [32minfo[39m: hm-rega.0 got state values
                  ! 2016-10-25 08:59:17.513 - [32minfo[39m: vis.0 starting. Version 0.10.14 in C:/ioBroker/node_modules/iobroker.vis, node: v4.3.1
                  ! 2016-10-25 08:59:28.545 - [32minfo[39m: host.host-pc-xyz instance system.adapter.vis.0 terminated while should be started once
                  ! 2016-10-25 08:59:42.311 - [32minfo[39m: host.host-pc-xyz instance system.adapter.javascript.0 started with pid 3680
                  ! 2016-10-25 08:59:46.420 - [32minfo[39m: javascript.0 starting. Version 3.1.0 in C:/ioBroker/node_modules/iobroker.javascript, node: v4.3.1
                  ! 2016-10-25 08:59:46.436 - [32minfo[39m: javascript.0 requesting all states
                  ! 2016-10-25 08:59:46.514 - [32minfo[39m: javascript.0 requesting all objects
                  ! 2016-10-25 08:59:47.170 - [32minfo[39m: javascript.0 received all states
                  ! 2016-10-25 08:59:47.873 - [32minfo[39m: javascript.0 received all objects[/spoiler]
                  Grüße
                  Rantanplan
                  • BluefoxB Offline
                    BluefoxB Offline
                    @RS_Tobi:
                    war das falsch?
                    tobi `
                    Leider geht js-controller on the run nicht.
                    Man muss immer js-controller erst stoppen.
                    Aber gute Punkt. Werde ich aus admin rausnehmen.
                      @Bluefox:
                      Aber gute Punkt. Werde ich aus admin rausnehmen. `
                      Hinweis:
                      Js-Controller ist auch bei github update in Admin mit drin!
                        RS_Tobi
                        Back….
                        so habe es nochmal "manuell" installiert.
                        hier der log
                        ! root@raspberrypi:/opt/iobroker# cd /opt/iobroker
                        ! root@raspberrypi:/opt/iobroker# iobroker stop
                        ! Stopping iobroker controller daemon…
                        ! iobroker controller daemon stopped.
                        ! Exit code for "killall.sh": 0
                        ! root@raspberrypi:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker .js-controller/tarball/master --production
                        ! npm WARN peerDependencies The peer dependency request@^2.75.0 included from iobr oker.js-controller will no
                        ! npm WARN peerDependencies longer be automatically installed to fulfill the peerD ependency
                        ! npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly.
                        ! npm WARN peerDependencies The peer dependency socket.io@^1.5.0 included from iob roker.js-controller will no
                        ! > ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
                        ! > node-gyp rebuild
                        ! make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
                        ! CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
                        ! SOLINK_MODULE(target) Release/obj.target/ursaNative.node
                        ! COPY Release/ursaNative.node
                        ! make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
                        ! > iobroker.js-controller@0.13.0 install /opt/iobroker/node_modules/iobroker.js-controller
                        ! > node lib/setup.js setup first
                        ! socket.io@1.5.1 node_modules/socket.io
                        ! ├── has-binary@0.1.7 (isarray@0.0.1)
                        ! ├── socket.io-parser@2.3.1 (isarray@0.0.1, json3@3.3.2, component-emitter@1.1.2)
                        ! ├── debug@2.2.0 (ms@0.7.1)
                        ! ├── socket.io-adapter@0.4.0 (socket.io-parser@2.2.2)
                        ! ├── engine.io@1.7.2 (base64id@0.1.0, ws@1.1.1, engine.io-parser@1.3.1, accepts@1.3.3)
                        ! └── socket.io-client@1.5.1 (to-array@0.1.4, component-emitter@1.2.0, indexof@0.0.1, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, parseuri@0.0.4, engine.io-client@1.7.2)
                        ! request@2.76.0 node_modules/request
                        ! ├── aws-sign2@0.6.0
                        ! ├── tunnel-agent@0.4.3
                        ! ├── forever-agent@0.6.1
                        ! ├── oauth-sign@0.8.2
                        ! ├── is-typedarray@1.0.0
                        ! ├── caseless@0.11.0
                        ! ├── stringstream@0.0.5
                        ! ├── aws4@1.5.0
                        ! ├── isstream@0.1.2
                        ! ├── json-stringify-safe@5.0.1
                        ! ├── extend@3.0.0
                        ! ├── tough-cookie@2.3.1
                        ! ├── node-uuid@1.4.7
                        ! ├── qs@6.3.0
                        ! ├── combined-stream@1.0.5 (delayed-stream@1.0.0)
                        ! ├── mime-types@2.1.12 (mime-db@1.24.0)
                        ! ├── form-data@2.1.1 (asynckit@0.4.0)
                        ! ├── hawk@3.1.3 (cryptiles@2.0.5, hoek@2.16.3, sntp@1.0.9, boom@2.10.1)
                        ! ├── http-signature@1.1.1 (assert-plus@0.2.0, jsprim@1.3.1, sshpk@1.10.1)
                        ! └── har-validator@2.0.6 (pinkie-promise@2.0.1, commander@2.9.0, chalk@1.1.3, is-my-json-valid@2.15.0)
                        ! iobroker.js-controller@0.13.0 node_modules/iobroker.js-controller
                        ! ├── safe-replace@1.0.2
                        ! ├── le-sni-auto@2.1.0
                        ! ├── le-challenge-fs@2.0.8
                        ! ├── pyconf@1.1.2
                        ! ├── winston-daily-rotate-file@1.3.1
                        ! ├── mime@1.3.4
                        ! ├── semver@5.3.0
                        ! ├── daemonize2@0.4.2
                        ! ├── ncp@2.0.0
                        ! ├── node.extend@1.1.6 (is@3.2.0)
                        ! ├── redis@2.6.2 (double-ended-queue@2.1.0-0, redis-parser@2.0.4, redis-commands@1.3.0)
                        ! ├── mkdirp@0.5.1 (minimist@0.0.8)
                        ! ├── bluebird@3.4.6
                        ! ├── node-schedule@1.1.1 (long-timeout@0.0.2, cron-parser@1.1.0)
                        ! ├── winston@2.2.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, async@1.0.0, pkginfo@0.3.1, colors@1.0.3)
                        ! ├── socket.io-client@1.5.1 (to-array@0.1.4, component-emitter@1.2.0, indexof@0.0.1, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, has-binary@0.1.7, socket.io-parser@2.3.1, debug@2.2.0, parseuri@0.0.4, engine.io-client@1.7.2)
                        ! ├── prompt@1.0.0 (revalidator@0.1.8, pkginfo@0.4.0, colors@1.1.2, read@1.0.7, winston@2.1.1, utile@0.3.0)
                        ! ├── yargs@6.3.0 (get-caller-file@1.0.2, decamelize@1.2.0, y18n@3.2.1, camelcase@3.0.0, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, yargs-parser@4.0.2, require-main-filename@1.0.1, require-directory@2.1.1, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.2, read-pkg-up@1.0.1)
                        ! ├── letsencrypt@2.1.8 (le-store-certbot@2.0.3, homedir@0.6.0, asn1js@1.2.12, localhost.daplie.com-certificates@1.2.3, certpem@1.0.1, pkijs@1.3.27, le-acme-core@2.0.7, le-challenge-sni@2.0.1, rsa-compat@1.2.7)
                        ! ├── tar.gz@1.0.5 (commander@2.9.0, tar@2.2.1, bluebird@2.11.0, fstream@1.0.10, mout@0.11.1)
                        ! ├── jszip@3.1.3 (es6-promise@3.0.2, lie@3.1.0, pako@1.0.3, readable-stream@2.0.6, core-js@2.3.0)
                        ! └── npm@2.15.11
                        ! root@raspberrypi:/opt/iobroker# iobroker start
                        ! Starting iobroker controller daemon...
                        ! iobroker controller daemon started. PID: 9386
                        hat bis jetzt auf den ersten Blick recht gut funktioniert.
                        grüße
                        • BluefoxB Offline
                          BluefoxB Offline
                          Bitte 0.13.1 testen. Ich will die Version releasen.
                          • Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            ich hab das jetzt mehrfach versucht auf meinem test host. Aber ich bekomme beim versuch den js-controller zu installieren immer eine Fehlermeldung.
                            root@iobroker-test:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
                            node-gyp rebuild
                            ! gyp ERR! configure error
                            gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
                            gyp ERR! stack at failNoPython (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:449:14)
                            gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:353:11
                            gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:16)
                            gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                            gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                            gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                            gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                            gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
                            gyp ERR! System Linux 4.4.0-45-generic
                            gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                            gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
                            gyp ERR! node -v v4.6.1
                            gyp ERR! node-gyp -v v3.4.0
                            gyp ERR! not ok
                            npm WARN optional dep failed, continuing ursa@0.9.4
                            ! > iobroker.js-controller@0.13.1 install /opt/iobroker/node_modules/iobroker.js-controller
                            ! fs.js:549
                            return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
                            ! Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
                            at Error (native)
                            at Object.fs.openSync (fs.js:549:18)
                            at Object.fs.writeFileSync (fs.js:1156:15)
                            at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:88:24)
                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:552:23
                            at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:573:11)
                            npm ERR! Linux 4.4.0-45-generic
                            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.js-controller/tarball/master" "--production"
                            npm ERR! node v4.6.1
                            npm ERR! npm v2.15.9
                            npm ERR! code ELIFECYCLE
                            ! npm ERR! iobroker.js-controller@0.13.1 install: node lib/setup.js setup first
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the iobroker.js-controller@0.13.1 install script 'node lib/setup.js setup first'.
                            npm ERR! This is most likely a problem with the iobroker.js-controller package,
                            npm ERR! not with npm itself.
                            npm ERR! Tell the author that this fails on your system:
                            npm ERR! node lib/setup.js setup first
                            npm ERR! You can get information on how to open an issue for this project with:
                            npm ERR! npm bugs iobroker.js-controller
                            npm ERR! Or if that isn't available, you can get their info via:
                            npm ERR!
                            npm ERR! npm owner ls iobroker.js-controller
                            npm ERR! There is likely additional logging output above.
                            ! npm ERR! Please include the following file with any support request:
                            npm ERR! /opt/iobroker/npm-debug.log</anonymous>
                            Versuche ich die version 0.12.2 zu installieren bekomme ich die gleich Fehlermeldung. Es scheint also ein Problem mit dem test host zu geben. Ich versteh nur nicht warum die Installation direkt davor Reibunglos läuft.
                            Persönlicher Support
                            Spenden -> paypal.me/J3YC33
                            • BluefoxB Offline
                              BluefoxB Offline
                              Kannst du bitte folgendes machen.
                              cd /opt/iobroker
                              sudo iobroker stop
                              sudo chmod 777 * -R
                              sudo apt-get install build-essential
                              sudo npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
                              sudo chmod 777 * -R
                              sudo iobroker start
                              • Jey CeeJ Online
                                Jey CeeJ Online
                                Jey Cee
                                Danke jetzt hat es funktioniert.
                                Nur eins es muss "sudo apt-get install build-essentials" heissen, nicht "sudo npm install build-essentials".
                                Auf den ersten Blick sieht mal alles gut aus.
                                Ich hab gesehen du hast meinen Adapter in die Hauptliste aufgenommen. Da er aber noch nicht in npm gelistet ist kann er nicht installiert werden.
                                Erledigt: Gibt es irgendwo einen crash-kurs wie man den in npm Veröffentlicht?
                                Edit: Ich hab den Adapter jetzt auf npm veröffentlicht und er lässt sich auch installieren. Aber es wird ein Fehler im Reiter Admin angezeigt. Siehe Bild.
                                  Stmiko
                                  Bekomme die version leider nicht installiert:
                                  ! ` > root@Raspi31:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.js … all/master --production
                                  npm WARN peerDependencies The peer dependency iobroker.admin@>=1.6.4 included from iobroker.js-controller will no
                                  npm WARN peerDependencies longer be automatically installed to fulfill the peerDependency
                                  node-gyp rebuild
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-babel/node_modules/gulp-util requires object-assign@'^3.0.0' but will load
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-babel/node_modules/object-assign,
                                  npm WARN unmet dependency which is version 4.1.0
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-concat/node_modules/gulp-util requires through2@'^2.0.0' but will load
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-concat/node_modules/through2,
                                  npm WARN unmet dependency which is version 0.6.5
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-less/node_modules/accord requires lodash@'4.11.2' but will load
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/lodash,
                                  npm WARN unmet dependency which is version 4.16.5
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-less/node_modules/gulp-util requires object-assign@'^3.0.0' but will load
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-less/node_modules/object-assign,
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-minify-html/node_modules/gulp-util requires through2@'^2.0.0' but will load
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-minify-html/node_modules/through2,
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/chokidar requires glob-parent@'^2.0.0' but will load
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/glob-parent,
                                  npm WARN unmet dependency which is version 3.0.1
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/gulp-util requires object-assign@'^3.0.0' but will load
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/object-assign,
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/gulp-util requires vinyl@'^0.5.0' but will load
                                  npm WARN unmet dependency /opt/iobroker/node_modules/javascript-build-essentials/node_modules/gulp-watch/node_modules/vinyl,
                                  npm WARN unmet dependency which is version 1.2.0
                                  npm ERR! Linux 4.4.27-v7+
                                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.js ... all/master" "--production"
                                  npm ERR! code EPEERINVALID
                                  npm ERR! peerinvalid The package iobroker.admin@0.8.3 does not satisfy its siblings' peerDependencies requirements!
                                  npm ERR! peerinvalid Peer iobroker.js-controller@0.13.1 wants iobroker.admin@>=1.6.4
                                  npm ERR! /opt/iobroker/npm-debug.log `
                                  Admin ist aber version 1.6.5:
                                  ! ` > update done
                                  Adapter "zwave" : 0.2.5
                                  Adapter "yr" : 1.0.5
                                  Adapter "yamaha" : 0.2.1
                                  Adapter "wolf" : 0.1.0
                                  Adapter "web" : 1.7.2 , installed 1.7.2
                                  Adapter "weatherunderground": 1.0.2
                                  Adapter "vis-timeandweather": 1.1.4 , installed 1.1.4
                                  Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
                                  Adapter "vis-plumb" : 0.1.6 , installed 0.1.6
                                  Adapter "vis-metro" : 1.0.4 , installed 1.0.4
                                  Adapter "vis-map" : 0.1.3 , installed 0.1.3
                                  Adapter "vis-lcars" : 1.0.1 , installed 1.0.1
                                  Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2
                                  Adapter "vis-justgage" : 0.6.0 , installed 0.6.0
                                  Adapter "vis-jqui-mfd" : 1.0.5 , installed 1.0.5
                                  Adapter "vis-hqwidgets" : 1.0.6 , installed 1.0.6
                                  Adapter "vis-history" : 0.2.4 , installed 0.2.4
                                  Adapter "vis-google-fonts": 0.1.0 , installed 0.1.0
                                  Adapter "vis-fancyswitch": 1.0.0 , installed 1.0.0
                                  Adapter "vis-colorpicker": 1.1.0 , installed 1.1.0
                                  Adapter "vis-canvas-gauges": 0.1.3
                                  Adapter "vis-bars" : 0.1.2 , installed 0.1.2
                                  Adapter "vis" : 0.10.14 , installed 0.10.14
                                  Adapter "vcard" : 0.0.8
                                  Adapter "upnp" : npm error
                                  Adapter "tvspielfilm" : 0.2.2
                                  Adapter "text2command" : 1.1.3 , installed 1.1.3
                                  Adapter "terminal" : 0.1.2 , installed 0.1.2
                                  Adapter "telegram" : 0.4.4 , installed 0.4.4
                                  Adapter "tankerkoenig" : 1.0.0
                                  Adapter "starline" : 0.1.7
                                  Adapter "sonos" : 0.2.2
                                  Adapter "solarwetter" : 0.1.2
                                  Adapter "socketio" : 1.7.1
                                  Adapter "squeezebox" : 0.1.0
                                  Adapter "sql" : 1.2.1
                                  Adapter "simple-api" : 1.3.0
                                  Adapter "scenes" : 0.2.6 , installed 0.2.6
                                  Adapter "sayit" : 1.1.2
                                  Adapter "samsung" : 0.0.11
                                  Adapter "s7" : 0.2.4
                                  Adapter "rwe-smarthome" : 0.1.9
                                  Adapter "rpi2" : 0.2.1
                                  Adapter "rickshaw" : 0.4.4
                                  Adapter "rflink" : 1.0.2
                                  Adapter "pushover" : 1.0.2
                                  Adapter "pushsafer" : 0.1.7
                                  Adapter "pushbullet" : 0.0.11
                                  Adapter "ping" : 1.1.1 , installed 1.1.1
                                  Adapter "piface" : 0.0.50
                                  Adapter "phantomjs" : 0.1.2
                                  Adapter "owntracks" : 0.1.1
                                  Adapter "owfs" : 0.3.4
                                  Adapter "onkyo" : 0.2.0
                                  Adapter "occ" : 0.2.4
                                  Adapter "nut" : 0.3.1
                                  Adapter "noolite" : 0.0.1
                                  Adapter "node-red" : 1.1.2
                                  Adapter "netatmo" : 0.4.0
                                  Adapter "mysensors" : 1.0.4
                                  Adapter "mqtt-client" : 0.3.0
                                  Adapter "mqtt" : 1.1.2
                                  Adapter "modbus" : 0.3.11
                                  Adapter "mobile" : 0.4.9
                                  Adapter "miele" : 0.0.16
                                  Adapter "megad" : 1.2.1
                                  Adapter "lgtv" : 1.0.0
                                  Adapter "kodi" : 0.1.4
                                  Adapter "knx" : 0.7.0
                                  Controller "js-controller" : 0.12.2 , installed 0.12.2
                                  Adapter "javascript" : 3.0.10 , installed 3.0.10
                                  Adapter "influxdb" : 1.1.0 , installed 1.1.0
                                  Adapter "icons-ultimate-png": 0.1.0
                                  Adapter "icons-open-icon-library-png": 0.1.3
                                  Adapter "icons-mfd-svg" : 1.0.0
                                  Adapter "icons-mfd-png" : 1.0.0 , installed 1.0.0
                                  Adapter "icons-material-svg": 0.1.0
                                  Adapter "icons-material-png": 0.1.0
                                  Adapter "icons-icons8" : 0.0.1
                                  Adapter "icons-addictive-flavour-png": 0.1.0
                                  Adapter "ical" : 1.2.0 , installed 1.2.0
                                  Adapter "hmm" : 1.0.1
                                  Adapter "homepilot" : 0.0.7
                                  Adapter "homekit2" : 0.1.6
                                  Adapter "hue" : 0.5.9 , installed 0.5.9
                                  Adapter "hm-rpc" : 1.3.3 , installed 1.3.3
                                  Adapter "hm-rega" : 1.3.0 , installed 1.3.0
                                  Adapter "history" : 1.3.1 , installed 1.3.1
                                  Adapter "harmony" : 0.5.6
                                  Adapter "geofency" : 0.1.5 , installed 0.1.5
                                  Adapter "fritzbox" : 0.2.1
                                  Adapter "foobar2000" : 0.1.2
                                  Adapter "feiertage" : 0.3.2
                                  Adapter "flot" : 1.5.5 , installed 1.5.5
                                  Adapter "fhem" : 0.2.2
                                  Adapter "epson_stylus_px830": 0.0.2
                                  Adapter "email" : 1.0.0
                                  Adapter "dwd" : 2.1.1
                                  Adapter "cul" : 0.0.4
                                  Adapter "cloud" : 0.1.1 , installed 0.1.1
                                  Adapter "chromecast" : 1.1.0
                                  Adapter "botvac" : 0.5.0
                                  Adapter "b-control-em" : 0.1.1
                                  Adapter "artnet" : 0.1.4
                                  Adapter "amazon-dash" : 0.1.0
                                  Adapter "admin" : 1.6.4 , installed 1.6.5 Was bedeuted eigentlich das hier: > npm ERR! peerinvalid The package iobroker.admin@0.8.3 does not satisfy its siblings' peerDependencies requirements! `
                                  build-essential ist installiert.
                                  Was kann ich tun?
                                  Lg
                                  iobroker auf Intel NUC mit Proxmox LXC und Raspi3+
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    npm findet irgendwo: iobroker.admin@0.8.3
                                    Kannst du mal in
                                    /opt/iobroker/node_modules/iobroker.admin/package.json
                                    und
                                    /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/package.json
                                    checken?
                                    Welche Versionen sind dadrin?
                                      Stmiko
                                      ` > Kannst du mal in
                                      und
                                      checken?
                                      Welche Versionen sind dadrin? `
                                      Im ersten package.json stand in der Tat bei admin noch eine 0.8.3 drin. Warum auch immer?
                                      Das zweite package.json gibts bei mir nicht.
                                      Ich habe das jetzt im ersten file händisch auf 1.6.5 geändert und jetzt läuft die Installation durch.:
                                      node-gyp rebuild
                                      iobroker.js-controller@0.13.1 node_modules/iobroker.js-controller
                                      ├── pyconf@1.1.2
                                      ├── semver@5.3.0
                                      ├── mime@1.3.4
                                      ├── ncp@2.0.0
                                      ├── redis@2.6.3 (double-ended-queue@2.1.0-0, redis-parser@2.1.1, redis-commands@1.3.0)
                                      ├── bluebird@3.4.6
                                      ├── socket.io-client@1.5.1 (to-array@0.1.4, indexof@0.0.1, component-bind@1.0.0, component-emitter@1.2.0, backo2@1.0.2, object-component@0.0.3, has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.3.1, parseuri@0.0.4, engine.io-client@1.7.2)
                                      ├── yargs@6.3.0 (get-caller-file@1.0.2, decamelize@1.2.0, camelcase@3.0.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, yargs-parser@4.0.2, require-main-filename@1.0.1, require-directory@2.1.1, os-locale@1.4.0, string-width@1.0.2, cliui@3.2.0, read-pkg-up@1.0.1)
                                      ├── letsencrypt@2.1.8 (le-store-certbot@2.0.3, homedir@0.6.0, asn1js@1.2.12, le-acme-core@2.0.7, localhost.daplie.com-certificates@1.2.3, certpem@1.0.1, pkijs@1.3.27, le-challenge-sni@2.0.1, rsa-compat@1.2.7)
                                      └── npm@2.15.11 Allerdings scheint das Update nicht geklappt zu haben, er zeigt mir im web interface immer noch die 0.12.2 an (auch nach einem reboot)? > host.Raspi31 2016-11-01 00:46:27.478 info Copyright © 2014-2016 bluefox, hobbyquaker
                                      host.Raspi31 2016-11-01 00:46:27.464 info iobroker.js-controller version 0.12.2 js-controller starting `
                                        Stmiko
                                        Ok, jetzt hat es nach mehreren Versuchen endlich geklappt: js-controller 0.13.1 installiert .
                                        Läuft bisher ohne Probleme.
                                        Lg,
                                          rantanplanR Offline
                                          rantanplan
                                          Hallo
                                          Kann mir bitte jemand die Befehle für das Update für Win10 angeben.
                                          Grüße
                                          Rantanplan
