Amazon Dash lässt sich nicht installieren
hab schon manuell kopiert und dann kommt trotzdem diese Fehlermeldung
! $ ./iobroker add amazon-dash
! npm install iobroker.amazon-dash –production --prefix "/opt/iobroker" (System call)
! npm
! WARN lifecycle iobroker.amazon-dash@0.2.5~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.5 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
! ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::New(const Nan::FunctionCallbackInfov8::value&)’:../socket_watcher.cpp:104:49: warning: ‘v8::Local v8::objectv8::Function::NewInstance() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
! info.GetReturnValue().Set(cons->NewInstance());
! In file included from /root/.node-gyp/6.11.4/include/node/v8.h:25:0, from /root/.node-gyp/6.11.4/include/node/node.h:42,
! from ../../nan/nan.h:49,
! from ../socket_watcher.hpp:8,
! from ../socket_watcher.cpp:5:
! /root/.node-gyp/6.11.4/include/node/v8.h:3276:52: note: declared here
! V8_DEPRECATED("Use maybe version", Local <object>NewInstance() const);
! /root/.node-gyp/6.11.4/include/node/v8config.h:333:3: note: in definition of macro ‘V8_DEPRECATED’
! declarator attribute((deprecated(message)))
! ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security pam_appl.h="">^
! compilation terminated.
! make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
! gyp
! ERR! build error
! gyp
! ERR! stack Error:make
failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
! gyp
! ERR! stack at emitTwo (events.js:106:13)gyp ERR! stack at ChildProcess.emit (events.js:191:7)
! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
! gyp ERR!
! System Linux 4.9.41-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
! gyp
! ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v6.11.4
! gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
! ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">^
! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1
! gyp
! ERR!
! build error
! gyp ERR! stack Error:make
! gyp ERR! stack at emitTwo (events.js:106:13)
! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
! gyp ERR! System Linux 4.9.41-v7+
! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
! gyp ERR! cwd /opt/iobroker/node_modules/pcap
! gyp ERR! node -v v6.11.4
! gyp ERR! not ok
! npm
! WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install:node-gyp rebuild
! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
! npm
! ERR! Linux 4.9.41-v7+npm
! ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.4
! npm ERR! npm v3.10.10
! npm ERR! code ELIFECYCLE
! npm ERR! pcap@2.0.0 install:node-gyp rebuild
! npm ERR! Exit status 1
! npm ERR!
! npm ERR! Failed at the pcap@2.0.0 install script 'node-gyp rebuild'.
! npm ERR! Make sure you have the latest version of node.js and npm installed.
! npm ERR! If you do, this is most likely a problem with the pcap package,
! npm ERR! not with npm itself.
! npm ERR! Tell the author that this fails on your system:
! npm ERR! node-gyp rebuild
! npm ERR! You can get information on how to open an issue for this project with:
! npm ERR! npm bugs pcap
! npm ERR! Or if that isn't available, you can get their info via:
! npm ERR! npm owner ls pcap
! npm ERR! There is likely additional logging output above.
! npm ERR! Please include the following file with any support request:npm ERR!
! /npm-debug.log
! host.All-in-One-Pi install adapter amazon-dash
! npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)
! npm
! WARN
! lifecycle iobroker.amazon-dash@0.2.5~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.5 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
! gyp
! ERR!
! build error
! gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
! gyp ERR! not ok
! gyp
! ERR!
! build error
! gyp
! ERR!
! stack
! Error:make
! gyp ERR! not ok
! npm
! npm
! npm ERR!
! npm
! ERR! There is likely additional logging output above.
! ERR!
! /npm-debug.log
! npm
! gyp
! ERR!
! build error
! ERR!
! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp
! gyp ERR!
! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1gyp ERR! build error
! gyp
! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap
! gyp
! ERR! node-gyp -v v3.4.0gyp ERR! not ok
! npm
! WARN optional
! SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install:node-gyp rebuild
! npm ERR! Linux 4.9.41-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--prefix" "/opt/iobroker"
! npm ERR! node v6.11.4
! npm ERR! npm v3.10.10npm ERR!
! code ELIFECYCLE
! npm ERR!
! Exit status 1npm ERR!
! npm
! ERR! If you do, this is most likely a problem with the pcap package,npm ERR! not with npm itself.
! /npm-debug.log
! ERROR: host.All-in-One-Pi Cannot install amazon-dash
! ERROR: process exited with code 13</pcap></security></object></v8::object></v8::value></pcap></security></object></v8::object></v8::value></pcap></security></object></v8::object></v8::value>
