[gelöst] xml Daten einer URL weiterverarbeiten
Probiere so aus:
var xml2js = require('xml2js'); var options = { explicitArray: false, mergeAttrs: true }; var parser = new xml2js.Parser(options); var request = require('request'); request('http://192.168.178.xx:8090/now_playing', function (error, response, body) { if (!error && response.statusCode == 200) { parser.parseString(body, function (err, result) { if (err) { log("Fehler: "+err); } else { log("Result: "+result.root.itemName); } }); } else { log(error); } });
Dann kommt dieser Eintrag im log:
undefined2015-06-15 05:46:43.104 - info: javascript.0 Start javascript script.js.xxxTESTSCRIPTxxx 2015-06-15 05:46:43.104 - info: javascript.0 script.js.xxxTESTSCRIPTxxx: sunset: Mon Jun 15 2015 21:52:24 GMT+0200 (Mitteleuropäische Sommerzeit) 2015-06-15 05:46:43.260 - info: javascript.0 script.js.xxxTESTSCRIPTxxx: registered 0 subscriptions and 0 schedules 2015-06-15 05:46:43.322 - error: uncaught exception: Uncaught, unspecified "error" event. 2015-06-15 05:46:43.322 - error: TypeError: Uncaught, unspecified "error" event. at TypeError (<anonymous>:null:null) at Parser.emit (events.js:74:15) at Parser.exports.Parser.Parser.parseString (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\xml2js\lib\xml2js.js:482:16) at Parser.parseString (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\xml2js\lib\xml2js.js:6:59) at Request._callback (script.js.xxxTESTSCRIPTxxx:23:11) at Request.self.callback (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:354:22) at Request.emit (events.js:98:17) at Request. <anonymous>(C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:1207:14) at Request.emit (events.js:117:20) at IncomingMessage. <anonymous>(C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:1153:12) at IncomingMessage.emit (events.js:117:20) at _stream_readable.js:929:16 at process._tickCallback (node.js:419:13) 2015-06-15 05:46:43.651 - error: host.IntelNuc instance system.adapter.javascript.0 terminated with code 6 (uncaught exception) 2015-06-15 05:46:43.666 - info: host.IntelNuc Restart adapter system.adapter.javascript.0 because enabled 2015-06-15 05:47:13.680 - info: host.IntelNuc instance system.adapter.javascript.0 started with pid 3952</anonymous></anonymous></anonymous>
Ich hab keine Ahnung ob es einen Unterschied macht, dass Du an einem Windows System bist?! Oder was sonst.
Jedenfalls aber:
Da musst Du anstelle von 'itemName' den Namen eines vorhandenen Tags aus dem xml-Ergebnis einsetzen. Bei meinem Sonos testweise zB:
log("Result: "+result.root.device.manufacturer);
Weiterhin hoffe ich, dass Du hier die xx-en weggemacht hast:
> request('[http://192.168.178.xx:8090/now_playing](http://192.168.178.xx:8090/now_playing)', function (error, response, body)
Was bringt bei dir:
var xml2js = require('xml2js'); var options = { explicitArray: false, mergeAttrs: true }; var parser = new xml2js.Parser(options); var request = require('request'); request('http://192.168.178.xx:8090/now_playing', function (error, response, body) { if (!error && response.statusCode == 200) { log("Body: " + body); parser.parseString(body, function (err, result) { if (err) { log("Fehler: "+err); } else { log("Result: "+result.root.itemName); } }); } else { log(error); } });
Abgestützt wird beim Parsen. D.h. Response ist vermutlich kein xml.
Wird heute Abend direkt ausprobiert.
Die xx habe ich natürlich ersetzt.
Nach der letzten Änderung erschein im log:
2015-06-15 18:21:07.828 - info: javascript.0 script.js.xxxTESTSCRIPTxxx: Body: <nowplaying deviceid="08DF1F46E63F" source="INTERNET_RADIO"><contentitem source="INTERNET_RADIO" location="32759" sourceaccount/ispresetable="true"><itemname>WDR 2 Münsterland</itemname></contentitem><track><artist></artist><album></album><stationname>WDR 2 Münsterland</stationname><art artimagestatus="IMAGE_PRESENT">http://logo.vtuner.net/007452/logo/logo-32759.jpg</art><playstatus>PLAY_STATE</playstatus><description>MP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.</description><stationlocation>Internet Only</stationlocation></nowplaying> 2015-06-15 18:21:07.844 - error: uncaught exception: Uncaught, unspecified "error" event. 2015-06-15 18:21:07.859 - error: TypeError: Uncaught, unspecified "error" event. at TypeError (<anonymous>:null:null) at Parser.emit (events.js:74:15) at Parser.exports.Parser.Parser.parseString (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\xml2js\lib\xml2js.js:482:16) at Parser.parseString (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\xml2js\lib\xml2js.js:6:59) at Request._callback (script.js.xxxTESTSCRIPTxxx:24:11) at Request.self.callback (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:354:22) at Request.emit (events.js:98:17) at Request. <anonymous>(C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:1207:14) at Request.emit (events.js:117:20) at IncomingMessage. <anonymous>(C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:1153:12) at IncomingMessage.emit (events.js:117:20) at _stream_readable.js:929:16 at process._tickCallback (node.js:419:13) 2015-06-15 18:21:08.187 - error: host.IntelNuc instance system.adapter.javascript.0 terminated with code 6 (uncaught exception)</anonymous></anonymous></anonymous>
var parseString = require('xml2js').parseString; var request = require('request'); request('http://192.168.178.xx:8090/now_playing', function (error, response, body) { if (!error && response.statusCode == 200) { log("Body: " + body); parseString(body, { explicitArray: false, mergeAttrs: true }, function (err, result) { if (err) { log("Fehler: " + err); } else { log("Result: " + JSON.stringify(result.nowPlaying)); } }); } else { log(error); } });
Ich hab kein Bose. Aber der String kopiert und eingefügt hatte bei mir auch Probleme gemacht. Kann es sein, dass das result noch irgend wie gefiltert und / oder utf-8-ed werden muss?
Ich hab kein Bose. Aber der String kopiert und eingefügt hatte bei mir auch Probleme gemacht. Kann es sein, dass das result noch irgend wie gefiltert und / oder utf-8-ed werden muss? `
Bei mir funktioniert das:var parseString = require('xml2js').parseString; var request = require('request'); //request('http://192.168.178.xx:8090/now_playing', function (error, response, body) { //if (!error && response.statusCode == 200) { var body = '<nowplaying deviceid="08DF1F46E63F" source="INTERNET_RADIO"><contentitem source="INTERNET_RADIO" location="32759" sourceaccount/ispresetable="true"><itemname>WDR 2 Münsterland</itemname></contentitem><track><artist></artist><album></album><stationname>WDR 2 Münsterland</stationname><art artimagestatus="IMAGE_PRESENT">http://logo.vtuner.net/007452/logo/logo-32759.jpg</art><playstatus>PLAY_STATE</playstatus><description>MP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.</description><stationlocation>Internet Only</stationlocation></nowplaying>'; log("Body: " + body); parseString(body, { explicitArray: false, mergeAttrs: true }, function (err, result) { if (err) { log("Fehler: " + err); } else { log("Result: " + JSON.stringify(result.nowPlaying)); } }); //} else { // log(error); //} //});
Output:
javascript-0 2015-06-15 21:45:30 info script.js.Script1: registered 0 subscriptions and 0 schedules javascript-0 2015-06-15 21:45:30 info script.js.Script1: Result: {'deviceID':'08DF1F46E63F','source':'INTERNET_RADIO','ContentItem':{'source':'INTERNET_RADIO','location':'32759','sourceAccount':'','isPresetable':'true','itemName':'WDR 2 Münsterland'},'track':'','artist':'','album':'','stationName':'WDR 2 Münsterland','art':{'_':'http://logo.vtuner.net/007452/logo/logo-32759.jpg','artImageStatus':'IMAGE_PRESENT'},'playStatus':'PLAY_STATE','description':'MP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.','stationLocation':'Internet Only'} javascript-0 2015-06-15 21:45:30 info script.js.Script1: Body: WDR 2 MünsterlandWDR 2 Münsterlandhttp://logo.vtuner.net/007452/logo/logo-32759.jpgPLAY_STATEMP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.Internet Only javascript-0 2015-06-15 21:45:30 info Start javascript script.js.Script1
yes…
Der code
var parseString = require('xml2js').parseString; var request = require('request'); request('http://192.168.178.26:8090/now_playing', function (error, response, body) { if (!error && response.statusCode == 200) { //var body = '<nowplaying deviceid="08DF1F46E63F" source="INTERNET_RADIO"><contentitem source="INTERNET_RADIO" location="32759" sourceaccount/ispresetable="true"><itemname>WDR 2 Münsterland</itemname></contentitem><track><artist></artist><album></album><stationname>WDR 2 Münsterland</stationname><art artimagestatus="IMAGE_PRESENT">http://logo.vtuner.net/007452/logo/logo-32759.jpg</art><playstatus>PLAY_STATE</playstatus><description>MP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.</description><stationlocation>Internet Only</stationlocation></nowplaying>'; log("Body: " + body); parseString(body, { explicitArray: false, mergeAttrs: true }, function (err, result) { if (err) { log("Fehler: " + err); } else { log("Result: " + JSON.stringify(result.nowPlaying)); } }); } else { log(error); } });
funktioniert. Zumindest habe ich jetzt keine Fehler mehr in der log-Datei.
Jetzt brauch ich nur noch ein Beispiel wie ich daraus die einzelnen Werte selektieren kann.
Kann ich dass jetzt wie ein Objekt ansprechen?
Als Ergebnis hast du ein Objekt:
{"nowPlaying": { 'deviceID' : '08DF1F46E63F', 'source' : 'INTERNET_RADIO', 'ContentItem' : { 'source' : 'INTERNET_RADIO', 'location' : '32759', 'sourceAccount' : '', 'isPresetable' : 'true', 'itemName' : 'WDR 2 Münsterland' }, 'track' : '', 'artist' : '', 'album' : '', 'stationName' : 'WDR 2 Münsterland', 'art' : { '_' : 'http://logo.vtuner.net/007452/logo/logo-32759.jpg', 'artImageStatus' : 'IMAGE_PRESENT' }, 'playStatus' : 'PLAY_STATE', 'description' : 'MP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.', 'stationLocation' : 'Internet Only' } }
Und ja das ist ein Objekt. Wenn du z.B. artImageStatus extrahieren willst dann solltest du result.nowPlaying.art.artImageStatus aufrufen.
Perfekt, funktioniert. Danke Euch allen.
Ich muss hier leider nochmal nachfragen…
ich kann meinen Heizölstand elektronisch abfragen.. unter http://192.168.xx.xx/xml bekomme ich vollgendes Ergebniss
This XML file does not appear to have any style information associated with it. The document tree is shown below. <seqsmartbox xmlns="http://tecson.dev.oilview.de/gateway/xsd" xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance" xsi:schemalocation="http://tecson.dev.oilview.de/gateway/xsd/smartbox.xsd"><seqheader><indication>Manuelle Abfrage</indication> <authcode>03B41236A899</authcode> <devoperator><devlocation><devid>2-852</devid> <devversion>V6.02</devversion></devlocation></devoperator></seqheader> <seqdata><seqtanks><tanknumber>1</tanknumber> <tankname>Heizöl</tankname> <seqtanklevel><tanklevel>490</tanklevel> <tankunit>L</tankunit></seqtanklevel> <tankpercent>5</tankpercent> <seqtanksize><tanksize>10000</tanksize> <tankunit>L</tankunit></seqtanksize> <seqtankclear><tankclearance>9010</tankclearance> <tankunit>L</tankunit></seqtankclear></seqtanks></seqdata> <seqpara><para1>30</para1> <para2>15</para2> <para4>0</para4> <para5>5</para5> <para9>0</para9></seqpara></seqsmartbox>
Was mich nun interessiert ist der wert von <tanklevel>490</tanklevel> …. also nur 490 in einem Objekt...
Ganz ehrlich... ich bekomms nicht hin.
Hat mir da noch jemand eine Idee ?
das mit dem xml2js habe ich schon probiert... Allerdings kann man unter Admin3 wohl keine Module mehr eintragen.. Der Save Button wird nicht aktiv... Zur Zeit ist es bei mir noch so, dass wenn ich über iobroker.pro gehe und damit die Admin Seite aufrufe noch eine 2.x Version kommt. Hier kann ich die xml2js eintragen (und die ist nachher auch in der 3.0 eingetragen..)
Ich bekomme nur einen "Error: Parse Error" , wenn ich das hier ausführe:
var parseString = require('xml2js').parseString; var request = require('request'); request('http://192.168.160.80/xml', function (error, response, body) { if (!error && response.statusCode == 200) { log("Body: " + body); parseString(body, { explicitArray: false, mergeAttrs: true }, function (err, result) { if (err) { log("Fehler: " + err); } else { log("Result: " + JSON.stringify(result.tankLevel)); } }); } else { log(error); } });
Irgendwelche Vorschläge ?
Allerdings kann man unter Admin3 wohl keine Module mehr eintragen.. Der Save Button wird nicht aktiv… Zur Zeit ist es bei mir noch so, dass wenn ich über iobroker.pro gehe und damit die Admin Seite aufrufe noch eine 2.x Version kommt. Hier kann ich die xml2js eintragen (und die ist nachher auch in der 3.0 eingetragen..) `
Da bin ich auch drüber gestolpert.
Du musst , wenn Du im Javascript-Adapter den Modulnamen eingegeben hast, [ENTER] drücken.
Ich bin anfangs immer mit [TAB] weiter und dann wird der Speicherbutton nicht aktiv.
Benötigst Du nur diesen einen Wert? <tanklevel>490</tanklevel>
Das ist dann wahrscheinlich am Einfachsten, wenn Du einfach den Parser oder Systeminfo-Adapter nimmst oder im Skript
Ein Beispiel für ein Regex für den Wert: https://regex101.com/r/uoymuu/1
Morgen…
Danke für den Tipp...
Das mit dem Sysinfo-Adapter hatte ich versucht... es scheiterte aber an der richtigen Regex...
Nun kommt mit dem Parsermodul: arser.0 2018-02-22 07:06:51.277 error Cannot read link "http://192.168.160.80/xml": Error: Parse Error
parser.0 2018-02-22 07:06:41.244 error Cannot read link "http://192.168.160.80/xml": Error: Parse Error
Sysinfo: ähnliche Fehlermeldung...
4885_parser.png -
Du bekommst beim Skript, Parser Adapter und Systeminfo Adapter jeweils einen parse Error.
Was bekommst Du denn im Log als Ausgabe, wenn Du bei Deinem Skript den Teil mit parseString weglässt.
Wird mit der Zeile log("Body: " + body); denn der Inhalt der XML im Log ausgegeben?
Aeeh…. Ne!
ich habe eine ähnliches Problem beim auslesen meines Akkustandes vom Sonos Move, habe allerdings einen neuen Thread dazu aufgemacht nachdem der Hinweis mit dem hohen Alter dieses Threads beim erstellen meiner Antwort aufkam.
Keine Ahnung wie sich das mit Doppelpostings verhält, daher möchte ich ungern hier nochmal alles komplett posten.
Falls sich jemand findet, der hier schon mal helfen konnte und bereit ist sich mein Problem unter folgendem Link hier im Forum anzusehen wäre ich dankbar.[https://forum.iobroker.net/topic/44272/xml-return-in-blockly-weiter-verarbeiten](Neuer Forumsbeitrag - XML return in Blockly weiterverarbeiten)
Vielen Dank im Voraus - Gruß
