[Frage] Bei Haustür Klingel Snapshot speichern
ich würde gerne dein script verwenden.
Bei einem türklingel soll ein Bild gespeichert und versendet werden.
Mit Blockly habe ich das so hinbekommen.
on({id: 'tr-064.0.callmonitor.inbound.callee', change: "any"}, function (obj) {
var value = obj.state.val;
if (getState("tr-064.0.callmonitor.inbound.callee").val == '100') {
sendTo("telegram", "send", {
text: 'hat geklingelt'
! 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wie kann ich das jetzt ohne Telegram natürlich in dein Bewegungsmelder ersetzen? Vielen dank
wie kann ich das jetzt ohne Telegram natürlich in dein Bewegungsmelder ersetzen? `
Du musst eigentlich nur den Auslöser, dass Event, ändern:Statt der Reaktion auf den Bewegungsmelder:
// Ereignisroutine on({id: oidLichtBewmelderTuer, val: true}, function (obj) { onEvent( obj ); });
Dein Event der Türklingel verwenden:
// Ereignisroutine on({id: 'tr-064.0.callmonitor.inbound.callee', change: "any"}, function (obj) { if (getState("tr-064.0.callmonitor.inbound.callee").val == '100') { onEvent( obj ); }); } });
hab da ein kleinen Fehler drin wenn ich das so mache!
was muss ich ändern damit da kein Fehler mehr kommt?
löschen
1518_unbenannt.png -
Oh man so einfach, vielen dank!
Hallo
Ich bekomme immer nur 2 Bilder ? Und die heißen alle gleich . Die Zeit ist eine andere
Gesendet von iPad mit Tapatalk Pro
` > Bei mir läuft ein ähnliches Script:
Ein Bewegungsmelder überwacht den Bereich der Eingangstür. Detektiert er eine Bewegung, wird ein Bild von der Überwachungskamera (die natürlich auch den gleichen Bereich abdeckt) geholt, gespeichert und via Telegram versendet. Das ganze noch einmal 10 Sek später. Es werden die letzten 8 Bilder gespeichert, das jüngste hat den Index 0, das vorletzte 1 usw. Damit kann man diese letzten Bilder auch sehr gut im vis darstellen (Dateiname ist eben immer gleich). `
Hallo Ohula, danke für das tolle script, welches ich gleich 2 mal nutze… 1x für den hier beschriebenen Zweck und 1 x für ein Alarmanlagenscript bei Alarmierung Foto...
Da ich mehrere Kameras habe, wollte ich mal Fragen ob es denn möglich wäre auf Basis dieses Scripts auch weitere IP Cams einzubinden?
Klar, ich könnte das script einfach kopieren und mehrer instanzen davon anlegen. hätte das aber lieber in einem Script...
Für etwas Hilfestellung/Starthilfe wie man das am Besten löst, würde ich mich echt freuen...
NACHTRAG: Es geht! Mit NODE RED kann man das TCP Paket einfangen und dann weiterverarbeiten. Bei Bewegung an der Axis Kamera wird nun ein Trigger gesetzt der eine Telegram-Nachricht auslöst. Dieses Socket.io ist unnötig. `
kannst du mir ein paar Informatione dazu geben und eventuell deinen NodeRed Flow bereitsstellen.
Meine HikVision kann auch eine "Alarmierung" bei Bewegungserkennung versenden welche ich gerne nutzen möchte.
Danke und Gruß
});Hi, kannst du mir sagen was du als Klingeltaster nutzt bzw. wie du den inbound.callee auf Value 100 bekommst wenn jemand klingelt? Hast du etwas an einen FON Anschluß der FB angeschlossen und als Türsprechanlage konfiguriert? Danke und Gruß Mirko `
` > Hi,
Danke und Gruß `
Hey,
guck mal ob die Hikvision einen Nachrichtenserver konfigurieren kann. Dort kannst du bei meiner Cam ein Schlagwort einstellen und darauf lauschen. In meinem Fall "true". Im Node Red dann den gleichen Port einstellen wie in dieser Kameraeinstellung.
4724_snap2.jpg -
Ich habe ein Gira ip gateway im zähler verbaut. Dadurch habe ich den klingeltaster mal digital im System, somit kann ich auch das Fritzfon klingeln lassen wenn der Klingeltaster gedrückt wird. Mit dem tr-064 adapter lausche ich dann einfach auf die internet telefonnummer 100 das der Klingetaster ist.
Ich habe ein Gira ip gateway im zähler verbaut. Dadurch habe ich den klingeltaster mal digital im System, somit kann ich auch das Fritzfon klingeln lassen wenn der Klingeltaster gedrückt wird. Mit dem tr-064 adapter lausche ich dann einfach auf die internet telefonnummer 100 das der Klingetaster ist. `
Wie funktioniert das mit dem Fritzfon klingeln lassen?
Mit Deiner Variante müsste das Fritzfon doch auch ein ipcamera Bild anzeigen können, oder?
(Ich glaube das können nur einige Modelle)
