Iobroker startet nicht mehr nach Ubuntu update
Yeep… das wars
Dann mach ich mal nen reinstall.
ist nicht ganz sauber durchgelaufen…
DONE iobroker.javascript npm WARN deprecated tar.gz@1.0.7: ⚠️ WARNING ⚠️ tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated npm WARN prefer global npm@2.15.12 should be installed with -g > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram > node-gyp rebuild gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/svenilee/.node-gyp/6.12.0" gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp" make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o SOLINK_MODULE(target) Release/obj.target/unix_dgram.node COPY Release/unix_dgram.node make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen > ursa@0.9.4 install /opt/iobroker/node_modules/ursa > node-gyp rebuild gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/svenilee/.node-gyp/6.12.0" gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/ursa/.node-gyp" make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird betreten CXX(target) Release/obj.target/ursaNative/src/ursaNative.o SOLINK_MODULE(target) Release/obj.target/ursaNative.node COPY Release/ursaNative.node make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird verlassen
npm ERR! code 1 FAIL iobroker.socketio iobroker@1.0.0 /opt/iobroker └─┬ iobroker.tankerkoenig@1.0.4 └─┬ xml2js@0.2.8 └── sax@0.5.8 DONE iobroker.tankerkoenig npm WARN deprecated to-iso-string@0.0.2: to-iso-string has been deprecated, use @segment/to-iso-string instead. npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue npm WARN deprecated node-uuid@1.4.8: Use uuid module instead npm WARN deprecated tough-cookie@2.2.2: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
./reinstall.sh: Zeile 34: Dateiende beim Suchen nach »"« erreicht. ./reinstall.sh: Zeile 37: Syntaxfehler: Unerwartetes Dateiende. svenilee@Gotham-City:/opt/iobroker$
Ggf. das Original-reinstall.sh mal mit einem FTP vom Linux ziehen und die Datei mit einem "vernünftiges" Editor wieder umkonvertierten.
Gruß,
Eric
Nimm diese Datei, nach dem Entfernen von .txt am Ende des Dateinamen.
so, alles gemacht aber noch kein erfolg…
2017-11-17 22:05:40.282 - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting 2017-11-17 22:05:40.288 - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker 2017-11-17 22:05:40.288 - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0 2017-11-17 22:05:40.289 - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxxx 2017-11-17 22:05:40.337 - ^[[32minfo^[[39m: host.Gotham-City inMem-states listening on port 9000 2017-11-17 22:05:40.358 - ^[[32minfo^[[39m: host.Gotham-City inMem-objects listening on port 9001 2017-11-17 22:05:40.365 - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected 2017-11-17 22:05:40.367 - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0 2017-11-17 22:05:40.371 - ^[[32minfo^[[39m: host.Gotham-City no instances found 2017-11-17 22:05:40.381 - ^[[31merror^[[39m: uncaught exception: logger is not defined 2017-11-17 22:05:40.383 - ^[[31merror^[[39m: ReferenceError: logger is not defined at Object.decryptPhrase (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:77:9) at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:128:27 at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21) at ontimeout (timers.js:386:11) at tryOnTimeout (timers.js:250:5) at Timer.listOnTimeout (timers.js:214:5) 2017-11-17 22:05:40.388 - ^[[32minfo^[[39m: host.Gotham-City terminated 2017-11-17 22:05:40.396 - ^[[32minfo^[[39m: iobroker _restart 2017-11-17 22:05:40.652 - ^[[32minfo^[[39m: iobroker Starting node restart.js 2017-11-17 22:05:40.662 - ^[[32minfo^[[39m: iobroker exit 0 2017-11-17 22:05:40.776 - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM 2017-11-17 22:05:40.777 - ^[[32minfo^[[39m: host.Gotham-City terminated
einen Fehler gab es doch beim reinstall
iobroker.core@0.1.0 /opt/iobroker └── (empty) npm ERR! code 1 FAIL iobroker.socketio iobroker.core@0.1.0 /opt/iobroker
kannes sein, das das Problem der iobroker.core ist?
Also ich bekomme iobroker einfach nicht mehr ans laufen… es läuft immer wieder auf den selben Fehler hinaus.
Da bei reinstall immer wieder der Fehler bei socketio auftritt habe ich versucht dieses Modul per Hand zu installieren-
Leider auch ohne erfolg
svenilee@Gotham-City:/opt/iobroker$ sudo npm install iobroker.socketio --loglevel verbose npm info it worked if it ends with ok npm verb cli [ '/usr/bin/node', npm verb cli '/usr/bin/npm', npm verb cli 'install', npm verb cli 'iobroker.socketio', npm verb cli '--loglevel', npm verb cli 'verbose' ] npm info using npm@3.10.10 npm info using node@v6.12.0 npm verb request uri https://registry.npmjs.org/iobroker.socketio npm verb request no auth needed npm info attempt registry request try #1 at 17:24:10 npm verb request id 7d087b006a900a50 npm verb etag W/"59f82d29-1200c" npm verb lastModified Tue, 31 Oct 2017 07:58:33 GMT npm http request GET https://registry.npmjs.org/iobroker.socketio npm http 304 https://registry.npmjs.org/iobroker.socketio npm verb headers { date: 'Sun, 19 Nov 2017 16:24:10 GMT', npm verb headers via: '1.1 varnish', npm verb headers 'cache-control': 'max-age=300', npm verb headers etag: 'W/"59f82d29-1200c"', npm verb headers age: '232', npm verb headers connection: 'keep-alive', npm verb headers 'x-served-by': 'cache-hhn1533-HHN', npm verb headers 'x-cache': 'HIT', npm verb headers 'x-cache-hits': '1', npm verb headers 'x-timer': 'S1511108650.285039,VS0,VE1', npm verb headers vary: 'Accept-Encoding, Accept' } npm verb etag https://registry.npmjs.org/iobroker.socketio from cache npm verb get saving iobroker.socketio to /home/svenilee/.npm/registry.npmjs.org/iobroker.socketio/.cache.json npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb cache add spec iobroker.socketio npm verb addNamed "latest" is being treated as a dist-tag for iobroker.socketio npm info addNameTag [ 'iobroker.socketio', 'latest' ] npm verb addNameTag registry:https://registry.npmjs.org/iobroker.socketio not in flight; fetching npm verb get https://registry.npmjs.org/iobroker.socketio not expired, no request npm verb addNamed "1.8.6" is a plain semver version for iobroker.socketio npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json not in flight; writing npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json written npm verb correctMkdir /home/svenilee/.npm/_locks correctMkdir not in flight; initializing npm verb lock using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging npm verb unbuild node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb tar unpack /home/svenilee/.npm/iobroker.socketio/1.8.6/package.tgz npm verb tar unpacking to /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c/node_modules npm info lifecycle iobroker.socketio@1.8.6~preinstall: iobroker.socketio@1.8.6 npm verb unbuild node_modules/iobroker.socketio npm info lifecycle iobroker.socketio@1.8.6~preuninstall: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~uninstall: iobroker.socketio@1.8.6 npm verb unbuild rmStuff iobroker.socketio@1.8.6 from /opt/iobroker/node_modules npm info lifecycle iobroker.socketio@1.8.6~postuninstall: iobroker.socketio@1.8.6 npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.socketio npm info linkStuff iobroker.socketio@1.8.6 npm verb linkBins iobroker.socketio@1.8.6 npm verb linkMans iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~install: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~postinstall: iobroker.socketio@1.8.6 npm verb unlock done using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging iobroker.core@0.1.0 /opt/iobroker └── (empty) ! npm verb exit [ 0, true ] npm ERR! code 1 svenilee@Gotham-City:/opt/iobroker$ !
Ich empfehle die neuste js-controller vom github zu installieren:
cd /opt/iobroker iobroker stop npm i https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production iobroker start
Danach sollte js-controller alle fehlende Pakete selbst nachinstallieren.
hallo Bluefox,
hab ich Probiert:
` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker stop
[sudo] Passwort für svenilee:
iobroker controller daemon is not running
svenilee@Gotham-City:/opt/iobroker$ sudo npm i https://github.com/ioBroker/ioBroker.js … all/master --production
npm WARN deprecated tar.gz@1.0.7: <emoji seq="26a0">️</emoji> WARNING <emoji seq="26a0">️</emoji> tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
iobroker.js-controller@1.2.1 install /opt/iobroker/node_modules/iobroker.js-controller
node iobroker.js setup first
└── iobroker.js-controller@1.2.1
svenilee@Gotham-City:/opt/iobroker$ sudo iobroker start
Starting iobroker controller daemon...
iobroker controller daemon started. PID: 13515 `
log:
` > 2017-11-19 20:45:53.635 - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.1 js-controller starting2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City Copyright 2014-2017 bluefox, 2014 hobbyquaker
2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
2017-11-19 20:45:53.641 - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 fd2d:5cf3:5594:0:be5f:f4ff:fe7d:a73c fe80::be5f:f4ff:fe7d:a$
2017-11-19 20:45:53.691 - ^[[32minfo^[[39m: host.Gotham-City inMem-states listening on port 9000
2017-11-19 20:45:53.711 - ^[[32minfo^[[39m: host.Gotham-City inMem-objects listening on port 9001
2017-11-19 20:45:53.718 - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
2017-11-19 20:45:53.720 - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
2017-11-19 20:45:53.725 - ^[[32minfo^[[39m: host.Gotham-City no instances found
2017-11-19 20:45:53.746 - ^[[33mwarn^[[39m: host.Gotham-City multihost service started on 0.0.0.0:50005 `
sollte laufen…
` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker status
iobroker is running `
ist aber unter port 8081 nicht erreichbar
muß ich noch einen reinstall ausführen?
hallo Bluefox,
hab ich Probiert:
log:
sollte laufen…
muß ich noch einen reinstall ausführen? `
Wo sind deine Einstellungen? Die datei /opt/iobroker-data/objects.json lehr oder default. -
ich würde sagen default…
steht fast überall was drin
Ich wollte damit sagen, dass die Einstellungen weg sind.
sorry… versteh nicht was Du meinst?
die Datei ist doch da?
oder Anders... wie bekomme ich diese wieder?
so, ich habe jetzt eine Image-Sicherung vom Server genommen und den iobroker-ordner in
mein aktuelles Image kopiert. Danach funktioniert es schon einmal wieder…
Aber wie bekomme ich jetzt meinen aktuellen Datenstand dort rein, einfach den iobroker-data ordner wieder zurück
kopieren?
kopieren? `
Definiere Datenstand, history Daten oder?
Send from mobile device
Objektpunkte, Skripte, Adaptereinstellungen
Edit: hat nicht funktioniert…
Gibt es einen Ordner in dem die Skripte abgelegt werden, do das ich wenigstens diese wieder herstellen kann?
