    4. [gelöst] - js-controller nach update nicht mehr zu starten
    • I
      iobroker-6043 last edited by
      Hach dem Update von heute kann ich den js-controller nicht mehr starten.
      npm install iobroker.js-controller –production klappt nicht und iobroker start ergibt
      module.js:327
      throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      at Function.Module._resolveFilename (module.js:325:15)
      at Function.Module._load (module.js:276:25)
      at Function.Module.runMain (module.js:441:10)
      at startup (node.js:139:18)
      at node.js:968:3
      Alles nicht so schlimm, neu installiert ist schnell nur fehlen mir meine JavaScripts. Wie komme ich denn an die ran ? 😞 😞 😞 😞
      root@raspberrypi:/opt/iobroker# iobroker stop
      module.js:327
      throw err;
      at node.js:968:3
      root@raspberrypi:/opt/iobroker# iobroker update module.js:327
      throw err;
      at node.js:968:3
      root@raspberrypi:/opt/iobroker# iobroker upgrade module.js:327
      throw err;
      at node.js:968:3
      root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller
      iobroker.js-controller@0.10.1 install /opt/iobroker/node_modules/iobroker.js-controller
      node lib/setup.js setup first
      fs.js:549
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
      at Error (native)
      at Object.fs.openSync (fs.js:549:18)
      at Object.fs.writeFileSync (fs.js:1156:15)
      at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:513:23
      at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:534:11)
      at Module._compile (module.js:409:26)
      at Object.Module._extensions..js (module.js:416:10)
      at Module.load (module.js:343:32)
      at Function.Module._load (module.js:300:12)
      npm ERR! Linux 4.4.11-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller"
      npm ERR! node v4.4.5
      npm ERR! npm v2.15.5
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.js-controller@0.10.1 install: node lib/setup.js setup first
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@0.10.1 install script 'node lib/setup.js setup first'.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node lib/setup.js setup first
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs iobroker.js-controller
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR! npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.</anonymous>
      • Homoran
        Bist du sicher, dass du im normalen Installationsordner "drüber"installiert hast?
        nicht dass du jetzt eine zweite ioBroker Installation hast.
        rainer
        • I
          Hallo Rainer
          Ja, gehe davon aus. Verzeichnis war immer /opt/iobroker
          root@raspberrypi****:/opt/iobroker#**** ls -lsa
          insgesamt 1360
          4 drwxrwxrwx 6 root root 4096 Jul 18 14:22 .
          4 drwxr-xr-x 8 root root 4096 Jun 8 16:54 ..
          4 drwxr-xr-x 2 root root 4096 Jun 8 16:55 etc
          4 -rwxr-xr-x 1 root root 297 Jun 8 16:58 install.sh
          4 -rwxrwxrwx 1 root root 67 Jun 8 16:58 iobroker
          4 drwxr-xr-x 4 root root 4096 Jun 8 16:59 iobroker-data
          4 -rwxr-xr-x 1 root root 90 Jun 8 16:57 killall.sh
          4 drwxr-xr-x 2 root root 4096 Jul 18 05:01 log
          4 drwxr-xr-x 11 pi pi 4096 Jul 18 14:22 node_modules
          1320 -rw-r–r-- 1 root root 1350135 Jul 18 14:22 npm-debug.log
          4 -rwxr-xr-x 1 root root 284 Jun 8 16:57 reinstall.sh
          root@raspberrypi:/# which iobroker
          /usr/bin/iobroker
          root@raspberrypi:/# find / -name iobroker
          /opt/iobroker
          /opt/iobroker/iobroker
          /usr/bin/iobroker
          root@raspberrypi:/#
          • Bluefox
            Bluefox last edited by
            @iobroker-6043:
            Hallo Rainer
            insgesamt 1360
            /usr/bin/iobroker
            /opt/iobroker
            /usr/bin/iobroker
            root@raspberrypi:/# `
            cd /opt/iobroker
            sudo chmod 777 * -R
            sudo npm install iobroker.js-controller --production
            • Homoran
              Das hattest du doch vor ein paar Tagen schon mal gepostet. Die Lösung wusste ich nicht mehr :oops:
              Ich habe nach "EACCESS" gesucht und nichts gefunden 😞
              Rainer
              • I
                Besten Dank, hat geklappt.
                cd /opt/iobroker
                sudo chmod 777 * -R
                sudo npm install iobroker.js-controller –production
                • P
                  pix last edited by
                  Kannst du schnell das im Topic das "HILFE !!" gegen "GELÖST" austauschen (ersten Post editieren), dann lösche ich diesen Eintrag wieder.
                  Pix
                  • S
                    Semenchkare last edited by
                    Hallo Rainer,
                    ja, ihabe Armbian, mit dem BananapiM2 hast nicht viele alternativen!
                    gelöst! Tatsächlich geht der Autostart mit der Node-Version 4.5.
                    Vielen Dank für Deine Mühe und dass Du geholfen hast!
                    Jetzt muss ich nur noch nach dem Flot-Update die Links Checken, denn meine Charts wollen nicht mehr…
                    Herzlichen Dank!
                    • S
                      Snuupy last edited by
                      Hallo zusammen, vielen Dank für diese Anleitung, das hat bei mir aber irgendwie immer noch nicht funktioniert.
                      Ich probiere nun schon mehrere Stunden daran herum, und ich bekomme die Installation einfach nicht sauber hin.
                      Mein Verdacht: defekte SD-Karte! Alles andere funktioniert sauber, nur bei der Installation von iobroker passieren komische Dinge. Ich habe iobroker jetzt auf einen USB-Stick installiert, das hat sofort funktioniert. Leider geht auch hier der Autostart nicht - das war das ursprüngliche Problem, welchem ich nachgegangen bin… Das muss ich mir nochmal ansehen.
                      • ruhr70
                        ruhr70 last edited by
                        @Snuupy:
                        Mein Verdacht: defekte SD-Karte! Alles andere funktioniert sauber, nur bei der Installation von iobroker passieren komische Dinge. Ich habe iobroker jetzt auf einen USB-Stick installiert, das hat sofort funktioniert. Leider geht auch hier der Autostart nicht - das war das ursprüngliche Problem, welchem ich nachgegangen bin… Das muss ich mir nochmal ansehen. `
                        Schon einmal prima, dass Deine aktuelle Installation funktioniert!
                        Willkommen im Forum und viel Spaß mit ioBroker.
                        Zu Deinem Post. Der Thread ist als gelöst markiert. Bitte nicht wundern, wenn über Deinen Post dann nur wenige stolpern und damit kaum Antworten zu erwarten sind.
                        Ich kann bestätigen, dass es mit der aktuellen Version ein Problem mit dem Autostart gibt. Voran das liegt…? (ioBroker, node.js Version, npm Version, ...?).
                        Hier findest Du ein paar Lösungen/Workarounds dazu:
                        http://forum.iobroker.net/viewtopic.php?f=17&t=10154
                        • C
                          C1500 last edited by
                          Servus
                          musste heute feststellen das mein ioBroker-Pi nicht mehr läuft.
                          Die Fehlermeldungen führten mich zu diesem Threat.
                          Doch leider hilft mir die Anleitung von Bluefox nicht weiter.
                          Es kommt folgende Fehlermeldung:
                          pi@ioBroker-Pi3:/opt/iobroker $ sudo npm install iobroker.js-controller --production
                          npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
                          npm ERR! path /opt/iobroker/node_modules/npm/node_modules/ansistyles
                          npm ERR! code ENOENT
                          npm ERR! errno -2
                          npm ERR! syscall rename
                          npm ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/npm/node_modules/ansistyles' -> '/opt/iobroker/node_modules/npm/node_modules/.ansistyles.DELETE'
                          npm ERR! enoent This is related to npm not being able to find a file.
                          npm ERR! enoent
                          npm ERR!     /root/.npm/_logs/2018-02-02T19_40_55_092Z-debug.log
                          node -v bringt sagt mir v9.4.0
                          Ich hoffe ihr habt noch einen Tip für mich.
                          Gruß Peer
                          • eric2905
                            eric2905 last edited by
                            Node v9 (ungerade Zahlen sind übrigens Entwickler-Versionen, die man nur nutzen sollte, „wenn man weiß, was man tut“) bringt npm v5 mit. Und damit gibt es bekanntermaßen Probleme mit ioBroker.
                            Downgrade auf Node 6 (bringt npm 3 oder 4 mit).
                            Dann weiter probieren.
                            Gruß,
                            Eric
                            Von unterwegs getippert
                            • C
                              Servus Eric
                              bin wieder einen Schritt weiter aber noch nicht am Ziel ;o)
                              pi@ioBroker-Pi3:/opt/iobroker $ node -v
                              v6.12.3
                              > iobroker.js-controller@1.2.3 install /opt/iobroker/node_modules/iobroker.js-controller
                              > node iobroker.js setup first
                              iobroker@1.0.0 /opt/iobroker
                              └─┬ iobroker.js-controller@1.2.3
                                └─┬ npm@2.15.12
                                  ├── ansistyles@0.1.3
                                  └── path-is-inside@1.0.2
                              npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/package.json'
                              npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.node-red/package.json'
                              Was nun?
                              Sorry bin nicht so fit in Linux…
                              • eric2905
                                Ich denke, ein
                                npm -v
                                bringt 2.15.x - zumindest laut dem Log-Auszug.
                                Du solltest auch npm updaten (v3 oder 4).
                                npm install -g npm@4
                                Gruß,
                                Eric
                                • C
                                  Servus
                                  Jetzt startet ioBroker zwar (ganz neue optik?)
                                  Aber alle Adapter außer Admin bleiben rot
                                  Help please ;o)
                                  • eric2905
                                    Das ist der Admin 3.
                                    Stehen Updates an?
                                    Gruß,
                                    Eric
                                    • C
                                      Servus Eric
                                      Kam erst jetzt zum weitermachen.
                                      Bisher kannte ich nur den Admin 3
                                      Hab ein "sudo iobroker update" probiert.
                                      Erster Eintrag dann direkt "Adapter "admin" : 2.0.9 , installed 3.1.7"
                                      Er nutzt also anscheinend den 2.0.9 obwohl der 3.1.7 installier ist.
                                      Im ioBroker selber steht rechts oben sogar das er 2.0.7 nutzt
                                      Sehr verwirrend
                                      Aber das könnte das Probelm mit den Adaptern erklären die nicht wie bisher normal funktoieren.
                                      Wie kann ich ioBroker denn davon überzeugen, das er die neue und schon installierten 3.1.7 nutzen soll?
                                      So, jetzt wird es noch schlimmer
                                      Ich hab versucht im über den Github ein Upgrade zu machen.
                                      Nach der Meldung "Erfolgreich" ging gar nix mehr.
                                      Jetzt steht da nur noch "cannot GET /"
                                      Hat noch jemand eine hilfreiche Idee?
                                      Gruß Peer
                                      Nachtrag:
                                      Das sind jetzt die aktuellen Versionen:
                                      pi@ioBroker-Pi3:/opt/iobroker $ iobroker admin -v
                                      3.1.10
                                      pi@ioBroker-Pi3:/opt/iobroker $ npm -v
                                      4.6.1
                                      v6.12.3
                                      Hier noch die Ausgabe von "sudo iobroker update"
                                      ! pi@ioBroker-Pi3:/opt/iobroker $ sudo iobroker update
                                      ! Used repository: default
                                      ! update done
                                      ! Adapter "admin" : 2.0.9 , installed 3.1.10
                                      ! Adapter "amazon-dash" : 0.2.7
                                      ! Adapter "artnet" : 0.1.6
                                      ! Adapter "b-control-em" : 0.2.1
                                      ! Adapter "benq" : 0.2.0
                                      ! Adapter "ble" : 0.3.4
                                      ! Adapter "bmw" : 1.3.1
                                      ! Adapter "botvac" : 1.0.0
                                      ! Adapter "broadlink2" : 1.8.0
                                      ! Adapter "chromecast" : 1.3.5
                                      ! Adapter "cloud" : 2.4.4 , installed 2.4.4
                                      ! Adapter "cul" : 0.2.2
                                      ! Adapter "daikin" : 0.2.3
                                      ! Adapter "daswetter" : 1.0.1
                                      ! Adapter "deconz" : 0.1.1
                                      ! Adapter "discovery" : 1.0.1
                                      ! Adapter "dwd" : 2.2.1 , installed 2.2.1
                                      ! Adapter "egigeozone" : 0.1.2
                                      ! Adapter "email" : 1.0.2
                                      ! Adapter "epson_stylus_px830": 0.0.2
                                      ! Adapter "fakeroku" : 0.2.1
                                      ! Adapter "feiertage" : 1.0.0
                                      ! Adapter "fhem" : 0.4.1
                                      ! Adapter "find-my-iphone": 0.2.15
                                      ! Adapter "firetv" : 0.0.27
                                      ! Adapter "flot" : 1.7.5 , installed 1.7.5
                                      ! Adapter "foobar2000" : 1.0.0
                                      ! Adapter "fritzbox" : 0.2.1
                                      ! Adapter "fritzdect" : 0.0.10
                                      ! Adapter "fronius" : 1.0.2
                                      ! Adapter "fullcalendar" : 0.2.4
                                      ! Adapter "g-homa" : 0.2.0
                                      ! Adapter "geofency" : 0.2.0
                                      ! Adapter "haier" : 1.0.0
                                      ! Adapter "harmony" : 0.9.0
                                      ! Adapter "hid" : 0.1.16
                                      ! Adapter "history" : 1.6.3 , installed 1.7.1
                                      ! Adapter "hm-rega" : 1.6.6 , installed 1.7.0
                                      ! Adapter "hm-rpc" : 1.4.14 , installed 1.5.1
                                      ! Adapter "hmm" : 1.0.1
                                      ! Adapter "homepilot" : 0.3.1
                                      ! Adapter "hue" : 0.6.9
                                      ! Adapter "ical" : 1.4.0 , installed 1.4.0
                                      ! Adapter "icons-addictive-flavour-png": 0.1.0
                                      ! Adapter "icons-fatcow-hosting": 0.1.0
                                      ! Adapter "icons-icons8" : 0.0.1
                                      ! Adapter "icons-material-png": 0.1.0
                                      ! Adapter "icons-material-svg": 0.1.0
                                      ! Adapter "icons-mfd-png" : 1.0.2
                                      ! Adapter "icons-mfd-svg" : 1.0.2
                                      ! Adapter "icons-open-icon-library-png": 0.1.3
                                      ! Adapter "icons-ultimate-png": 1.0.1
                                      ! Adapter "influxdb" : 1.4.5
                                      ! Adapter "innogy-smarthome": 0.1.17
                                      ! Adapter "javascript" : 3.5.1 , installed 3.6.3
                                      ! Controller "js-controller" : 1.2.3 , installed 1.2.3
                                      ! Adapter "js2fs" : 0.1.3
                                      ! Adapter "km200" : 1.1.6
                                      ! Adapter "knx" : 0.8.6
                                      ! Adapter "kodi" : 1.0.0
                                      ! Adapter "landroid" : 1.0.0
                                      ! Adapter "lgtv" : 1.0.2
                                      ! Adapter "lgtv-rs" : 0.0.4
                                      ! Adapter "lifx" : 0.0.4
                                      ! Adapter "lightify" : 0.2.16
                                      ! Adapter "loxone" : 0.4.0
                                      ! Adapter "maxcul" : 0.3.0
                                      ! Adapter "megad" : 1.2.1
                                      ! Adapter "megadd" : 0.2.0
                                      ! Adapter "megaesp" : 0.1.0 , installed 0.1.0
                                      ! Adapter "miele" : 0.1.5
                                      ! Adapter "mihome" : 1.0.4
                                      ! Adapter "mihome-plug" : 0.1.1
                                      ! Adapter "mihome-vacuum" : 0.6.0
                                      ! Adapter "mikrotik" : 1.0.0
                                      ! Adapter "milight" : 0.3.3 , installed 0.3.3
                                      ! Adapter "milight-smart-light": 0.0.5
                                      ! Adapter "mobile" : 0.4.11 , installed 0.4.11
                                      ! Adapter "modbus" : 1.0.3
                                      ! Adapter "mpd" : 1.0.0
                                      ! Adapter "mqtt" : 1.4.1 , installed 1.4.2
                                      ! Adapter "mqtt-client" : 1.0.1
                                      ! Adapter "mysensors" : 1.0.10
                                      ! Adapter "netatmo" : 1.3.0
                                      ! Adapter "node-red" : 1.4.1
                                      ! Adapter "noolite" : 0.0.1
                                      ! Adapter "nut" : 1.1.1
                                      ! Adapter "onkyo" : 0.2.1
                                      ! Adapter "openhab" : 0.2.1
                                      ! Adapter "opi" : 0.1.1
                                      ! Adapter "owfs" : 0.4.1
                                      ! Adapter "owntracks" : 0.2.0
                                      ! Adapter "panasonic-viera": 0.1.0
                                      ! Adapter "parser" : 1.0.1
                                      ! Adapter "paw" : 0.0.7 , installed 0.0.7
                                      ! Adapter "phantomjs" : 0.1.2
                                      ! Adapter "piface" : 1.0.0
                                      ! Adapter "pimatic" : 0.1.5
                                      ! Adapter "ping" : 1.3.2
                                      ! Adapter "proxy" : 0.2.0
                                      ! Adapter "pushbullet" : 0.0.11
                                      ! Adapter "pushover" : 1.0.4
                                      ! Adapter "pushsafer" : 0.1.7
                                      ! Adapter "radar" : 1.1.3
                                      ! Adapter "rflink" : 1.1.6
                                      ! Adapter "rickshaw" : 0.4.5
                                      ! Adapter "rpi2" : 0.3.2 , installed 0.3.2
                                      ! Adapter "rwe-smarthome" : 0.1.11
                                      ! Adapter "s7" : 1.1.3
                                      ! Adapter "samsung" : 0.2.9
                                      ! Adapter "sayit" : 1.6.6 , installed 1.6.6
                                      ! Adapter "sbfspot" : 2.0.1
                                      ! Adapter "scenes" : 1.0.2
                                      ! Adapter "simple-api" : 1.6.2 , installed 1.6.2
                                      ! Adapter "smartmeter" : 1.0.0
                                      ! Adapter "socketio" : 1.8.6 , installed 1.8.6
                                      ! Adapter "solarwetter" : 1.0.0
                                      ! Adapter "sonoff" : 1.0.0
                                      ! Adapter "sonos" : 1.6.2
                                      ! Adapter "sony-bravia" : 0.1.0
                                      ! Adapter "sql" : 1.5.6
                                      ! Adapter "squeezebox" : 0.2.1
                                      ! Adapter "starline" : 1.0.0
                                      ! Adapter "tankerkoenig" : 1.0.4 , installed 1.0.4
                                      ! Adapter "telegram" : 1.0.9 , installed 1.1.0
                                      ! Adapter "terminal" : 0.1.2
                                      ! Adapter "text2command" : 1.1.6
                                      ! Adapter "tr-064" : 0.4.14 , installed 0.4.17
                                      ! Adapter "tradfri" : 1.0.6
                                      ! Adapter "tvspielfilm" : 1.0.4
                                      ! Adapter "unifi" : 0.3.1
                                      ! Adapter "upnp" : 0.3.6 , installed 0.3.6
                                      ! Adapter "vcard" : 0.0.9
                                      ! Adapter "viessmann" : 0.2.6 , installed 0.4.0
                                      ! Adapter "vis" : 1.1.1 , installed 1.1.1
                                      ! Adapter "vis-bars" : 0.1.4
                                      ! Adapter "vis-canvas-gauges": 0.1.5 , installed 0.1.5
                                      ! Adapter "vis-colorpicker": 1.1.1 , installed 1.1.1
                                      ! Adapter "vis-fancyswitch": 1.1.0
                                      ! Adapter "vis-google-fonts": 0.1.0
                                      ! Adapter "vis-history" : 0.2.7 , installed 0.2.7
                                      ! Adapter "vis-hqwidgets" : 1.1.1 , installed 1.1.1
                                      ! Adapter "vis-jqui-mfd" : 1.0.9
                                      ! Adapter "vis-justgage" : 1.0.0
                                      ! Adapter "vis-keyboard" : 0.0.2
                                      ! Adapter "vis-lcars" : 1.0.4
                                      ! Adapter "vis-map" : 1.0.1
                                      ! Adapter "vis-metro" : 1.1.2
                                      ! Adapter "vis-players" : 0.1.5
                                      ! Adapter "vis-plumb" : 1.0.1 , installed 1.0.1
                                      ! Adapter "vis-rgraph" : 0.0.2
                                      ! Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7
                                      ! Adapter "vis-weather" : 1.1.2
                                      ! Adapter "weatherunderground": 1.1.1
                                      ! Adapter "web" : 2.1.9 , installed 2.1.9
                                      ! Adapter "wetty" : 0.1.1
                                      ! Adapter "wifilight" : 0.2.0
                                      ! Adapter "wm-bus" : 0.1.12
                                      ! Adapter "wolf" : 0.9.2
                                      ! Adapter "xs1" : 1.0.2
                                      ! Adapter "yahka" : 0.5.5
                                      ! Adapter "yamaha" : 0.3.18
                                      ! Adapter "yr" : 1.0.6
                                      ! Adapter "zwave" : 1.0.0
                                      Nachtrag 2:
                                      Komischerweise funktioniert die VIS und ich kann auch die eine MiLight Lampe die aktuell in der VIS ist schalten.
                                      Nur http://iobroker:8081 bringt den Fehler…
                                      • C
                                        Hi
                                        immerhin läuft jetzt eine Admin Instanz wieder
                                        Was mich total verwirrt ist die Angabe der Version von Admin.
                                        Installiert 3.1.11 Verfügbar 2.0.9 und rechts oben dann ioBroker.admin 2.0.7
                                        Hier ein Screenshot:
                                        Ist das die Alte oder neue Optik von ioBroker?
                                        Ich kannte bisher nur die andere ohne großes Logo links oben.
                                        Unter Instanzen bleiben so gut wie alle Instanzen rot.
                                        Ich hoffe mir kann jemand helfen.
                                        Gruß Peer
                                        • A
                                          Arnulf last edited by
                                          leider scheint diese Lösung wohl nicht mehr zu funktionieren.
                                          Eine andere Lösung
                                          cd /opt/iobroker
                                          sudo rm -rf node_modules
                                          curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
                                          Bring mir leider nur den Fehler, dass iobroker nicht über iobroker installiert werden kann.
                                          Obwohl ich der Meinung bin, dass mit den ersten Befehlen alles (bis auf die Daten) gelöscht werden würde
                                          Hat jemand ein erbarmen mit mir?
                                          stephan1827 1 Reply Last reply Reply Quote 0
                                          • stephan1827
                                            stephan1827 @Arnulf last edited by
                                            pi@raspberrypi:/opt/iobroker/node_modules $ sudo npm install iobroker.js-controller --production
                                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                            > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                            > node lib/preinstallCheck.js
                                            NPM version: 6.14.16
                                            > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
                                            Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                                            Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                                            Cannot delete file. Not critical: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
                                            Uncaught Rejection: Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                                at Object.mkdirSync (fs.js:921:3)
                                                at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:1054:16)
                                                at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:571:23)
                                                at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5)
                                                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                                                at Module._compile (internal/modules/cjs/loader.js:999:30)
                                                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                                                at Module.load (internal/modules/cjs/loader.js:863:32)
                                                at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                                                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                                            npm ERR! errno 6
                                            npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
                                            npm ERR! Exit status 6
                                            npm ERR!
                                            npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
                                            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                            npm ERR!     /root/.npm/_logs/2022-04-29T04_58_56_926Z-debug.log
                                            Bei mir startet iobroker ebenfalls nicht mehr. Ich habe versucht js neu zu installieren aber bekomme eine Fehlermeldung. Der Ordner /opt/iobroker/node_modules/iobroker.js-controller existiert nicht. Hat jemand noch eine Idee?
                                            Stephan
                                            mikeal created this issue in request/request
                                            open Request’s Past, Present and Future #3142
                                            1.0k
                                            32.3k
                                            81.0k
                                            39
                                            44462
