Unklare Fehlermeldung
Ich bekommen alle 2-3 Tage folgende Fehlermeldung und habe keine Idee, was ich dagegen machen könnte.
Hat jemand einen Tip für mich?
host.raspberrypi 2018-06-20 15:35:59.664 error instance system.adapter.javascript.0 terminated with code 0 (OK) Caught 2018-06-20 15:35:59.664 error by controller[1]: port: '8087' } Caught 2018-06-20 15:35:59.664 error by controller[1]: host: 'undefined', Caught 2018-06-20 15:35:59.663 error by controller[1]: hostname: 'undefined', Caught 2018-06-20 15:35:59.663 error by controller[1]: syscall: 'getaddrinfo', Caught 2018-06-20 15:35:59.663 error by controller[1]: errno: 'ENOTFOUND', Caught 2018-06-20 15:35:59.663 error by controller[1]: code: 'ENOTFOUND', Caught 2018-06-20 15:35:59.663 error by controller[1]: at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26) Caught 2018-06-20 15:35:59.663 error by controller[1]: at errnoException (dns.js:28:10) Caught 2018-06-20 15:35:59.662 error by controller[1]: { Error: getaddrinfo ENOTFOUND undefined undefined:8087 Caught 2018-06-20 15:35:59.662 error by controller[0]: port: '8087' } Caught 2018-06-20 15:35:59.662 error by controller[0]: host: 'undefined', Caught 2018-06-20 15:35:59.661 error by controller[0]: hostname: 'undefined', Caught 2018-06-20 15:35:59.660 error by controller[0]: syscall: 'getaddrinfo', Caught 2018-06-20 15:35:59.660 error by controller[0]: errno: 'ENOTFOUND', Caught 2018-06-20 15:35:59.660 error by controller[0]: code: 'ENOTFOUND', Caught 2018-06-20 15:35:59.659 error by controller[0]: at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26) Caught 2018-06-20 15:35:59.658 error by controller[0]: at errnoException (dns.js:28:10) Caught 2018-06-20 15:35:59.649 error by controller[0]: { Error: getaddrinfo ENOTFOUND undefined undefined:8087 javascript.0 2018-06-20 15:35:59.572 error uncaught exception: getaddrinfo ENOTFOUND undefined undefined:8087
Scheinbar macht eines deiner JavaScript Skripte einen DNS lookup oder sowas und der schlägt fehl. Ein Fehler den du in deinem Skript abfangen solltest.
Muss nicht zwangsläufig ein DNS Lookup sein. HTTP requests (z.B. mit dem "request"-Modul) greifen intern darauf zurück.
Hmmm….
sieht wie schon beschrieben nach einem DNS Fehler aus.
Wenn ein dedizierter DNS Server hier verwendet wird, sollte der Endknoten auch in der Reverse Lookup Zone sein.
UX Systeme sind das etwas empfindlich.
Wäre hilfreich zu wissen ob das Script die IP Adresse, den Netbios oder den FQDN des Endknotens verwendet....
Bester Test einfach vom Host wo IoBroker läuft ein Ping und Nslookup auf das Ziel zu machen.
My 2 Cents
Equilora aka Harald
Hat das was mit Amazon Dash-Buttons zu tun?
Ich mache explizt keinen DNS Lookup.
Aber vielleicht liegt es an dem Zugriff auf eine Website via HTTP, die ich anschließend parse.
Danke fürs Feedback.
Ich habe noch eine andere Fehlermeldung, die ich zwar dem Telegram Adapter zuordnen kann, bei der ich aber auch keine Idee habe, was ich tun kann.
telegram.0 2018-06-21 03:36:15.522 error telegram.0 2018-06-21 03:36:15.522 error telegram.0 2018-06-21 03:36:15.522 error * * * <center>nginx/1.12.2</center> telegram.0 2018-06-21 03:36:15.522 error <center> # 502 Bad Gateway </center> telegram.0 2018-06-21 03:36:15.522 error telegram.0 2018-06-21 03:36:15.522 error <title>502 Bad Gateway</title> telegram.0 2018-06-21 03:36:15.522 error polling_error:EPARSE, EPARSE: Error parsing response:
DIese Fehlermeldung kommt immer einmal am Tag in der Nacht.
