Sonos Cover keine Anzeige in IOBroker App
ich habe mal wieder ein Problem mit dem ich nicht weiterkomme.
Ich versuche gerade in VIS anzeigen zu lassen welcher Radiosender oder welches Album gerade über Sonos wiedergegeben wird.
Ich habe hier hierfür folgendes Widgets verwendet "basic -String img src"
[{"tpl":"tplValueStringImg","data":{"oid":"sonos.0.root.192_168_178_26.current_cover","g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"2000","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","visibility-oid":""},"style":{"left":"281px","top":"287px","width":"225px","height":"231px","background":""},"widgetSet":"basic"}]
über die Normal IP Adresse am Laptop funktioniert es ohne Probleme das Senderlogo wird mir schön angezeigt.
Leider bekomme ich über die IoBroker App am Wandtablet oder am Handy nur ein Platzhalter ohne Icon angezeigt. Was muss ich ändern, damit auch über die App das richtige Senderlogo angezeigt wird?
Vielen Dank für eure Hilfe
Gruß Daniel
Stell mal die Update Zeit auf "0"
Stell mal die Update Zeit auf "0" `
Vielen Dank für die Antwort.
Ich habe es mal probiert die Update Zeit auf 0 zu stellen. Jedoch leider ohne Erfolg.
Steht die Zeit auf 0 wird auch das Cover im Webbrowser beim ändern des Radiosenders oder beim wechsel zu einem änderen Interpreten nicht mehr geändert.
Grüße Daniel
Willst du mal mein Widget versuchen?
Ich habe zwar kein Sonos aber vielleicht klappt es ja.
[{"tpl":"tplValueStringImg","data":{"oid":"musiccast.0.WX-030_00677AD3.netusb.albumarturl","g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"net_radio","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-oid":"musiccast.0.WX-030_00677AD3.netusb.input"},"style":{"left":"79px","top":"255px","height":"250px","width":"250px","border-radius":""},"widgetSet":"basic"}]
`Vielen Dank für deine Nachricht.
Leider ergibt sich hier kein Erfolg!
Ich habe mal ein Bild angehängt wie es bei Aufrufen über die App aussieht!
2797_screenshot_20180201-181906.png -
Hm,
Wenn ich dein WIdget importiere und als Quelle meinen Yamaha WX-030 eintrage bekomme ich ein Bild wenn ich die Update Zeit auf „0“ stelle.
Könnte also ein lokales Problem bei dir oder von deiner Installation sein.
Ich hatte das mit dem Albumcover oder Senderlogo auch mal, da lag es an der WLAN Verbindung zum Yamaha WX-030. Konnte das Teil zwar Steuern und alles aber das Bild wurde nicht übertragen.
Das ging erst nachdem ich die Netzwerk Einstellungen zurückgesetzt und neu gemacht hatte.
Kannst du mal versuchen ob du den Sonos per Ping erreichen kannst?
Hast du den link mal auf dem Tablet in einem Browser eingegeben und geschaut ob das Bild kommt oder nur am PC?
Hm,
Hast du den link mal auf dem Tablet in einem Browser eingegeben und geschaut ob das Bild kommt oder nur am PC? `
Sonos kann ich über Ping ohne Probleme erreichen.
Wenn ich die Adresse vom Handy bzw. Tab. Browser aufrufe, werden mir die Logos angezeigt. (Siehe Bild)
Nur über die App will es nicht klappen. :?
2797_screenshot_2.png -
VIS oder App?
Was meinst du jetzt genau?
VIS oder App?
Was meinst du jetzt genau? `
in VIS wird mir alles ohne Probleme angezeigt egal ob über PC oder Tab Browser.
Mir geht es nur um die App! Hier bekomme ich es nicht zum laufen.
Welche App ?
Welche App ?
Gesendet von iPhone mit Tapatalk Pro `
Dies App
Ok. Kann ich leider mangels Android nicht testen.
Dann hätte ich das vorher falsch verstanden.
Sorry!
Ja bei mir läuft es jetzt ohne Probleme.
Bin leider gerade nur Mobil in Hamburg unterwegs.
Wenn ich wieder an den Rechner komme, stelle ich meine Lösung hier ein.
LG Daniel
Das wäre perfekt !!
Gute Reise noch !!
Hier der gewünschte Weg, der bei mir zum Erfolg geführt hat.
Ich stelle Dir mal mein verwendetes Witget ein.
Du musst hier nur noch deine IP Adressen abändern.
Bei mir wird das Widget bei keiner Wiedergabe automatisch ausgeblendet. Wenn Du dies nicht möchtest, einfach den Eintrag unter Sichtbarkeit entfernen.
[{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"1000","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"[http://192.168.178.22:8082/state/sonos. … et](http://192.168.178.22:8082/state/sonos.0.root.192_168_178_26.cover.png%22,%22refreshOnViewChange%22:true,%22refreshOnWakeUp%22:true,%22visibility-oid%22:%22sonos.0.root.192_168_178_26.state_simple%22%7D,%22style%22:%7B%22left%22:%2236px%22,%22top%22:%22110px%22,%22width%22:%22225px%22,%22height%22:%22225px%22,%22background%22:%22#ffffff%22,%22z-index%22:3%7D,%22widgetSet%22:%22basic)"}]
Ich hoffe Du kommst hiermit auch zum Erfolg. bei Fragen helfe ich natürlich gern weiter.
Gruß Daniel
@Daniel81 Bekomme es einfach nicht dargestellt. Wenn ich das Widget importieren will komm eine Fehlermeldung.
Invalid JSON SyntaxError: Unexpected token ! in JSON at position 0
