SQL-Fehlermeldung bei Neustart "Duplicate entry"
Hi zusammen,
Ich hab auf meinem ProxMox eine VM für ioBroker und eine wo MariaDB 10 drauf läuft.
Wenn ich den NUC mal neustarte dann erhalte ich im log massig an solchen Fehlermeldungen.
2018-08-07 00:02:06.893 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(67, 1533592926847, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '67-1533592926847' for key 'PRIMARY' 2018-08-07 00:02:06.919 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(67, 1533592926848, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '67-1533592926848' for key 'PRIMARY' 2018-08-07 00:02:06.934 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(65, 1533592926850, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '65-1533592926850' for key 'PRIMARY' 2018-08-07 00:02:06.934 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(65, 1533592926849, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '65-1533592926849' for key 'PRIMARY' 2018-08-07 00:02:06.935 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(65, 1533592926849, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '65-1533592926849' for key 'PRIMARY' 2018-08-07 00:02:06.946 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(66, 1533592926860, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '66-1533592926860' for key 'PRIMARY' 2018-08-07 00:02:06.952 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(66, 1533592926861, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '66-1533592926861' for key 'PRIMARY' 2018-08-07 00:02:06.953 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(65, 1533592926850, 19, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '65-1533592926850' for key 'PRIMARY' 2018-08-07 00:02:06.954 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(64, 1533592926863, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '64-1533592926863' for key 'PRIMARY' 2018-08-07 00:02:06.955 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(64, 1533592926862, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '64-1533592926862' for key 'PRIMARY' 2018-08-07 00:02:06.956 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(64, 1533592926862, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '64-1533592926862' for key 'PRIMARY' 2018-08-07 00:02:06.961 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(64, 1533592926863, 58.63, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '64-1533592926863' for key 'PRIMARY'
Proxmox ist so eingestellt das zuerst die VM mit SQL gestartet wird und drei Minuten Später die VM für iobroker.
Weiß jemand wieso diese Fehlermeldungen mit duplicate auflaufen?
Oder soll ich die MariaDB lieber auf der gleichen VM laufen lassen wie ioBroker?
Was meint ihr?
Johnny
Der Fehler kommt weil (warum auch immer) er für eine ID und einen Timestamp mehrfach Werte loggen will … Man müsste jetzt rausfinden warum das passiert ...
hmmm…das ist jetzt ne gute Frage warum er das machen will.
Wie würde ich denn das am besten rausbekommen?
Johnny
Instanz mal auf Loglevel Debug stellen und Log posten
so, hier mal ein auszug aus m log
sql.0 2018-08-07 16:04:06.630 debug SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.Temp-Core0'; sql.0 2018-08-07 16:04:06.630 debug Type (from State) for javascript.0.IntelNUC.Temp-Core0: 0 sql.0 2018-08-07 16:04:06.616 debug Type set in Def for javascript.0.IntelNUC.Temp-Core0: undefined sql.0 2018-08-07 16:04:06.616 debug Type (from Obj) for javascript.0.IntelNUC.Temp-Core0: undefined sql.0 2018-08-07 16:04:06.616 debug mixed / undefined / {"name":"Systemtemperatur Core-0","unit":"°C","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":" sql.0 2018-08-07 16:04:06.616 debug Type set in Def for javascript.0.IntelNUC.Temp-Core0: undefined sql.0 2018-08-07 16:04:06.616 debug Type (from Obj) for javascript.0.IntelNUC.Temp-Core0: undefined sql.0 2018-08-07 16:04:06.616 debug mixed / undefined / {"name":"Systemtemperatur Core-0","unit":"°C","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":" sql.0 2018-08-07 16:04:06.614 debug Type set in Def for javascript.0.IntelNUC.Temp-Core0: false sql.0 2018-08-07 16:04:06.614 debug Datatype javascript.0.IntelNUC.Temp-Core0: Currently: number, StorageType: false sql.0 2018-08-07 16:04:06.535 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641391, 0.22, 0, 7, 0); sql.0 2018-08-07 16:04:06.535 info changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load15Min sql.0 2018-08-07 16:04:06.528 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '303-1533650641389' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.525 error Cannot delete DELETE FROM `iobroker`.undefined WHERE id=303 AND ts < 1530972240511;: Error: ER_NO_SUCH_TABLE: Table 'iobroker.undefined' doesn't exist sql.0 2018-08-07 16:04:06.522 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641390, 0.22, 0, 7, 0); sql.0 2018-08-07 16:04:06.522 debug Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0 sql.0 2018-08-07 16:04:06.522 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.522 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.522 debug mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes sql.0 2018-08-07 16:04:06.522 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0); sql.0 2018-08-07 16:04:06.522 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0 sql.0 2018-08-07 16:04:06.522 debug UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 303; sql.0 2018-08-07 16:04:06.521 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0 sql.0 2018-08-07 16:04:06.521 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641388, 0.22, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '303-1533650641388' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.521 debug DELETE FROM `iobroker`.undefined WHERE id=303 AND ts < 1530972240511; sql.0 2018-08-07 16:04:06.501 error Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641340' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.501 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '302-1533650641374' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.501 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.501 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.501 debug mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes sql.0 2018-08-07 16:04:06.501 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '302-1533650641373' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.501 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641388, 0.22, 0, 7, 0); sql.0 2018-08-07 16:04:06.501 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641389, 0.22, 0, 7, 0); sql.0 2018-08-07 16:04:06.501 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(303, 1533650641388, 0.22, 0, 7, 0); sql.0 2018-08-07 16:04:06.501 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641375, 0.17, 0, 7, 0); sql.0 2018-08-07 16:04:06.501 info changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load5Min sql.0 2018-08-07 16:04:06.501 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641355' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.501 debug DELETE FROM `iobroker`.ts_number WHERE id=302 AND ts < 1530972240481; sql.0 2018-08-07 16:04:06.501 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.501 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.501 debug mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes sql.0 2018-08-07 16:04:06.500 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641356, 0.12, 0, 7, 0); sql.0 2018-08-07 16:04:06.500 info changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.load1Min sql.0 2018-08-07 16:04:06.500 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0 sql.0 2018-08-07 16:04:06.500 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641354' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.447 debug INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0); sql.0 2018-08-07 16:04:06.447 info changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.StorageUsed sql.0 2018-08-07 16:04:06.447 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.447 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.447 debug mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes sql.0 2018-08-07 16:04:06.447 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0); sql.0 2018-08-07 16:04:06.447 debug Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0 sql.0 2018-08-07 16:04:06.447 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.447 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.447 debug mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.447 error Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641339' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.447 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641355' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.447 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '301-1533650641354' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.447 debug DELETE FROM `iobroker`.ts_number WHERE id=301 AND ts < 1530972240424; sql.0 2018-08-07 16:04:06.447 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0 sql.0 2018-08-07 16:04:06.447 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0); sql.0 2018-08-07 16:04:06.447 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0 sql.0 2018-08-07 16:04:06.447 debug SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.VM-ioBroker.load15Min'; sql.0 2018-08-07 16:04:06.447 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load15Min: 0 sql.0 2018-08-07 16:04:06.447 debug UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 302; sql.0 2018-08-07 16:04:06.446 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0 sql.0 2018-08-07 16:04:06.446 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0); sql.0 2018-08-07 16:04:06.446 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0 sql.0 2018-08-07 16:04:06.446 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641318, 27, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '299-1533650641318' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.446 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641374, 0.17, 0, 7, 0); sql.0 2018-08-07 16:04:06.446 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(302, 1533650641373, 0.17, 0, 7, 0); sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.446 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.446 debug mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.446 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.446 debug mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.446 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0); sql.0 2018-08-07 16:04:06.446 debug Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0 sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined sql.0 2018-08-07 16:04:06.446 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined sql.0 2018-08-07 16:04:06.446 debug mixed / undefined / {"name":"System-load 1-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.446 error Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641340' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.446 error Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '300-1533650641339' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.446 debug DELETE FROM `iobroker`.ts_string WHERE id=300 AND ts < 1530972240406; sql.0 2018-08-07 16:04:06.446 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0 sql.0 2018-08-07 16:04:06.446 debug UPDATE `iobroker`.datapoints SET type = 0 WHERE id = 301; sql.0 2018-08-07 16:04:06.446 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0 sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.446 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load15Min: undefined sql.0 2018-08-07 16:04:06.446 debug mixed / undefined / {"name":"System-load 15-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changes sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.446 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.446 debug mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined sql.0 2018-08-07 16:04:06.446 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined sql.0 2018-08-07 16:04:06.446 debug mixed / undefined / {"name":"System-load 1-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load15Min: false sql.0 2018-08-07 16:04:06.446 debug Datatype javascript.0.IntelNUC.VM-ioBroker.load15Min: Currently: number, StorageType: false sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.446 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.446 debug mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.446 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined sql.0 2018-08-07 16:04:06.445 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined sql.0 2018-08-07 16:04:06.445 debug mixed / undefined / {"name":"System-load 1-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.445 debug INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641339, '2,8', 0, 7, 0); sql.0 2018-08-07 16:04:06.445 debug Type (from DB-Type) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: 1 sql.0 2018-08-07 16:04:06.445 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: undefined sql.0 2018-08-07 16:04:06.445 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: undefined sql.0 2018-08-07 16:04:06.445 debug mixed / undefined / {"name":"HDD-Speicher Verbraucht","unit":"GByte","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention sql.0 2018-08-07 16:04:06.445 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0); sql.0 2018-08-07 16:04:06.445 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0); sql.0 2018-08-07 16:04:06.445 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641355, 0.12, 0, 7, 0); sql.0 2018-08-07 16:04:06.445 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(301, 1533650641354, 0.12, 0, 7, 0); sql.0 2018-08-07 16:04:06.445 debug INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641318, 27, 0, 7, 0); sql.0 2018-08-07 16:04:06.445 info changed history configuration to pin detected datatype for javascript.0.IntelNUC.VM-ioBroker.StorageFree sql.0 2018-08-07 16:04:06.445 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(298, 1533650641285, 0.962891, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '298-1533650641285' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.445 debug SELECT id, type, name FROM `iobroker`.datapoints WHERE name='javascript.0.IntelNUC.VM-ioBroker.load5Min'; sql.0 2018-08-07 16:04:06.445 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load5Min: 0 sql.0 2018-08-07 16:04:06.445 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.load1Min: 0 sql.0 2018-08-07 16:04:06.445 debug UPDATE `iobroker`.datapoints SET type = 1 WHERE id = 300; sql.0 2018-08-07 16:04:06.445 debug Type (from State) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: 1 sql.0 2018-08-07 16:04:06.445 error Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(299, 1533650641317, 27, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '299-1533650641317' for key 'PRIMARY' sql.0 2018-08-07 16:04:06.445 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.445 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load5Min: undefined sql.0 2018-08-07 16:04:06.445 debug mixed / undefined / {"name":"System-load 5-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.445 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined sql.0 2018-08-07 16:04:06.445 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.load1Min: undefined sql.0 2018-08-07 16:04:06.445 debug mixed / undefined / {"name":"System-load 1-Min","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention":"2678400","changesR sql.0 2018-08-07 16:04:06.445 debug Type set in Def for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: undefined sql.0 2018-08-07 16:04:06.445 debug Type (from Obj) for javascript.0.IntelNUC.VM-ioBroker.StorageUsed: undefined sql.0 2018-08-07 16:04:06.445 debug mixed / undefined / {"name":"HDD-Speicher Verbraucht","unit":"GByte","role":"javascript","type":"mixed","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"5000","maxLength":10,"retention sql.0 2018-08-07 16:04:06.445 debug INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(300, 1533650641340, '2,8', 0, 7, 0);
Konntest du was erkennen?
Gruß Johnny
Auszug zu kurz. Am besten wirklich starten mit dem Start vom Adapter und dann bis der ganze initiale Kram durch ist.
Gesendet vom Handy …
So Apollon, hier der log ab dem Moment wo ich den sql Adapter auf debug gestellt habe, bis zu dem Zeitpunkt wo sich die sache mit den errors beruhigt hat.
Ich hoffe Du finest was raus!?!?
Johnny
Apollon hattest Du schon mal n Minütchen wo Du den log ansehen konntest?
Hast Du was entdeckt?
Johnny
Nope noch keine Zeit gehabt
Die Datenbank irrt hier nicht:
Zuerst:
INSERT INTO ts_number .... VALUES(107, 1533758018663, 22.98, 0, 7, 0); INSERT INTO ts_number .... VALUES(107, 1533758018664, 22.98, 0, 7, 0); INSERT INTO ts_number .... VALUES(107, 1533758018663, 22.98, 0, 7, 0); INSERT INTO ts_number .... VALUES(107, 1533758018664, 22.98, 0, 7, 0); INSERT INTO ts_number .... VALUES(107, 1533758018663, 22.98, 0, 7, 0); INSERT INTO ts_number .... VALUES(107, 1533758018664, 22.98, 0, 7, 0); INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0); INSERT INTO ts_number .... VALUES(168, 1533758018669, 22.98, 0, 5, 0); INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0); INSERT INTO ts_number .... VALUES(168, 1533758018669, 22.98, 0, 5, 0); INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0); INSERT INTO ts_number .... VALUES(168, 1533758018669, 22.98, 0, 5, 0);
dann kommt
changed history configuration to pin detected datatype ... ````für die verschiedenen Datenpunkte und dann gleich darauf:
DELETE FROM ts_number WHERE id=107 AND ts < 1502221980756;
INSERT INTO ts_number .... VALUES(107, 1533758018663, 22.98, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '107-1533758018663' for key 'PRIMARY'
INSERT INTO ts_number .... VALUES(107, 1533758018664, 22.98, 0, 7, 0);: Error: ER_DUP_ENTRY: Duplicate entry '107-1533758018664' for key 'PRIMARY'
INSERT INTO ts_number .... VALUES(168, 1533758018669, 22.98, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '168-1533758018669' for key 'PRIMARY'DELETE FROM ts_number WHERE id=168 AND ts < 1502221980762;
INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '168-1533758018668' for key 'PRIMARY'
INSERT INTO ts_number .... VALUES(168, 1533758018668, 22.98, 0, 5, 0);: Error: ER_DUP_ENTRY: Duplicate entry '168-1533758018668' for key 'PRIMARY'Hmm, das Delete ist um ein Jahr nach vorne verschoben … 08.08.2017 21:53:01 Kannst Du zur Vollständigkeit das JavaScript posten, das die Werte setzt?
Das ist ein Timing-Issue in der Initialisierung. Soweit bin ich schon …
Das Problem ist das Dinge noch nicht sauber initialisiert sind (sql calls sind halt asynchron) aber dann schnell Werte reinkommen. Und dann passieren komische Dinge ...
Mal warten bitte
So, bitte mal die 1.9.3 vom Github installieren, instanz neustarten (mit Debug an wieder) und mir in jedem Fall das Log schicken/posten.
jetzt besser?
Hab das update durchgeführt und den Adapter auf debugging gestellt. bis jetzt keine Verbesserung. Was mir aber aufgefallen ist, auf den ersten blick sind das alles Fehlermeldungen von Statusänderungen durch z.b. Arduinos die über simple api senden (http://<ip-adresse>:8082/set/javascript.0.xxxxxx)
hier mal das log-File
Johnny</ip-adresse>
javascript.0.IntelNUC.*
Das ist kein Javascript sondern ein bash-script auf dem Proxmox
Der vollständigkeithalber
#!/bin/sh ### Scriptname: sysinfo.sh ### Kurzbeschreibung: Ermitteln von Systemwerten InterlNUC root-System und überträgt an ioBroker ### Ersteller: Prinzeisenherz1 (Schneider Johnny) am 24072018 ### ######################################################### ### Lokale Variablen anlegen ioBrokerIP="192.168.178.2:8082" echo "ip "$ioBrokerIP URL_set_StorageTotal="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageTotal?value=" URL_set_StorageFree="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageFree?value=" URL_set_StorageUsed="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.StorageUsed?value=" URL_set_MemTotal="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemTotal?value=" URL_set_MemFree="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemFree?value=" URL_set_MemUsed="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.MemUsed?value=" URL_set_load1Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load1Min?value=" URL_set_load5Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load5Min?value=" URL_set_load15Min="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.load15Min?value=" URL_set_Uptime_day="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.UptimeDay?value=" URL_set_Uptime_hour="http://"$ioBrokerIP"/set/javascript.0.IntelNUC.VM-ioBroker.UptimeHour?value=" ### Gesamtspeicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen tmp2=$(free -m | awk '{print $2/1024}' | sed -n '2p' | sed 's/G//g') ### Freier Speicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen tmp3=$(free -m | awk '{print $4/1024}' | sed -n '2p' | sed 's/G//g') ### Belegter Speicherplatz Arbeitsspeicher in Gigabyte ermitteln und an die ioBroker übertragen tmp4=$(free -m | awk '{print $3/1024}' | sed -n '2p' | sed 's/G//g') ### Gesamtspeicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen tmp10=$(df -H | awk '{print $2}' | sed -n '4p' | sed 's/G//g') ### Freier Speicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen tmp11=$(df -H | awk '{print $4}' | sed -n '4p' | sed 's/G//g') ### Belegter Speicherplatz Datenträger in Gigabyte ermitteln und an die ioBroker übertragen tmp12=$(df -H | awk '{print $3}' | sed -n '4p' | sed 's/G//g') ### Systemload 1-Min ermitteln und an die ioBroker übertragen tmp5=$(cat /proc/loadavg | awk '{print $1}') ### Systemload 5-Min ermitteln und an die ioBroker übertragen tmp6=$(cat /proc/loadavg | awk '{print $2}') ### Systemload 15-Min ermitteln und an die ioBroker übertragen tmp7=$(cat /proc/loadavg | awk '{print $3}') ### UpTime in Tage und Stunden ermitteln und an ioBroker übertragen tmp8=$(cat /proc/uptime | awk '{printf"%.0f\n", $1}') ############################################################################################## days=$(($tmp8 / 86400 )) hours=$((($tmp8 / 3600) - (days * 24))) ############################################################################################## ####### Sende Gesamtspeicherplatz in Gigabyte an ioBroker url_tmp2=$URL_set_MemTotal$tmp2 echo "$url_tmp2" curl -s $url_tmp2 > /dev/null 2>&1 ################################################################################################ ####### Sende freien Speicherplatz in Gigabyte an ioBroker url_tmp3=$URL_set_MemFree$tmp3 echo "$url_tmp3" curl -s $url_tmp3 > /dev/null 2>&1 ################################################################################################ ####### Sende belegter Speicherplatz in Gigabyte an ioBroker url_tmp4=$URL_set_MemUsed$tmp4 echo "$url_tmp4" curl -s $url_tmp4 > /dev/null 2>&1 ################################################################################################ ####### Sende Gesamtspeicherplatz in Gigabyte an ioBroker url_tmp10=$URL_set_StorageTotal$tmp10 echo "$url_tmp10" curl -s $url_tmp10 > /dev/null 2>&1 ################################################################################################ ####### Sende freien Speicherplatz in Gigabyte an ioBroker url_tmp11=$URL_set_StorageFree$tmp11 echo "$url_tmp11" curl -s $url_tmp11 > /dev/null 2>&1 ################################################################################################ ####### Sende belegter Speicherplatz in Gigabyte an ioBroker url_tmp12=$URL_set_StorageUsed$tmp12 echo "$url_tmp12" curl -s $url_tmp12 > /dev/null 2>&1 ################################################################################################ ####### Sende freien Speicherplatz in Prozent an ioBroker url_tmp5=$URL_set_load1Min$tmp5 echo "$url_tmp5" curl -s $url_tmp5 > /dev/null 2>&1 ################################################################################################ ####### Sende belegter Speicherplatz in Prozent an ioBroker url_tmp6=$URL_set_load5Min$tmp6 echo "$url_tmp6" curl -s $url_tmp6 > /dev/null 2>&1 ################################################################################################ ####### Sende belegter Speicherplatz in Prozent an ioBroker url_tmp7=$URL_set_load15Min$tmp7 echo "$url_tmp7" curl -s $url_tmp7 > /dev/null 2>&1 ################################################################################################ ####### Sende UpTime an ioBroker url_days=$URL_set_Uptime_day$days echo "$url_days" curl -s $url_days > /dev/null 2>&1 ################################################################################################ url_hours=$URL_set_Uptime_hour$hours echo "$url_hours" curl -s $url_hours > /dev/null 2>&1 ################################################################################################
Johnny
Hab mal auf Version 1.6.1 downgegraded und da gibt es die Probleme nicht!
Johnny
Hi, sorry für die Wartezeit … bitte versuch die Github Version nochmal. Habe noch was gefunden.
Zuerst wurden alle Typen und Indizes aus der DB eingelesen nur um das dann grad wieder zu überschreiben
Wenn immer noch blöd dann bitte wieder log.
Das muss zu fixen sein
@PrinzEisenherz1: kamst Du schon zum testen der Github Version?
Habe ebenso das Problem mit Duplicate Entry mit meiner NAS SQL-DB.
Bin auch an der Lösung interessiert. Habe mir mal ein Lesezeichen gesetzt.
2018-08-20 06:25:28.243 - [31merror[39m: sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(1760, 1970000, false, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1760-1970000' for key 'PRIMARY'
oder möchtest du das ich das teste ? habe aber kein Testsystem, kann ich nur auf meinem Prod. System machen.
