Windows 10 Installation failed - nicht dringend
versuche gerade ein ioBroker Testsystem auf einem alten Windows Notebook zu installieren.
Bin nach der Anleitung
http://www.iobroker.net/docu/?page_id=2291&lang=de
vorgegangen
Auch
hat bei mir nicht funktioniert und wurde abgebrochen.
Die
c:\ioBroker\node_modules\iobroker.js-controller\node_modules\greenlock\node_modules\rsa-compat\node_modules\ursa-optional\npm-debug.log
beinhaltet:
0 info it worked if it ends with ok 1 verbose cli [ 'C:\\Program Files\\nodejs\\node.exe', 1 verbose cli 'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js', 1 verbose cli 'run', 1 verbose cli 'rebuild' ] 2 info using npm@2.15.9 3 info using node@v4.5.0 4 verbose run-script [ 'prerebuild', 'rebuild', 'postrebuild' ] 5 info prerebuild ursa-optional@0.9.8 6 info rebuild ursa-optional@0.9.8 7 verbose unsafe-perm in lifecycle true 8 info ursa-optional@0.9.8 Failed to exec rebuild script 9 verbose stack Error: ursa-optional@0.9.8 rebuild: `node-gyp rebuild` 9 verbose stack Exit status 1 9 verbose stack at EventEmitter. <anonymous>(C:\Program Files\nodejs\node_modules\npm\lib\utils\lifecycle.js:217:16) 9 verbose stack at emitTwo (events.js:87:13) 9 verbose stack at EventEmitter.emit (events.js:172:7) 9 verbose stack at ChildProcess. <anonymous>(C:\Program Files\nodejs\node_modules\npm\lib\utils\spawn.js:24:14) 9 verbose stack at emitTwo (events.js:87:13) 9 verbose stack at ChildProcess.emit (events.js:172:7) 9 verbose stack at maybeClose (internal/child_process.js:829:16) 9 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5) 10 verbose pkgid ursa-optional@0.9.8 11 verbose cwd C:\ioBroker\node_modules\iobroker.js-controller\node_modules\greenlock\node_modules\rsa-compat\node_modules\ursa-optional 12 error Windows_NT 10.0.17134 13 error argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "run" "rebuild" 14 error node v4.5.0 15 error npm v2.15.9 16 error code ELIFECYCLE 17 error ursa-optional@0.9.8 rebuild: `node-gyp rebuild` 17 error Exit status 1 18 error Failed at the ursa-optional@0.9.8 rebuild script 'node-gyp rebuild'. 18 error This is most likely a problem with the ursa-optional package, 18 error not with npm itself. 18 error Tell the author that this fails on your system: 18 error node-gyp rebuild 18 error You can get information on how to open an issue for this project with: 18 error npm bugs ursa-optional 18 error Or if that isn't available, you can get their info via: 18 error 18 error npm owner ls ursa-optional 18 error There is likely additional logging output above. 19 verbose exit [ 1, true ]</anonymous></anonymous>
Kann man daraus etwas erkennen?
Nicht dringend, soll nur ein Testsystem werden und die Windows updates haben auch reichlich Zeit gebraucht.
Nur für Dich und nur zum Test: Probiere die Installation nach https://iobroker.github.io/ioBroker.docs/#/install/windows. Wenn Du vorher Node.js installiert hattest in einer Version älter als 8.12.0, dann deinstalliere Node.js vorher über die Systemsteuerung -> Apps.
Hallo klassisch!
Mach es bitte genau nach der verlinkten Anleitung.
Feedback wäre toll.
Danke!
Rainer
Der Link oben ist nur für die Installation eines Testsystems gedacht! Ein Feedback hier wäre toll. Danke!
So, herzlichen Dank, es hat was funktioniert, wenn auch mit Fehlermeldungen.
Bin gerade bei der (Auto-)Installation über Admin-Browser.
Am Ende gab es eine Abweichung: ioBroker war am Ende der Installation nicht gestartet. Habs dann manuell aus der Kommandozeile heraus gestartet, wie ich es vom OPi her gewohnt bin.
Protokoll
Your environment has been set up for using Node.js 8.12.0 (x64) and npm.
! C:\Windows\System32>npm install --global windows-build-tools
! > windows-build-tools@4.0.0 postinstall C:\Users\JS\AppData\Roaming\npm\node_modules\windows-build-tools
node ./dist/index.js
! Downloading python-2.7.14.amd64.msi
[============================================>] 100.0% of 20.17 MB (2.99 MB/s)
Downloaded python-2.7.14.amd64.msi. Saved to C:\Users\JS.windows-build-tools\python-2.7.14.amd64.msi.
Downloading BuildTools_Full.exe
[============================================>] 100.0% of 3.29 MB (3.29 MB/s)
Downloaded BuildTools_Full.exe. Saved to C:\Users\JS.windows-build-tools\BuildTools_Full.exe.
! Starting installation...
Launched installers, now waiting for them to finish.
This will likely take some time - please be patient!
! Status from the installers:
---------- Visual Studio Build Tools ----------
Successfully installed Visual Studio Build Tools.
------------------- Python --------------------
Successfully installed Python 2.7
! Now configuring the Visual Studio Build Tools and Python...
! All done!
! + windows-build-tools@4.0.0
added 143 packages from 95 contributors in 305.183s
! C:\Windows\System32>md C:\iobroker
Ein Unterverzeichnis oder eine Datei mit dem Namen "C:\iobroker" existiert bereits.
! C:\Windows\System32>cd /d C:\iobroker
! C:\ioBroker>npm install https://github.com/ioBroker/ioBroker/tarball/master
! > unix-dgram@0.2.3 install C:\ioBroker\node_modules\unix-dgram
node-gyp rebuild
! C:\ioBroker\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu ermöglichen, müssen Sie den Schalter "/m" hinzufügen.
C:\ioBroker\node_modules\unix-dgram\build\unix_dgram.vcxproj(20,3): error MSB4019: Das importierte Projekt "C:\Microsof
t.Cpp.Default.props" wurde nicht gefunden. Vergewissern Sie sich, dass der Pfad in der <import>-Deklaration korrekt und
die Datei auf dem Datenträger vorhanden ist.
gyp ERR! build error
gyp ERR! stack Error:C:\Program Files (x86)\MSBuild\14.0\bin\msbuild.exe
failed with exit code: 1
gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
gyp ERR! stack at emitTwo (events.js:126:13)
gyp ERR! stack at ChildProcess.emit (events.js:214:7)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
gyp ERR! System Windows_NT 10.0.17134
gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
gyp ERR! cwd C:\ioBroker\node_modules\unix-dgram
gyp ERR! node -v v8.12.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
! > iobroker@1.3.0 install C:\ioBroker\node_modules\iobroker
node lib/checkVersions.js
! NPM version: 6.4.1
! > iobroker@1.3.0 postinstall C:\ioBroker\node_modules\iobroker
node lib/install.js
│ The iobroker files have been downloaded successfully. │
│ To complete the installation, you need to run │
│ npm i --production │
! npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules\unix-dgram):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install:node-gyp rebuild
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
! + iobroker@1.3.0
added 4 packages from 4 contributors, removed 9 packages, updated 1 package, moved 46 packages and audited 1731 packages in 148.259s
found 23 vulnerabilities (17 low, 6 high)
runnpm audit fix
to fix them, ornpm audit
for details
! C:\ioBroker>npm install --production
node-gyp rebuild
unix_dgram.cc
win_delay_load_hook.cc
..\src\unix_dgram.cc(9): fatal error C1083: Cannot open include file: 'unistd.h': No such file or directory [C:\ioBroke
r\node_modules\unix-dgram\build\unix_dgram.vcxproj]
gyp ERR! not ok
! > iobroker.inst@1.3.0 install C:\ioBroker
! > iobroker.inst@1.3.0 postinstall C:\ioBroker
node lib/install.js
! Write "iobroker start" to start the ioBroker
npm install node-windows@0.1.14 --production --save --prefix "C:/ioBroker"
ioBroker service installed. Write "serviceIoBroker start" to start the service and go to http://localhost:8081 to open the admin UI.
To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
! removed 5 packages and audited 1808 packages in 53.828s
runnpm audit fix
for details
! C:\ioBroker>iobroker status
! C:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js status
iobroker is not running
! C:\ioBroker>C:\iobroker
Der Befehl "C:\iobroker" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
! C:\ioBroker>npm install --global windows-build-tools
[> ] 0.0% (0 B/s)
[> ] 0.0% (0 B/s)
! Could not install Visual Studio Build Tools.
Please find more details in the log files, which can be found at
! All done!
updated 1 package in 72.267s
! C:\ioBroker>cd /d C:\iobroker
node-gyp rebuild
unix_dgram.cc
gyp ERR! not ok
node lib/install.js
! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules\unix-dgram):
! + iobroker@1.3.0
removed 5 packages, updated 1 package and audited 1808 packages in 24.188s
runnpm audit fix
for details
node-gyp rebuild
unix_dgram.cc
gyp ERR! not ok
node lib/install.js
! audited 1808 packages in 36.974s
runnpm audit fix
for details
! C:\ioBroker>iobroker start
! C:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js start
Starting iobroker controller daemon...
! C:\ioBroker>
iobroker is running
! C:\ioBroker></import> -
So sieht es jetzt aus.
Auf den ersten Blick wurden erstmal die HM-Datenpunkte übernommen. Dann wwurde noch ein dritter hm-rpc erzeugt, der auf mein ioBroker Hauptsystem verweist, aber dessen Instanz noch rot ist.
Was hat es damit auf sich?
Am Ende gab es eine Abweichung: ioBroker war am Ende der Installation nicht gestartet. `
Sehr interessant!Wie hast du installiert?
"Konsole" im Adminmodus ist klar.
Aber warst du vorher schon user mit Adminrechten, oder nicht?
Gruß Rainer
Dann wwurde noch ein dritter hm-rpc erzeugt, der auf mein ioBroker Hauptsystem verweist, `
Ich nutze Disvovery nicht, kann aber ein "falsch positiver" bei der Suche gewesen sein.Dazu gibt es ja die Möglichkeit, die gewünschten Instanzen zu wählen oder die ungewünschten abzuwählen.
Gruß Rainer
Aber warst du vorher schon user mit Adminrechten, oder nicht? ` Ja, das war ein und dieselbe Konsolensitzung.
Diese endigte so
C:\ioBroker>iobroker status C:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js status iobroker is not running
Da das nicht das richtige Ergebnis war, habe ich manuell nachgesetzt - in derselben Sitzung
C:\ioBroker>iobroker start C:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js start Starting iobroker controller daemon... C:\ioBroker> C:\ioBroker>iobroker status C:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js status iobroker is running
Ansonsten muss ich gestehen, dass ich nicht direkt vor dem Rechner saß, sondern über ultraVNC verbunden. Aber natürlich als Admin auf dem Adminkonto eingeloggt.
@Homoran:Ich nutze Disvovery nicht, kann aber ein "falsch positiver" bei der Suche gewesen sein.
Dazu gibt es ja die Möglichkeit, die gewünschten Instanzen zu wählen oder die ungewünschten abzuwählen. ` Ich nutze Discovery auch nicht wissentlich und willentlich (da müßte ich erst nachlesen was das ist) Aber nach dem Start von ioBroker über den Browser kam das automatisch und wollte etliche Einstellungen haben und hat dann angefangen zu suchen.
Soll ich diese überflüssige Instanz löschen oder ist das ein Brückenkopf zu einem Multihostsystem?
Was würde passieren, wenn ich jetzt das Backup aus meinem Produktivsystem einspielen würde?
Hab ich mich da falsch ausgedrückt oder verstehe ich dich jetzt nicht - sorry!
Ich versuche es nochmal.
Bist du an deinem Laptop an windows als admin oder als user angemeldet?
Laptop an - anmelden- ???
Wenn da kein anmelden kommt bist du eh admin
Ich nutze Discovery auch nicht wissentlich und willentlich `
Ja, das kommt automatisch.Wenn man es erkennt, kann man es abbrechen.
Die Systemeinstellungen und die Einstellungen für den Discovery Adapter gehen ineinander über.
Soll ich diese überflüssige Instanz löschen `
Kannst du ohne Probleme löschen.Wenn du eine weitere (cuxd, ip, rfd, wired) brauchst, kannst du sie neu anlegen
- Was würde passieren, wenn ich jetzt das Backup aus meinem Produktivsystem einspielen würde? `
Dann solltest du exakt den letzten Zustand haben, den du beim Backup hattest.
Gruß Rainer
Super, das Du die Anleitung probiert hast. Ich werde das mit dem automatischen Dienststart noch in der Doku berücksichtigen.
Wie fandest Du die Doku und das neue Installationsverfahren?
PS: Das mit Remote-Zugriff und Admin- oder User-Anmeldung sollte bei dieser Art der Installation egal sein.
Es wird Euch Computerexperten nicht freuen - und die Linuxgurus schon gar nicht, aber auf meinen eigenen Maschinen war und bin ich immer Admin - KISS. Mit einer Ausnahme vor Jahren, wo ich den guten Rat beherzigt und ein weiteres Konto eröffnet habe. War mir aber letztlich zu umständlich.
So, jetzt zur Anleitung:
Erst mal herzlichen Dank, daß es diese gibt und sie hat ja auch funktioniert, wenn auch mit vielen Errors, warnings etc. Das kenne ich ja schon vom OPi her und schreibe das mal den Linux- Computer-Profis zu, die alles immer ganz genau wissen wollen, was die Maschine alles macht und "probiert", bevor sie erfolgreich ist.
Irgendwie hatte ich aber den Eindruck, daß sich die Anleitung wiederholt.
Node.js war auf der Maschine und ich habe das wie im Post empfohlen, entfernt.
Dann habe ich den "Schnellstart" durchgeführt und dabei node-js installiert.
Nach dem Schnellstart war aber iobroker nicht running.
Und da ich der Anleitung genau folgen sollte, habe ich ihn dort auch nicht manuell gestartet, sondern mit "3. Installation von ioBroker" weiter gemacht.
Dann gab es eine erneute Installation von node, die ich dann in Form von "reparieren" (node war ja schon durch den "Schnellstart" vorhanden) durchgeführt habe.
Den rest habe ich dann stur C&P eingegeben und es lief ja, bis auf den berits erwähnten iobroker start.
Wahrscheinlich hätte auch der Schnellstart auf Anhieb funktioniert, wenn ich den ioBroker manuell gestartet hätte.
Also herzlichen Dank nochmals für die aktualisierte und funktionierende Anleitung, die sicherlich noch ihren We in die offizielle Doku findet.
Was ich noch nicht verstanden habe: Warum ist die Anleitung nur für Testsysteme gedacht? Passt bei mir zwar, aber man kann doch so auch ein Produktivsystem aufsetzen.
Ok, ich lerne, der „Schnellstart“ -Abschnitt in der Doku ging nach hinten los. [emoji24]
Das sollte eine Zusammenfassung aller nachfolgenden Schritte sein für jemanden, der die Installation mit den Detailerklärungen weiter unten schon einmal gemacht hat. Das hatte ich auch davor so geschrieben.
Wie kann ich das besser formulieren bzw. visualisieren?
Warum das nur für Testsysteme ist? Weil im Hintergrund ein neues ioBroker-Installationsverfahren genutzt wird, das sich noch in Entwicklung befindet. Es könnte momentan noch sein, dass bei damit aufgesetzten Systemen npm später Probleme macht (z.B. wenn die Installationsquelle entfernt wird).
Es wird Euch Computerexperten nicht freuen - und die Linuxgurus schon gar nicht, aber auf meinen eigenen Maschinen war und bin ich immer Admin - KISS. Mit einer Ausnahme vor Jahren, wo ich den guten Rat beherzigt und ein weiteres Konto eröffnet habe. War mir aber letztlich zu umständlich. `
Das machen sehr viele. Ich wollte nur den Status kennen. Alles gut!Irgendwie hatte ich aber den Eindruck, daß sich die Anleitung wiederholt. `
Nicht wirklich. Die Installation ist mehrschrttig.Erst werden Installationsdateien installiert, dann werden sie ausgeführt.
Zumindest hoffe ich dass es das ist was du meinst
Gruß Rainer
Ok, ich lerne, der „Schnellstart“ -Abschnitt in der Doku ging nach hinten los. [emoji24] `
Das würde ich so nicht sagen.
@Stabilostick:Das sollte eine Zusammenfassung aller nachfolgenden Schritte sein für jemanden, der die Installation mit den Detailerklärungen weiter unten schon einmal gemacht hat. Das hatte ich auch davor so geschrieben. ` Habe ich sogar gelesen. Aber am Ende des Schnellstartteils war einfach das gewünschte Ergebnis nicht da: ioBroker hätte laufen sollen, lief aber nicht. Also habe ich mit der "Vollversion" weiter gemacht.
@Stabilostick:Wie kann ich das besser formulieren bzw. visualisieren? ` Wahrscheinlich reicht es, ioBroker start noch mit in die Anleitung(en) aufzunehmen. Dann hätti ich wahrscheinlich schon nach dem Schnellstartteil aufgehört. So habe ich eben als dummer Tester weiter gemacht bis zum Ende der Anweisungen und erst dann davon abweichend ioBroker gestartet. Also eine winzige Kleinigkeit und die Sache läuft wohl rund.
@Stabilostick:Warum das nur für Testsysteme ist? Weil im Hintergrund ein neues ioBroker-Installationsverfahren genutzt wird, das sich noch in Entwicklung befindet. Es könnte momentan noch sein, dass bei damit aufgesetzten Systemen npm später Probleme macht (z.B. wenn die Installationsquelle entfernt wird). ` Prima, dann passt das ja zu meinem Testsystem. Möchte mal schauen, wie ioBroker mit Windows zu recht kommt und denke daran, am Ende der Zykluszeit meines OPi auf alte Notebooks und Windows umzusteigen.
Teststrategie habe ich aber noch keine. Wahrscheinlich werde ich Teile meines Produktivsystems doppeln und ein paar Adapter installieren. Sowas wie RFLink über USB könnte interessant sein. Zum einen weil es HW-abhängig ist zum anderen wei ich gerade viele 433MHz Sensoren habe.
Kann aber sicher auch den natürlichen Zustand als DAU annehmen und was testen wenn Ihr was braucht. Der alte Rechner läuft erst mal. Braucht zwar zur Zeit 25W, aber daran werden ich hoffentlich nicht verarmen. Einmal den Gefrierschrank aufgeräumt und enteist und das Geld sollte wieder drin sein…
Ich danke Dir für die Rückmeldung.
Die Doku ist jetzt offiziell: viewtopic.php?f=8&t=16933
Jede Anregung ist gerne gesehen. Mitmachen noch mehr.
Noch eine Anmerkung zur Installation. Sie scheint so noch nicht persistent zu sein. Nach einem Reboot ist ioBroker nicht mehr an Deck und muß wieder neu gestartet werden.
Was passiert eigentlich in den DOS-Boxen die es für jeden Adapter gibt?
Und nochwas: Beim Restart des Testsystems hat mein Produktivsystem (OPI) Logeintrge produziert:
hm-rpc.1 2018-09-17 06:39:14.363 error Error: timeout hm-rpc.1 2018-09-17 06:39:14.358 error binrpc -> setValue ["0","RSSI_PEER",-60] INTEGER hm-rpc.1 2018-09-17 06:38:30.247 error Error: timeout hm-rpc.1 2018-09-17 06:38:30.216 error binrpc -> setValue ["0","RSSI_PEER",-63] INTEGER
DOS-Boxen soll es keine geben. ioBroker wird als Dienst im Hintergrund gestartet. Ich habe die Doku aufgrund Deiner Anregung („is not running“) diesbezüglich inzwischen erweitert. Hast Du einen Dienst, der iobroker heißt (siehe z.B. Taskmanager -> Erweiterte Darstellung -> Dienste)? Wenn ja und Du DOS-Boxen hast, dann auf Kommandozeile „iobroker stop“ eingeben und stattdessen den Dienst starten.
Was hat der hm-rpc Adapter vom OPI mit Deinem Testsystem am Hut? Sind die beiden über Multihost gekoppelt?
DOS-Boxen soll es keine geben. `
-Bei mir gibt es die nach dem manuellen Start
@Stabilostick:ioBroker wird als Dienst im Hintergrund gestartet. `
-war bei mir nicht der Fall
@Stabilostick:Ich habe die Doku aufgrund Deiner Anregung („is not running“) diesbezüglich inzwischen erweitert. `
- Vielen Dank, ich sehe die Erweiterung allerdings nicht beim "Schnellstart". Danach war bei mir ioBroker ja auch nicht gestartet.
@Stabilostick:
Hast Du einen Dienst, der iobroker heißt (siehe z.B. Taskmanager -> Erweiterte Darstellung -> Dienste)? `
-habe ich , hatte aber den Status "gestoppt".
@Stabilostick:Wenn ja und Du DOS-Boxen hast, dann auf Kommandozeile „iobroker stop“ eingeben und stattdessen den Dienst starten. `
- habe den Dienst wie in der Anleitung ausgeführt mit
net start iobroker.exe
gestartet. Dann erscheint er auch in der Diensteliste des Taskmanagers als "Wird ausgeführt" und läuft auch.
Wird er jetzt nach jedem Neustart automatisch gestartet?
@Stabilostick:Was hat der hm-rpc Adapter vom OPI mit Deinem Testsystem am Hut? Sind die beiden über Multihost gekoppelt? `
- wissentlich und willentlich nichts (mehr). Die greifen halt auf dieselbe piVCCU zu. Und nach der Installation des Testsystems via "discovery" gab zwei zusätzliche hm-rpc, die auf mein ioBroker Produktivsystem verwiesen und Fehler im Log produzierten. Ich habe sie gelöscht.
Multihost habe ich zumindest nicht bewußt aufgesetzt. Müßte ich erst nachlesen wie das geht und welche Implikationen (oder Verwicklungen) das mit sich bringt.
Vielen Dank!
Der Dienst sollte schon vorher automatisch bei Systemstart gestartet worden sein. „iobroker stop/start“-Befehle solltest Du zukünftig durch die direkte Steuerung des iobroker-Dienstes ersetzen.
Starte Dein System gelegentlich durch und schaue, ob ioBroker automatisch gestartet wird.
