@wendy2702 said in Tote Hose nach Node js Update:
iobroker start
...Was soll ich sagen...
Ihr seid die geilsten!
Es läuft!
Vielen Dank.
pi@raspberrypi:~ $ cd /opt/iobroker
pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller
> iobroker.js-controller@3.0.20 preinstall /opt/iobroker/node_modules/iobroker.js-controller
> node lib/preinstallCheck.js
NPM version: 6.14.4
> unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
> node-gyp rebuild
make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
COPY Release/unix_dgram.node
make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
> ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
> node rebuild.js
> diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
> node-gyp rebuild
make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
CXX(target) Release/obj.target/diskusage/src/main.o
CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
SOLINK_MODULE(target) Release/obj.target/diskusage.node
COPY Release/diskusage.node
make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
> iobroker.js-controller@3.0.20 install /opt/iobroker/node_modules/iobroker.js-controller
> node iobroker.js setup first
object system.certificates updated
object 0_userdata.0.example_state created
object 0_userdata.0 created
object alias.0 created
ioBroker configuration updated
> acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
> node scripts/postinstall
Greenlock and ACME.js v3 are on the way!
Watch for updates at https://indiegogo.com/at/greenlock
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
+ iobroker.js-controller@3.0.20
added 231 packages from 218 contributors and audited 933 packages in 103.47s
6 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
│ New patch version of npm available! 6.14.4 → 6.14.5 │
│ Changelog: https://github.com/npm/cli/releases/tag/v6.14.5 │
│ Run npm install -g npm to update! │
pi@raspberrypi:/opt/iobroker $ iobroker start
Starting iobroker controller daemon...
iobroker controller daemon started. PID: 1184
