<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Kein Zugriff auf Admin & kein Upgrade auf 8.3.5]]></title><description><![CDATA[<p dir="auto">Ich wollte in der GUI den Admin Adapter von 8.2.0 auf 8.3.5 updaten.<br />
Wurde mit Code25 abgebrochen. Hab es dann in der Console mit "iob upgrade admin" versucht, bekomme aber  nur folgende Rückmeldung.</p>
<pre><code>Would you like to upgrade admin from @8.2.0 to @8.3.5 now? [(y)es, (n)o]: y
Update admin from @8.2.0 to @8.3.5
host.iobroker Adapter "system.adapter.admin.1" is stopped.
NPM version: 11.19.1
Installing iobroker.admin@8.3.5... (System call)
npm error Invalid Version:
npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-11-03T13_47_52_656Z-debug-0.log
host.iobroker Cannot install iobroker.admin@8.3.5: 1
</code></pre>
<p dir="auto">Und im Log kommt folgendes</p>
<pre><code>0 verbose cli /usr/bin/node /usr/bin/npm
1 info using npm@11.19.1
2 info using node@v24.22.2
3 silly config load:file:/usr/lib/node_modules/npm/npmrc
4 silly config load:file:/opt/iobroker/.npmrc
5 silly config load:file:/home/iobroker/.npmrc
6 silly config load:file:/usr/etc/npmrc
7 verbose title npm install iobroker.admin@8.3.5
8 verbose argv "install" "--save-exact" "--loglevel" "error" "iobroker.admin@8.3.5"
9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2026-11-03T13_47_52_656Z-
10 verbose logfile /home/iobroker/.npm/_logs/2026-11-03T13_47_52_656Z-debug-0.log
11 silly logfile start cleaning logs, removing 1 files
12 silly logfile done cleaning log files
13 silly packumentCache heap:2348810240 maxSize:587202560 maxEntrySize:293601280
14 silly idealTree buildDeps
15 silly fetch manifest iobroker.admin@8.3.5
16 silly packumentCache full:https://registry.npmjs.org/iobroker.admin cache-miss
17 http fetch GET 200 https://registry.npmjs.org/iobroker.admin 1148ms (cache revalidated)
18 silly packumentCache full:https://registry.npmjs.org/iobroker.admin set size:2080689 disposed:false
19 silly placeDep ROOT iobroker.admin@8.3.5 REPLACE for: iobroker.inst@1.1.2 want: 8.3.5
20 silly fetch manifest @iobroker/ai-core@^0.0.5
21 silly packumentCache full:https://registry.npmjs.org/@iobroker%2fai-core cache-miss
22 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fai-core 253ms (cache revalidated)
23 silly packumentCache full:https://registry.npmjs.org/@iobroker%2fai-core set size:28222 disposed:false
24 silly fetch manifest @aws-sdk/core@^3.978.7
25 silly packumentCache full:https://registry.npmjs.org/@aws-sdk%2fcore cache-miss
26 http cache https://registry.npmjs.org/@aws-sdk%2fcore 19ms (cache hit)
27 silly packumentCache full:https://registry.npmjs.org/@aws-sdk%2fcore set size:1078788 disposed:false
28 silly placeDep ROOT @aws-sdk/core@3.979.1 KEEP for: @aws-sdk/client-polly@3.1159.0 want: ^3.978.7
29 verbose stack TypeError: Invalid Version:
29 verbose stack     at SemVer (/usr/lib/node_modules/npm/node_modules/semver/classes/semver.js:56:13)
29 verbose stack     at compare (/usr/lib/node_modules/npm/node_modules/semver/functions/compare.js:5:32)
29 verbose stack     at Object.eq (/usr/lib/node_modules/npm/node_modules/semver/functions/eq.js:4:29)
29 verbose stack     at Node.canDedupe (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:1138:32)
29 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:427:14)
29 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:445:14)
29 verbose stack     at new PlaceDep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:220:12)
29 verbose stack     at #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1016:18)
29 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:180:7)
30 error Invalid Version:
31 silly unfinished npm timer reify 1793713673078
32 silly unfinished npm timer reify:loadTrees 1793713673086
33 silly unfinished npm timer idealTree:buildDeps 1793713675734
34 silly unfinished npm timer idealTree:node_modules/@aws-sdk/client-polly 1793713677211
35 verbose cwd /opt/iobroker
36 verbose os Linux 6.1.0-35-amd64
37 verbose node v24.22.2
38 verbose npm  v11.19.1
39 verbose exit 1
40 verbose code 1
</code></pre>
<p dir="auto">Ich kann seitdem auch nicht mehr auf den admin zugreifen...<br />
Was mich wundert ist, dass ein NPM Error mit invalid Version kommt. Im Log kommt mir Zeile 28 komisch vor.</p>
<ul>
<li>Adaptername: Admin</li>
<li>Link zu Adapterrepository: <a href="http://www.github.com" rel="nofollow ugc">www.github.com</a>...</li>
<li>Adapterversion:  8.2.0</li>
<li>js-controller Version:  7.2.5</li>
<li>Admin Version:  8.2.0</li>
<li>Hardwaresystem: Intel XEON CPU</li>
<li>Arbeitsspeicher:  12GB</li>
<li>Festplattenart: SSD</li>
<li>Betriebssystem:  Debian Trixie unter ESXI</li>
<li>Nodejs-Version:  24.22.2</li>
<li>NPM-Version:  11.19.1</li>
<li>Installationsart: Skript oder Manuell ?</li>
<li>Image,  Docker genutzt: Nein</li>
<li>Ort, Name der Imagedatei: ...</li>
</ul>
<p dir="auto">Linux User bitte hier den Output von <em>iob diag</em> einfügen.</p>
<pre><code>========== Start marking the full check here ===========
```bash
Script v.2026-10-01
*** BASE SYSTEM ***
Operating System: Debian GNU/Linux 13 (trixie)
 Static hostname: iobroker
       Icon name: computer-vm
         Chassis: vm 🖴
  Virtualization: vmware
          Kernel: Linux 6.1.0-35-amd64
    Architecture: x86-64
 Hardware Vendor: VMware, Inc.
  Hardware Model: VMware Virtual Platform
Firmware Version: 6.00
OS is similar to:
model name      : Intel(R) Xeon(R) CPU D-1521 @ 2.40GHz
Docker          : false
Virtualization  : vmware
Kernel          : x86_64
Userland        : 64bit
System was installed 427 days ago (on 2025-09-02).
Systemuptime and Load:
 15:03:19 up 21 min,  1 user,  load average: 0.77, 0.92, 0.90
CPU threads     : 6
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'trixie'!
*** TIME AND TIMEZONES ***
               Local time: Tue 2026-11-03 15:03:19 CET
           Universal time: Tue 2026-11-03 14:03:19 UTC
                 RTC time: Tue 2026-11-03 14:03:19
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
prozac
HOME=/home/prozac
GROUPS=prozac cdrom floppy sudo audio dip video plugdev netdev iobroker
js-controller is not running
*** DISPLAY-SERVER SETUP ***
Display-Server:         Unknown
Display-Manager:        Not found
Desktop:
Session:
Boot Target:            multi-user.target
*** MEMORY ***
Mem:             12G        655M         10G        3.3M        1.7G         11G
Swap:           1.1G          0B        1.1G
Total:           13G        655M         11G
Active iob-Instances:   1
        11960 M total memory
          625 M used memory
          697 M active memory
          663 M inactive memory
        10037 M free memory
          276 M buffer memory
         1351 M swap cache
         1046 M total swap
            0 M used swap
         1046 M free swap
top - 15:03:20 up 21 min,  1 user,  load average: 0.77, 0.92, 0.90
Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
%Cpu(s):  5.6 us, 11.1 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :  11960.3 total,  10035.6 free,    627.2 used,   1628.0 buff/cache
MiB Swap:   1047.0 total,   1047.0 free,      0.0 used.  11333.1 avail Mem
*** FAILED SERVICES ***
  UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
* apache2.service                      loaded failed failed The Apache HTTP Server
* emonhub.service                      loaded failed failed emonHub data multiplexer
* influxdb.service                     loaded failed failed InfluxDB is an open-source, distributed, time series database
* iobroker.service                     loaded failed failed ioBroker Server
* rc-local.service                     loaded failed failed /etc/rc.local Compatibility
* systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
6 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  5.9G     0  5.9G   0% /dev
tmpfs          tmpfs     1.2G  788K  1.2G   1% /run
/dev/sda1      ext4       30G   23G  5.4G  81% /
tmpfs          tmpfs     5.9G     0  5.9G   0% /dev/shm
tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/0
Messages concerning filesystems in dmesg (Last 15 lines only):
[Tue Nov  3 14:41:31 2026] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
[Tue Nov  3 14:41:32 2026] EXT4-fs (sda1): re-mounted. Quota mode: none.
[Tue Nov  3 14:41:35 2026] ext4 filesystem being remounted at /run/systemd/unit-root/usr/bin/redis-check-rdb supports timestamps until 2038-01-19 (0x7fffffff)
Show mounted filesystems:
TARGET SOURCE    FSTYPE OPTIONS
/      /dev/sda1 ext4   rw,relatime,errors=remount-ro
/var:
5.4G    /var/
3.1G    /var/log
2.8G    /var/log/journal/91a0581ee00d4f58892f6fddf1fb1989
1.7G    /var/cache
Archived and active journals take up 554.1M in the file system.
/opt/iobroker/backups:
265M    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
1.2G    /opt/iobroker/iobroker-data/
413M    /opt/iobroker/iobroker-data/backup-objects
322M    /opt/iobroker/iobroker-data/files
269M    /opt/iobroker/iobroker-data/history
51M     /opt/iobroker/iobroker-data/files/vis
53M     /opt/iobroker/iobroker-data/objects.jsonl
43M     /opt/iobroker/iobroker-data/states.jsonl
15M     /opt/iobroker/iobroker-data/test/objects.json.migrated
15M     /opt/iobroker/iobroker-data/test/objects.json.bak.migrated
11M     /opt/iobroker/iobroker-data/files/devices.admin/assets/index-h2WSMjGw.js
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
/dev/serial/by-id/usb-0658_0200-if00
*** ZigBee Settings ***
Zigbee Network Settings on your coordinator / in nvbackup are:
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
*** NodeJS-Installation ***
/usr/bin/nodejs         v24.22.2
/usr/bin/node           v24.22.2
/usr/bin/npm            11.19.1
/usr/bin/npx            11.19.1
✓ Node.js installation is correct
Recommended versions are nodejs  and npm
nodejs:
  Installed: 24.22.2-1nodesource1
  Candidate: 24.22.2-1nodesource1
  Version table:
 *** 24.22.2-1nodesource1 1001
        500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages
        100 /var/lib/dpkg/status
     24.22.1-1nodesource1 1001
     24.22.0-1nodesource1 1001
     24.21.0-1nodesource1 1001
     24.20.0-1nodesource1 1001
     24.19.0-1nodesource1 1001
     24.18.1-1nodesource1 1001
     24.18.0-1nodesource1 1001
     24.17.0-1nodesource1 1001
     24.16.0-1nodesource1 1001
     24.15.0-1nodesource1 1001
     24.14.1-1nodesource1 1001
     24.14.0-1nodesource1 1001
     24.13.1-1nodesource1 1001
     24.13.0-1nodesource1 1001
     24.12.0-1nodesource1 1001
     24.11.1-1nodesource1 1001
     24.11.0-1nodesource1 1001
     24.10.0-1nodesource1 1001
     24.9.0-1nodesource1 1001
     24.8.0-1nodesource1 1001
     24.7.0-1nodesource1 1001
     24.6.0-1nodesource1 1001
     24.5.0-1nodesource1 1001
     24.4.1-1nodesource1 1001
     24.4.0-1nodesource1 1001
     24.3.0-1nodesource1 1001
     24.1.0-1nodesource1 1001
     24.0.2-1nodesource1 1001
     24.0.1-1nodesource1 1001
     24.0.0-1nodesource1 1001
     20.19.2+dfsg-1+deb13u2 500
        500 http://deb.debian.org/debian trixie/main amd64 Packages
No problems detected
Errors in npm tree: 0
he state system.host.iobroker.versions.nodeNewestNext was not found!
The state system.host.iobroker.versions.npmNewestNext was not found!
No known Vulnerabilities detected!
*** ioBroker-Installation ***
ioBroker Status
iobroker is not running on this host.
Objects type: jsonl
States  type: jsonl
Hosts:
iobroker            iobroker (version: 7.2.5, hostname: iobroker      , alive, uptime: 878)
Core adapters versions
js-controller:  7.2.5
admin:          8.2.0
javascript:     10.4.4
nodejs modules from github:     0
Adapter State
  system.adapter.admin.1                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
  system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
  system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
  system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
  system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
  system.adapter.devices.0                : devices               : iobroker                                 - disabled
  system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
  system.adapter.e3oncan.0                : e3oncan               : iobroker                                 -  enabled
  system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
  system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
  system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 -  enabled
  system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
  system.adapter.go-e-charger.0           : go-e-charger          : iobroker                                 -  enabled
  system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
  system.adapter.hass.1                   : hass                  : iobroker                                 -  enabled, port: 8123
  system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
  system.adapter.history.0                : history               : iobroker                                 -  enabled
  system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
  system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
  system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
  system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
  system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
  system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
  system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
  system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
  system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
  system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
  system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
  system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1884
  system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
  system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
  system.adapter.open-meteo-weather.0     : open-meteo-weather    : iobroker                                 -  enabled
  system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
  system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
  system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
  system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
  system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
  system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
  system.adapter.roborock.1               : roborock              : iobroker                                 - disabled
  system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
  system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
  system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 10.0.100.100
  system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
  system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
  system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
  system.adapter.solarlog.0               : solarlog              : iobroker                                 -  enabled, port: 80
  system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 50000, bind: 10.0.100.100
  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
  system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
  system.adapter.unifi-protect.0          : unifi-protect         : iobroker                                 - disabled
  system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
  system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 - disabled
  system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
  system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
  system.adapter.worx.0                   : worx                  : iobroker                                 - disabled
  system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
  system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
  system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
  system.adapter.zwave2.0                 : zwave2                : iobroker                                 -  enabled
+ instance is alive
ioBroker-Repositories
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
│ (index) │ id                                      │ name                     │ version  │ upgrade policy │
│ 0       │ 'system.adapter.admin'                  │ 'admin'                  │ '8.2.0'  │ 'none'         │
│ 1       │ 'system.adapter.alexa2'                 │ 'alexa2'                 │ '3.28.3' │ 'none'         │
│ 2       │ 'system.adapter.alias-manager'          │ 'alias-manager'          │ '2.1.0'  │ 'none'         │
│ 3       │ 'system.adapter.backitup'               │ 'backitup'               │ '4.0.3'  │ 'none'         │
│ 4       │ 'system.adapter.device-reminder'        │ 'device-reminder'        │ '3.1.2'  │ 'none'         │
│ 5       │ 'system.adapter.devices'                │ 'devices'                │ '4.2.2'  │ 'none'         │
│ 6       │ 'system.adapter.discovery'              │ 'discovery'              │ '5.0.0'  │ 'none'         │
│ 7       │ 'system.adapter.e3oncan'                │ 'e3oncan'                │ '1.1.3'  │ 'none'         │
│ 8       │ 'system.adapter.echarts'                │ 'echarts'                │ '5.1.1'  │ 'none'         │
│ 9       │ 'system.adapter.energiefluss-erweitert' │ 'energiefluss-erweitert' │ '0.8.3'  │ 'none'         │
│ 10      │ 'system.adapter.feiertage'              │ 'feiertage'              │ '1.4.0'  │ 'none'         │
│ 11      │ 'system.adapter.go-e-charger'           │ 'go-e-charger'           │ '1.8.1'  │ 'none'         │
│ 12      │ 'system.adapter.harmony'                │ 'harmony'                │ '3.0.0'  │ 'none'         │
│ 13      │ 'system.adapter.hass'                   │ 'hass'                   │ '2.1.2'  │ 'none'         │
│ 14      │ 'system.adapter.hass-mqtt'              │ 'hass-mqtt'              │ '0.0.7'  │ 'none'         │
│ 15      │ 'system.adapter.heatingcontrol'         │ 'heatingcontrol'         │ '3.3.1'  │ 'none'         │
│ 16      │ 'system.adapter.history'                │ 'history'                │ '5.1.1'  │ 'none'         │
│ 17      │ 'system.adapter.homeconnect'            │ 'homeconnect'            │ '1.6.1'  │ 'none'         │
│ 18      │ 'system.adapter.hue'                    │ 'hue'                    │ '3.17.4' │ 'none'         │
│ 19      │ 'system.adapter.ical'                   │ 'ical'                   │ '1.21.2' │ 'none'         │
│ 20      │ 'system.adapter.icons-mfd-svg'          │ 'icons-mfd-svg'          │ '1.2.0'  │ 'none'         │
│ 21      │ 'system.adapter.influxdb'               │ 'influxdb'               │ '5.1.8'  │ 'none'         │
│ 22      │ 'system.adapter.iot'                    │ 'iot'                    │ '7.1.2'  │ 'none'         │
│ 23      │ 'system.adapter.javascript'             │ 'javascript'             │ '10.4.4' │ 'none'         │
│ 24      │ 'system.adapter.lgtv'                   │ 'lgtv'                   │ '3.0.5'  │ 'none'         │
│ 25      │ 'system.adapter.linkeddevices'          │ 'linkeddevices'          │ '1.5.5'  │ 'none'         │
│ 26      │ 'system.adapter.modbus'                 │ 'modbus'                 │ '9.2.1'  │ 'none'         │
│ 27      │ 'system.adapter.mqtt'                   │ 'mqtt'                   │ '6.1.4'  │ 'none'         │
│ 28      │ 'system.adapter.mqtt-client'            │ 'mqtt-client'            │ '4.1.0'  │ 'none'         │
│ 29      │ 'system.adapter.node-red'               │ 'node-red'               │ '6.0.7'  │ 'none'         │
│ 30      │ 'system.adapter.open-meteo-weather'     │ 'open-meteo-weather'     │ '3.1.4'  │ 'none'         │
│ 31      │ 'system.adapter.openweathermap'         │ 'openweathermap'         │ '2.0.2'  │ 'none'         │
│ 32      │ 'system.adapter.parser'                 │ 'parser'                 │ '4.0.1'  │ 'none'         │
│ 33      │ 'system.adapter.ping'                   │ 'ping'                   │ '3.1.4'  │ 'none'         │
│ 34      │ 'system.adapter.pushover'               │ 'pushover'               │ '6.1.0'  │ 'none'         │
│ 35      │ 'system.adapter.pvforecast'             │ 'pvforecast'             │ '6.2.0'  │ 'none'         │
│ 36      │ 'system.adapter.rickshaw'               │ 'rickshaw'               │ '1.0.0'  │ 'none'         │
│ 37      │ 'system.adapter.roborock'               │ 'roborock'               │ '0.7.4'  │ 'none'         │
│ 38      │ 'system.adapter.sayit'                  │ 'sayit'                  │ '5.3.2'  │ 'none'         │
│ 39      │ 'system.adapter.scenes'                 │ 'scenes'                 │ '5.1.0'  │ 'none'         │
│ 40      │ 'system.adapter.shelly'                 │ 'shelly'                 │ '12.0.0' │ 'none'         │
│ 41      │ 'system.adapter.shuttercontrol'         │ 'shuttercontrol'         │ '2.1.2'  │ 'none'         │
│ 42      │ 'system.adapter.simple-api'             │ 'simple-api'             │ '3.0.7'  │ 'none'         │
│ 43      │ 'system.adapter.snmp'                   │ 'snmp'                   │ '4.0.0'  │ 'none'         │
│ 44      │ 'system.adapter.socketio'               │ 'socketio'               │ '9.0.1'  │ 'none'         │
│ 45      │ 'system.adapter.solarlog'               │ 'solarlog'               │ '2.4.0'  │ 'none'         │
│ 46      │ 'system.adapter.sonoff'                 │ 'sonoff'                 │ '3.3.0'  │ 'none'         │
│ 47      │ 'system.adapter.sonos'                  │ 'sonos'                  │ '3.0.0'  │ 'none'         │
│ 48      │ 'system.adapter.sourceanalytix'         │ 'sourceanalytix'         │ '0.4.14' │ 'none'         │
│ 49      │ 'system.adapter.statistics'             │ 'statistics'             │ '5.0.0'  │ 'none'         │
│ 50      │ 'system.adapter.sunnyportal'            │ 'sunnyportal'            │ '0.1.5'  │ 'none'         │
│ 51      │ 'system.adapter.unifi'                  │ 'unifi'                  │ '1.0.2'  │ 'none'         │
│ 52      │ 'system.adapter.unifi-protect'          │ 'unifi-protect'          │ '1.0.1'  │ 'none'         │
│ 53      │ 'system.adapter.viessmannapi'           │ 'viessmannapi'           │ '2.4.3'  │ 'none'         │
│ 54      │ 'system.adapter.virtualpowermeter'      │ 'virtualpowermeter'      │ '1.5.0'  │ 'none'         │
│ 55      │ 'system.adapter.vis'                    │ 'vis'                    │ '1.5.6'  │ 'none'         │
│ 56      │ 'system.adapter.vis-bars'               │ 'vis-bars'               │ '0.1.4'  │ 'none'         │
│ 57      │ 'system.adapter.vis-colorpicker'        │ 'vis-colorpicker'        │ '2.1.0'  │ 'none'         │
│ 58      │ 'system.adapter.vis-fancyswitch'        │ 'vis-fancyswitch'        │ '1.1.0'  │ 'none'         │
│ 59      │ 'system.adapter.vis-history'            │ 'vis-history'            │ '1.0.0'  │ 'none'         │
│ 60      │ 'system.adapter.vis-jqui-mfd'           │ 'vis-jqui-mfd'           │ '1.1.3'  │ 'none'         │
│ 61      │ 'system.adapter.vis-justgage'           │ 'vis-justgage'           │ '2.1.7'  │ 'none'         │
│ 62      │ 'system.adapter.web'                    │ 'web'                    │ '8.0.0'  │ 'none'         │
│ 63      │ 'system.adapter.worx'                   │ 'worx'                   │ '3.3.0'  │ 'none'         │
│ 64      │ 'system.adapter.ws'                     │ 'ws'                     │ '4.1.0'  │ 'none'         │
│ 65      │ 'system.adapter.yahka'                  │ 'yahka'                  │ '1.1.6'  │ 'none'         │
│ 66      │ 'system.adapter.yamaha'                 │ 'yamaha'                 │ '0.5.4'  │ 'none'         │
│ 67      │ 'system.adapter.zigbee'                 │ 'zigbee'                 │ '1.10.3' │ 'none'         │
│ 68      │ 'system.adapter.zigbee2mqtt'            │ 'zigbee2mqtt'            │ '3.2.2'  │ 'none'         │
│ 69      │ 'system.adapter.zwave2'                 │ 'zwave2'                 │ '3.1.0'  │ 'none'         │
ioBroker-Adapter Versions and update status
Used repository: stable
Adapter    "admin"        : 8.3.5    , installed 8.2.0  [Updatable]
Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
Adapter    "alias-manager": 3.0.0    , installed 2.1.0  [Updatable]
Adapter    "backitup"     : 4.0.3    , installed 4.0.3
Adapter    "devices"      : 4.2.2    , installed 4.2.2
Adapter    "e3oncan"      : 1.2.0    , installed 1.1.3  [Updatable]
Adapter    "echarts"      : 5.1.1    , installed 5.1.1
Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.3
Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
Adapter    "go-e-charger" : 1.8.1    , installed 1.8.1
Adapter    "harmony"      : 3.0.0    , installed 3.0.0
Adapter    "hass"         : 2.1.2    , installed 2.1.2
Adapter    "heatingcontrol": 3.3.1   , installed 3.3.1
Adapter    "history"      : 5.1.1    , installed 5.1.1
Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
Adapter    "hue"          : 3.17.4   , installed 3.17.4
Adapter    "ical"         : 1.21.2   , installed 1.21.2
Adapter    "influxdb"     : 5.1.8    , installed 5.1.8
Adapter    "iot"          : 7.1.2    , installed 7.1.2
Adapter    "javascript"   : 10.4.4   , installed 10.4.4
Controller "js-controller": 7.2.5    , installed 7.2.5
Adapter    "lgtv"         : 3.0.5    , installed 3.0.5
Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
Adapter    "modbus"       : 9.2.1    , installed 9.2.1
Adapter    "mqtt"         : 8.1.2    , installed 6.1.4  [Updatable]
Adapter    "mqtt-client"  : 4.1.0    , installed 4.1.0
Adapter    "node-red"     : 6.0.7    , installed 6.0.7
Adapter    "open-meteo-weather": 3.1.4, installed 3.1.4
Adapter    "openweathermap": 2.0.2   , installed 2.0.2
Adapter    "parser"       : 4.0.1    , installed 4.0.1
Adapter    "ping"         : 3.1.4    , installed 3.1.4
Adapter    "pushover"     : 6.1.0    , installed 6.1.0
Adapter    "pvforecast"   : 6.2.0    , installed 6.2.0
Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
Adapter    "roborock"     : 0.7.4    , installed 0.7.4
Adapter    "sayit"        : 5.3.2    , installed 5.3.2
Adapter    "scenes"       : 5.1.0    , installed 5.1.0
Adapter    "shelly"       : 12.0.0   , installed 12.0.0
Adapter    "shuttercontrol": 2.1.2   , installed 2.1.2
Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
Adapter    "snmp"         : 4.0.0    , installed 4.0.0
Adapter    "socketio"     : 9.0.2    , installed 9.0.1  [Updatable]
Adapter    "solarlog"     : 2.4.0    , installed 2.4.0
Adapter    "sonoff"       : 5.1.1    , installed 3.3.0  [Updatable]
Adapter    "statistics"   : 5.0.0    , installed 5.0.0
Adapter    "unifi"        : 1.0.2    , installed 1.0.2
Adapter    "unifi-protect": 1.0.1    , installed 1.0.1
Adapter    "virtualpowermeter": 1.5.0, installed 1.5.0
Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
Adapter    "web"          : 8.0.0    , installed 8.0.0
Adapter    "worx"         : 3.3.0    , installed 3.3.0
Adapter    "ws"           : 4.1.0    , installed 4.1.0
Adapter    "yahka"        : 1.1.6    , installed 1.1.6
Adapter    "yamaha"       : 2.11.0   , installed 0.5.4  [Updatable]
Adapter    "zigbee"       : 3.5.5    , installed 1.10.3 [Updatable]
Adapter    "zigbee2mqtt"  : 3.2.2    , installed 3.2.2
Objects and States
Objects:        44971
States:         35153
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY DA61C26A0585BD3B
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY DA61C26A0585BD3B
W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY DA61C26A0585BD3B
W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY DA61C26A0585BD3B
W: Some index files failed to download. They have been ignored, or old ones used instead.
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://deb.debian.org/debian trixie-updates InRelease
Hit:3 https://deb.nodesource.com/node_24.x nodistro InRelease
Get:4 https://apt.syncthing.net syncthing InRelease [24.2 kB]
Get:5 https://repos.influxdata.com/debian bullseye InRelease [12.9 kB]
Get:6 https://repos.influxdata.com/debian stable InRelease [6922 B]
Err:5 https://repos.influxdata.com/debian bullseye InRelease
Err:6 https://repos.influxdata.com/debian stable InRelease
Fetched 24.2 kB in 3s (7158 B/s)
Reading package lists...
Pending systemupdates: 1
*** Listening Ports ***
Netid State  Recv-Q Send-Q                     Local Address:Port   Peer Address:PortProcess
udp   UNCONN 0      0                                0.0.0.0:1905        0.0.0.0:*    users:(("MainThread",pid=2391,fd=22))
udp   UNCONN 0      0                                0.0.0.0:43583       0.0.0.0:*    users:(("avahi-daemon",pid=693,fd=14))
udp   UNCONN 0      0                                0.0.0.0:mdns        0.0.0.0:*    users:(("avahi-daemon",pid=693,fd=12))
udp   UNCONN 0      0                                0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=675,fd=5),("systemd",pid=1,fd=123))
udp   UNCONN 0      0                           10.0.100.100:ntp         0.0.0.0:*    users:(("ntpd",pid=958,fd=19))
udp   UNCONN 0      0                              127.0.0.1:ntp         0.0.0.0:*    users:(("ntpd",pid=958,fd=18))
udp   UNCONN 0      0                                0.0.0.0:ntp         0.0.0.0:*    users:(("ntpd",pid=958,fd=17))
udp   UNCONN 0      0                                   [::]:46281          [::]:*    users:(("avahi-daemon",pid=693,fd=15))
udp   UNCONN 0      0                                   [::]:mdns           [::]:*    users:(("avahi-daemon",pid=693,fd=13))
udp   UNCONN 0      0                                   [::]:sunrpc         [::]:*    users:(("rpcbind",pid=675,fd=7),("systemd",pid=1,fd=125))
udp   UNCONN 0      0      [fe80::20c:29ff:fed0:2afe]%ens192:ntp            [::]:*    users:(("ntpd",pid=958,fd=22))
udp   UNCONN 0      0                                  [::1]:ntp            [::]:*    users:(("ntpd",pid=958,fd=20))
udp   UNCONN 0      0                                   [::]:ntp            [::]:*    users:(("ntpd",pid=958,fd=16))
tcp   LISTEN 0      4096                             0.0.0.0:http        0.0.0.0:*    users:(("lighttpd",pid=2161,fd=5))
tcp   LISTEN 0      4096                             0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=675,fd=4),("systemd",pid=1,fd=122))
tcp   LISTEN 0      128                              0.0.0.0:ssh         0.0.0.0:*    users:(("sshd",pid=969,fd=6))
tcp   LISTEN 0      20                             127.0.0.1:smtp        0.0.0.0:*    users:(("exim4",pid=2333,fd=5))
tcp   LISTEN 0      511                              0.0.0.0:5005        0.0.0.0:*    users:(("MainThread",pid=2391,fd=23))
tcp   LISTEN 0      511                            127.0.0.1:redis       0.0.0.0:*    users:(("redis-server",pid=945,fd=8))
tcp   LISTEN 0      4096                                [::]:http           [::]:*    users:(("lighttpd",pid=2161,fd=4))
tcp   LISTEN 0      4096                                [::]:sunrpc         [::]:*    users:(("rpcbind",pid=675,fd=6),("systemd",pid=1,fd=124))
tcp   LISTEN 0      128                                 [::]:ssh            [::]:*    users:(("sshd",pid=969,fd=7))
tcp   LISTEN 0      20                                 [::1]:smtp           [::]:*    users:(("exim4",pid=2333,fd=6))
tcp   LISTEN 0      511                                [::1]:redis          [::]:*    users:(("redis-server",pid=945,fd=9))
2026-11-03 15:00:05.274  - warn: host.iobroker instance system.adapter.harmony.0 terminated due to SIGKILL
2026-11-03 15:00:05.295  - warn: host.iobroker instance system.adapter.modbus.0 terminated due to SIGKILL
2026-11-03 15:00:05.430  - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGKILL
2026-11-03 15:00:05.446  - warn: host.iobroker instance system.adapter.yamaha.0 terminated due to SIGKILL
2026-11-03 15:00:05.462  - warn: host.iobroker instance system.adapter.hass.1 terminated due to SIGKILL
2026-11-03 15:00:05.489  - warn: host.iobroker instance system.adapter.shelly.0 terminated due to SIGKILL
2026-11-03 15:00:05.489  - warn: host.iobroker instance system.adapter.modbus.1 terminated due to SIGKILL
2026-11-03 15:00:05.506  - warn: host.iobroker instance system.adapter.parser.0 terminated due to SIGKILL
2026-11-03 15:00:05.521  - warn: host.iobroker instance system.adapter.energiefluss-erweitert.0 terminated due to SIGKILL
2026-11-03 15:00:05.538  - warn: host.iobroker instance system.adapter.e3oncan.0 terminated due to SIGKILL
2026-11-03 15:00:05.554  - warn: host.iobroker instance system.adapter.sourceanalytix.0 terminated due to SIGKILL
2026-11-03 15:00:05.590  - warn: host.iobroker instance system.adapter.virtualpowermeter.0 terminated due to SIGKILL
2026-11-03 15:00:05.718  - warn: host.iobroker instance system.adapter.energiefluss-erweitert.1 terminated due to SIGKILL
2026-11-03 15:00:05.760  - warn: host.iobroker instance system.adapter.open-meteo-weather.0 terminated due to SIGKILL
2026-11-03 15:00:05.802  - warn: host.iobroker instance system.adapter.go-e-charger.0 terminated due to SIGKILL
2026-11-03 15:00:05.842  - warn: host.iobroker instance system.adapter.simple-api.0 terminated due to SIGKILL
2026-11-03 15:00:05.876  - warn: host.iobroker instance system.adapter.javascript.1 terminated due to SIGKILL
2026-11-03 15:00:05.876  - warn: host.iobroker instance system.adapter.solarlog.0 terminated due to SIGKILL
2026-11-03 15:00:05.893  - warn: host.iobroker instance system.adapter.linkeddevices.0 terminated due to SIGKILL
2026-11-03 15:00:05.913  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
2026-11-03 15:00:05.930  - warn: host.iobroker instance system.adapter.zwave2.0 terminated due to SIGKILL
2026-11-03 15:00:05.948  - warn: host.iobroker instance system.adapter.pvforecast.0 terminated due to SIGKILL
2026-11-03 15:00:05.964  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGKILL
2026-11-03 15:00:06.507  - warn: host.iobroker instance system.adapter.zigbee2mqtt.0 terminated due to SIGKILL
2026-11-03 15:00:06.535  - warn: host.iobroker instance system.adapter.iot.0 terminated due to SIGKILL
</code></pre>
<p dir="auto">============= Mark until here for C&amp;P =============</p>
<pre><code></code></pre>
]]></description><link>https://forum.iobroker.net/topic/85755/kein-zugriff-auf-admin-kein-upgrade-auf-8.3.5</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 21:43:21 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/85755.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Nov 2026 16:36:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Wed, 04 Nov 2026 10:57:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: Bluefox">@<bdi>Bluefox</bdi></a> nachdem ich den genannten Pfad gelöscht hatte kam identischer Fehler mit dem Roborock Adapter und "zod". Bin da jetzt identisch vorgegangen und nun scheint wirklich alles sauber zu laufen.<br />
Konnte jetzt admin auf 8.3.5 updaten und andere Adapter sauber installieren und auch löschen.<br />
Jetzt gehts ans prüfen der Services und aufräumen der Sources.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: bluefox">@<bdi>bluefox</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/mcm1957" aria-label="Profile: mcm1957">@<bdi>mcm1957</bdi></a><br />
Nochmals vielen, vielen Dank für eure Unterstützung <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=216b35ebc9e" class="not-responsive emoji emoji-android emoji--+1" style="height:1.4em;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://forum.iobroker.net/post/1361829</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361829</guid><dc:creator><![CDATA[PRozAC]]></dc:creator><pubDate>Wed, 04 Nov 2026 10:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Wed, 04 Nov 2026 09:22:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/prozac" aria-label="Profile: PRozAC">@<bdi>PRozAC</bdi></a> Der kaputte Ordner steht schon in deiner <code>npm ls</code>-Ausgabe aus #6:</p>
<pre><code>/opt/iobroker/node_modules/@aws-sdk/client-polly/node_modules/@aws-sdk/core
</code></pre>
<p dir="auto">Dort fehlt die Version, und daran scheitert npm bei jedem install/uninstall. Mein <code>find</code> von oben hat mit <code>-maxdepth 3</code> so tief gar nicht gesucht, sorry. Dieser eine Ordner ist nur eine verschachtelte Kopie und kann weg. Das oberste <code>@aws-sdk/core@3.979.1</code> erfüllt <code>^3.978.7</code> auch so:</p>
<pre><code>cd /opt/iobroker
rm -rf node_modules/@aws-sdk/client-polly/node_modules/@aws-sdk/core
npm ls @aws-sdk/core
</code></pre>
<p dir="auto">Wenn <code>npm ls</code> kein <code>invalid</code> mehr meldet, sollten <code>iob upgrade admin</code> und auch <code>iob del sayit</code> wieder durchlaufen.</p>
<p dir="auto">Dass sayit nach <code>rm -rf</code> wieder auftaucht, liegt sehr wahrscheinlich an einer übrig gebliebenen Instanz. Für vorhandene Instanzen installiert der Controller den Adapter beim Start einfach nach. Was zeigen diese beiden Befehle?</p>
<pre><code>iob list instances | grep -i sayit
iob object list system.adapter.sayit*
</code></pre>
<p dir="auto"><strong>Erstellt mit Claude</strong></p>
]]></description><link>https://forum.iobroker.net/post/1361819</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361819</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Wed, 04 Nov 2026 09:22:33 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 21:41:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a></p>
<pre><code>
prozac@iobroker:/opt/iobroker/node_modules/iobroker.sayit$ cd /opt/iobroker &amp;&amp; npm ls
[sudo] Passwort für prozac:
iobroker.inst@1.1.2 /opt/iobroker
├── @iobroker-javascript.0/axios@npm:axios@1.21.0
├── @iobroker-javascript.0/dayjs@npm:dayjs@1.11.23
├── @iobroker-javascript.0/moment-parseformat@npm:moment-parseformat@4.0.0
├── @iobroker-javascript.0/moment@npm:moment@2.31.0
├── @iobroker-javascript.0/tcp-ping@npm:tcp-ping@0.1.1
├── @iobroker-javascript.1/axios@npm:axios@1.21.0
├── @iobroker-javascript.1/cheerio-select@npm:cheerio-select@2.1.0
├── @iobroker-javascript.1/dayjs@npm:dayjs@1.11.23
├── @iobroker-javascript.1/moment-parseformat@npm:moment-parseformat@4.0.0
├── @iobroker-javascript.1/moment@npm:moment@2.31.0
├── @iobroker-javascript.1/request@npm:request@2.88.2
├── @iobroker/adapter-core@3.4.3
├── iobroker.admin@8.2.0
├── iobroker.alexa2@3.28.3
├── iobroker.alias-manager@3.0.0
├── iobroker.backitup@4.0.3
├── iobroker.device-reminder@3.1.2
├── iobroker.devices@4.2.2
├── iobroker.discovery@5.0.0
├── iobroker.e3oncan@1.2.0
├── iobroker.echarts@5.1.1
├── iobroker.energiefluss-erweitert@0.8.3
├── iobroker.feiertage@1.4.0
├── iobroker.go-e-charger@1.8.1
├── iobroker.harmony@3.0.0
├── iobroker.hass-mqtt@0.0.7
├── iobroker.hass@2.1.2
├── iobroker.heatingcontrol@3.3.1
├── iobroker.history@5.1.1
├── iobroker.homeconnect@1.6.1
├── iobroker.hue@3.17.4
├── iobroker.ical@1.21.2
├── iobroker.icons-mfd-svg@1.2.0
├── iobroker.influxdb@5.1.8
├── iobroker.iot@7.1.2
├── iobroker.javascript@10.4.4
├── iobroker.js-controller@7.2.5
├── iobroker.lgtv@3.0.5
├── iobroker.linkeddevices@1.5.5
├── iobroker.modbus@9.2.1
├── iobroker.mqtt-client@4.1.0
├── iobroker.mqtt@8.1.2
├── iobroker.node-red@6.0.7
├── iobroker.open-meteo-weather@3.1.4
├── iobroker.openweathermap@2.0.2
├── iobroker.parser@4.0.1
├── iobroker.ping@3.1.4
├── iobroker.pushover@6.1.0
├── iobroker.pvforecast@6.2.0
├── iobroker.rickshaw@1.0.0
├── iobroker.roborock@0.7.4
├── iobroker.sayit@5.3.2
├── iobroker.scenes@5.1.0
├── iobroker.shelly@12.0.0
├── iobroker.shuttercontrol@2.1.2
├── iobroker.simple-api@3.0.7
├── iobroker.snmp@4.0.0
├── iobroker.socketio@9.0.2
├── iobroker.solarlog@2.4.0
├── iobroker.sonoff@5.1.1
├── iobroker.sourceanalytix@0.4.14
├── iobroker.statistics@5.0.0
├── iobroker.sunnyportal@0.1.5
├── iobroker.unifi-protect@1.0.1
├── iobroker.unifi@1.0.2
├── iobroker.viessmannapi@2.4.3
├── iobroker.virtualpowermeter@1.5.0
├── iobroker.vis-bars@0.1.4
├── iobroker.vis-colorpicker@2.1.0
├── iobroker.vis-fancyswitch@1.1.0
├── iobroker.vis-history@1.0.0
├── iobroker.vis-jqui-mfd@1.1.3
├── iobroker.vis-justgage@2.1.7
├── iobroker.vis@1.5.6
├── iobroker.web@8.0.0
├── iobroker.worx@3.3.0
├── iobroker.ws@4.1.0
├── iobroker.yahka@1.1.6
├── iobroker.yamaha@2.11.0
├── iobroker.zigbee@1.10.3
├── iobroker.zigbee2mqtt@3.2.2
├── iobroker.zwave2@3.1.0
└── pushover-notifications@1.2.3
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1361787</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361787</guid><dc:creator><![CDATA[PRozAC]]></dc:creator><pubDate>Tue, 03 Nov 2026 21:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 21:11:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/prozac" aria-label="Profile: PRozAC">@<bdi>PRozAC</bdi></a></p>
<p dir="auto">Ich würde gerne den Baum mal sehen.</p>
<pre><code>cd /opt/iobroker &amp;&amp; npm ls
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1361785</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361785</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 03 Nov 2026 21:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 20:54:30 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcm1957" aria-label="Profile: mcm1957">@<bdi>mcm1957</bdi></a> <a href="/post/1361772">sagte</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/prozac" aria-label="Profile: prozac">@<bdi>prozac</bdi></a> Bitte mit manuellen Löschaktionen warten bis mher Feedback da ist.</p>
</blockquote>
</blockquote>
<p dir="auto">Hatte das sayit Verzeichnis vor einer Stunde bereits mit</p>
<pre><code>rm -rf /opt/iobroker/node_modules/iobroker.sayit/
</code></pre>
<p dir="auto">Einmal gelöscht. Wurde aber nach einem Neustart wieder automatisch hergestellt. Hatte diese Möglichkeit hier im Forum gefunden und musste es testen.</p>
<p dir="auto">Edit:</p>
<p dir="auto">Hab nochmal über die CLI mit debug geschaut</p>
<pre><code>
prozac@iobroker:/opt/iobroker$ iob del sayit --debug
Delete adapter "sayit"
host.iobroker object sayit deleted
host.iobroker object sayit.admin deleted
host.iobroker Deleting 1 object(s).
Error deleting adapter sayit from disk: host.iobroker: Cannot uninstall iobroker.sayit: 1
You might have to delete it yourself!
prozac@iobroker:/opt/iobroker$ cd node_modules/iobroker.sayit/
prozac@iobroker:/opt/iobroker/node_modules/iobroker.sayit$ ls
admin  build  cmdmp3  io-package.json  LICENSE  mp3  nircmd  node_modules  package.json  README.md  say
prozac@iobroker:/opt/iobroker/node_modules/iobroker.sayit$ ls -l
insgesamt 140
drwxrwxr-x+ 3 iobroker iobroker  4096  3. Nov 19:42 admin
drwxrwxr-x+ 3 iobroker iobroker  4096  3. Nov 19:42 build
drwxrwxr-x+ 2 iobroker iobroker  4096  3. Nov 19:42 cmdmp3
-rw-rw-r--+ 1 iobroker iobroker 33097  3. Nov 19:42 io-package.json
-rw-rw-r--+ 1 iobroker iobroker  1100  3. Nov 19:42 LICENSE
drwxrwxr-x+ 2 iobroker iobroker  4096  3. Nov 19:42 mp3
drwxrwxr-x+ 2 iobroker iobroker  4096  3. Nov 19:42 nircmd
drwxrwxr-x+ 5 iobroker iobroker  4096  3. Nov 19:42 node_modules
-rw-rw-r--+ 1 iobroker iobroker  2558  3. Nov 19:42 package.json
-rw-rw-r--+ 1 iobroker iobroker 20693  3. Nov 19:42 README.md
drwxrwxr-x+ 2 iobroker iobroker  4096  3. Nov 19:42 say
</code></pre>
<p dir="auto">Edit 2:<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/mcm1957" aria-label="Profile: mcm1957">@<bdi>mcm1957</bdi></a> Hatte vor Ewigkeit mal das System als Master im Multihost mit Slave im anderen Subnetz. Nicht, dass eventuell noch etwas von übrig geblieben ist.</p>
]]></description><link>https://forum.iobroker.net/post/1361773</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361773</guid><dc:creator><![CDATA[PRozAC]]></dc:creator><pubDate>Tue, 03 Nov 2026 20:54:30 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 19:47:44 GMT]]></title><description><![CDATA[<p dir="auto">Da ist was zerstört:</p>
<p dir="auto">iobroker.inst@1.1.2 /opt/iobroker<br />
└─┬ iobroker.sayit@5.3.2<br />
└─┬ @aws-sdk/client-polly@3.1159.0<br />
├── <strong>@aws-sdk/core@ in</strong>valid: "^3.978.7" from node_modules/@aws-sdk/client-polly<br />
└─┬ @aws-sdk/credential-provider-node@3.972.92</p>
<p dir="auto">Da fehlt eine Versionsangabe in der 4ten Zeile</p>
<p dir="auto">Ev ein beschädigtes package-lock.json?<br />
Ev wär es ausnahmsweise sinnvoll den sayit Ordner explizit zu löschen?</p>
<p dir="auto">Was meinst du Thomas? (<a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a>)</p>
]]></description><link>https://forum.iobroker.net/post/1361772</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361772</guid><dc:creator><![CDATA[mcm1957]]></dc:creator><pubDate>Tue, 03 Nov 2026 19:47:44 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 19:40:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>
prozac@iobroker:/opt/iobroker/node_modules$ cd /opt/iobroker &amp;&amp; npm uninstall iobroker.sayit
npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-11-03T19_37_05_597Z-debug-0.log
</code></pre>
<pre><code>
7 verbose title npm uninstall iobroker.sayit
8 verbose argv "uninstall" "iobroker.sayit"
9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2026-11-03T19_37_05_597Z-
10 verbose logfile /home/iobroker/.npm/_logs/2026-11-03T19_37_05_597Z-debug-0.log
15 silly fetch manifest @aws-sdk/core@^3.978.7
16 silly packumentCache full:https://registry.npmjs.org/@aws-sdk%2fcore cache-miss
17 http fetch GET 200 https://registry.npmjs.org/@aws-sdk%2fcore 1093ms (cache revalidated)
18 silly packumentCache full:https://registry.npmjs.org/@aws-sdk%2fcore set size:1078788 disposed:false
19 silly placeDep ROOT @aws-sdk/core@3.979.1 KEEP for: @aws-sdk/client-polly@3.1159.0 want: ^3.978.7
20 verbose stack TypeError: Invalid Version:
20 verbose stack     at SemVer (/usr/lib/node_modules/npm/node_modules/semver/classes/semver.js:56:13)
20 verbose stack     at compare (/usr/lib/node_modules/npm/node_modules/semver/functions/compare.js:5:32)
20 verbose stack     at Object.eq (/usr/lib/node_modules/npm/node_modules/semver/functions/eq.js:4:29)
20 verbose stack     at Node.canDedupe (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:1138:32)
20 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:427:14)
20 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:445:14)
20 verbose stack     at new PlaceDep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:220:12)
20 verbose stack     at #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1016:18)
20 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:&gt;
21 error Invalid Version:
22 silly unfinished npm timer reify 1793734625963
23 silly unfinished npm timer reify:loadTrees 1793734625964
24 silly unfinished npm timer idealTree:buildDeps 1793734628860
25 silly unfinished npm timer idealTree:node_modules/@aws-sdk/client-polly 1793734628868
26 verbose cwd /opt/iobroker
27 verbose os Linux 6.1.0-35-amd64
28 verbose node v24.22.2
29 verbose npm  v11.19.1
30 verbose exit 1
31 verbose code 1
32 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-11-03T19_37_05_597Z-debug-0.log
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1361771</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361771</guid><dc:creator><![CDATA[PRozAC]]></dc:creator><pubDate>Tue, 03 Nov 2026 19:40:20 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 19:17:53 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/prozac" aria-label="Profile: PRozAC">@<bdi>PRozAC</bdi></a> <a href="/post/1361760">sagte</a>:</p>
<p dir="auto">iobroker.sayit</p>
</blockquote>
<p dir="auto">Was spuckt denn</p>
<pre><code>cd /opt/iobroker &amp;&amp; npm uninstall iobroker.sayit
</code></pre>
<p dir="auto">aus?</p>
]]></description><link>https://forum.iobroker.net/post/1361766</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361766</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 03 Nov 2026 19:17:53 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 18:46:53 GMT]]></title><description><![CDATA[<p dir="auto">Leider doch noch nicht ganz gelöst. Weiterhin gleiche Fehlermeldung sobald ich irgendwas updaten möchte. Den Sayit Adapter hatte ich gelöscht (iob del sayit) bin der Meinung er schrieb noch etwas von manuell löschen. Weiß aber leider nicht mehr was…</p>
<pre><code>
    ├── @aws-sdk/core@ invalid: "^3.978.7" from node_modules/@aws-sdk/client-polly
      ├─┬ @aws-sdk/credential-provider-env@3.972.80
      │ └── @aws-sdk/core@3.979.1
      ├─┬ @aws-sdk/credential-provider-http@3.972.82
      │ └── @aws-sdk/core@3.979.1 deduped
      ├─┬ @aws-sdk/credential-provider-ini@3.973.25
      │ ├── @aws-sdk/core@3.979.1 deduped
      │ ├─┬ @aws-sdk/credential-provider-login@3.972.87
      │ │ └── @aws-sdk/core@3.979.1 deduped
      │ └─┬ @aws-sdk/nested-clients@3.997.54
      ├─┬ @aws-sdk/credential-provider-process@3.972.80
      ├─┬ @aws-sdk/credential-provider-sso@3.973.24
      │ └─┬ @aws-sdk/token-providers@3.1161.0
      └─┬ @aws-sdk/credential-provider-web-identity@3.972.86
npm error code ELSPROBLEMS
npm error invalid: @aws-sdk/core@ /opt/iobroker/node_modules/@aws-sdk/client-polly/node_modules/@aws-sdk/core
npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-11-03T18_15_25_200Z-debug-0.log
</code></pre>
<p dir="auto">Edit: der Sayit Adapter lässt sich nicht löschen<br />
<img src="/assets/uploads/files/1793730535613-img_1177.jpeg" alt="IMG_1177.jpeg" class="img-markdown  img-fluid" width="1721" height="298" /></p>
Hab ihn auch schon mit</p>
</code></pre>
<p dir="auto">Gelöscht aber er installiert sich immer wieder selbst.</p>
]]></description><link>https://forum.iobroker.net/post/1361760</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361760</guid><dc:creator><![CDATA[PRozAC]]></dc:creator><pubDate>Tue, 03 Nov 2026 18:46:53 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 17:24:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> hatte ich auch schon gesehen 🙈 Apache, Emoncms &amp; Influx sind Leichen und kommen raus. Den Rest prüfe ich gleich.</p>
<p dir="auto">Aber zurück zum eigentlichen Thema:<br />
Es war der Sayit Adpter. Gelöscht, iob restart und das Update auf Admin 8.3.5 lief erfolgreich durch.<br />
Damit konnte auch das scheinbar gescheiterte vorherige Update korrigiert werden. Es läuft wieder alles!<br />
Vielen Dank für eure Hilfe!!</p>
]]></description><link>https://forum.iobroker.net/post/1361752</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361752</guid><dc:creator><![CDATA[PRozAC]]></dc:creator><pubDate>Tue, 03 Nov 2026 17:24:47 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 17:16:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/prozac" aria-label="Profile: PRozAC">@<bdi>PRozAC</bdi></a></p>
<p dir="auto">Ich würde mir auch mal anschauen, warum da so viele Dienste nicht laufen:</p>
<pre><code>*** FAILED SERVICES ***
</code></pre>
<p dir="auto">Das riecht komisch. Bei influxdb ist zusätzlich die Quelle veraltet, muss nochmal mit aktuellem Schlüssel neuangelegt werden.</p>
]]></description><link>https://forum.iobroker.net/post/1361747</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361747</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 03 Nov 2026 17:16:22 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 17:10:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluefox" aria-label="Profile: bluefox">@<bdi>bluefox</bdi></a> wurde schon gemacht. Vergessen zu schreiben, sorry.</p>
<pre><code>
prozac@iobroker:~$ iob start admin
The adapter "admin.0" was started.
prozac@iobroker:~$ iob list instances
  system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
</code></pre>
<p dir="auto">Leider auch erfolglos. Habe den Verdacht, dass das Update auf 8.3.5 in die Hose ging und nun Dateien fehlen. Es wird ja versucht eine die Admin Seite zu laden. Auch ein iob add Admin —force hat nicht geholfen.</p>
<p dir="auto">Und bzgl. des update Problem werde ich mal das genannte testen.</p>
]]></description><link>https://forum.iobroker.net/post/1361743</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361743</guid><dc:creator><![CDATA[PRozAC]]></dc:creator><pubDate>Tue, 03 Nov 2026 17:10:03 GMT</pubDate></item><item><title><![CDATA[Reply to Kein Zugriff auf Admin & kein Upgrade auf 8.3.5 on Tue, 03 Nov 2026 17:00:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/prozac" aria-label="Profile: PRozAC">@<bdi>PRozAC</bdi></a> Der Admin ist nur gestoppt (<code>Adapter "system.adapter.admin.1" is stopped</code>), 8.2.0 ist noch installiert. Zuerst wieder starten:</p>
<pre><code>iob start admin
</code></pre>
<p dir="auto">Das "Invalid Version:" mit leerer Version kommt von npm selbst. Es heißt fast immer, dass in <code>/opt/iobroker/node_modules</code> ein Paket mit einer kaputten oder leeren <code>package.json</code> liegt, meist nach einer abgebrochenen Installation. Laut Log bricht npm genau bei <code>@aws-sdk/client-polly</code> / <code>@aws-sdk/core</code> ab. Bitte mal das hier ausführen:</p>
find node_modules/@aws-sdk -maxdepth 3 -name package.json -exec grep -L '"version"' {} +
</code></pre>
<p dir="auto">Der Befehl listet alle <code>package.json</code> ohne Versionsfeld auf. Wenn da etwas kommt, lösch den betroffenen Ordner (z. B. <code>rm -rf node_modules/@aws-sdk/&lt;name&gt;</code>) und versuch es dann noch mal:</p>
<pre><code>iob upgrade admin
</code></pre>
<p dir="auto">Wenn nichts gefunden wird oder es danach immer noch nicht geht, poste bitte die Ausgabe und auch die von <code>npm ls @aws-sdk/core</code>.</p>
]]></description><link>https://forum.iobroker.net/post/1361737</link><guid isPermaLink="true">https://forum.iobroker.net/post/1361737</guid><dc:creator><![CDATA[Bluefox]]></dc:creator><pubDate>Tue, 03 Nov 2026 17:00:41 GMT</pubDate></item></channel></rss>
