<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HASS Adapter, Entity exclude Filter]]></title><description><![CDATA[<p dir="auto">Hallo Zusammen</p>
<p dir="auto">Da ich nicht alle DPs von Home Assistant in IoBroker brauche/will, wollte ich den Filter benutzen, welcher auch hier beschrieben wird:<br />
<a href="https://www.iobroker.com/adapters/iobroker.hass/" rel="nofollow ugc">https://www.iobroker.com/adapters/iobroker.hass/</a></p>
<p dir="auto">Eventuell eine ganz blöde Frage, aber wo finde ich das "Feld" um den Filter einzutragen.<br />
Bei den Instanz-Settings finde ich nichts...<br />
<img src="/assets/uploads/files/1790427059963-ca8702a0-c521-41cb-a0e7-26a9636da155-image-resized.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="2287" height="1202" /></p>
]]></description><link>https://forum.iobroker.net/topic/85446/hass-adapter-entity-exclude-filter</link><generator>RSS for Node</generator><lastBuildDate>Wed, 30 Sep 2026 15:30:02 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/85446.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 26 Sep 2026 12:51:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Tue, 29 Sep 2026 13:22:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bananajoe" aria-label="Profile: BananaJoe">@<bdi>BananaJoe</bdi></a></p>
<blockquote>
<p dir="auto">crunchip <a href="/post/1356713">sagte</a>:</p>
<p dir="auto">sollte ab v 2.1.1 funktionieren</p>
</blockquote>
<p dir="auto"><a href="https://github.com/ioBroker/ioBroker.hass/commit/0be14d3c395511a424f484e21996a89904c6d46b" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.hass/commit/0be14d3c395511a424f484e21996a89904c6d46b</a></p>
]]></description><link>https://forum.iobroker.net/post/1356767</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356767</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 29 Sep 2026 13:22:48 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Tue, 29 Sep 2026 12:26:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> ich habe es gerade bei mir getestet, die beiden Zeilen nachgetragen und den Haken bei <code>Ausgefilfterte Entitäten beim Adapter-Start löschen</code> gesetzt.<br />
Der Filter passt wohl nicht:</p>
<pre><code>2026-09-29 14:19:29.735  - info: hass.0 (1398065) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.hass, node: v22.23.3, js-controller: 7.2.3
2026-09-29 14:19:29.772  - info: hass.0 (1398065) Entity filter active: 2 pattern(s) loaded: entities.*.*.device_class, entities.*.*.state_class
2026-09-29 14:19:30.256  - info: hass.0 (1398065) Cleanup: no existing objects matched exclude patterns
</code></pre>
<p dir="auto">Dieser Datenpunkt hätte ja verschwinden müssen:</p>
<pre><code>hass.0.entities.binary_sensor.balkontur.device_class
</code></pre>
<p dir="auto">Adapter ist v2.1.0</p>
]]></description><link>https://forum.iobroker.net/post/1356759</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356759</guid><dc:creator><![CDATA[BananaJoe]]></dc:creator><pubDate>Tue, 29 Sep 2026 12:26:35 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Tue, 29 Sep 2026 12:14:22 GMT]]></title><description><![CDATA[<p dir="auto">Muss ich heute Abend schauen, habe die aus dem latest installiert.<br />
Wahrscheinlich die 2.1?</p>
]]></description><link>https://forum.iobroker.net/post/1356757</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356757</guid><dc:creator><![CDATA[mickemup]]></dc:creator><pubDate>Tue, 29 Sep 2026 12:14:22 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Tue, 29 Sep 2026 07:40:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickemup" aria-label="Profile: mickemup">@<bdi>mickemup</bdi></a> welche Version hast du laufen?</p>
<pre><code>entities.*.*.device_class
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1356713</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356713</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 29 Sep 2026 07:40:28 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Mon, 28 Sep 2026 18:44:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickemup" aria-label="Profile: mickemup">@<bdi>mickemup</bdi></a> Kann ich Dir leider nix weiter sagen, bei mir laufen die Filter so, wie ich will. Evtl. machst Du ein Issue auf Github auf, dann kann es ein Developer anschauen.</p>
<p dir="auto">Gruss, Jürgen</p>
]]></description><link>https://forum.iobroker.net/post/1356685</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356685</guid><dc:creator><![CDATA[Wildbill]]></dc:creator><pubDate>Mon, 28 Sep 2026 18:44:58 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Mon, 28 Sep 2026 17:54:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wildbill" aria-label="Profile: wildbill">@<bdi>wildbill</bdi></a> gerade probiert, geht leider nicht<br />
Es wurde nix zusätzliches gelöscht...<br />
Objekte sind noch da<br />
<img src="/assets/uploads/files/1790618034105-9a6125ce-732c-4697-8290-65dd6f6d5d90-image-resized.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="2102" height="205" /></p>
<pre><code>
hass.0 2026-09-28 19:49:18.355	info	Initialization completed
hass.0 2026-09-28 19:49:18.355	info	Entity filter excluded: update.hacs_update
hass.0 2026-09-28 19:49:18.355	info	Entity filter excluded: automation.tw_level
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: person.iob_ha
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: person.mqttha
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: person.egolz
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: zone.home
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: sensor.backup_last_attempted_automatic_backup
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: sensor.backup_last_successful_automatic_backup
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: sensor.backup_next_scheduled_automatic_backup
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: sensor.backup_backup_manager_state
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: event.backup_automatic_backup
hass.02026-09-28 19:49:18.354	info	Entity filter excluded: conversation.home_assistant
hass.02026-09-28 19:49:18.354	info	Entity filter excluded: update.get_hacs_update
hass.0 2026-09-28 19:49:18.354	info	Entity filter excluded: update.home_assistant_operating_system_update
hass.0 2026-09-28 19:49:18.353	info	Entity filter excluded: update.home_assistant_core_update
hass.0 2026-09-28 19:49:18.353	info	Entity filter excluded: update.home_assistant_supervisor_update
hass.0 2026-09-28 19:49:18.353	info	Entity filter excluded 16 entities from sync
hass.0 2026-09-28 19:49:17.816	info	Cleanup: no existing objects matched exclude patterns
hass.0 2026-09-28 19:49:17.752	info	Entity filter active: 11 pattern(s) loaded: *.backup*, person.*, zone.*, conversation.*, automation.*, update.get_hacs_update, update.hacs_update, update.home_assistant*, *device_class, *state_class, * hass.0.entities.sensor.grillplats_plug_voltage.device_class
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1356672</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356672</guid><dc:creator><![CDATA[mickemup]]></dc:creator><pubDate>Mon, 28 Sep 2026 17:54:54 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Mon, 28 Sep 2026 05:36:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickemup" aria-label="Profile: mickemup">@<bdi>mickemup</bdi></a> Ich glaube, das mit den Wildcards klappt nur ohne Punkte davor und danach. Zumindest habe ich bei mir das alles so eingetragen. Da musst Du vermutlich anders filtern.<br />
Wenn Du alle device und state class weghaben willst wäre wohl</p>
<pre><code>*device_class
*state_class
</code></pre>
<p dir="auto">passend.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickemup" aria-label="Profile: mickemup">@<bdi>mickemup</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/1356592</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356592</guid><dc:creator><![CDATA[Wildbill]]></dc:creator><pubDate>Mon, 28 Sep 2026 05:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Sun, 27 Sep 2026 21:05:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wildbill" aria-label="Profile: wildbill">@<bdi>wildbill</bdi></a><br />
Ich bin nun fleissig am filtern..</p>
<p dir="auto">Aber dieser Teil vom Filter klappt bei mir irgendwie nicht.</p>
<pre><code># Drop noisy attributes from all synced entities while keeping the main state:
</code></pre>
<p dir="auto">Hast du ein Tipp?</p>
<p dir="auto">Die Filter, welche direkt auf die HA Entitäts-ID gehen, habe ich hingekriegt.</p>
]]></description><link>https://forum.iobroker.net/post/1356581</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356581</guid><dc:creator><![CDATA[mickemup]]></dc:creator><pubDate>Sun, 27 Sep 2026 21:05:41 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Sun, 27 Sep 2026 18:25:38 GMT]]></title><description><![CDATA[<p dir="auto">Ah super. Danke, habe gerade im Changelog gesehen, dass die ja erst nach 1.4 dazukam :-)</p>
]]></description><link>https://forum.iobroker.net/post/1356571</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356571</guid><dc:creator><![CDATA[mickemup]]></dc:creator><pubDate>Sun, 27 Sep 2026 18:25:38 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Sat, 26 Sep 2026 17:37:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickemup" aria-label="Profile: mickemup">@<bdi>mickemup</bdi></a> Der Filter funktioniert hervorragend, ist aber erst ab Adapter-Version 2.1.0 verfüpgbar. vermutlich bist Du (lobenswerterweise!) im STABLE unterwegs, und da kommt bislang nur die 1.4.0. Also entweder warten, bis die 2.1.0 ins stable kommt, oder einmal das Repository auf BETA stellen, genau diesen einen Adapter updaten und anschließend SOFORT zurück auf stable gehen. Dann hast Du den Filter.</p>
]]></description><link>https://forum.iobroker.net/post/1356475</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356475</guid><dc:creator><![CDATA[Wildbill]]></dc:creator><pubDate>Sat, 26 Sep 2026 17:37:56 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Sat, 26 Sep 2026 17:25:39 GMT]]></title><description><![CDATA[<p dir="auto">Hm immerhin ist die Doku der direkte Link aus der Instanz (Fragezeichen Symbol)<br />
Schade, weiss niemand ob es diese "filtern" überhaupt gibt und wenn ja wo es zu finden ist?</p>
]]></description><link>https://forum.iobroker.net/post/1356473</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356473</guid><dc:creator><![CDATA[mickemup]]></dc:creator><pubDate>Sat, 26 Sep 2026 17:25:39 GMT</pubDate></item><item><title><![CDATA[Reply to HASS Adapter, Entity exclude Filter on Sat, 26 Sep 2026 14:59:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickemup" aria-label="Profile: mickemup">@<bdi>mickemup</bdi></a></p>
<p dir="auto">Aktuell wird hier anscheinend alles mit KI gemacht . Vermutlich inklusive der Doku.<br />
Die HASS Doku , die Du verlinkt hast , kannste vergessen. Da wird sogar noch auf ne SmartHome Seite (Doku dort) verwiesen , die 6 Jahre alt ist .<br />
Fraglich , ob der Inhaber mit der Verlinkung einverstanden war.</p>
]]></description><link>https://forum.iobroker.net/post/1356453</link><guid isPermaLink="true">https://forum.iobroker.net/post/1356453</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Sat, 26 Sep 2026 14:59:05 GMT</pubDate></item></channel></rss>
