<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[telegram update auf 5.0.3 - Instanz bleibt gelb]]></title><description><![CDATA[<p dir="auto">Hatte eben ca. 8 stable updates.</p>
<p dir="auto">u.a. auch telegram auf 5.0.3</p>
<p dir="auto">Instanz bleibt gelb. Im log kommt</p>
<pre><code>telegram.0
2026-09-01 18:53:48.459	error	getMe (reconnect #100) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:53:38.449	error	getMe (reconnect #90) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:53:28.439	error	getMe (reconnect #80) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:53:18.432	error	getMe (reconnect #70) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:53:08.424	error	getMe (reconnect #60) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:52:58.415	error	getMe (reconnect #50) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:52:48.404	error	getMe (reconnect #40) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:52:38.396	error	getMe (reconnect #30) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:52:28.390	error	getMe (reconnect #20) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:52:18.381	error	getMe (reconnect #10) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:52:08.374	error	getMe (reconnect #0) Error:FatalError: EFATAL: Failed to parse URL from /bot2630_kTpS-ExGV8/getMe
telegram.0
2026-09-01 18:52:08.373	error	setWebhook Error:FatalError: EFATAL: Failed to parse URL from /bot2633765Jvbtr0_kTpS-ExGV8/setWebhook
</code></pre>
<p dir="auto">Hab ich etwas übersehen ?</p>
]]></description><link>https://forum.iobroker.net/topic/85272/telegram-update-auf-5.0.3-instanz-bleibt-gelb</link><generator>RSS for Node</generator><lastBuildDate>Thu, 03 Sep 2026 17:50:41 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/85272.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Sep 2026 16:55:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 19:11:37 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliverio" aria-label="Profile: OliverIO">@<bdi>OliverIO</bdi></a> <a href="/post/1353211">sagte</a>:</p>
<p dir="auto">iobroker.telegram@6.0.0-alpha.1</p>
</blockquote>
<p dir="auto">Rückinfo<br />
habe<br />
iobroker.telegram@6.0.0-alpha.1<br />
installiert</p>
<p dir="auto">und die instanz wird grün und alles funktioniert.</p>
<p dir="auto">Danke</p>
]]></description><link>https://forum.iobroker.net/post/1353216</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353216</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 19:11:37 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 19:07:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a><br />
es sollte eigentlich so sein<br />
Denis hat aber die meisten adapter auf admin8 umgestellt<br />
evtl hat ihm einfach nur ein grünes build gereicht und ein bisschen in der oberfläche klicken gereicht. bei telegram muss man einen bot einrichten wenn man den nicht schon hat. das ist meist etwas zeitaufwändig</p>
<p dir="auto">für sowas  habe ich bei meinen adapter  je einen support thread wo neue versionen alpha und beta/latest angekündigt werden, das die leute es testen können, bevor es dann in stable geht. ich schaue dann auch noch auf dem dev portal wieviele installationen es bei beta gibt, bevor es ins stable geht.<br />
wenn dann probleme ist nicht immer garantiert das ich es zeitnah beheben kann.<br />
oft aber schon</p>
]]></description><link>https://forum.iobroker.net/post/1353214</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353214</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Tue, 01 Sep 2026 19:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:59:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliverio" aria-label="Profile: OliverIO">@<bdi>OliverIO</bdi></a><br />
Nur mal so Interessehalber.<br />
telegram steht doch explizit im o.g. Beitrag von bluefox drin.</p>
<p dir="auto">Wird denn sowas nicht getestet ?</p>
<p dir="auto">P.S.<br />
upload all ist gerade fertig und iob startet neu.<br />
Ich teste dann mal.</p>
<p dir="auto">Im Zweifel gehe ich wieder auf 4.1.0 zurück</p>
]]></description><link>https://forum.iobroker.net/post/1353212</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353212</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:59:05 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:51:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a><br />
das wird wahrscheinlich nicht funktionieren.<br />
wenn du risikofreudig bis kannst du<br />
über custom install das eintragen</p>
<p dir="auto">habe ich aber nicht empfohlen.<br />
das paket ist erst wenige stunden alt<br />
und du siehst als alpha markiert</p>
]]></description><link>https://forum.iobroker.net/post/1353211</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353211</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:51:16 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:43:52 GMT]]></title><description><![CDATA[<p dir="auto">ok, danke für die info</p>
<p dir="auto">upload all läuft aber nun trotzdem; kann ja nicht schade.<br />
Probiere dann mal die telegram git version.</p>
]]></description><link>https://forum.iobroker.net/post/1353207</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353207</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:43:52 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:40:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a><br />
ok issue brauchst nicht<br />
<a href="https://github.com/iobroker-community-adapters/ioBroker.telegram/issues/1371" rel="nofollow ugc">https://github.com/iobroker-community-adapters/ioBroker.telegram/issues/1371</a><br />
gibt wohl bald eine v6</p>
]]></description><link>https://forum.iobroker.net/post/1353205</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353205</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:40:24 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:37:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a></p>
<p dir="auto">-neustarten<br />
-evtl mal auf konsole<br />
iobroker upload all<br />
-zum schluss issue</p>
]]></description><link>https://forum.iobroker.net/post/1353204</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353204</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:37:41 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:22:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a> <a href="/post/1353198">sagte</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliverio" aria-label="Profile: OliverIO">@<bdi>OliverIO</bdi></a></p>
<p dir="auto">Soll ich mal iob neustarten ?<br />
Oder liegt das Problem woanders</p>
</blockquote>
<p dir="auto">Den ioBroker, den Adapter, den Host neu starten ist doch keine Raketenforschung.<br />
Was soll da schon passieren?<br />
Mach's doch einfach mal.</p>
]]></description><link>https://forum.iobroker.net/post/1353199</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353199</guid><dc:creator><![CDATA[Meister Mopper]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:22:08 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:17:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliverio" aria-label="Profile: OliverIO">@<bdi>OliverIO</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/1353198</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353198</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:17:51 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:08:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliverio" aria-label="Profile: OliverIO">@<bdi>OliverIO</bdi></a></p>
<p dir="auto">Danke für die Info.</p>
<p dir="auto">Und was mach ich jetzt ?<br />
Instanz blieb ja gelb.</p>
]]></description><link>https://forum.iobroker.net/post/1353197</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353197</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:08:31 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 18:06:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a></p>
<p dir="auto">nein das ist schon richtig. ohne admin8 würde dir das update des telegram adapters (wenn es im adapter richtig eingestellt ist) nicht updatefähig angezeigt werden.</p>
<p dir="auto"><a href="https://github.com/iobroker-community-adapters/ioBroker.telegram/blob/master/io-package.json#L228" rel="nofollow ugc">https://github.com/iobroker-community-adapters/ioBroker.telegram/blob/master/io-package.json#L228</a><br />
es ist richtig eingestellt</p>
]]></description><link>https://forum.iobroker.net/post/1353196</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353196</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:06:52 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 17:21:04 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/warp735" aria-label="Profile: warp735">@<bdi>warp735</bdi></a> <a href="/post/1353179">sagte</a>:</p>
<p dir="auto">Dann wird das der Grund sein :-)</p>
</blockquote>
<p dir="auto">versteht ich jetzt nicht.</p>
<p dir="auto">Hab ich das so falsch gelesen ?<br />
Ich dachte erst admin 8 und dann die Adapter</p>
<p dir="auto">umgedreht ?</p>
<p dir="auto">Wenn falsch gelesen, was mach ich jetzt ?</p>
]]></description><link>https://forum.iobroker.net/post/1353182</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353182</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 17:21:04 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 17:12:36 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a> <a href="/post/1353176">sagte</a>:</p>
<p dir="auto">vorher admin 8 installiert</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1353179</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353179</guid><dc:creator><![CDATA[warp735]]></dc:creator><pubDate>Tue, 01 Sep 2026 17:12:36 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 17:07:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meister-mopper" aria-label="Profile: Meister-Mopper">@<bdi>Meister-Mopper</bdi></a></p>
<p dir="auto">und node 22 hab ich auch:<br />
<img src="/assets/uploads/files/1788282433554-f1998d5a-575d-4b75-9046-8fff860ef12d-image.jpeg" alt="f1998d5a-575d-4b75-9046-8fff860ef12d-image.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/1353177</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353177</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 17:07:16 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 17:06:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meister-mopper" aria-label="Profile: Meister-Mopper">@<bdi>Meister-Mopper</bdi></a></p>
<p dir="auto">ja,<br />
und ich habe ja vorher admin 8 installiert.<br />
<img src="/assets/uploads/files/1788282377932-71c8dabf-2969-4eea-af76-c3ac08a417a9-image.jpeg" alt="71c8dabf-2969-4eea-af76-c3ac08a417a9-image.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">oder meinst du was anderes.</p>
]]></description><link>https://forum.iobroker.net/post/1353176</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353176</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 17:06:28 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 17:03:58 GMT]]></title><description><![CDATA[<p dir="auto">Schon gesehen?</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/85270/admin-8-nun-im-stable-repository">https://forum.iobroker.net/topic/85270/admin-8-nun-im-stable-repository</a></p>
]]></description><link>https://forum.iobroker.net/post/1353175</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353175</guid><dc:creator><![CDATA[Meister Mopper]]></dc:creator><pubDate>Tue, 01 Sep 2026 17:03:58 GMT</pubDate></item><item><title><![CDATA[Reply to telegram update auf 5.0.3 - Instanz bleibt gelb on Tue, 01 Sep 2026 17:01:25 GMT]]></title><description><![CDATA[<p dir="auto">Bin wieder auf 4.1.0<br />
Da läuft alles.</p>
<p dir="auto">Eine Antwort wäre aber gut. Muss ja (wenn es läuft) wieder updaten.</p>
]]></description><link>https://forum.iobroker.net/post/1353174</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353174</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Tue, 01 Sep 2026 17:01:25 GMT</pubDate></item></channel></rss>
