<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[gesperrter Datenpunkt bei adapter daikin-cloud]]></title><description><![CDATA[<ul>
<li>Adaptername: daikin-cloud</li>
<li>Adapterversion: 0.4.12</li>
<li>js-controller Version: 7.2.2</li>
<li>Admin Version: 7.8.23</li>
<li>Hardwaresystem: proxmox</li>
<li>Arbeitsspeicher:  6 GB</li>
<li>Festplattenart: container</li>
<li>Betriebssystem:  debian</li>
<li>Nodejs-Version: 22.22.3</li>
<li>NPM-Version: 10.9.8</li>
</ul>
<p dir="auto">Linux User bitte hier den Output von <em>iob diag</em> einfügen.<br />
</p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><br />
========== Start marking the full check here ===========<p></p>
<pre><code class="language-bash">Script v.2026-06-06
*** BASE SYSTEM ***
 Static hostname: iobroker
       Icon name: computer-container
         Chassis: container ☐
  Virtualization: lxc
          Kernel: Linux 7.0.12-1-pve
    Architecture: x86-64
OS is similar to:
model name      : Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
Docker          : false
Virtualization  : lxc
Kernel          : x86_64
Userland        : 64bit
System was installed 391 days ago (on 2025-05-31).
Systemuptime and Load:
 13:38:20 up 14:04,  2 users,  load average: 2.27, 2.39, 2.42
CPU threads     : 8
*** LIFE CYCLE STATUS ***
Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
*** TIME AND TIMEZONES ***
               Local time: Sat 2026-06-27 13:38:20 CEST
           Universal time: Sat 2026-06-27 11:38:20 UTC
                 RTC time: n/a
                Time zone: Europe/Vienna (CEST, +0200)
              NTP service: inactive
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
maximal1981
HOME=/home/maximal1981
GROUPS=maximal1981 sudo users iobroker
iobroker
HOME=/home/iobroker
GROUPS=iobroker tty dialout audio video plugdev
*** DISPLAY-SERVER SETUP ***
Display-Server:         Unknown
Display-Manager:        Not found
Desktop:
Session:
System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
*** MEMORY ***
Mem:            6.4G        3.9G        2.2G         81K        342M        2.5G
Swap:           1.1G        1.1G         19M
Total:          7.5G        4.9G        2.2G
Active iob-Instances:   48
         6144 M total memory
         3714 M used memory
         1090 M active memory
         2751 M inactive memory
         2103 M free memory
            0 M buffer memory
          326 M swap cache
         1024 M total swap
         1005 M used swap
           18 M free swap
top - 13:38:21 up 14:04,  2 users,  load average: 2.27, 2.39, 2.42
Tasks:  73 total,   2 running,  71 sleeping,   0 stopped,   0 zombie
%Cpu(s): 47.8 us,  4.3 sy,  0.0 ni, 30.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   6144.0 total,   2101.4 free,   3716.2 used,    326.6 buff/cache
MiB Swap:   1024.0 total,     19.0 free,   1005.0 used.   2427.8 avail Mem
*** FAILED SERVICES ***
  UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
* run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
1 loaded units listed.
*** DMESG CRITICAL ERRORS ***
dmesg: read kernel buffer failed: Operation not permitted
No critical errors detected
*** FILESYSTEM ***
Filesystem                       Type      Size  Used Avail Use% Mounted on
/dev/mapper/pve-vm--101--disk--1 ext4      9.8G  6.4G  2.9G  70% /
none                             tmpfs     492K  4.0K  488K   1% /dev
udev                             devtmpfs  3.1G     0  3.1G   0% /dev/tty
tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
Messages concerning filesystems in dmesg:
Show mounted filesystems:
TARGET SOURCE                           FSTYPE OPTIONS
/      /dev/mapper/pve-vm--101--disk--1 ext4   rw,relatime,stripe=16
/var:
1.2G    /var/
948M    /var/log
947M    /var/log/journal/fdf5cd495bb345a58900f9d60cd51d5c
147M    /var/lib
Archived and active journals take up 15.0M in the file system.
/opt/iobroker/backups:
508M    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
665M    /opt/iobroker/iobroker-data/
393M    /opt/iobroker/iobroker-data/files
170M    /opt/iobroker/iobroker-data/backup-objects
78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
47M     /opt/iobroker/iobroker-data/files/admin.admin
72M     /opt/iobroker/iobroker-data/objects.jsonl
28M     /opt/iobroker/iobroker-data/states.jsonl
21M     /opt/iobroker/iobroker-data/files/0_userdata.0/iobroker_2023_09_02-14_14_06_backupiobroker.tar.gz
9.4M    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
8.0M    /opt/iobroker/iobroker-data/files/daswetter.admin/assets/index-84bRrRlB.js
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
No Devices found 'by-id'
No nvbackup.json found.
*** NodeJS-Installation ***
/usr/bin/nodejs         v22.22.3
/usr/bin/node           v22.22.3
/usr/bin/npm            10.9.8
/usr/bin/npx            10.9.8
✓ Node.js installation is correct
nodejs:
  Installed: 22.22.3-1nodesource1
  Candidate: 22.22.3-1nodesource1
  Version table:
 *** 22.22.3-1nodesource1 1001
        500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
        100 /var/lib/dpkg/status
     22.22.2-1nodesource1 1001
     22.22.1-1nodesource1 1001
     22.22.0-1nodesource1 1001
     22.21.0-1nodesource1 1001
     22.20.0-1nodesource1 1001
     22.19.0-1nodesource1 1001
     22.18.0-1nodesource1 1001
     22.17.1-1nodesource1 1001
     22.17.0-1nodesource1 1001
     22.16.0-1nodesource1 1001
     22.15.1-1nodesource1 1001
     22.15.0-1nodesource1 1001
     22.14.0-1nodesource1 1001
     22.13.1-1nodesource1 1001
     22.13.0-1nodesource1 1001
     22.12.0-1nodesource1 1001
     22.11.0-1nodesource1 1001
     22.10.0-1nodesource1 1001
     22.9.0-1nodesource1 1001
     22.8.0-1nodesource1 1001
     22.7.0-1nodesource1 1001
     22.6.0-1nodesource1 1001
     22.5.1-1nodesource1 1001
     22.5.0-1nodesource1 1001
     22.4.1-1nodesource1 1001
     22.4.0-1nodesource1 1001
     22.3.0-1nodesource1 1001
     22.2.0-1nodesource1 1001
     22.1.0-1nodesource1 1001
     22.0.0-1nodesource1 1001
     18.20.4+dfsg-1~deb12u2 500
        500 http://security.debian.org bookworm-security/main amd64 Packages
     18.20.4+dfsg-1~deb12u1 500
        500 http://deb.debian.org/debian bookworm/main amd64 Packages
No problems detected
Errors in npm tree: 0
Vulnerabilities detected in the Node.js version!
node:fs:2430
    return binding.writeFileUtf8(
Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
    at Object.writeFileSync (node:fs:2430:20)
    at ClientRequest.&lt;anonymous&gt; (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
    at Object.onceWrapper (node:events:634:26)
    at ClientRequest.emit (node:events:519:28)
    at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:780:27)
    at HTTPParser.parserOnHeadersComplete (node:_http_common:125:17)
    at TLSSocket.socketOnData (node:_http_client:615:22)
    at TLSSocket.emit (node:events:519:28)
    at addChunk (node:internal/streams/readable:561:12)
    at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
  errno: -13,
  code: 'EACCES',
  syscall: 'open',
  path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
Node.js v22.22.3
npm notice
npm notice New major version of npm available! 10.9.8 -&gt; 11.17.0
npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.17.0
npm notice To update run: npm install -g npm@11.17.0
npm notice
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
iobroker            iobroker (version: 7.2.2, hostname: iobroker      , alive, uptime: 50660)
Core adapters versions
js-controller:  7.2.2
admin:          7.8.23
javascript:     9.0.18
nodejs modules from github:     3
+-- hafas-client@6.3.5 (git+ssh://git@github.com/public-transport/hafas-client.git#06b572424f07ee8ec612a9706ee0a94b6f889d4d)
+-- iobroker.todoist2@0.9.1 (git+ssh://git@github.com/rde-master/ioBroker.todoist2.git#531241af9356c641158a3cb63e3bd45a1d11a8d8)
+-- iobroker.vw-connect@0.9.4 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#4321b81482d5d8ce71ce9cf87fe597a069f26852)
Adapter State
+ system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
+ system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
  system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
  system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
+ system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
+ system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
+ system.adapter.awtrix-light.2           : awtrix-light          : iobroker                                 -  enabled
+ system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
+ system.adapter.bambulab.0               : bambulab              : iobroker                                 -  enabled, port: 8883
+ system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
+ system.adapter.daikin.0                 : daikin                : iobroker                                 -  enabled
+ system.adapter.daikin.1                 : daikin                : iobroker                                 -  enabled
+ system.adapter.daikin.2                 : daikin                : iobroker                                 -  enabled
+ system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
+ system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
  system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
+ system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
+ system.adapter.email.0                  : email                 : iobroker                                 -  enabled
+ system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
+ system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
+ system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
+ system.adapter.fahrplan.0               : fahrplan              : iobroker                                 -  enabled
  system.adapter.fakeroku.0               : fakeroku              : iobroker                                 - disabled
  system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
+ system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
+ system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : iobroker                                 -  enabled
+ system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
  system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : iobroker                                 -  enabled
+ system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
  system.adapter.iceroad.0                : iceroad               : iobroker                                 -  enabled
  system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
  system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
  system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
+ system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
+ system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
  system.adapter.info.0                   : info                  : iobroker                                 - disabled
+ system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
+ system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
+ system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
  system.adapter.meross.0                 : meross                : iobroker                                 - disabled
+ system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
+ system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
  system.adapter.parser.0                 : parser                : iobroker                                 - disabled
  system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
+ system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
+ system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
+ system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
  system.adapter.roomba.0                 : roomba                : iobroker                                 - disabled
+ system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
+ system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
  system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
+ system.adapter.todoist2.0               : todoist2              : iobroker                                 -  enabled
+ system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
+ system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
  system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
+ system.adapter.unifi-network.0          : unifi-network         : iobroker                                 -  enabled, port: 8443
+ system.adapter.unifi-protect.0          : unifi-protect         : iobroker                                 -  enabled
+ system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
  system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
  system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
+ system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
+ system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
+ instance is alive
ioBroker-Repositories
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
│ (index) │ id                                           │ name                          │ version  │ upgrade policy │
│ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
│ 1       │ 'system.adapter.alexa2'                      │ 'alexa2'                      │ '3.27.4' │ 'none'         │
│ 2       │ 'system.adapter.alias-manager'               │ 'alias-manager'               │ '2.1.0'  │ 'none'         │
│ 3       │ 'system.adapter.awattar'                     │ 'awattar'                     │ '1.0.6'  │ 'none'         │
│ 4       │ 'system.adapter.awtrix-light'                │ 'awtrix-light'                │ '3.0.0'  │ 'none'         │
│ 5       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.17' │ 'none'         │
│ 6       │ 'system.adapter.bambulab'                    │ 'bambulab'                    │ '0.4.3'  │ 'none'         │
│ 7       │ 'system.adapter.daikin'                      │ 'daikin'                      │ '1.5.1'  │ 'none'         │
│ 8       │ 'system.adapter.daikin-cloud'                │ 'daikin-cloud'                │ '0.4.12' │ 'none'         │
│ 9       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'  │ 'none'         │
│ 10      │ 'system.adapter.device-reminder'             │ 'device-reminder'             │ '3.1.2'  │ 'none'         │
│ 11      │ 'system.adapter.device-watcher'              │ 'device-watcher'              │ '2.15.5' │ 'none'         │
│ 12      │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'  │ 'none'         │
│ 13      │ 'system.adapter.email'                       │ 'email'                       │ '2.0.4'  │ 'none'         │
│ 14      │ 'system.adapter.energiefluss'                │ 'energiefluss'                │ '3.6.2'  │ 'none'         │
│ 15      │ 'system.adapter.energiefluss-erweitert'      │ 'energiefluss-erweitert'      │ '0.8.1'  │ 'none'         │
│ 16      │ 'system.adapter.fahrplan'                    │ 'fahrplan'                    │ '1.4.1'  │ 'none'         │
│ 17      │ 'system.adapter.fakeroku'                    │ 'fakeroku'                    │ '0.4.0'  │ 'none'         │
│ 18      │ 'system.adapter.feiertage'                   │ 'feiertage'                   │ '1.4.0'  │ 'none'         │
│ 19      │ 'system.adapter.followthesun'                │ 'followthesun'                │ '0.5.2'  │ 'none'         │
│ 20      │ 'system.adapter.fronius'                     │ 'fronius'                     │ '2.2.0'  │ 'none'         │
│ 21      │ 'system.adapter.fronius-wattpilot'           │ 'fronius-wattpilot'           │ '4.8.0'  │ 'none'         │
│ 22      │ 'system.adapter.fuelpricemonitor'            │ 'fuelpricemonitor'            │ '0.4.2'  │ 'none'         │
│ 23      │ 'system.adapter.harmony'                     │ 'harmony'                     │ '2.1.0'  │ 'none'         │
│ 24      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.20.1' │ 'none'         │
│ 25      │ 'system.adapter.iceroad'                     │ 'iceroad'                     │ '1.2.1'  │ 'none'         │
│ 26      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'  │ 'none'         │
│ 27      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'  │ 'none'         │
│ 28      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'  │ 'none'         │
│ 29      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
│ 30      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2'  │ 'none'         │
│ 31      │ 'system.adapter.imap'                        │ 'imap'                        │ '0.4.0'  │ 'none'         │
│ 32      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'  │ 'none'         │
│ 33      │ 'system.adapter.info'                        │ 'info'                        │ '2.0.0'  │ 'none'         │
│ 34      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18' │ 'none'         │
│ 35      │ 'system.adapter.lgtv'                        │ 'lgtv'                        │ '2.5.0'  │ 'none'         │
│ 36      │ 'system.adapter.logparser'                   │ 'logparser'                   │ '2.5.0'  │ 'none'         │
│ 37      │ 'system.adapter.meross'                      │ 'meross'                      │ '1.17.0' │ 'none'         │
│ 38      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.4'  │ 'none'         │
│ 39      │ 'system.adapter.netatmo'                     │ 'netatmo'                     │ '3.1.0'  │ 'none'         │
│ 40      │ 'system.adapter.nuki-extended'               │ 'nuki-extended'               │ '2.8.2'  │ 'none'         │
│ 41      │ 'system.adapter.parser'                      │ 'parser'                      │ '3.1.0'  │ 'none'         │
│ 42      │ 'system.adapter.ping'                        │ 'ping'                        │ '1.7.9'  │ 'none'         │
│ 43      │ 'system.adapter.pollenflug'                  │ 'pollenflug'                  │ '2.0.0'  │ 'none'         │
│ 44      │ 'system.adapter.proxmox'                     │ 'proxmox'                     │ '2.6.1'  │ 'none'         │
│ 45      │ 'system.adapter.pvforecast'                  │ 'pvforecast'                  │ '6.1.0'  │ 'none'         │
│ 46      │ 'system.adapter.roomba'                      │ 'roomba'                      │ '1.3.0'  │ 'none'         │
│ 47      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1' │ 'none'         │
│ 48      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
│ 49      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
│ 50      │ 'system.adapter.sonos'                       │ 'sonos'                       │ '3.0.0'  │ 'none'         │
│ 51      │ 'system.adapter.tado'                        │ 'tado'                        │ '0.8.4'  │ 'none'         │
│ 52      │ 'system.adapter.telegram'                    │ 'telegram'                    │ '4.1.0'  │ 'none'         │
│ 53      │ 'system.adapter.todoist2'                    │ 'todoist2'                    │ '0.9.1'  │ 'none'         │
│ 54      │ 'system.adapter.trashschedule'               │ 'trashschedule'               │ '5.3.0'  │ 'none'         │
│ 55      │ 'system.adapter.tvspielfilm'                 │ 'tvspielfilm'                 │ '2.1.0'  │ 'none'         │
│ 56      │ 'system.adapter.unifi'                       │ 'unifi'                       │ '0.7.0'  │ 'none'         │
│ 57      │ 'system.adapter.unifi-network'               │ 'unifi-network'               │ '1.4.0'  │ 'none'         │
│ 58      │ 'system.adapter.unifi-protect'               │ 'unifi-protect'               │ '1.0.1'  │ 'none'         │
│ 59      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
│ 60      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'  │ 'none'         │
│ 61      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.3' │ 'none'         │
│ 62      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '4.1.1'  │ 'none'         │
│ 63      │ 'system.adapter.vis-jqui-mfd'                │ 'vis-jqui-mfd'                │ '1.1.3'  │ 'none'         │
│ 64      │ 'system.adapter.vis-map'                     │ 'vis-map'                     │ '1.1.2'  │ 'none'         │
│ 65      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.9'  │ 'none'         │
│ 66      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'  │ 'none'         │
│ 67      │ 'system.adapter.vw-connect'                  │ 'vw-connect'                  │ '0.9.4'  │ 'none'         │
│ 68      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
│ 69      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'  │ 'none'         │
ioBroker-Adapter Versions and update status
Used repository: stable
Adapter    "admin"        : 7.8.23   , installed 7.8.23
Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
Adapter    "alias-manager": 2.1.0    , installed 2.1.0
Adapter    "awattar"      : 1.0.6    , installed 1.0.6
Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
Adapter    "backitup"     : 3.3.17   , installed 3.3.17
Adapter    "daikin"       : 1.5.1    , installed 1.5.1
Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
Adapter    "device-reminder": 3.1.2  , installed 3.1.2
Adapter    "device-watcher": 2.15.5  , installed 2.15.5
Adapter    "email"        : 2.0.4    , installed 2.0.4
Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
Adapter    "fakeroku"     : 0.4.0    , installed 0.4.0
Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
Adapter    "followthesun" : 0.5.2    , installed 0.5.2
Adapter    "fronius"      : 2.2.0    , installed 2.2.0
Adapter    "fronius-wattpilot": 4.8.0, installed 4.8.0
Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
Adapter    "harmony"      : 2.1.0    , installed 2.1.0
Adapter    "ical"         : 1.20.1   , installed 1.20.1
Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
Adapter    "imap"         : 0.4.0    , installed 0.4.0
Adapter    "javascript"   : 9.0.18   , installed 9.0.18
Controller "js-controller": 7.2.2    , installed 7.2.2
Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
Adapter    "logparser"    : 2.5.0    , installed 2.5.0
Adapter    "meross"       : 1.17.0   , installed 1.17.0
Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
Adapter    "nuki-extended": 2.8.2    , installed 2.8.2
Adapter    "parser"       : 3.1.0    , installed 3.1.0
Adapter    "ping"         : 1.7.9    , installed 1.7.9
Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
Adapter    "proxmox"      : 2.6.1    , installed 2.6.1
Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
Adapter    "roomba"       : 1.3.0    , installed 1.3.0
Adapter    "shelly"       : 10.6.1   , installed 10.6.1
Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
Adapter    "socketio"     : 7.1.3    , installed 7.1.3
Adapter    "sonos"        : 3.0.0    , installed 3.0.0
Adapter    "tado"         : 0.8.4    , installed 0.8.4
Adapter    "trashschedule": 5.3.0    , installed 5.3.0
Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
Adapter    "unifi"        : 0.7.0    , installed 0.7.0
Adapter    "unifi-network": 1.4.0    , installed 1.4.0
Adapter    "unifi-protect": 1.0.1    , installed 1.0.1
Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
Adapter    "web"          : 8.0.0    , installed 8.0.0
Adapter    "ws"           : 4.1.0    , installed 4.1.0
Objects and States
Objects:        19358
States:         16013
Hit:1 http://security.debian.org bookworm-security InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
Reading package lists...
Pending systemupdates: 4
*** Listening Ports ***
Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
udp   UNCONN 0      0            0.0.0.0:55935       0.0.0.0:*    users:(("io.shelly.0",pid=9337,fd=36))
udp   UNCONN 0      0            0.0.0.0:bootpc      0.0.0.0:*    users:(("dhclient",pid=93,fd=7))
udp   UNCONN 0      0            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=100,fd=5),("systemd",pid=1,fd=28))
udp   UNCONN 0      0            0.0.0.0:61991       0.0.0.0:*    users:(("io.harmony.0",pid=500,fd=30))
udp   UNCONN 0      0            0.0.0.0:5683        0.0.0.0:*    users:(("io.shelly.0",pid=9337,fd=50))
udp   UNCONN 0      0               [::]:sunrpc         [::]:*    users:(("rpcbind",pid=100,fd=7),("systemd",pid=1,fd=30))
tcp   LISTEN 0      4096         0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=100,fd=4),("systemd",pid=1,fd=27))
tcp   LISTEN 0      511          0.0.0.0:1882        0.0.0.0:*    users:(("io.shelly.1",pid=642,fd=39))
tcp   LISTEN 0      511          0.0.0.0:1883        0.0.0.0:*    users:(("io.mqtt.0",pid=570,fd=35))
tcp   LISTEN 0      511        127.0.0.1:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=150,fd=23))
tcp   LISTEN 0      511        127.0.0.1:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=150,fd=29))
tcp   LISTEN 0      100        127.0.0.1:smtp        0.0.0.0:*    users:(("master",pid=311,fd=13))
tcp   LISTEN 0      511          0.0.0.0:34027       0.0.0.0:*    users:(("io.alexa2.0",pid=786,fd=37))
tcp   LISTEN 0      511                *:8084              *:*    users:(("io.ws.0",pid=1113,fd=34))
tcp   LISTEN 0      511                *:tproxy            *:*    users:(("io.admin.1",pid=327,fd=34))
tcp   LISTEN 0      511                *:8082              *:*    users:(("io.web.0",pid=1094,fd=35))
tcp   LISTEN 0      511                *:3500              *:*    users:(("io.sonos.0",pid=666,fd=31))
tcp   LISTEN 0      511                *:61991             *:*    users:(("io.harmony.0",pid=500,fd=29))
tcp   LISTEN 0      100            [::1]:smtp           [::]:*    users:(("master",pid=311,fd=14))
tcp   LISTEN 0      4096               *:ssh               *:*    users:(("sshd",pid=157,fd=3),("systemd",pid=1,fd=45))
tcp   LISTEN 0      4096            [::]:sunrpc         [::]:*    users:(("rpcbind",pid=100,fd=6),("systemd",pid=1,fd=29))
2026-06-27 13:32:06.247  - info: admin.1 (327) ==&gt; Connected system.user.maximal1981 from ::ffff:192.168.98.43
2026-06-27 13:32:13.991  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
2026-06-27 13:32:38.075  - info: javascript.0 (373) script.js.EG.Raphael.Klima-Raphael: +++ Raphael-Temp. hat sich geändert auf: 25.06 von Soll: 22 +++
2026-06-27 13:32:40.753  - info: awtrix-light.0 (871) error ECONNABORTED from notify: timeout of 3000ms exceeded
2026-06-27 13:32:58.858  - info: daikin.1 (437) 2 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":2,"demandControl":0}
2026-06-27 13:33:14.256  - info: fahrplan.0 (1208) Updated 3 routes, 3 enabled and 0 disabled
2026-06-27 13:33:14.768  - info: fahrplan.0 (1208) Updated 1 departure timetables, 1 enabled and 0 disabled
2026-06-27 13:33:32.588  - info: admin.1 (327) &lt;== Disconnect system.user.maximal1981 from ::ffff:192.168.98.43
2026-06-27 13:34:15.400  - info: javascript.0 (373) script.js.EG.Raphael.Klima-Raphael: +++ Raphael-Temp. hat sich geändert auf: 24.84 von Soll: 22 +++
2026-06-27 13:35:02.509  - info: javascript.0 (373) script.js.Outdoor.Solarweb-Abfrage: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
2026-06-27 13:35:06.326  - info: javascript.0 (373) script.js.Outdoor.Solarweb-Abfrage: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
2026-06-27 13:35:17.202  - info: daikin.2 (449) 2 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":2,"demandControl":0}
2026-06-27 13:35:21.904  - info: daikin.0 (420) 2 Values updated: {"deviceInfo":0,"modelInfo":0,"control":0,"controlInfo":0,"sensorInfo":2,"demandControl":0}
2026-06-27 13:35:29.049  - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 30539
2026-06-27 13:35:32.949  - info: tvspielfilm.0 (30539) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v22.22.3, js-controller: 7.2.2
2026-06-27 13:35:35.050  - info: tvspielfilm.0 (30539) objects written
2026-06-27 13:35:45.557  - info: tvspielfilm.0 (30539) Terminated (NO_ERROR): Without reason
2026-06-27 13:35:46.107  - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 30539 terminated with code 0 (NO_ERROR)
2026-06-27 13:35:50.268  - info: javascript.0 (373) script.js.EG.Raphael.Klima-Raphael: +++ Raphael-Temp. hat sich geändert auf: 24.61 von Soll: 22 +++
2026-06-27 13:37:00.535  - info: javascript.0 (373) script.js.Outdoor.Solarweb-Abfrage: Solarweb Token erstellt
2026-06-27 13:37:25.152  - info: javascript.0 (373) script.js.EG.Raphael.Klima-Raphael: +++ Raphael-Temp. hat sich geändert auf: 24.22 von Soll: 22 +++
2026-06-27 13:37:25.508  - info: daikin.1 (437) 1 Values updated: {"deviceInfo":0,"modelInfo":0,"control":1,"controlInfo":0,"sensorInfo":0,"demandControl":0}
2026-06-27 13:39:00.832  - info: javascript.0 (373) script.js.EG.Raphael.Klima-Raphael: +++ Raphael-Temp. hat sich geändert auf: 23.88 von Soll: 22 +++
2026-06-27 13:39:17.863  - info: fahrplan.0 (1208) Updated 3 routes, 3 enabled and 0 disabled
2026-06-27 13:39:30.226  - info: fahrplan.0 (1208) Updated 1 departure timetables, 1 enabled and 0 disabled
</code></pre>
<p dir="auto">============= Mark until here for C&amp;P =============</p>
<p dir="auto">iob diag has finished.<br />
</p></section></section><p></p>
<p dir="auto">ich habe einen Datenpunkt boolean der im false normalerweise weiß bzw. true blau dargestellt wird. Jedoch bleibt er ab und an auf true hängen und ist dann rot.<br />
In dem Adapter werden noch 4 andere Geräte ausgelesen, und bei denen passiert das nie.<br />
Kann mir wer sagen woher das kommt, und wie ich es verhindern kann bzw. dagegen wirken kann? Muss dann am Objekt ein paar draufdrücken damit er wieder "normal" wird, und das Script wieder ordnungsgemäß arbeiten kann.</p>
]]></description><link>https://forum.iobroker.net/topic/84873/gesperrter-datenpunkt-bei-adapter-daikin-cloud</link><generator>RSS for Node</generator><lastBuildDate>Wed, 01 Jul 2026 02:21:00 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84873.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Jun 2026 11:50:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to gesperrter Datenpunkt bei adapter daikin-cloud on Sat, 27 Jun 2026 14:22:53 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maximal1981" aria-label="Profile: maximal1981">@<bdi>maximal1981</bdi></a> <a href="/post/1346262">sagte</a>:</p>
<p dir="auto">Jetzt bin ich komplett raus, habe jetzt einen Knopf im Kopf. Soweit ich es jetzt bemerkt habe, sobald das Objekt auf rot wechselt, kann es das Script nicht mehr steuern/umschalten. Wann nimmt man jetzt steuern bzw. aktualisieren?<br />
Zeig nochmal bitte</p>
</blockquote>
<ul>
<li>die Objekte / Datenpunkte um die es geht</li>
<li>den Skript-teil mit dem du den Steuerst.</li>
</ul>
<p dir="auto">A.<br />
p.s. alternativ kann ich auf Discord kommen - da können wir reden statt schreiben</p>
]]></description><link>https://forum.iobroker.net/post/1346263</link><guid isPermaLink="true">https://forum.iobroker.net/post/1346263</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Sat, 27 Jun 2026 14:22:53 GMT</pubDate></item><item><title><![CDATA[Reply to gesperrter Datenpunkt bei adapter daikin-cloud on Sat, 27 Jun 2026 14:22:19 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/asgothian" aria-label="Profile: Asgothian">@<bdi>Asgothian</bdi></a> <a href="/post/1346261">sagte</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maximal1981" aria-label="Profile: maximal1981">@<bdi>maximal1981</bdi></a> <a href="/post/1346259">sagte</a>:</p>
<p dir="auto">Ja, habe immer steuere genommen, habe einen Automatisierungstechniker Background, und ich aktualisiere Variablen, und steure dann die Komponenten mit den Werten an. Hier gehe ich mit einer anderen Denkweise an die Sache ran.<br />
Spannend ist aber trotzdem, dass die anderen Scripte der 4 Geräte gleich aufgebaut sind - nur mit anderen Parametern - und dieses Verhalten nicht aufzeigen (werde mal aber für das eine Device auf aktualisieren wechseln).</p>
</blockquote>
<p dir="auto">Ich denke ich habe mich schlecht ausgedrückt. Das Problem sind nicht deine Skripte, sondern die Verbindung zu dem oder das zu steuernde Gerät.</p>
<p dir="auto">Der Befehl wird nicht erfolgreich umgesetzt und damit nicht bestätigt. Damit ist Zustand auf dem Gerät und im Adapter nicht synchronisiert.</p>
<p dir="auto">Was du in deinen Skripten tun kannst ist versuchen zu erkennen wenn das passiert (sprich wenn ein Befehl nicht <em>acknowledged</em> wird, und dann nach einem Delay den Befehl wiederholen.</p>
<p dir="auto">A.</p>
</blockquote>
<p dir="auto">Jetzt bin ich komplett raus, habe jetzt einen Knopf im Kopf. Soweit ich es jetzt bemerkt habe, sobald das Objekt auf rot wechselt, kann es das Script nicht mehr steuern/<s>umschalten</s> aktualisieren. Wann nimmt man jetzt steuern bzw. aktualisieren?</p>
<p dir="auto">EDIT: falsche Wortwahl umschalten - aktualisieren</p>
]]></description><link>https://forum.iobroker.net/post/1346262</link><guid isPermaLink="true">https://forum.iobroker.net/post/1346262</guid><dc:creator><![CDATA[maximal1981]]></dc:creator><pubDate>Sat, 27 Jun 2026 14:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to gesperrter Datenpunkt bei adapter daikin-cloud on Sat, 27 Jun 2026 14:13:29 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1346261</link><guid isPermaLink="true">https://forum.iobroker.net/post/1346261</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Sat, 27 Jun 2026 14:13:29 GMT</pubDate></item><item><title><![CDATA[Reply to gesperrter Datenpunkt bei adapter daikin-cloud on Sat, 27 Jun 2026 14:10:28 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> <a href="/post/1346256">sagte</a>:<br />
Nein, das habe ich nicht behauptet. Es ist aber ein Punkt, der angegangen werden muss. Unabhängig von deinem konkreten Problem mit XYZ.</p>
</blockquote>
<p dir="auto">Dafür bin ich auch dankbar. Habe aber das Hochziehen der Systeme rausgeschoben, da ich aktuell beruflich mit einer längeren Weiterbildung eingespannt bin. Somit bin ich bewusst auf EOL gelaufen.</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/asgothian" aria-label="Profile: Asgothian">@<bdi>Asgothian</bdi></a> <a href="/post/1346255">sagte</a>:</p>
<p dir="auto">Du wirst überwachen müssen wann dieser DP vom Adapter 'bestätigt' wird. Wenn ein DP 'rot' bleibt dann</p>
<ul>
<li>wurde er zumeist via <code>steuere</code> angesteuert</li>
<li>hat der Adapter zumeist diesen DP nicht via <code>aktualisiere</code> aktualisiert.</li>
</ul>
<p dir="auto">Das passiert in den meisten Fällen wenn das dahinter stehende Gerät den Schaltbefehl nicht annimmt.</p>
</blockquote>
<blockquote>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maximal1981" aria-label="Profile: maximal1981">@<bdi>maximal1981</bdi></a> <a href="/post/1346254">sagte</a>:</p>
<p dir="auto">Jedoch willst du mir jetzt nicht damit sagen, dass das jetzt das Problem ist.</p>
</blockquote>
<p dir="auto">Nein, das ist es sicher <strong>nicht</strong>.</p>
</blockquote>
<p dir="auto">Habe ich vermutet, jedoch verstehe ich das Problem nicht, da bei mir eben alles via <strong>steuere</strong> aufgebaut ist (auch wenn falsch), und es nur bei dem einen Datenpunkt auftritt <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":confused:" alt="😕" /></p>
<p dir="auto">EDIT: hab mir jetzt noch die Latenz von dem Gerät angeschaut, die ist eigentlich unter den besten der anderen Geräte, um dies auszuschließen.</p>
]]></description><link>https://forum.iobroker.net/post/1346259</link><guid isPermaLink="true">https://forum.iobroker.net/post/1346259</guid><dc:creator><![CDATA[maximal1981]]></dc:creator><pubDate>Sat, 27 Jun 2026 14:10:28 GMT</pubDate></item><item><title><![CDATA[Reply to gesperrter Datenpunkt bei adapter daikin-cloud on Sat, 27 Jun 2026 13:44:05 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
<p dir="auto">Nein, das habe ich nicht behauptet. Es ist aber ein Punkt, der angegangen werden muss. Unabhängig von deinem konkreten Problem mit XYZ.</p>
]]></description><link>https://forum.iobroker.net/post/1346256</link><guid isPermaLink="true">https://forum.iobroker.net/post/1346256</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 27 Jun 2026 13:44:05 GMT</pubDate></item><item><title><![CDATA[Reply to gesperrter Datenpunkt bei adapter daikin-cloud on Sat, 27 Jun 2026 13:40:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maximal1981" aria-label="Profile: maximal1981">@<bdi>maximal1981</bdi></a> <a href="/post/1346239">sagte</a>:</p>
<p dir="auto">Kann mir wer sagen woher das kommt, und wie ich es verhindern kann bzw. dagegen wirken kann? Muss dann am Objekt ein paar draufdrücken damit er wieder "normal" wird, und das Script wieder ordnungsgemäß arbeiten kann.</p>
</blockquote>
<ul>
</ul>
p.s.</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1346255</link><guid isPermaLink="true">https://forum.iobroker.net/post/1346255</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Sat, 27 Jun 2026 13:40:18 GMT</pubDate></item><item><title><![CDATA[Reply to gesperrter Datenpunkt bei adapter daikin-cloud on Sat, 27 Jun 2026 13:35:22 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> <a href="/post/1346250">sagte</a>:</p>
<blockquote>
<p dir="auto">Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!</p>
</blockquote>
<p dir="auto">Bring es langsam mal auf Debian 13  'Trixie'.</p>
</blockquote>
<p dir="auto">da bin ich bei dir, habe vor kurzem PBS master &amp; slave hochgezogen, danach PVE, und nach dem Testbetrieb kommen die CT's dran.</p>
<blockquote>
<p dir="auto">Dann ohne graphical.target.</p>
<blockquote>
<p dir="auto">Please set BootTarget to 'multi-user.target' or run 'iobroker fix'</p>
</blockquote>
</blockquote>
<p dir="auto">ist natürlich auch ein Thema.</p>
<p dir="auto">Jedoch willst du mir jetzt nicht damit sagen, dass das jetzt das Problem ist. EOL von bookworm ist erst seit gut 2 Wochen, Problem besteht aber schon seit Aktivierung der Klima dieses Jahres. Voriges Jahr ohne Probleme. Deine Antwort zielt nur auf auf Kleinigkeiten ab, die jetzt nicht direkt mit dem Problem zusammen hängen können.</p>
<p dir="auto">Trotzdem Danke für deine Antwort, auch wenn sie dafür meines Erachtens nicht weiter zielführend sind.</p>
]]></description><link>https://forum.iobroker.net/post/1346254</link><guid isPermaLink="true">https://forum.iobroker.net/post/1346254</guid><dc:creator><![CDATA[maximal1981]]></dc:creator><pubDate>Sat, 27 Jun 2026 13:35:22 GMT</pubDate></item><item><title><![CDATA[Reply to gesperrter Datenpunkt bei adapter daikin-cloud on Sat, 27 Jun 2026 12:41:05 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1346250</link><guid isPermaLink="true">https://forum.iobroker.net/post/1346250</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 27 Jun 2026 12:41:05 GMT</pubDate></item></channel></rss>
