<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Iobroker startet nicht mehr Js 7.2.2 Update]]></title><description><![CDATA[<p dir="auto">Hallo zusammen</p>
<p dir="auto">Mein Iobroker im Synology docker will nach einem abgebrochenen Update des Js Controllers von 7.2.1 auf 7.2.2.nicht mehr starten.</p>
<pre><code>Uncaught Rejection: Error: Could not determine controller directory
    at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1854:11)
    at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1327:37)
    at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3324:30)
    at runNextTicks (node:internal/process/task_queues:64:5)
    at processImmediate (node:internal/timers:452:9)
This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
</code></pre>
<p dir="auto">wie kann ich das reparieren?</p>
<p dir="auto">Gruß<br />
HappyUser20</p>
]]></description><link>https://forum.iobroker.net/topic/84815/iobroker-startet-nicht-mehr-js-7.2.2-update</link><generator>RSS for Node</generator><lastBuildDate>Fri, 19 Jun 2026 13:51:22 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84815.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jun 2026 08:48:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 13:50:10 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcm1957" aria-label="Profile: mcm1957">@<bdi>mcm1957</bdi></a> <a href="/post/1345244">sagte</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser20" aria-label="Profile: happyuser20">@<bdi>happyuser20</bdi></a><br />
Hat eine Reinstallation wie von Marc oben beschrieben das Problem gelöst?</p>
</blockquote>
<p dir="auto">Leider nur zum Teil.<br />
Er startete zumindest wieder, aber stürzt jetzt in unregelmäßigen Abständen ab.<br />
Mal nach 5min, mal nach über 2 Std.</p>
<p dir="auto">Was auch seltsam ist, der Ordner "iobroker data! auf dem NAS ist Leer!?!</p>
<pre><code>2026/06/19 15:36:34	stderr	/opt/scripts/iobroker_startup.sh: line 591:   284 Aborted                 (core dumped) gosu iobroker node node_modules/iobroker.js-controller/controller.js
2026/06/19 15:35:32	stderr	13: 0x7f9e2666caf6
2026/06/19 15:35:32	stderr	12: 0x15080fe v8::internal::Runtime_KeyedStoreIC_Slow(int, unsigned long*, v8::internal::Isolate*) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	11: 0x18804b5 v8::internal::Runtime::SetObjectProperty(v8::internal::Isolate*, v8::internal::Handle&lt;v8::internal::Object&gt;, v8::internal::Handle&lt;v8::internal::Object&gt;, v8::internal::Handle&lt;v8::internal::Object&gt;, v8::internal::StoreOrigin, v8::Maybe&lt;v8::internal::ShouldThrow&gt;) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	10: 0x1714db2 v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle&lt;v8::internal::Object&gt;, v8::internal::PropertyAttributes, v8::Maybe&lt;v8::internal::ShouldThrow&gt;, v8::internal::StoreOrigin, v8::internal::EnforceDefineSemantics) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 9: 0x1692f37 v8::internal::JSObject::AddDataElement(v8::internal::Handle&lt;v8::internal::JSObject&gt;, unsigned int, v8::internal::Handle&lt;v8::internal::Object&gt;, v8::internal::PropertyAttributes) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 8: 0x15e7efe  [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 7: 0x17278e5 v8::internal::Handle&lt;v8::internal::NumberDictionary&gt; v8::internal::Dictionary&lt;v8::internal::NumberDictionary, v8::internal::NumberDictionaryShape&gt;::Add&lt;v8::internal::Isolate, (v8::internal::AllocationType)0&gt;(v8::internal::Isolate*, v8::internal::Handle&lt;v8::internal::NumberDictionary&gt;, unsigned int, v8::internal::Handle&lt;v8::internal::Object&gt;, v8::internal::PropertyDetails, v8::internal::InternalIndex*) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 6: 0x1726c52 v8::internal::Handle&lt;v8::internal::NumberDictionary&gt; v8::internal::HashTable&lt;v8::internal::NumberDictionary, v8::internal::NumberDictionaryShape&gt;::EnsureCapacity&lt;v8::internal::Isolate&gt;(v8::internal::Isolate*, v8::internal::Handle&lt;v8::internal::NumberDictionary&gt;, int, v8::internal::AllocationType) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 5: 0x1726a80 v8::internal::HashTable&lt;v8::internal::NumberDictionary, v8::internal::NumberDictionaryShape&gt;::Shrink(v8::internal::Isolate*, v8::internal::Handle&lt;v8::internal::NumberDictionary&gt;, int) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 4: 0x144d015  [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 3: 0x121e1a7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&amp;) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 2: 0x121ded0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&amp;) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	 1: 0xe42d60 node::OOMErrorHandler(char const*, v8::OOMDetails const&amp;) [iobroker.js-controller]
2026/06/19 15:35:32	stderr	----- Native stack trace -----
2026/06/19 15:35:32	stderr	FATAL ERROR: invalid table size Allocation failed - JavaScript heap out of memory
2026/06/19 15:35:32	stderr	&lt;--- JS stacktrace ---&gt;
2026/06/19 15:35:32	stderr	99[284:0x8436000]  8300520 ms: Mark-Compact 316.4 (345.5) -&gt; 292.4 (320.4) MB, pooled: 66 MB, 27.68 / 0.00 ms  (+ 0.1 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 459 ms) (average mu = 0.998, current mu = 0.959)[284:0x8436000]  8303988 ms: Mark-Compact 580.4 (608.4) -&gt; 412.4 (440.4) MB, pooled: 66 MB, 57.26 / 0.00 ms  (+ 0.1 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 2068 ms) (average mu = 0.996, current mu = 0.983
2026/06/19 15:35:32	stderr	&lt;--- Last few GCs ---&gt;
2026/06/19 15:34:28	stderr
2026/06/19 15:34:28	stderr	strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/properties/items/patternProperties/%5E.%2B/allOf/43/then/properties/blink" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/properties/items/patternProperties/%5E.%2B/allOf/43/then/properties/blinkOnUpdate" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/properties/items/patternProperties/%5E.%2B/allOf/43/then/properties/data" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/patternProperties/%5E.%2B/allOf/43/then/properties/blink" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/patternProperties/%5E.%2B/allOf/43/then/properties/blinkOnUpdate" (strictTypes)
2026/06/19 15:34:28	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/patternProperties/%5E.%2B/allOf/43/then/properties/data" (strictTypes)
2026/06/19 15:34:27	stderr
2026/06/19 15:34:27	stderr	strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
2026/06/19 15:34:27	stderr	strict mode: unknown keyword: "size"
2026/06/19 15:34:27	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/items/allOf/39/then/properties/blink" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/items/allOf/39/then/properties/blinkOnUpdate" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/items/allOf/39/then/properties/data" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: required property "simple" is not defined at "#/items/allOf/23/then/oneOf/1" (strictRequired)
2026/06/19 15:34:27	stderr	strict mode: required property "complex" is not defined at "#/items/allOf/23/then/oneOf/0" (strictRequired)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: required property "#include" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/1" (strictRequired)
2026/06/19 15:34:27	stderr	strict mode: required property "items" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/0" (strictRequired)
2026/06/19 15:34:27	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/properties/width" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:34:27	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:34:26	stderr
2026/06/19 15:34:26	stderr	strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
2026/06/19 15:34:26	stderr	strict mode: unknown keyword: "size"
2026/06/19 15:34:26	stderr	strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
2026/06/19 15:34:26	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
2026/06/19 15:34:26	stderr	strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
2026/06/19 15:34:26	stderr	strict mode: required property "#include" is not defined at "#/patternProperties/%5E.%2B/allOf/11/then/oneOf/1" (strictRequired)
2026/06/19 15:34:26	stderr	strict mode: required property "items" is not defined at "#/patternProperties/%5E.%2B/allOf/11/then/oneOf/0" (strictRequired)
2026/06/19 15:34:26	stderr	strict mode: required property "#include" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/11/then/oneOf/1" (strictRequired)
2026/06/19 15:34:26	stderr	strict mode: required property "items" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/11/then/oneOf/0" (strictRequired)
2026/06/19 15:34:26	stderr	strict mode: missing type "object" for keyword "properties" at "#/if" (strictTypes)
2026/06/19 15:31:18	stderr
2026/06/19 15:31:18	stderr	(Use `node --trace-deprecation ...` to show where the warning was created)
2026/06/19 15:31:18	stderr	(node:8024) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
2026/06/19 15:27:01	stderr
2026/06/19 15:27:01	stderr	strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/properties/items/patternProperties/%5E.%2B/allOf/43/then/properties/blink" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/properties/items/patternProperties/%5E.%2B/allOf/43/then/properties/blinkOnUpdate" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/properties/items/patternProperties/%5E.%2B/allOf/43/then/properties/data" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:27:01	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:27:00	stderr
2026/06/19 15:27:00	stderr	strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/interfaceProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/yamlEditorProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/jsonEditorProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/coordinatesProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/timePickerProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/oauth2Props" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/patternProperties/%5E.%2B/allOf/43/then/properties/blink" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/patternProperties/%5E.%2B/allOf/43/then/properties/blinkOnUpdate" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/patternProperties/%5E.%2B/allOf/43/then/properties/data" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:27:00	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:26:59	stderr
2026/06/19 15:26:59	stderr	strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
2026/06/19 15:26:59	stderr	strict mode: unknown keyword: "size"
2026/06/19 15:26:59	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/items/allOf/39/then/properties/blink" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/items/allOf/39/then/properties/blinkOnUpdate" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/items/allOf/39/then/properties/data" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/certificatesProps" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: required property "simple" is not defined at "#/items/allOf/23/then/oneOf/1" (strictRequired)
2026/06/19 15:26:59	stderr	strict mode: required property "complex" is not defined at "#/items/allOf/23/then/oneOf/0" (strictRequired)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: required property "#include" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/1" (strictRequired)
2026/06/19 15:26:59	stderr	strict mode: required property "items" is not defined at "#/items/allOf/10/then/allOf/1/oneOf/0" (strictRequired)
2026/06/19 15:26:59	stderr	strict mode: use allowUnionTypes to allow union type keyword at "#/properties/width" (strictTypes)
2026/06/19 15:26:59	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
2026/06/19 15:26:58	stderr
2026/06/19 15:26:58	stderr	strict mode: required property "en" is not defined at "#/definitions/multilingual" (strictRequired)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/deviceManagerProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: required property "simple" is not defined at "#/definitions/cronProps/oneOf/1" (strictRequired)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/1" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: required property "complex" is not defined at "#/definitions/cronProps/oneOf/0" (strictRequired)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps/oneOf/0" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/cronProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/qrCodeProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/aliveProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/fileSelectorProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/checkboxProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "required" at "#/definitions/passwordProps" (strictTypes)
2026/06/19 15:26:58	stderr	strict mode: unknown keyword: "size"
2026/06/19 15:26:58	stderr	strict mode: required property "#include" is not defined at "#/patternProperties/%5E.%2B/allOf/11/then/oneOf/1" (strictRequired)
2026/06/19 15:26:58	stderr	strict mode: required property "items" is not defined at "#/patternProperties/%5E.%2B/allOf/11/then/oneOf/0" (strictRequired)
2026/06/19 15:26:58	stderr	strict mode: required property "#include" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/11/then/oneOf/1" (strictRequired)
2026/06/19 15:26:58	stderr	strict mode: required property "items" is not defined at "#/properties/items/patternProperties/%5E.%2B/allOf/11/then/oneOf/0" (strictRequired)
2026/06/19 15:26:58	stderr	strict mode: missing type "object" for keyword "properties" at "#/if" (strictTypes)
2026/06/19 15:25:17	stderr	Invalid group id "g00011" in widget "w00086"
2026/06/19 15:25:17	stderr	Invalid group id "g00011" in widget "w00085"
2026/06/19 15:25:17	stderr	Invalid group id "g00011" in widget "w00084"
2026/06/19 15:25:17	stderr	Invalid group id "g00010" in widget "w00074"
2026/06/19 15:25:17	stderr	Invalid group id "g00010" in widget "w00073"
2026/06/19 15:25:17	stderr	Invalid group id "g00009" in widget "w00072"
2026/06/19 15:25:17	stderr	Invalid group id "g00009" in widget "w00064"
2026/06/19 15:25:17	stderr	Invalid group id "g00002" in widget "w00059"
2026/06/19 15:25:17	stderr	Invalid group id "g00002" in widget "w00058"
2026/06/19 15:25:17	stderr	Invalid group id "g00002" in widget "w00057"
2026/06/19 15:25:17	stderr	Invalid group id "g00002" in widget "w00056"
2026/06/19 15:25:17	stderr	Invalid group id "g00003" in widget "w00055"
2026/06/19 15:25:17	stderr	Invalid group id "g00003" in widget "w00054"
2026/06/19 15:25:17	stderr	Invalid group id "g00003" in widget "w00053"
2026/06/19 15:25:17	stderr	Invalid group id "g00003" in widget "w00052"
2026/06/19 15:25:17	stderr	Invalid group id "g00005" in widget "w00051"
2026/06/19 15:25:17	stderr	Invalid group id "g00005" in widget "w00050"
2026/06/19 15:25:17	stderr	Invalid group id "g00005" in widget "w00049"
2026/06/19 15:25:17	stderr	Invalid group id "g00005" in widget "w00048"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00047"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00046"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00045"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00044"
2026/06/19 15:25:17	stderr	Invalid group id "g00005" in widget "w00030"
2026/06/19 15:25:17	stderr	Invalid group id "g00003" in widget "w00029"
2026/06/19 15:25:17	stderr	Invalid group id "g00002" in widget "w00028"
2026/06/19 15:25:17	stderr	Invalid group id "g00004" in widget "w00021"
2026/06/19 15:25:17	stderr	Invalid group id "g00004" in widget "w00020"
2026/06/19 15:25:17	stderr	Invalid group id "g00004" in widget "w00019"
2026/06/19 15:25:17	stderr	Invalid group id "g00004" in widget "w00018"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00017"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00016"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00015"
2026/06/19 15:25:17	stderr	Invalid group id "g00006" in widget "w00014"
2026/06/19 15:25:17	stderr	Invalid group id "g00006" in widget "w00013"
2026/06/19 15:25:17	stderr	Invalid group id "g00006" in widget "w00012"
2026/06/19 15:25:17	stderr	Invalid group id "g00006" in widget "w00011"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00010"
2026/06/19 15:25:17	stderr	Invalid group id "g00008" in widget "w00009"
2026/06/19 15:25:17	stderr	Invalid group id "g00007" in widget "w00008"
2026/06/19 15:25:17	stderr	Invalid group id "g00007" in widget "w00003"
2026/06/19 15:25:16	stderr	Invalid group id "g00011" in widget "w00086"
2026/06/19 15:25:16	stderr	Invalid group id "g00011" in widget "w00085"
2026/06/19 15:25:16	stderr	Invalid group id "g00011" in widget "w00084"
2026/06/19 15:25:16	stderr	Invalid group id "g00010" in widget "w00074"
2026/06/19 15:25:16	stderr	Invalid group id "g00010" in widget "w00073"
2026/06/19 15:25:16	stderr	Invalid group id "g00009" in widget "w00072"
2026/06/19 15:25:16	stderr	Invalid group id "g00009" in widget "w00064"
2026/06/19 15:25:16	stderr	Invalid group id "g00002" in widget "w00059"
2026/06/19 15:25:16	stderr	Invalid group id "g00002" in widget "w00058"
2026/06/19 15:25:16	stderr	Invalid group id "g00002" in widget "w00057"
2026/06/19 15:25:16	stderr	Invalid group id "g00002" in widget "w00056"
2026/06/19 15:25:16	stderr	Invalid group id "g00003" in widget "w00055"
2026/06/19 15:25:16	stderr	Invalid group id "g00003" in widget "w00054"
2026/06/19 15:25:16	stderr	Invalid group id "g00003" in widget "w00053"
2026/06/19 15:25:16	stderr	Invalid group id "g00003" in widget "w00052"
2026/06/19 15:25:16	stderr	Invalid group id "g00005" in widget "w00051"
2026/06/19 15:25:16	stderr	Invalid group id "g00005" in widget "w00050"
2026/06/19 15:25:16	stderr	Invalid group id "g00005" in widget "w00049"
2026/06/19 15:25:16	stderr	Invalid group id "g00005" in widget "w00048"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00047"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00046"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00045"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00044"
2026/06/19 15:25:16	stderr	Invalid group id "g00005" in widget "w00030"
2026/06/19 15:25:16	stderr	Invalid group id "g00003" in widget "w00029"
2026/06/19 15:25:16	stderr	Invalid group id "g00002" in widget "w00028"
2026/06/19 15:25:16	stderr	Invalid group id "g00004" in widget "w00021"
2026/06/19 15:25:16	stderr	Invalid group id "g00004" in widget "w00020"
2026/06/19 15:25:16	stderr	Invalid group id "g00004" in widget "w00019"
2026/06/19 15:25:16	stderr	Invalid group id "g00004" in widget "w00018"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00017"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00016"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00015"
2026/06/19 15:25:16	stderr	Invalid group id "g00006" in widget "w00014"
2026/06/19 15:25:16	stderr	Invalid group id "g00006" in widget "w00013"
2026/06/19 15:25:16	stderr	Invalid group id "g00006" in widget "w00012"
2026/06/19 15:25:16	stderr	Invalid group id "g00006" in widget "w00011"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00010"
2026/06/19 15:25:16	stderr	Invalid group id "g00008" in widget "w00009"
2026/06/19 15:25:16	stderr	Invalid group id "g00007" in widget "w00008"
2026/06/19 15:25:16	stderr	Invalid group id "g00007" in widget "w00003"
2026/06/19 15:25:06	stdout	Send diag info: {"uuid":"db9a0c91-73f5-efce-85ee-dab4a2d48543","language":"de","country":"Germany","hosts":[{"version":"7.2.2","platform":"Javascript/Node.js","type":"linux"},{"version":"7.2.2","platform":"Javascript/Node.js","type":"linux"}],"node":"v22.22.2","arch":"x64","docker":true,"adapters":{"admin":{"version":"7.8.23","platform":"Javascript/Node.js","installedFrom":"iobroker.admin@7.8.23"},"discovery":{"version":"5.0.0","platform":"Javascript/Node.js"},"backitup":{"version":"3.3.17","platform":"Javascript/Node.js","installedFrom":"iobroker.backitup@3.3.17"},"alexa2":{"version":"3.27.4","platform":"Javascript/Node.js","installedFrom":"iobroker.alexa2@3.27.4"},"bambulab":{"version":"0.3.2","platform":"Javascript/Node.js","installedFrom":"DrozmotiX/ioBroker.bambulab#fd28f98d7ec46f36f4a2dae2d9ac740966453704"},"birthdays":{"version":"5.0.0","platform":"Javascript/Node.js","installedFrom":"iobroker.birthdays@5.0.0"},"device-reminder":{"version":"3.1.2","platform":"Javascript/Node.js","installedFrom":"iobroker.device-reminder@3.1.2"},"devices":{"version":"1.2.14","platform":"Javascript/Node.js","installedFrom":"iobroker.devices@1.2.14"},"dwd":{"version":"2.8.5","platform":"Javascript/Node.js","installedFrom":"iobroker.dwd@2.8.5"},"echarts":{"version":"3.1.0","platform":"Javascript/Node.js","installedFrom":"iobroker.echarts@3.1.0"},"energiefluss":{"version":"3.6.2","platform":"Javascript/Node.js","installedFrom":"iobroker.energiefluss@3.6.2"},"energiefluss-erweitert":{"version":"0.8.1","platform":"Javascript/Node.js","installedFrom":"iobroker.energiefluss-erweitert@0.8.1"},"esphome":{"version":"0.5.0-beta.10","platform":"Javascript/Node.js","installedFrom":"DrozmotiX/ioBroker.esphome#8ca51cd0460c21c1a817acc18c774da1fcf4f5ff"},"fb-checkpresence":{"version":"1.4.2","platform":"Javascript/Node.js","installedFrom":"iobroker.fb-checkpresence@1.4.2"},"fronius":{"version":"2.2.0","platform":"Javascript/Node.js","installedFrom":"iobroker.fronius@2.2.0"},"fronius-solarweb":{"version":"0.1.0","platform":"Javascript/Node.js","installedFrom":"TA2k/ioBroker.fronius-solarweb#ca2f1a4972992cbd0d14bb25f5f7546219dd5b9e"},"fullybrowser":{"version":"3.1.2","platform":"Javascript/Node.js","installedFrom":"iobroker.fullybrowser@3.1.2"},"hass":{"version":"1.4.0","platform":"Javascript/Node.js","installedFrom":"iobroker.hass@1.4.0"},"heizoel":{"version":"1.0.3","platform":"Javascript/Node.js","installedFrom":"iobroker.heizoel@1.0.3"},"history":{"version":"4.0.0","platform":"Javascript/Node.js","installedFrom":"iobroker.history@4.0.0"},"hmip":{"version":"1.27.0","platform":"Javascript/Node.js","installedFrom":"iobroker.hmip@1.27.0"},"homeconnect":{"version":"1.6.1","platform":"Javascript/Node.js","installedFrom":"iobroker.homeconnect@1.6.1"},"ical":{"version":"1.20.1","platform":"Javascript/Node.js","installedFrom":"iobroker.ical@1.20.1"},"icons-mfd-svg":{"version":"1.2.0","platform":"Javascript/Node.js","installedFrom":"iobroker.icons-mfd-svg@1.2.0"},"influxdb":{"version":"4.0.2","platform":"Javascript/Node.js","installedFrom":"iobroker.influxdb@4.0.2"},"iot":{"version":"6.0.3","platform":"Javascript/Node.js","installedFrom":"iobroker.iot@6.0.3"},"javascript":{"version":"9.0.18","platform":"Javascript/Node.js","installedFrom":"iobroker.javascript@9.0.18"},"linkeddevices":{"version":"1.5.5","platform":"Javascript/Node.js","installedFrom":"Scrounger/ioBroker.linkeddevices"},"modbus":{"version":"8.0.3","platform":"Javascript/Node.js","installedFrom":"iobroker.modbus@8.0.3"},"mqtt":{"version":"6.1.4","platform":"Javascript/Node.js","installedFrom":"iobroker.mqtt@6.1.4"},"pvforecast":{"version":"6.1.0","platform":"Javascript/Node.js","installedFrom":"iobroker.pvforecast@6.1.0"},"reolink":{"version":"1.4.2","platform":"Javascript/Node.js","installedFrom":"iobroker.reolink@1.4.2"},"sayit":{"version":"5.1.0","platform":"Javascript/Node.js","installedFrom":"iobroker.sayit@5.1.0"},"shelly":{"version":"10.6.1","platform":"Javascript/Node.js","installedFrom":"iobroker.shelly@10.6.1"},"simple-api":{"version":"3.0.7","platform":"Javascript/Node.js","installedFrom":"iobroker.simple-api@3.0.7"},"smartgarden":{"version":"2.0.1","platform":"Javascript/Node.js","installedFrom":"iobroker.smartgarden@2.0.1"},"smartmeter":{"version":"3.4.0","platform":"Javascript/Node.js","installedFrom":"iobroker.smartmeter@3.4.0"},"snmp":{"version":"3.4.0","platform":"Javascript/Node.js","installedFrom":"iobroker.snmp@3.4.0"},"socketio":{"version":"7.1.3","platform":"Javascript/Node.js","installedFrom":"iobroker.socketio@7.1.3"},"sourceanalytix":{"version":"0.4.14","platform":"Javascript/Node.js","installedFrom":"DrozmotiX/ioBroker.sourceanalytix#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19"},"spritmonitor":{"version":"0.0.2-beta.10","platform":"Javascript/Node.js","installedFrom":"ice987987/ioBroker.spritmonitor#4059f9e2e3019b0a025fd7af850c259a84a797de"},"synology":{"version":"3.1.0","platform":"Javascript/Node.js","installedFrom":"iobroker.synology@3.1.0"},"tankerkoenig":{"version":"3.4.0","platform":"Javascript/Node.js","installedFrom":"iobroker.tankerkoenig@3.4.0"},"text2command":{"version":"4.0.0","platform":"Javascript/Node.js","installedFrom":"iobroker.text2command@4.0.0"},"tr-064":{"version":"4.3.0","platform":"Javascript/Node.js","installedFrom":"iobroker.tr-064@4.3.0"},"trashschedule":{"version":"5.3.0","platform":"Javascript/Node.js","installedFrom":"iobroker.trashschedule@5.3.0"},"tuya":{"version":"3.17.0","platform":"Javascript/Node.js","installedFrom":"iobroker.tuya@3.17.0"},"upnp":{"version":"1.1.0","platform":"Javascript/Node.js","installedFrom":"iobroker.upnp@1.1.0"},"vis":{"version":"1.5.6","platform":"Javascript/Node.js","installedFrom":"iobroker.vis@1.5.6"},"vis-2":{"version":"2.13.8","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-2@2.13.8"},"vis-canvas-gauges":{"version":"1.0.1","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-canvas-gauges@1.0.1"},"vis-colorpicker":{"version":"2.1.0","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-colorpicker@2.1.0"},"vis-google-fonts":{"version":"1.0.4","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-google-fonts@1.0.4"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-history@1.0.0"},"vis-hqwidgets":{"version":"1.6.1","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-hqwidgets@1.6.1"},"vis-icontwo":{"version":"2.11.3","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-icontwo@2.11.3"},"vis-inventwo":{"version":"4.1.1","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-inventwo@4.1.1"},"vis-jqui-mfd":{"version":"1.1.3","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-jqui-mfd@1.1.3"},"vis-justgage":{"version":"2.1.7","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-justgage@2.1.7"},"vis-material-advanced":{"version":"1.7.4","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-material-advanced@1.7.4"},"vis-materialdesign":{"version":"0.5.94","platform":"Javascript/Node.js","installedFrom":"Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92"},"vis-metro":{"version":"1.2.0","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-metro@1.2.0"},"vis-plumb":{"version":"1.0.2","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-plumb@1.0.2"},"vis-rgraph":{"version":"0.0.2","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-rgraph@0.0.2"},"vis-timeandweather":{"version":"1.2.2","platform":"Javascript/Node.js","installedFrom":"iobroker.vis-timeandweather@1.2.2"},"weatherunderground":{"version":"3.7.0","platform":"Javascript/Node.js","installedFrom":"iobroker.weatherunderground@3.7.0"},"web":{"version":"8.0.0","platform":"Javascript/Node.js","installedFrom":"iobroker.web@8.0.0"},"whatsapp-cmb":{"version":"0.3.0","platform":"Javascript/Node.js","installedFrom":"iobroker.whatsapp-cmb@0.3.0"},"wled":{"version":"0.7.3","platform":"Javascript/Node.js","installedFrom":"iobroker.wled@0.7.3"},"ws":{"version":"4.1.0","platform":"Javascript/Node.js","installedFrom":"iobroker.ws@4.1.0"},"ds18b20":{"version":"3.1.1","platform":"Javascript/Node.js","installedFrom":"iobroker.ds18b20@3.1.1"},"viessmann":{"version":"1.7.3","platform":"Javascript/Node.js","installedFrom":"iobroker.viessmann@1.7.3"},"viessmannapi":{"version":"2.4.4","platform":"Javascript/Node.js","installedFrom":"TA2k/ioBroker.viessmannapi#6181ab8a2a820b718d64e6c784a2d5f78e4d8e9d"},"daswetter":{"version":"4.5.3","platform":"Javascript/Node.js","installedFrom":"iobroker.daswetter@4.5.3"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":75,"compactMode":false,"noCompactInstances":0,"model":"Intel(R) Celeron(R) CPU J3355 @ 2.00GHz","cpus":2,"mem":16624197632,"ostype":"Linux","city":"93474","vis":274,"vis-2":274}
2026/06/19 15:25:05	stderr	Invalid group id "g00011" in widget "w00086"
2026/06/19 15:25:05	stderr	Invalid group id "g00011" in widget "w00085"
2026/06/19 15:25:05	stderr	Invalid group id "g00011" in widget "w00084"
2026/06/19 15:25:05	stderr	Invalid group id "g00010" in widget "w00074"
2026/06/19 15:25:05	stderr	Invalid group id "g00010" in widget "w00073"
2026/06/19 15:25:05	stderr	Invalid group id "g00009" in widget "w00072"
2026/06/19 15:25:05	stderr	Invalid group id "g00009" in widget "w00064"
2026/06/19 15:25:05	stderr	Invalid group id "g00002" in widget "w00059"
2026/06/19 15:25:05	stderr	Invalid group id "g00002" in widget "w00058"
2026/06/19 15:25:05	stderr	Invalid group id "g00002" in widget "w00057"
2026/06/19 15:25:05	stderr	Invalid group id "g00002" in widget "w00056"
2026/06/19 15:25:05	stderr	Invalid group id "g00003" in widget "w00055"
2026/06/19 15:25:05	stderr	Invalid group id "g00003" in widget "w00054"
2026/06/19 15:25:05	stderr	Invalid group id "g00003" in widget "w00053"
2026/06/19 15:25:05	stderr	Invalid group id "g00003" in widget "w00052"
2026/06/19 15:25:05	stderr	Invalid group id "g00005" in widget "w00051"
2026/06/19 15:25:05	stderr	Invalid group id "g00005" in widget "w00050"
2026/06/19 15:25:05	stderr	Invalid group id "g00005" in widget "w00049"
2026/06/19 15:25:05	stderr	Invalid group id "g00005" in widget "w00048"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00047"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00046"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00045"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00044"
2026/06/19 15:25:05	stderr	Invalid group id "g00005" in widget "w00030"
2026/06/19 15:25:05	stderr	Invalid group id "g00003" in widget "w00029"
2026/06/19 15:25:05	stderr	Invalid group id "g00002" in widget "w00028"
2026/06/19 15:25:05	stderr	Invalid group id "g00004" in widget "w00021"
2026/06/19 15:25:05	stderr	Invalid group id "g00004" in widget "w00020"
2026/06/19 15:25:05	stderr	Invalid group id "g00004" in widget "w00019"
2026/06/19 15:25:05	stderr	Invalid group id "g00004" in widget "w00018"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00017"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00016"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00015"
2026/06/19 15:25:05	stderr	Invalid group id "g00006" in widget "w00014"
2026/06/19 15:25:05	stderr	Invalid group id "g00006" in widget "w00013"
2026/06/19 15:25:05	stderr	Invalid group id "g00006" in widget "w00012"
2026/06/19 15:25:05	stderr	Invalid group id "g00006" in widget "w00011"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00010"
2026/06/19 15:25:05	stderr	Invalid group id "g00008" in widget "w00009"
2026/06/19 15:25:05	stderr	Invalid group id "g00007" in widget "w00008"
2026/06/19 15:25:05	stderr	Invalid group id "g00007" in widget "w00003"
2026/06/19 15:25:04	stderr	Invalid group id "g00004" in widget "w00021"
2026/06/19 15:25:04	stderr	Invalid group id "g00004" in widget "w00020"
2026/06/19 15:25:04	stderr	Invalid group id "g00004" in widget "w00019"
2026/06/19 15:25:04	stderr	Invalid group id "g00004" in widget "w00018"
2026/06/19 15:25:04	stderr	Invalid group id "g00008" in widget "w00017"
2026/06/19 15:25:04	stderr	Invalid group id "g00008" in widget "w00016"
2026/06/19 15:25:04	stderr	Invalid group id "g00008" in widget "w00015"
2026/06/19 15:25:04	stderr	Invalid group id "g00006" in widget "w00014"
2026/06/19 15:25:04	stderr	Invalid group id "g00006" in widget "w00013"
2026/06/19 15:25:04	stderr	Invalid group id "g00006" in widget "w00012"
2026/06/19 15:25:04	stderr	Invalid group id "g00006" in widget "w00011"
2026/06/19 15:25:04	stderr	Invalid group id "g00008" in widget "w00010"
2026/06/19 15:25:04	stderr	Invalid group id "g00008" in widget "w00009"
2026/06/19 15:25:04	stderr	Invalid group id "g00007" in widget "w00008"
2026/06/19 15:25:04	stderr	Invalid group id "g00007" in widget "w00003"
2026/06/19 15:25:01	stdout	================================== &gt; LOG REDIRECT system.adapter.admin.0 =&gt; true [system.adapter.admin.0.logging]
2026/06/19 15:19:01	stdout	================================== &gt; LOG REDIRECT system.adapter.admin.0 =&gt; false [system.adapter.admin.0.logging]
2026/06/19 15:18:11	stdout	================================== &gt; LOG REDIRECT system.adapter.admin.0 =&gt; true [system.adapter.admin.0.logging]
2026/06/19 15:06:53	stdout	================================== &gt; LOG REDIRECT system.adapter.admin.0 =&gt; false [system.adapter.admin.0.logging]
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345245</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345245</guid><dc:creator><![CDATA[Happyuser20]]></dc:creator><pubDate>Fri, 19 Jun 2026 13:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 13:47:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser20" aria-label="Profile: happyuser20">@<bdi>happyuser20</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/1345244</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345244</guid><dc:creator><![CDATA[mcm1957]]></dc:creator><pubDate>Fri, 19 Jun 2026 13:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 13:43:53 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcm1957" aria-label="Profile: mcm1957">@<bdi>mcm1957</bdi></a> <a href="/post/1345200">sagte</a>:</p>
<blockquote>
<p dir="auto">nach einem abgebrochenen Update des Js Controllers</p>
</blockquote>
<p dir="auto">Was hat den Abbruch ausgelöst? Ein Fehler im Updateprozess selbst  oder ein Bedienungsfehler, Stromausfall, ...<br />
Geht nur drum zu beobachten ob ein generelles Problem vorliegen könnte.</p>
</blockquote>
<p dir="auto">Das kann ich leider nicht mehr genau sagen Irgendwas mit "Failure Fetch Localhost"</p>
]]></description><link>https://forum.iobroker.net/post/1345243</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345243</guid><dc:creator><![CDATA[Happyuser20]]></dc:creator><pubDate>Fri, 19 Jun 2026 13:43:53 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 09:48:04 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1345200</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345200</guid><dc:creator><![CDATA[mcm1957]]></dc:creator><pubDate>Fri, 19 Jun 2026 09:48:04 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 09:15:03 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser20" aria-label="Profile: Happyuser20">@<bdi>Happyuser20</bdi></a> <a href="/post/1345180">sagte</a>:</p>
<p dir="auto">wie kann ich das reparieren?</p>
</blockquote>
<p dir="auto">Versuch's mal so:</p>
<pre><code>cd /opt/iobroker
npm install iobroker.js-controller
</code></pre>
<ul>
<li>Container Neustart</li>
</ul>
]]></description><link>https://forum.iobroker.net/post/1345190</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345190</guid><dc:creator><![CDATA[Marc Berg]]></dc:creator><pubDate>Fri, 19 Jun 2026 09:15:03 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 09:11:37 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcm1957" aria-label="Profile: mcm1957">@<bdi>mcm1957</bdi></a> <a href="/post/1345186">sagte</a>:</p>
<blockquote>
<p dir="auto">Hallo zusammen</p>
<p dir="auto">Mein Iobroker im Synology docker will nach einem abgebrochenen Update des Js Controllers von 7.2.1 auf 7.2.2.nicht mehr starten.</p>
<pre><code>Uncaught Rejection: Error: Could not determine controller directory
    at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1854:11)
    at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1327:37)
    at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3324:30)
    at runNextTicks (node:internal/process/task_queues:64:5)
    at processImmediate (node:internal/timers:452:9)
This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
</code></pre>
<p dir="auto">Gruß<br />
HappyUser20</p>
</blockquote>
<p dir="auto">Welche node.js Version verwendet du?</p>
</blockquote>
<p dir="auto">soweit ich das noch im Kopf habe, v22.22.3 ?</p>
]]></description><link>https://forum.iobroker.net/post/1345189</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345189</guid><dc:creator><![CDATA[Happyuser20]]></dc:creator><pubDate>Fri, 19 Jun 2026 09:11:37 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 08:58:18 GMT]]></title><description><![CDATA[<blockquote>
</code></pre>
HappyUser20</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1345186</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345186</guid><dc:creator><![CDATA[mcm1957]]></dc:creator><pubDate>Fri, 19 Jun 2026 08:58:18 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 08:53:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/happyuser20" aria-label="Profile: Happyuser20">@<bdi>Happyuser20</bdi></a> .. den Punkt bei der Version falsch gesetzt. Bitte berichtigen.</p>
<p dir="auto">Die Versionen lauten:<br />
7.2.1 und 7.2.2</p>
<p dir="auto">Das verwirrt sonst nur.</p>
]]></description><link>https://forum.iobroker.net/post/1345185</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345185</guid><dc:creator><![CDATA[skvarel]]></dc:creator><pubDate>Fri, 19 Jun 2026 08:53:08 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 08:52:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skvarel" aria-label="Profile: skvarel">@<bdi>skvarel</bdi></a> <a href="/post/1345182">sagte</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ro75" aria-label="Profile: Ro75">@<bdi>Ro75</bdi></a> .. die 7.2.2 ist Stable</p>
<p dir="auto"><img src="/assets/uploads/files/1781859073671-f9b19a7c-57ef-4714-bfd9-d448a9c188b0-image.jpeg" alt="f9b19a7c-57ef-4714-bfd9-d448a9c188b0-image.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>EDIT:</strong><br />
Helfen kann ich aber leider nicht. Hier läuft es mir der Version einwandfrei</p>
</blockquote>
<p dir="auto">Die wars.</p>
]]></description><link>https://forum.iobroker.net/post/1345183</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345183</guid><dc:creator><![CDATA[Happyuser20]]></dc:creator><pubDate>Fri, 19 Jun 2026 08:52:39 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 08:54:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ro75" aria-label="Profile: Ro75">@<bdi>Ro75</bdi></a> .. die 7.2.2 ist Stable</p>
Helfen kann ich aber leider nicht. Hier läuft es mir der Version einwandfrei<br />
<img src="/assets/uploads/files/1781859287937-14bec45b-6e68-4bfd-abce-c950541039d6-image.jpeg" alt="14bec45b-6e68-4bfd-abce-c950541039d6-image.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/1345182</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345182</guid><dc:creator><![CDATA[skvarel]]></dc:creator><pubDate>Fri, 19 Jun 2026 08:54:50 GMT</pubDate></item><item><title><![CDATA[Reply to Iobroker startet nicht mehr Js 7.2.2 Update on Fri, 19 Jun 2026 08:49:47 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Update des Js Controllers von 7.21 auf 7.22.</p>
</blockquote>
<p dir="auto">wo holst du diese Version her? Aktuell ist 7.1.2. Bist du BETA-Tester?</p>
<p dir="auto">Ro75.</p>
]]></description><link>https://forum.iobroker.net/post/1345181</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345181</guid><dc:creator><![CDATA[Ro75]]></dc:creator><pubDate>Fri, 19 Jun 2026 08:49:47 GMT</pubDate></item></channel></rss>
