<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Disk voll und Cloud Problem]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">weis jemand warum iobroker meldet meine Disk sei voll? Laut iob diag ist Sie nicht, oder?<br />
Die InfluxDB hab ich von 3 Monaten mal auf 1 Monat "speichern" gestellt.<br />
Desweiteren melde mein mein Cloud Adapter:</p>
<pre><code>host.raspberrypi
2026-05-04 10:42:29.928	error	startInstance system.adapter.cloud.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "7.7.22", required "&gt;=7.8.3"!
</code></pre>
<pre><code>
```bash
Script v.2026-01-31
*** BASE SYSTEM ***
Operating System: Debian GNU/Linux 13 (trixie)
 Static hostname: raspberrypi
       Icon name: computer
          Kernel: Linux 6.12.75+rpt-rpi-v8
    Architecture: arm64
OS is similar to:
Model           : Raspberry Pi 4 Model B Rev 1.5
Docker          : false
Virtualization  : none
Kernel          : aarch64
Userland        : 64 bit
Systemuptime and Load:
 10:03:39 up  1:07,  1 user,  load average: 0.78, 0.41, 0.35
CPU threads: 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'trixie'!
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** TIME AND TIMEZONES ***
               Local time: Mon 2026-05-04 10:03:39 CEST
           Universal time: Mon 2026-05-04 08:03:39 UTC
                 RTC time: n/a
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
pi
HOME=/home/pi
GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c        spi render input iobroker
iobroker
HOME=/home/iobroker
SUDO_HOME=/home/pi
*** DISPLAY-SERVER SETUP ***
Display-Server:         false
Unit display-manager.service could not be found.
Display-Manager:
Desktop:
Session:                tty
*** MEMORY ***
Mem:            4.0G        3.0G        412M        5.1M        621M        932M
Swap:           2.1G        345M        1.8G
Total:          6.1G        3.4G        2.2G
Active iob-Instances:   24
         3796 M total memory
         2907 M used memory
         1924 M active memory
         1112 M inactive memory
          392 M free memory
           66 M buffer memory
          525 M swap cache
         2047 M total swap
          329 M used swap
         1718 M free swap
top - 10:03:39 up  1:07,  1 user,  load average: 0.78, 0.41, 0.35
Tasks: 221 total,   1 running, 220 sleeping,   0 stopped,   0 zombie
%Cpu(s):  2.1 us,  2.1 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   3796.7 total,    392.0 free,   2908.3 used,    592.8 buff/cache
MiB Swap:   2048.0 total,   1718.4 free,    329.6 used.    888.3 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  1.6G     0  1.6G   0% /dev
tmpfs          tmpfs     760M  9.3M  751M   2% /run
/dev/mmcblk0p2 ext4       29G   27G  1.4G  96% /
tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald        .service
tmpfs          tmpfs     1.9G  2.5M  1.9G   1% /tmp
/dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.servi        ce
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@tty        S0.service
tmpfs          tmpfs     380M  8.0K  380M   1% /run/user/1000
[Mon May  4 08:55:50 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[Mon May  4 08:55:50 2026] EXT4-fs (mmcblk0p2): mounted filesystem 21724cc6-e5a3        -48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
[Mon May  4 08:55:52 2026] EXT4-fs (mmcblk0p2): re-mounted 21724cc6-e5a3-48a1-86        43-7917dba3a9fb r/w.
Show mounted filesystems:
TARGET           SOURCE         FSTYPE OPTIONS
/                /dev/mmcblk0p2 ext4   rw,noatime
`-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
20G     /var/
18G     /var/lib/influxdb/engine/data/18d2b1b0b749b5ec/autogen
Archived and active journals take up 8M in the file system.
/opt/iobroker/backups:
265M    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
289M    /opt/iobroker/iobroker-data/
144M    /opt/iobroker/iobroker-data/files
108M    /opt/iobroker/iobroker-data/backup-objects
47M     /opt/iobroker/iobroker-data/files/admin.admin
46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
34M     /opt/iobroker/iobroker-data/objects.jsonl
8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.j        s
4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescrip        t/tsWorker.js
4.4M    /opt/iobroker/iobroker-data/backup-objects/2026-05-04_06-25_objects.json        l.gz
4.4M    /opt/iobroker/iobroker-data/backup-objects/2026-05-04_04-25_objects.json        l.gz
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
No nvbackup.json found.
*** NodeJS-Installation ***
/usr/bin/nodejs         v24.15.0
/usr/bin/node           v24.15.0
/usr/bin/npm            11.12.1
/usr/bin/npx            11.12.1
✓ Node.js installation is correct
nodejs:
  Installed: 24.15.0-1nodesource1
  Candidate: 24.15.0-1nodesource1
  Version table:
 *** 24.15.0-1nodesource1 1001
        500 https://deb.nodesource.com/node_24.x nodistro/main arm64 Packages
        100 /var/lib/dpkg/status
     24.14.1-1nodesource1 1001
     24.14.0-1nodesource1 1001
     24.13.1-1nodesource1 1001
     24.13.0-1nodesource1 1001
     24.12.0-1nodesource1 1001
     24.11.1-1nodesource1 1001
     24.11.0-1nodesource1 1001
     24.10.0-1nodesource1 1001
     24.9.0-1nodesource1 1001
     24.8.0-1nodesource1 1001
     24.7.0-1nodesource1 1001
     24.6.0-1nodesource1 1001
     24.5.0-1nodesource1 1001
     24.4.1-1nodesource1 1001
     24.4.0-1nodesource1 1001
     24.3.0-1nodesource1 1001
     24.1.0-1nodesource1 1001
     24.0.2-1nodesource1 1001
     24.0.1-1nodesource1 1001
     24.0.0-1nodesource1 1001
     20.19.2+dfsg-1+deb13u2 500
        500 http://deb.debian.org/debian-security trixie-security/main arm64 Pac        kages
     20.19.2+dfsg-1 500
        500 http://deb.debian.org/debian trixie/main arm64 Packages
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive        , uptime: 4032)
Core adapters versions
js-controller:  7.0.7
admin:          7.7.22
javascript:     9.0.18
nodejs modules from github:     0
Adapter State
+ system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
+ system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi        -  enabled
+ system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
  system.adapter.cloud.0                  : cloud                 : raspberrypi        -  enabled
+ system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi        -  enabled
+ system.adapter.daikin.0                 : daikin                : raspberrypi        -  enabled
+ system.adapter.daikin.1                 : daikin                : raspberrypi        -  enabled
+ system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
+ system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi        -  enabled
+ system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi        -  enabled
+ system.adapter.history.0                : history               : raspberrypi        -  enabled
  system.adapter.homeconnect.0            : homeconnect           : raspberrypi        - disabled
+ system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
+ system.adapter.iqontrol.0               : iqontrol              : raspberrypi        -  enabled
+ system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
+ system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi        -  enabled
+ system.adapter.meross.0                 : meross                : raspberrypi        -  enabled
+ system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1885, bind: 0.0.0.0
+ system.adapter.myenergi.0               : myenergi              : raspberrypi        -  enabled
+ system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.sun2000.0                : sun2000               : raspberrypi        -  enabled, port: 502
+ system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi        -  enabled
+ system.adapter.tuya.0                   : tuya                  : raspberrypi        -  enabled
+ system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
+ system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi        -  enabled
+ instance is alive
ioBroker-Repositories
│ (index) │ name     │ url                                                     │        auto upgrade │
│ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │        false        │
│ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │        false        │
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
Used repository: stable
Adapter    "admin"        : 7.7.22   , installed 7.7.22
Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
Adapter    "backitup"     : 3.3.14   , installed 3.3.14
Adapter    "cloud"        : 5.0.1    , installed 6.0.1
Adapter    "daikin"       : 1.5.1    , installed 1.5.1
Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
Adapter    "history"      : 4.0.0    , installed 4.0.0
Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
Adapter    "javascript"   : 9.0.18   , installed 9.0.18
Controller "js-controller": 7.0.7    , installed 7.0.7
Adapter    "lg-thinq"     : 1.1.6    , installed 1.1.6
Adapter    "meross"       : 1.17.0   , installed 1.17.0
Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
Adapter    "shelly"       : 10.6.1   , installed 10.6.1
Adapter    "socketio"     : 7.0.8    , installed 7.0.8
Adapter    "sun2000"      : 2.4.3    , installed 2.4.3
Adapter    "tesla-motors" : 1.5.0    , installed 1.5.0
Adapter    "tuya"         : 3.17.0   , installed 3.17.0
Adapter    "web"          : 8.0.0    , installed 8.0.0
Adapter    "ws"           : 4.0.0    , installed 4.0.0
Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
Objects and States
Objects:        6669
States:         5202
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://deb.debian.org/debian trixie-updates InRelease
Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
Hit:5 https://apt.grafana.com stable InRelease
Hit:6 https://deb.nodesource.com/node_24.x nodistro InRelease
Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B]
Fetched 6922 B in 1s (8849 B/s)
Reading package lists...
Pending systemupdates: 0
*** Listening Ports ***
Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
tcp        0      0 127.0.0.1:46303         0.0.0.0:*               LISTEN        1000       11458      1422/homebridge: ho
tcp        0      0 127.0.0.1:44889         0.0.0.0:*               LISTEN        1000       7168       1434/homebridge: ho
tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN        1001       12067      2145/io.mqtt.0
tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        102        7872       1179/mosquitto
tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN        1001       12142      2230/io.shelly.0
tcp        0      0 127.0.0.1:34551         0.0.0.0:*               LISTEN        1000       9457       1416/homebridge: @0
tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN        1000       11168      2338/node
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN        0          2269       1/init
tcp        0      0 127.0.0.1:43421         0.0.0.0:*               LISTEN        1000       9028       1415/homebridge: ho
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          7752       1143/sshd: /usr/sbi
tcp        0      0 127.0.0.1:39371         0.0.0.0:*               LISTEN        1000       10319      1409/homebridge: ho
tcp        0      0 127.0.0.1:33077         0.0.0.0:*               LISTEN        1000       9546       1424/homebridge: ho
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       7010       1302/iobroker.js-co
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       8041       1302/iobroker.js-co
tcp        0      0 127.0.0.1:39697         0.0.0.0:*               LISTEN        1000       9349       1408/homebridge: ho
tcp        0      0 127.0.0.1:39559         0.0.0.0:*               LISTEN        1000       11276      1435/homebridge: ho
tcp6       0      0 :::44253                :::*                    LISTEN        1000       10329      1434/homebridge: ho
tcp6       0      0 :::52403                :::*                    LISTEN        1000       10311      1415/homebridge: ho
tcp6       0      0 :::1883                 :::*                    LISTEN        102        7873       1179/mosquitto
tcp6       0      0 :::32570                :::*                    LISTEN        1000       9370       1424/homebridge: ho
tcp6       0      0 :::8086                 :::*                    LISTEN        999        7971       1171/influxd
tcp6       0      0 :::8081                 :::*                    LISTEN        1001       11680      1727/io.admin.0
tcp6       0      0 :::8082                 :::*                    LISTEN        1001       39157      3447/io.web.0
tcp6       0      0 :::111                  :::*                    LISTEN        0          1523       1/init
tcp6       0      0 :::53299                :::*                    LISTEN        1000       8831       1422/homebridge: ho
tcp6       0      0 :::22                   :::*                    LISTEN        0          7762       1143/sshd: /usr/sbi
tcp6       0      0 :::51399                :::*                    LISTEN        1000       10281      1328/homebridge
tcp6       0      0 :::37356                :::*                    LISTEN        1000       9382       1416/homebridge: @0
tcp6       0      0 :::8581                 :::*                    LISTEN        1000       6974       1265/hb-service
tcp6       0      0 :::39667                :::*                    LISTEN        1000       8783       1409/homebridge: ho
tcp6       0      0 :::47961                :::*                    LISTEN        1000       10313      1408/homebridge: ho
tcp6       0      0 :::3000                 :::*                    LISTEN        105        8771       1301/grafana
tcp6       0      0 :::52120                :::*                    LISTEN        1000       9373       1435/homebridge: ho
udp        0      0 0.0.0.0:6666            0.0.0.0:*        1001       11180      2301/io.tuya.0
udp        0      0 0.0.0.0:6667            0.0.0.0:*        1001       11181      2301/io.tuya.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*        1000       10334      1409/homebridge: ho
udp        0      0 0.0.0.0:5353            0.0.0.0:*        1000       6971       1265/hb-service
udp        0      0 0.0.0.0:5353            0.0.0.0:*        101        7288       643/avahi-daemon: r
udp        0      0 0.0.0.0:40291           0.0.0.0:*        101        7290       643/avahi-daemon: r
udp        0      0 0.0.0.0:111             0.0.0.0:*        0          3952       1/init
udp6       0      0 fe80::da3a:ddff:fe1:546 :::*        0          6091       680/NetworkManager
udp6       0      0 :::5353                 :::*        101        7289       643/avahi-daemon: r
udp6       0      0 :::43090                :::*        101        7291       643/avahi-daemon: r
udp6       0      0 :::111                  :::*        0          3953       1/init
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/84473/disk-voll-und-cloud-problem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 13:58:12 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84473.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 May 2026 08:47:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Disk voll und Cloud Problem on Mon, 04 May 2026 09:38:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marcelinho" aria-label="Profile: marcelinho">@<bdi>marcelinho</bdi></a> <a href="/post/1337767">sagte</a>:</p>
</blockquote>
<pre><code>Filesystem     Type      Size  Used Avail Use% Mounted on
</code></pre>
<p dir="auto">Rappelvoll.</p>
]]></description><link>https://forum.iobroker.net/post/1337779</link><guid isPermaLink="true">https://forum.iobroker.net/post/1337779</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 04 May 2026 09:38:20 GMT</pubDate></item><item><title><![CDATA[Reply to Disk voll und Cloud Problem on Mon, 04 May 2026 09:01:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marcelinho" aria-label="Profile: marcelinho">@<bdi>marcelinho</bdi></a> <a href="/post/1337767">sagte</a>:<br />
</blockquote>
<p dir="auto">Die 6.0.1 war zu früh im stable. Wurde hier schon diskutiert:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/84455/admin-adapter-aktuelle-version">https://forum.iobroker.net/topic/84455/admin-adapter-aktuelle-version</a></p>
<p dir="auto">Vermutlich gehörst Du zu denen, die genau da dann auch aktualisiert haben. Im Zweifel erstmal wieder auf die 5.0.7 zurück. Die sollte funktionieren und dann ist auch der Fehler weg. Wenn der Admin im stable ist, wird auch die aktuelle Cloud 6.0.x dann sicher wieder offiziell ins stable kommen.</p>
]]></description><link>https://forum.iobroker.net/post/1337770</link><guid isPermaLink="true">https://forum.iobroker.net/post/1337770</guid><dc:creator><![CDATA[Samson71]]></dc:creator><pubDate>Mon, 04 May 2026 09:01:29 GMT</pubDate></item></channel></rss>
