<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst] Jeelink-Adapter 1.2.8 stürzt ab]]></title><description><![CDATA[<p dir="auto">Guten Morgen,<br />
habe gestern die V 1.2.8 installiert, diese (und auch 1.2.7) funktionieren bei mir beide nicht!</p>
<p dir="auto">Musste zurück auf 1.2.4 gehen. Dort fehlt jetzt aber die Konfigurationsdatei "jsonConfig.json"!</p>
<pre><code>jeelink.0
	2026-04-12 10:00:17.854	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
jeelink.0
	2026-04-12 10:00:17.854	info	terminating
jeelink.0
	2026-04-12 10:00:17.852	error	"baudRate" must be a number: 57600
jeelink.0
	2026-04-12 10:00:17.852	error	TypeError: "baudRate" must be a number: 57600 at new SerialPortStream (/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/stream/dist/index.js:60:19) at new SerialPort (/opt/iobroker/node_modules/iobroker.jeelink/node_modules/serialport/dist/serialport.js:15:9) at Jeelink.onReady (/opt/iobroker/node_modules/iobroker.jeelink/main.js:77:20)
jeelink.0
	2026-04-12 10:00:17.851	error	unhandled promise rejection: "baudRate" must be a number: 57600
jeelink.0
	2026-04-12 10:00:17.851	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
jeelink.0
	2026-04-12 10:00:17.850	info	instantiating SerialPort path: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI04PGZY-if00-port0 baudrate : 57600
jeelink.0
	2026-04-12 10:00:17.850	info	configured baudrate : 57600
jeelink.0
	2026-04-12 10:00:17.849	info	configured port : /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AI04PGZY-if00-port0
jeelink.0
	2026-04-12 10:00:17.848	info	RFM12B setting up object = LaCrosse 4
jeelink.0
	2026-04-12 10:00:17.845	info	RFM12B setting up object = LaCrosse 3
jeelink.0
	2026-04-12 10:00:17.843	info	RFM12B setting up object = LaCrosse 2
jeelink.0
	2026-04-12 10:00:17.836	info	RFM12B setting up object = LaCrosse 1
jeelink.0
	2026-04-12 10:00:17.822	info	start of main
jeelink.0
	2026-04-12 10:00:17.813	info	starting. Version 1.2.7 in /opt/iobroker/node_modules/iobroker.jeelink, node: v22.22.0, js-controller: 7.0.7
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/84277/gelöst-jeelink-adapter-1.2.8-stürzt-ab</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 21:54:24 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84277.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Apr 2026 08:05:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst] Jeelink-Adapter 1.2.8 stürzt ab on Sun, 12 Apr 2026 08:25:46 GMT]]></title><description><![CDATA[<p dir="auto">Oh Wunder, hat funktioniert!<br />
Vielen Dank für Deine Hilfe!</p>
]]></description><link>https://forum.iobroker.net/post/1334149</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334149</guid><dc:creator><![CDATA[iobroker2001]]></dc:creator><pubDate>Sun, 12 Apr 2026 08:25:46 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Jeelink-Adapter 1.2.8 stürzt ab on Sun, 12 Apr 2026 08:20:27 GMT]]></title><description><![CDATA[<p dir="auto">Geh einfach in die Einstellungen und setze die Baudrate neu. Da wurde der Type bei der Änderung auf Typeskript nicht korrekt gewandelt.</p>
]]></description><link>https://forum.iobroker.net/post/1334145</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334145</guid><dc:creator><![CDATA[peterfido]]></dc:creator><pubDate>Sun, 12 Apr 2026 08:20:27 GMT</pubDate></item></channel></rss>
