<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Variable resistant to shutdown iobroker ?]]></title><description><![CDATA[<p dir="auto">My problem looks like this:<br />
I want to create two variables whose values ​​I will set from e.g. vis. This means, for example, setting the time "from - to".<br />
I can create variables in the iobroker tree. It's not a problem.<br />
But how to ensure that the values ​​entered there do not reset to zero after restarting the computer?</p>
]]></description><link>https://forum.iobroker.net/topic/72591/variable-resistant-to-shutdown-iobroker</link><generator>RSS for Node</generator><lastBuildDate>Mon, 05 Oct 2026 18:58:15 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/72591.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Feb 2024 10:48:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Variable resistant to shutdown iobroker ? on Fri, 09 Feb 2024 17:55:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
It actually works. After restarting the server (tests), all manually set values ​​are the same.<br />
Thank you.<br />
<img src="/assets/uploads/files/1707501327756-test.jpg" alt="test.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/1126500</link><guid isPermaLink="true">https://forum.iobroker.net/post/1126500</guid><dc:creator><![CDATA[mguc]]></dc:creator><pubDate>Fri, 09 Feb 2024 17:55:49 GMT</pubDate></item><item><title><![CDATA[Reply to Variable resistant to shutdown iobroker ? on Fri, 09 Feb 2024 11:21:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mguc" aria-label="Profile: mguc">@<bdi>mguc</bdi></a> sagte in <a href="/post/1126307">Variable resistant to shutdown iobroker ?</a>:</p>
<blockquote>
<p dir="auto">I can create variables in the iobroker tree.</p>
</blockquote>
<p dir="auto">sure that you mean variables? and not states?<br />
variables in scripts will forget their values if the script is stopped.</p>
<p dir="auto">Values of states will be kept "forever"</p>
]]></description><link>https://forum.iobroker.net/post/1126317</link><guid isPermaLink="true">https://forum.iobroker.net/post/1126317</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 09 Feb 2024 11:21:04 GMT</pubDate></item></channel></rss>
