<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Erledigt: Kanalwechsel beim Zigbee Adap. funktioniert nicht]]></title><description><![CDATA[<p dir="auto">Ich will beim Zigbee Adapter den Kanal wechseln. Dabei wird die bleibt die Anzeige "Verbunden mit Gerät oder Dienst" leider rot.</p>
<p dir="auto">Im Log steht das</p>
<pre><code>
zigbee.1
2023-08-30 11:30:47.663	error	Error herdsman start
zigbee.1
2023-08-30 11:30:47.663	error	Failed to start Zigbee
zigbee.1
2023-08-30 11:30:47.662	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
zigbee.1
2023-08-30 11:30:47.445	info	Installed Version: iobroker.zigbee@1.8.23
zigbee.1
2023-08-30 11:30:47.416	info	Starting Zigbee npm ...
zigbee.1
2023-08-30 11:30:47.415	info	Try to reconnect. 1 attempts left
zigbee.1
2023-08-30 11:30:37.409	error	Error herdsman start
zigbee.1
2023-08-30 11:30:37.408	error	Failed to start Zigbee
zigbee.1
2023-08-30 11:30:37.408	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
zigbee.1
2023-08-30 11:30:37.218	error	Re-commissioning your network will require re-pairing of all devices!
zigbee.1
2023-08-30 11:30:37.216	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_1/nvbackup.json.
zigbee.1
2023-08-30 11:30:37.215	error	Please update configuration to prevent further issues.
zigbee.1
2023-08-30 11:30:37.215	error	- Channel List: configured=25, adapter=14
zigbee.1
2023-08-30 11:30:37.212	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
zigbee.1
2023-08-30 11:30:37.211	error	- Extended PAN ID: configured=00124b0024c2b553, adapter=00124b0024c2b553
zigbee.1
2023-08-30 11:30:37.210	error	- PAN ID: configured=6750, adapter=6750
zigbee.1
2023-08-30 11:30:37.209	error	Configuration is not consistent with adapter state/backup!
zigbee.1
2023-08-30 11:30:36.856	info	Installed Version: iobroker.zigbee@1.8.23```
@bananajoe wenn ich jetzt
</code></pre>
<p dir="auto">wenn ich daraufhin wie in der Fehlermeldung steht hier /opt/iobroker/iobroker-data/zigbee_1/nvbackup.json. nachschaue, kam das hier</p>
<pre><code>pi@raspberrypi:~ $ /opt/iobroker/iobroker-data/zigbee_1/nvbackup.json
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 2: metadata:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 3: format:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 4: version:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 5: source:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 6: internal:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 7: date:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 8: znpVersion:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 10: },: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 11: stack_specific:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 12: zstack:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 13: tclk_seed:: command not found
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 14: syntax error near unexpected token `}'
/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json: line 14: `    }'
</code></pre>
<p dir="auto">damit kann ich leider nichts anfangen.<br />
Kann mir dabei bitte jemand helfen?</p>
<p dir="auto">Gruß Björn</p>
]]></description><link>https://forum.iobroker.net/topic/67942/erledigt-kanalwechsel-beim-zigbee-adap-funktioniert-nicht</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 18:28:19 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/67942.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Aug 2023 10:01:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Erledigt: Kanalwechsel beim Zigbee Adap. funktioniert nicht on Fri, 01 Sep 2023 10:44:30 GMT]]></title><description><![CDATA[<p dir="auto">@dp20eic Danke Bernd</p>
<p dir="auto">Ja ich habe es hinbekommen, ich bin jetzt mit 45 Aktoren auf einen anderen Kanal umgezogen.</p>
<p dir="auto">Den Kanalwechsel habe ich gemacht weil, ich nach einem Firmware Update auf meinem Sonoff Zigbee Stick, die Aktoren gar nicht oder nur noch mit Verzögerung nutzen konnt, ein neu anlernen der Aktoren alleine hätte auch geholfen aber wenn ich schon alles neu anlernen muss dann wollte ich doch lieber gleich auf einen stärkeren Kanal wechseln.</p>
<p dir="auto">Nochmals danke</p>
]]></description><link>https://forum.iobroker.net/post/1037711</link><guid isPermaLink="true">https://forum.iobroker.net/post/1037711</guid><dc:creator><![CDATA[Geesthachter]]></dc:creator><pubDate>Fri, 01 Sep 2023 10:44:30 GMT</pubDate></item><item><title><![CDATA[Reply to Erledigt: Kanalwechsel beim Zigbee Adap. funktioniert nicht on Wed, 30 Aug 2023 10:30:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geesthachter" aria-label="Profile: geesthachter">@<bdi>geesthachter</bdi></a> sagte in <a href="/post/1036344">Kanalwechsel beim Zigbee Adapter funktioniert nicht</a>:</p>
<blockquote>
<p dir="auto">Kann mir dabei bitte jemand helfen?</p>
</blockquote>
<p dir="auto">Moin,</p>
<p dir="auto">helfen, keine Ahnung, aber Dich vielleicht in die richtige Richtung schubsen.<br />
Fangen wir mal an.</p>
<blockquote>
<p dir="auto">pi@raspberrypi:~ $ /opt/iobroker/iobroker-data/zigbee_1/nvbackup.json</p>
</blockquote>
<p dir="auto">Das geht so nicht, denn die Kommandozeile interpretiert das als Programm und nicht als eine Datei, zum Anschauen auf der Konsole</p>
<pre><code># cat /opt/iobroker/iobroker-data/zigbee_1/nvbackup.json
oder mittels Editor nano
# nano /opt/iobroker/iobroker-data/zigbee_1/nvbackup.json
</code></pre>
<p dir="auto">Dann sagt Dir das Log File, dass die aktuelle Konfiguration nicht mit der aus dem Backup übereinstimmt</p>
<pre><code>2023-08-30 11:30:37.209	error	Configuration is not consistent with adapter state/backup!
passent dazu
</code></pre>
<p dir="auto">Das sagt mir, dass Du im Backup die eine Zahl stehen hast, aber im neuen Adapter eine andere, daher musst Du erst alles so restoren wie im Backup, danach kannst Du den Kanal usw. anpassen/ändern.</p>
<p dir="auto">VG<br />
Bernd</p>
<p dir="auto">P.S.: hab gesehen, dass Du es in der Zwischenzeit hinbekommen hast.</p>
]]></description><link>https://forum.iobroker.net/post/1036361</link><guid isPermaLink="true">https://forum.iobroker.net/post/1036361</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 30 Aug 2023 10:30:55 GMT</pubDate></item><item><title><![CDATA[Reply to Erledigt: Kanalwechsel beim Zigbee Adap. funktioniert nicht on Wed, 30 Aug 2023 10:19:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/geesthachter" aria-label="Profile: geesthachter">@<bdi>geesthachter</bdi></a></p>
<p dir="auto">hat sich erledigt. Ich habe es selbst raus gefunden.</p>
<p dir="auto">Für alle die vielleicht mal das gleiche Problem habe,<br />
Ich habe</p>
<pre><code>sudo rm  /opt/iobroker/iobroker-data/zigbee_1/nvbackup.json
</code></pre>
<p dir="auto">in der Kommandozeile eingegeben.<br />
daraufhin ging der Adapter auf grün.</p>
]]></description><link>https://forum.iobroker.net/post/1036356</link><guid isPermaLink="true">https://forum.iobroker.net/post/1036356</guid><dc:creator><![CDATA[Geesthachter]]></dc:creator><pubDate>Wed, 30 Aug 2023 10:19:57 GMT</pubDate></item></channel></rss>
