<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nach js-controller-Update geht LGTV nicht mehr]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">ich habe grade einen Update durchgeführt, danach starten die Instanzen meines lgtv Adapters nicht mehr, ermeckert irgendwelche fehlenden Datein/Directorys an, da hab ich aber nichts dran gemacht.<br />
iob auf proxmox container (bullseye)<br />
node.js v18.16.0<br />
NPM v9.5.1<br />
Beta repository, alle Adapter aktuell (der lgtv hat v1.1.10)<br />
nach dem Update hatte ich noch iob fix durchlaufen lassen</p>
<pre><code>lgtv.0
	2023-06-13 19:00:14.596	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
lgtv.0
	2023-06-13 19:00:14.595	info	terminating
lgtv.0
	2023-06-13 19:00:14.075	error	Exception-Code: ENOENT: ENOENT: no such file or directory, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/build/../../iobroker-data/lgtv_0/'
lgtv.0
	2023-06-13 19:00:14.074	error	Error: ENOENT: no such file or directory, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/build/../../iobroker-data/lgtv_0/' at Object.mkdirSync (node:fs:1396:3) at main (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:606:37) at Object.ready (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:340:13) at AdapterClass._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9030:31) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9010:26
lgtv.0
	2023-06-13 19:00:14.071	error	unhandled promise rejection: ENOENT: no such file or directory, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/build/../../iobroker-data/lgtv_0/'
lgtv.0
	2023-06-13 19:00:14.070	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
lgtv.0
	2023-06-13 19:00:14.063	info	Ready. Configured WebOS TV IP: 192.168.1.19
lgtv.0
	2023-06-13 19:00:14.021	info	starting. Version 1.1.10 (non-npm: SebastianSchultz/ioBroker.lgtv#85254f6f2f87ab5ea7032cec3932347fc586b051) in /opt/iobroker/node_modules/iobroker.lgtv, node: v18.16.0, js-controller: 5.0.2
lgtv.0
	2023-06-13 18:59:39.311	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
lgtv.0
	2023-06-13 18:59:39.310	info	terminating
</code></pre>
<p dir="auto">Hat hier jemand eine Idee woran es liegen könnte?</p>
]]></description><link>https://forum.iobroker.net/topic/66145/nach-js-controller-update-geht-lgtv-nicht-mehr</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 20:17:08 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/66145.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Jun 2023 17:09:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nach js-controller-Update geht LGTV nicht mehr on Tue, 13 Jun 2023 17:33:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amg_666" aria-label="Profile: amg_666">@<bdi>amg_666</bdi></a> sagte in <a href="/post/1003151">Nach js-controller-Update geht LGTV nicht mehr</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Moin,</p>
<p dir="auto">erst einmal, wenn Du hier im Forum gesucht hättest, dann hättest Du das hier gefunden <a href="https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta/">https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta/</a></p>
<p dir="auto">Da der JS-Controler noch Beta ist, gibt/kann es sein, dass da einiges noch nicht funktioniert, zum Beispiel auch dieser Adapter :)</p>
<p dir="auto">VG<br />
BErnd</p>
]]></description><link>https://forum.iobroker.net/post/1003166</link><guid isPermaLink="true">https://forum.iobroker.net/post/1003166</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 13 Jun 2023 17:33:52 GMT</pubDate></item></channel></rss>
