<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Musiccast restart loop]]></title><description><![CDATA[<p dir="auto">Hallo<br />
Seit heute habe ich auf einmal das Problem dass ich folgende Logs bekomme</p>
<pre><code>musiccast.0
	2023-05-30 11:36:18.229	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:16.569	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:15.435	error	[getMusicTunerInfo] error: socket hang up, stack: Error: socket hang up at connResetException (node:internal/errors:705:14) at Socket.socketOnEnd (node:_http_client:518:23) at Socket.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
musiccast.0
	2023-05-30 11:36:12.296	error	[getMusicTunerInfo] error: connect ETIMEDOUT 192.168.111.151:80, stack: Error: connect ETIMEDOUT 192.168.111.151:80 at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
musiccast.0
	2023-05-30 11:36:10.642	error	[getMusicTunerInfo] error: socket hang up, stack: Error: socket hang up at connResetException (node:internal/errors:705:14) at Socket.socketOnEnd (node:_http_client:518:23) at Socket.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
musiccast.0
	2023-05-30 11:36:10.248	error	[getMusicTunerInfo] error: connect ETIMEDOUT 192.168.111.151:80, stack: Error: connect ETIMEDOUT 192.168.111.151:80 at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
musiccast.0
	2023-05-30 11:36:06.172	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:05.870	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:04.990	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:04.171	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:02.724	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:02.639	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:01.717	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:01.264	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:36:00.952	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:35:55.913	error	[getMusicTunerInfo] error: connect ETIMEDOUT 192.168.111.151:80, stack: Error: connect ETIMEDOUT 192.168.111.151:80 at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
musiccast.0
	2023-05-30 11:35:49.029	error	[getMusicTunerInfo] error: socket hang up, stack: Error: socket hang up at connResetException (node:internal/errors:705:14) at Socket.socketOnEnd (node:_http_client:518:23) at Socket.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
musiccast.0
	2023-05-30 11:35:48.949	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
musiccast.0
	2023-05-30 11:35:48.568	warn	State "musiccast.0.RX-A3080_00E9F513.tuner.band" has no existing object, this might lead to an error in future versions
</code></pre>
<p dir="auto"><img src="/assets/uploads/files/1685439515041-c2aa070f-511e-47db-9c37-6d1b78932502-grafik.png" alt="c2aa070f-511e-47db-9c37-6d1b78932502-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Der Adapter ist v0.1.5</p>
<p dir="auto">Vielleicht noch ein Hinweis: Die Musiccast App auf dem Handy hat vor ein paar Tagen den Verstärker nicht mehr gefunden. ch musste die nochmal neu aufsetzen.</p>
<p dir="auto">Wenn ich jetzt auf das Widget schaue, dann sehe ich auch, dass es nicht verbunden ist. Ich muss dann MusicCast anwählen, mich nochmal anmelden und dann geht die App.<br />
Das passt zu den "connect ETIMEDOUT"s. Aber der Verstärker hängt am Kabel am Router. Ebenso IOBroker.</p>
<p dir="auto">Gruss Ralf</p>
]]></description><link>https://forum.iobroker.net/topic/65843/musiccast-restart-loop</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 02:42:22 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/65843.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 May 2023 09:39:28 GMT</pubDate><ttl>60</ttl></channel></rss>
