<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Backitup läuft nicht:  &quot;admin has wrong version...&quot;]]></title><description><![CDATA[<p dir="auto">Moin!<br />
Ich habe vor kurzem mal wieder alles auf dem System aktualisiert, nun bekommt aber der Backitup keine Verbindung mehr zum Host: admin" has wrong version. Installed "5.3.8", required "&gt;=6.0.0<br />
Kann ich aber nicht nachvollziehen, denn:</p>
<pre><code>pi@raspberrypi:~ $ iobroker version
4.0.24
pi@raspberrypi:~ $ type -P nodejs node npm npx &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v                                              &amp;&amp; npx -v
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
/usr/bin/npx
v18.16.0
v18.16.0
9.5.1
9.5.1
pi@raspberrypi:~ $ iobroker update
Used repository: stable
Adapter    "admin"        : 6.3.5    , installed 6.3.5
Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
Adapter    "backitup"     : 2.6.19   , installed 2.6.19
Adapter    "denon"        : 1.15.0   , installed 1.15.0
Adapter    "discovery"    : 3.1.0    , installed 3.1.0
Adapter    "ham"          : 5.3.1    , installed 5.3.1
Adapter    "heos"         : 1.10.0   , installed 1.10.0
Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
Adapter    "info"         : 1.9.26   , installed 1.9.26
Adapter    "javascript"   : 6.1.4    , installed 6.1.4
Controller "js-controller": 4.0.24   , installed 4.0.24
Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
Adapter    "milight"      : 0.3.6    , installed 0.3.6
Adapter    "node-red"     : 4.0.0    , installed 4.0.0
Adapter    "scenes"       : 2.3.9    , installed 2.3.9
Adapter    "socketio"     : 4.2.0    , installed 4.2.0
Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
Adapter    "vaillant"     : 0.1.2    , installed 0.1.2
Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
Adapter    "web"          : 4.3.0    , installed 4.3.0
Adapter    "worx"         : 2.1.3    , installed 2.1.3
Adapter    "ws"           : 1.3.0    , installed 1.3.0
pi@raspberrypi:~ $
</code></pre>
<p dir="auto">iobroker fix hat nichts gebracht... kann es vielleicht auch daran liegen, dass ich zusätzlich einen lxc-Container mit Ubuntu auf dem System erstellt habe? Da ist aber eigentlich nur diyhue drin...</p>
]]></description><link>https://forum.iobroker.net/topic/65714/backitup-läuft-nicht-admin-has-wrong-version</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 02:50:04 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/65714.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 May 2023 11:30:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Wed, 24 May 2023 16:17:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>======================= SUMMARY =======================
                     v.2023-04-16
Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
Kernel:                 5.10.103-v7l+
Installation:           Native
Timezone:               Europe/Berlin (CEST, +0200)
User-ID:                1000
X-Server:               false
Pending OS-Updates:     0
Pending iob updates:    0
Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                        /usr/bin/node           v18.16.0
                        /usr/bin/npm            9.5.1
                        /usr/bin/npx            9.5.1
Recommended versions are nodejs 18.x.y and npm 9.x.y
MEMORY:
Mem:            3.8G        1.2G        1.7G        1.0M        961M        2.5G
Swap:            99M          0B         99M
Total:          3.9G        1.2G        1.8G
Active iob-Instances:   19
Active repo(s): stable
ioBroker Core:          js-controller           4.0.24
                        admin                   6.3.5
Objects type: jsonl
States  type: jsonl
+ system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
  system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
Objects:                11169
States:                 11568
Size of iob-Database:
14M     /opt/iobroker/iobroker-data/objects.jsonl
11M     /opt/iobroker/iobroker-data/states.jsonl
</code></pre>
]]></description><link>https://forum.iobroker.net/post/995467</link><guid isPermaLink="true">https://forum.iobroker.net/post/995467</guid><dc:creator><![CDATA[schubi82]]></dc:creator><pubDate>Wed, 24 May 2023 16:17:47 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 21:38:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schubi82" aria-label="Profile: schubi82">@<bdi>schubi82</bdi></a></p>
<p dir="auto">Was sagt jetzt</p>
<pre><code>iob diag
</code></pre>
<p dir="auto">zu der ganzen Geschichte?</p>
]]></description><link>https://forum.iobroker.net/post/995211</link><guid isPermaLink="true">https://forum.iobroker.net/post/995211</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 23 May 2023 21:38:28 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 19:08:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Hab's gewagt, scheint alles zu funktionieren! Vielen Dank nochmal an alle!</p>
]]></description><link>https://forum.iobroker.net/post/995172</link><guid isPermaLink="true">https://forum.iobroker.net/post/995172</guid><dc:creator><![CDATA[schubi82]]></dc:creator><pubDate>Tue, 23 May 2023 19:08:35 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 15:12:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schubi82" aria-label="Profile: schubi82">@<bdi>schubi82</bdi></a><br />
Wenn die Grundlage robust ist geht es so:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye">https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye</a></p>
]]></description><link>https://forum.iobroker.net/post/995079</link><guid isPermaLink="true">https://forum.iobroker.net/post/995079</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 23 May 2023 15:12:12 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 15:09:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Oh nein, danke für die Info! Jetzt läuft gerade alles mal wieder super, und dann das. Hab noch etwas Angst, dass dann irgendwas nicht mehr funktioniert. Ist alles auf einem Raspberry, iobroker, CCU, diyhue, NAS, Plex... irgendwas bleibt da sicher auf der Strecke :)<br />
Vielleicht mache ich dann bei Zeiten lieber gleich alles neu.</p>
]]></description><link>https://forum.iobroker.net/post/995077</link><guid isPermaLink="true">https://forum.iobroker.net/post/995077</guid><dc:creator><![CDATA[schubi82]]></dc:creator><pubDate>Tue, 23 May 2023 15:09:33 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 14:34:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> sagte in <a href="/post/995047">Backitup läuft nicht: "admin has wrong version..."</a>:</p>
<blockquote>
<p dir="auto">Pending OS-Updates: 1<br />
Da steht noch ein Update an</p>
</blockquote>
<p dir="auto">Nicht nur eines...<br />
Dein 'Buster' ist abgekündigt worden und muss durch den Nachfolger 'Bullseye' ersetzt werden.</p>
]]></description><link>https://forum.iobroker.net/post/995064</link><guid isPermaLink="true">https://forum.iobroker.net/post/995064</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 23 May 2023 14:34:53 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 14:20:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> Du meinst wenn man den Admin-Adapter manuell installiert/upgedated hat? Ist mir nicht bewusst, ausschließen kann ich es aber auch nicht… beim nächsten Update des Adapters über die Oberfläche ist das wieder ok?</p>
]]></description><link>https://forum.iobroker.net/post/995053</link><guid isPermaLink="true">https://forum.iobroker.net/post/995053</guid><dc:creator><![CDATA[schubi82]]></dc:creator><pubDate>Tue, 23 May 2023 14:20:34 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 14:07:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schubi82" aria-label="Profile: schubi82">@<bdi>schubi82</bdi></a> es aktualisiert die Daten was üblicherweise automatisch passieren sollte, ausser man installiert manuell/von Github dann muss man  ein upload anstoßen</p>
]]></description><link>https://forum.iobroker.net/post/995047</link><guid isPermaLink="true">https://forum.iobroker.net/post/995047</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 23 May 2023 14:07:55 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 13:02:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> iobroker upload all hat das Problem anscheinend behoben, vielen Dank!! Was hat das genau gemacht? Hab es nicht so ganz verstanden, lädt Webseiten von www und admin storage in das Filesystem!? Ist es da nicht sowieso schon?</p>
]]></description><link>https://forum.iobroker.net/post/995025</link><guid isPermaLink="true">https://forum.iobroker.net/post/995025</guid><dc:creator><![CDATA[schubi82]]></dc:creator><pubDate>Tue, 23 May 2023 13:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 16:11:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> js-controller/nodejs nach Anleitung und "sudo apt update &amp;&amp; sudo apt upgrade" sowie alle Adapter in iobroker.</p>
<p dir="auto">Copy text starting here:</p>
                     v.2023-04-16
Operatingsystem:        Raspbian GNU/Linux 10 (buster)
User-ID:                1000
X-Server:               false
                        /usr/bin/npm            9.5.1
                        /usr/bin/npx            9.5.1
MEMORY:
Mem:           3.8G        1.2G        1.6G        9.0M        1.1G        2.5G
Swap:           99M          0B         99M
Total:         3.9G        1.2G        1.7G
Active iob-Instances:   18
                        admin                   6.3.5
Objects type: jsonl
States  type: jsonl
Objects:                11170
States:                 11554
18M     /opt/iobroker/iobroker-data/objects.jsonl
21M     /opt/iobroker/iobroker-data/states.jsonl
</code></pre>
<p dir="auto">pi@raspberrypi:~ $</p>
<pre><code>
Upload läuft, starte dann nochmal neu...</code></pre>
]]></description><link>https://forum.iobroker.net/post/995020</link><guid isPermaLink="true">https://forum.iobroker.net/post/995020</guid><dc:creator><![CDATA[schubi82]]></dc:creator><pubDate>Tue, 23 May 2023 16:11:55 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup läuft nicht:  &quot;admin has wrong version...&quot; on Tue, 23 May 2023 12:38:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schubi82" aria-label="Profile: schubi82">@<bdi>schubi82</bdi></a> sagte in <a href="/post/994996">Backitup läuft nicht: "admin has wrong version..."</a>:</p>
<blockquote>
<p dir="auto">alles auf dem System aktualisiert</p>
</blockquote>
<p dir="auto">Das wäre?<br />
Probier mal ein</p>
<pre><code>iobroker upload all
</code></pre>
<p dir="auto">ansonsten die Ausgabe von</p>
<pre><code>iob diag
</code></pre>
]]></description><link>https://forum.iobroker.net/post/995016</link><guid isPermaLink="true">https://forum.iobroker.net/post/995016</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 23 May 2023 12:38:34 GMT</pubDate></item></channel></rss>
