<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem mit dem Reminder Adapter]]></title><description><![CDATA[<p dir="auto">Ich habe einen Fehler in meiner Log Datei die mit dem Reminder Adapter zusamen hängt.<br />
Alexa sagt mir wann unsere Waschmaschien, Trockner und Spülmaschiene fertig ist.<br />
Mit hilfe des Reminder Adapters klappt das auch.<br />
Es taucht aber im Log folgender Fehler auf:</p>
<pre><code>2023-05-09 21:26:44.675 - info: admin.0 (801) ==&gt; Connected system.user.admin from ::ffff:192.168.178.2
2023-05-09 21:26:47.433 - info: host.raspberrypi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
2023-05-09 21:27:07.746 - info: admin.0 (801) &lt;== Disconnect system.user.admin from ::ffff:192.168.178.2
**2023-05-09 21:31:44.675 - info: device-reminder.0 (28494) State value to set for "alexa2.0.Echo-Devices.G2A1A603117300LW.Commands.speak-volume" has to be type "number" but received type "string"
2023-05-09 21:31:44.723 - error: alexa2.0 (21121) Datatype for Echo-Devices.G2A1A603117300LW.Commands.speak-volume differs from expected, ignore state change! Please write correct datatype (number)**
2023-05-09 21:31:44.727 - info: device-reminder.0 (28494) State value to set for "alexa2.0.Echo-Devices.G2A0WK04904707CJ.Commands.speak-volume" has to be type "number" but received type "string"
2023-05-09 21:31:44.733 - error: alexa2.0 (21121) Datatype for Echo-Devices.G2A0WK04904707CJ.Commands.speak-volume differs from expected, ignore state change! Please write correct datatype (number)
2023-05-09 21:31:44.785 - info: device-reminder.0 (28494) State value to set for "alexa2.0.Echo-Devices.G090U509908506M7.Commands.speak-volume" has to be type "number" but received type "string"
2023-05-09 21:31:44.791 - error: alexa2.0 (21121) Datatype for Echo-Devices.G090U509908506M7.Commands.speak-volume differs from expected, ignore state change! Please write correct datatype (number)
2023-05-09 21:31:47.832 - info: device-reminder.0 (28494) State value to set for "alexa2.0.Echo-Devices.G2A1A603117300LW.Commands.speak-volume" has to be type "number" but received type "string"
2023-05-09 21:31:47.837 - info: device-reminder.0 (28494) State value to set for "alexa2.0.Echo-Devices.G2A0WK04904707CJ.Commands.speak-volume" has to be type "number" but received type "string"
2023-05-09 21:31:47.838 - error: alexa2.0 (21121) Datatype for Echo-Devices.G2A1A603117300LW.Commands.speak-volume differs from expected, ignore state change! Please write correct datatype (number)
2023-05-09 21:31:47.844 - error: alexa2.0 (21121) Datatype for Echo-Devices.G2A0WK04904707CJ.Commands.speak-volume differs from expected, ignore state change! Please write correct datatype (number)
2023-05-09 21:31:47.881 - info: device-reminder.0 (28494) State value to set for "alexa2.0.Echo-Devices.G090U509908506M7.Commands.speak-volume" has to be type "number" but received type "string"
2023-05-09 21:31:47.887 - error: alexa2.0 (21121) Datatype for Echo-Devices.G090U509908506M7.Commands.speak-volume differs from expected, ignore state change! Please write correct datatype (number)
</code></pre>
<p dir="auto"><strong>MOD-EDIT: Code in code-tags gesetzt!</strong></p>
<p dir="auto">Kann mir jemand sagen wo der Fehler bei den Alexas liegt.<br />
Ich habe den Datenpunkt Speak eingestellt so wie es als Beispielpfad im Reminder Adapter beschrieben ist eingetragen.</p>
<p dir="auto"><img src="/assets/uploads/files/1683661818684-27893321-1742-4457-9742-da787f347250-grafik.png" alt="27893321-1742-4457-9742-da787f347250-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Danke schon mal für die Mühen</p>
]]></description><link>https://forum.iobroker.net/topic/65274/problem-mit-dem-reminder-adapter</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 07:32:09 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/65274.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 May 2023 19:56:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem mit dem Reminder Adapter on Tue, 16 May 2023 19:38:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schmakus" aria-label="Profile: schmakus">@<bdi>schmakus</bdi></a><br />
Hallo Schmarkus Hier meine Instanzen Einstellunmgen des Reminder Adapter</p>
<p dir="auto"><img src="/assets/uploads/files/1684265589433-5350106b-63b2-4a49-b76b-6e501f0bccd9-grafik.png" alt="5350106b-63b2-4a49-b76b-6e501f0bccd9-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Ich hatte die Lautstärke Einstellungen mal in irgenwas geändert um zu testen</p>
<p dir="auto"><img src="/assets/uploads/files/1684265644219-39346644-0ef9-42be-95ab-1ac4b7af2116-grafik.png" alt="39346644-0ef9-42be-95ab-1ac4b7af2116-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Und hier noch mal die aktuelle Log Datei</p>
<p dir="auto"><img src="/assets/uploads/files/1684265828626-594c379b-8730-4ae9-9c58-e014d5d04519-grafik.png" alt="594c379b-8730-4ae9-9c58-e014d5d04519-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/992683</link><guid isPermaLink="true">https://forum.iobroker.net/post/992683</guid><dc:creator><![CDATA[Venjacob]]></dc:creator><pubDate>Tue, 16 May 2023 19:38:51 GMT</pubDate></item><item><title><![CDATA[Reply to Problem mit dem Reminder Adapter on Wed, 10 May 2023 09:03:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/venjacob" aria-label="Profile: venjacob">@<bdi>venjacob</bdi></a> Zeig mal deine Instanzeinstellungen. Anstatt der Lautstärke (0-100) wird bei dir die Object-ID geschrieben.</p>
]]></description><link>https://forum.iobroker.net/post/989660</link><guid isPermaLink="true">https://forum.iobroker.net/post/989660</guid><dc:creator><![CDATA[Schmakus]]></dc:creator><pubDate>Wed, 10 May 2023 09:03:12 GMT</pubDate></item></channel></rss>
