<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Info] Adapter statistics 2.3.0 liefert Fehler]]></title><description><![CDATA[<p dir="auto">Dies nur zur Info, das Problem hat für mich keine Priorität:</p>
<p dir="auto">Nach Update des statistics-Adapter von 2.2.0 auf 2.3.0 finde ich folgende Fehler im Protokoll</p>
<pre><code>statistics.0
	2023-04-27 09:39:12.573	error	The id "save.sumGroup." is invalid. Ids are not allowed to end in "."
statistics.0
	2023-04-27 09:39:12.572	error	Error: The id "save.sumGroup." is invalid. Ids are not allowed to end in "." at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/utils.ts:215:23) at Statistics.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:3509:23) at /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2126:16 at new Promise (&lt;anonymous&gt;) at Statistics.setObjectNotExistsAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2125:16) at Statistics.defineObject (/opt/iobroker/node_modules/iobroker.statistics/main.js:1001:20) at Statistics.onReady (/opt/iobroker/node_modules/iobroker.statistics/main.js:174:32)
statistics.0
	2023-04-27 09:39:12.240	error	unhandled promise rejection: The id "save.sumGroup." is invalid. Ids are not allowed to end in "."
statistics.0
	2023-04-27 09:39:12.239	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
statistics.0
	2023-04-27 09:39:12.232	info	[SETUP] enabled statistics for statistics.0.save.minmax.fritzdect.0.DECT_116300313410.power.absMax
statistics.0
	2023-04-27 09:39:12.231	info	[SETUP] enabled statistics for deyeidc.0.4172604716.Etdy_ge0
statistics.0
	2023-04-27 09:39:12.230	info	[SETUP] enabled statistics for deyeidc.0.4172604716.Apo_t1
statistics.0
	2023-04-27 09:39:12.229	info	[SETUP] enabled statistics for fritzdect.0.DECT_116300313410.power
statistics.0
	2023-04-27 09:39:12.133	info	starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.statistics, node: v18.15.0, js-controller: 4.0.24
statistics.0
	2023-04-27 09:38:38.981	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
statistics.0
	2023-04-27 09:38:38.979	info	terminating
statistics.0
	2023-04-27 09:38:38.976	info	cleaned everything up...
</code></pre>
<p dir="auto">Der Adapter wurde kurz grün und kurz danach wieder rot. Ich habe mir das dreimal mit angesehen und dann ein Downgrade auf 2.2.0 gemacht. Seitdem ist wieder Ruhe.</p>
<p dir="auto">Vielleicht ist das ja von Interesse. Wegen mir muss das nicht weiter verfolgt werden - Danke.</p>
]]></description><link>https://forum.iobroker.net/topic/64961/info-adapter-statistics-2-3-0-liefert-fehler</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 14:49:03 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/64961.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Apr 2023 12:33:53 GMT</pubDate><ttl>60</ttl></channel></rss>
