<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[backitup kein FTP]]></title><description><![CDATA[<table class="table table-bordered table-striped">
<thead>
<tr>
<th>Systemdata</th>
<th>Bitte Ausfüllen</th>
</tr>
</thead>
<tbody>
<tr>
<td>Hardwaresystem:</td>
<td>VM auf Proxmox</td>
</tr>
<tr>
<td>Arbeitsspeicher:</td>
<td>8GB</td>
</tr>
<tr>
<td>Festplattenart:</td>
<td>SSD</td>
</tr>
<tr>
<td>Betriebssystem:</td>
<td>Debian 5.10</td>
</tr>
<tr>
<td>Node-Version:</td>
<td>v16.19.1</td>
</tr>
<tr>
<td>Installationsart:</td>
<td>Skript/Manuell</td>
</tr>
<tr>
<td>Image genutzt:</td>
<td>Nein</td>
</tr>
</tbody>
</table>
<p dir="auto">Seit ca. 3 Tagen läuft mein Backup nicht mehr<br />
Ich lasse das Backup per FTP übers Internet versenden</p>
<p dir="auto">Wenn ich eine Verbindung mit FileZilla aufbaue dann funktioniert es</p>
<p dir="auto">Hier der Fehler im Log</p>
<pre><code>[DEBUG] [ftp] - FTP connected.
[DEBUG] [ftp] - Send iobroker_2023_03_30-18_24_48_backupiobroker.tar.gz
[ERROR] [ftp] - Error: Timed out while making data connection
[DEBUG] [ftp] - Send zigbee.0_2023_03_30-18_24_55_backupiobroker.tar.gz
[DEBUG] [ftp] - Send javascripts_2023_03_30-18_24_55_backupiobroker.tar.gz
[DEBUG] [ftp] - Send yahka.0_2023_03_30-18_24_56_backupiobroker.tar.gz
[DEBUG] [ftp] - done
[ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
[DEBUG] [clean] - done
[DEBUG] [telegram] - done
[DEBUG] [historyHTML] - new history html values created
[DEBUG] [historyHTML] - done
[DEBUG] [historyJSON] - new history json values created
[DEBUG] [historyJSON] - done
[EXIT] 0
</code></pre>
<p dir="auto">Danke im Voraus<br />
Gruß<br />
Marcel</p>
]]></description><link>https://forum.iobroker.net/topic/64283/backitup-kein-ftp</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 08:42:18 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/64283.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Mar 2023 16:27:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to backitup kein FTP on Mon, 03 Apr 2023 10:11:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> said in <a href="/post/972087">backitup kein FTP</a>:</p>
<blockquote>
<p dir="auto">Grundsätzlich sollte man NFS oder halt wenn NFS nicht unterstützt wird CIFS verwenden.</p>
</blockquote>
<p dir="auto">Ich nutze WebDav auf IONOS HiDrive.<br />
Aber eigentlich wäre es auch wünschenswert, wenn ioBroker SSH unterstützen würde.</p>
]]></description><link>https://forum.iobroker.net/post/972450</link><guid isPermaLink="true">https://forum.iobroker.net/post/972450</guid><dc:creator><![CDATA[GombersIOB]]></dc:creator><pubDate>Mon, 03 Apr 2023 10:11:28 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Mon, 03 Apr 2023 10:30:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wszene" aria-label="Profile: wszene">@<bdi>wszene</bdi></a> said in <a href="/post/970549">backitup kein FTP</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Laut dem angezeigten Log funktioniert die Connection aber nicht die Data-Connection. FTP benutzt zwei Ports. In der Regel wird über Port 21 die Session aufgebaut und gesteuert und über Port 20 werden die Daten übertragen. Wenn der Datenport (i.d.R. Port 20, wie gesagt - aber auch das ist steuerbar) zu ist (Firewall??), dann erwarte ich den beschriebenen Fehler.<br />
Es kann auch sein, wenn die Datenmenge zu groß ist, dass es zu einem Timeout auf Port 21 kommt, weil während der Übertragung über Port 21 nichts mehr läuft. Man braucht, um das zu vermeiden, eine Keep-Alive-Routine. In vielen Clients ist das implementiert.</p>
]]></description><link>https://forum.iobroker.net/post/972447</link><guid isPermaLink="true">https://forum.iobroker.net/post/972447</guid><dc:creator><![CDATA[GombersIOB]]></dc:creator><pubDate>Mon, 03 Apr 2023 10:30:23 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Mon, 03 Apr 2023 08:18:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
Danke das habe ich schon gesehen<br />
Das Problem ist ich finde im O2-Router den Punkt nicht um die statische Route einzutragen</p>
]]></description><link>https://forum.iobroker.net/post/972393</link><guid isPermaLink="true">https://forum.iobroker.net/post/972393</guid><dc:creator><![CDATA[Wszene]]></dc:creator><pubDate>Mon, 03 Apr 2023 08:18:12 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Mon, 03 Apr 2023 07:37:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wszene" aria-label="Profile: wszene">@<bdi>wszene</bdi></a> sagte in <a href="/post/972318">backitup kein FTP</a>:</p>
<blockquote>
<p dir="auto">Nur habe ich keine Ahnung wie ich eine Site-tp-Site Verbindung mit Wireguard einrichten kann</p>
</blockquote>
<p dir="auto">schau mal <a href="https://schroederdennis.de/allgemein/wireguard-site-to-site-vpn-zwei-netzwerke-sicher-verbinden/" rel="nofollow ugc">hier</a> .... ist recht gut erklärt</p>
]]></description><link>https://forum.iobroker.net/post/972376</link><guid isPermaLink="true">https://forum.iobroker.net/post/972376</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Mon, 03 Apr 2023 07:37:50 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Mon, 03 Apr 2023 07:09:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wszene" aria-label="Profile: wszene">@<bdi>wszene</bdi></a> WireGuard hat ein sehr simples Protokoll und ist in 5-10 Minuten auf beiden Seiten eingerichtet.<br />
Wäre auf jeden fall sinnvoll gegenüber einer unsicheren FTP Verbindung.</p>
<p dir="auto">Wenn du an einem Laptop mit Filezilla testest, muss noch lange nicht der Proxmox Host eine Verbindung haben.</p>
]]></description><link>https://forum.iobroker.net/post/972353</link><guid isPermaLink="true">https://forum.iobroker.net/post/972353</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Mon, 03 Apr 2023 07:09:34 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Mon, 03 Apr 2023 03:13:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> sagte in <a href="/post/972040">backitup kein FTP</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wszene" aria-label="Profile: wszene">@<bdi>wszene</bdi></a> Du schreibst, über Filezilla geht die Verbindung. Hast du auf deinem iobroker System Filezilla laufen oder auf deinem Rechner?</p>
</blockquote>
<p dir="auto">Nein habe ich nicht<br />
Es geht um das Backup in meinem Wochendgrundstück dort habe ich nur einen MiniPC mit Proxmox stehen<br />
Habe dort mit dem Laptop probiert</p>
<p dir="auto">Am liebsten würde ich es ja wie so machen</p>
<ul>
<li>Site-toSite VPN Wireguard</li>
<li>ioBroker als Slave</li>
</ul>
<p dir="auto">Natürlich müsste ich dann auch meinen ioB zuhause als Master machen wo ich auch nicht wirklich die Ahnung habe<br />
Nur habe ich keine Ahnung wie ich eine Site-tp-Site Verbindung mit Wireguard einrichten kann<br />
Wenn mir da jemand zur Hand gehen kann wäre ich sehr Dankbar</p>
]]></description><link>https://forum.iobroker.net/post/972318</link><guid isPermaLink="true">https://forum.iobroker.net/post/972318</guid><dc:creator><![CDATA[Wszene]]></dc:creator><pubDate>Mon, 03 Apr 2023 03:13:29 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Sun, 02 Apr 2023 13:58:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Jup ist halt ne Notlösung und macht auch nur als solche Sinn.<br />
]]></description><link>https://forum.iobroker.net/post/972087</link><guid isPermaLink="true">https://forum.iobroker.net/post/972087</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Sun, 02 Apr 2023 13:58:20 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Sun, 02 Apr 2023 13:14:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> sagte in <a href="/post/971556">backitup kein FTP</a>:</p>
<blockquote>
<p dir="auto">FTP sollte man nur lokal verwenden</p>
</blockquote>
<p dir="auto">Und auch da besser nicht.</p>
]]></description><link>https://forum.iobroker.net/post/972046</link><guid isPermaLink="true">https://forum.iobroker.net/post/972046</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 02 Apr 2023 13:14:30 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Sun, 02 Apr 2023 13:04:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wszene" aria-label="Profile: wszene">@<bdi>wszene</bdi></a> Du schreibst, über Filezilla geht die Verbindung. Hast du auf deinem iobroker System Filezilla laufen oder auf deinem Rechner?</p>
]]></description><link>https://forum.iobroker.net/post/972040</link><guid isPermaLink="true">https://forum.iobroker.net/post/972040</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Sun, 02 Apr 2023 13:04:59 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Sun, 02 Apr 2023 06:08:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
Das ist richtig<br />
Aber das löst ja das Problem nicht</p>
<p dir="auto">Es muss ja ein Grund geben warum es nicht mehr geht</p>
]]></description><link>https://forum.iobroker.net/post/971797</link><guid isPermaLink="true">https://forum.iobroker.net/post/971797</guid><dc:creator><![CDATA[Wszene]]></dc:creator><pubDate>Sun, 02 Apr 2023 06:08:39 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Sat, 01 Apr 2023 15:49:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wszene" aria-label="Profile: wszene">@<bdi>wszene</bdi></a> sagte in <a href="/post/970549">backitup kein FTP</a>:</p>
<blockquote>
<p dir="auto">Ich lasse das Backup per FTP übers Internet versenden</p>
</blockquote>
<p dir="auto">Unverschlüsselt übers Internet... Keine gute Idee?<br />
Alle Daten können mitgelesen werden.</p>
<p dir="auto">FTP sollte man nur lokal verwenden ... Dann nimm lieber ne Cloud</p>
]]></description><link>https://forum.iobroker.net/post/971556</link><guid isPermaLink="true">https://forum.iobroker.net/post/971556</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Sat, 01 Apr 2023 15:49:52 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Fri, 31 Mar 2023 04:58:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> sagte in <a href="/post/970554">backitup kein FTP</a>:</p>
<blockquote>
<p dir="auto">und das ist ein Bug von ioBroker?</p>
</blockquote>
<p dir="auto">Ich dachte es ist die eine Kategorie wo es allgemein um "Error" geht</p>
<blockquote>
<p dir="auto">und hetzt die Gretchenfrage:<br />
was ist vor 3 Tagen geändert worden</p>
</blockquote>
<p dir="auto">Das ist es Ja es ist nichts geändert worden<br />
Das Update vom Backitup habe ich erst danach gemacht mit der Hoffnung das es wieder geht</p>
<p dir="auto">Und wie ich schon geschrieben habe<br />
Es kann auch nicht an meiner Infrastruktur liegen denn über Filezilla kann ich ganz normal die Verbindung aufbauen<br />
Auch von dem Standort wo sich der ioB befindet</p>
]]></description><link>https://forum.iobroker.net/post/970809</link><guid isPermaLink="true">https://forum.iobroker.net/post/970809</guid><dc:creator><![CDATA[Wszene]]></dc:creator><pubDate>Fri, 31 Mar 2023 04:58:52 GMT</pubDate></item><item><title><![CDATA[Reply to backitup kein FTP on Thu, 30 Mar 2023 16:34:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wszene" aria-label="Profile: wszene">@<bdi>wszene</bdi></a> sagte in <a href="/post/970549">backitup kein FTP</a>:</p>
<blockquote>
<p dir="auto">Seit ca. 3 Tagen läuft mein Backup nicht mehr</p>
</blockquote>
<hr />
<hr />
<blockquote>
<p dir="auto">Ich lasse das Backup per FTP <span style="color:#ff0000"><strong>übers Internet</strong></span> versenden</p>
</blockquote>
<blockquote>
<p dir="auto">Error: Timed out while making data connection</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/970554</link><guid isPermaLink="true">https://forum.iobroker.net/post/970554</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Thu, 30 Mar 2023 16:34:22 GMT</pubDate></item></channel></rss>
