<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Neueinsteiger - Vis2 Installation]]></title><description><![CDATA[<p dir="auto">Moin,</p>
<p dir="auto">komme frisch von Openhab zu Iobroker und versuche gerade Vis2 zu installieren. Die Anleitung, die ich gefunden habe funktioniert nur leider nicht.<br />
<a href="https://forum.iobroker.net/topic/60398/test-adapter-vis-2-0-alpha">https://forum.iobroker.net/topic/60398/test-adapter-vis-2-0-alpha</a></p>
<p dir="auto">Kann mir jemand zeigen wie ich Vis2 ans laufen bekomme...</p>
<pre><code>
deresdas@iobroker-pi:~ $ cd /opt/iobroker
deresdas@iobroker-pi:/opt/iobroker $ npm i iobroker.vis-2-beta
npm ERR! code EACCES
npm ERR! syscall mkdir
npm ERR! path /opt/iobroker/node_modules/fsevents
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/fsevents'
npm ERR!  [Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/fsevents'] {
npm ERR!   errno: -13,
npm ERR!   code: 'EACCES',
npm ERR!   syscall: 'mkdir',
npm ERR!   path: '/opt/iobroker/node_modules/fsevents'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR!     /home/deresdas/.npm/_logs/2023-03-19T17_14_21_468Z-debug-0.log
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/64014/neueinsteiger-vis2-installation</link><generator>RSS for Node</generator><lastBuildDate>Thu, 09 Apr 2026 07:59:39 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/64014.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Mar 2023 17:17:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Neueinsteiger - Vis2 Installation on Tue, 21 Mar 2023 14:42:28 GMT]]></title><description><![CDATA[<p dir="auto">@s-esders</p>
<pre><code>groups
</code></pre>
<p dir="auto">sagt zu deinem user?</p>
]]></description><link>https://forum.iobroker.net/post/966452</link><guid isPermaLink="true">https://forum.iobroker.net/post/966452</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 21 Mar 2023 14:42:28 GMT</pubDate></item><item><title><![CDATA[Reply to Neueinsteiger - Vis2 Installation on Tue, 21 Mar 2023 14:27:32 GMT]]></title><description><![CDATA[<p dir="auto">@s-esders dann solltest du mit VIS2 aber noch etwas warten und dies noch nicht produktiv nutzen. Im vis2 Faden hat kürzlich ein User berichtet, dass eine Aktion bei ihm dazu geführt hat, dass er sein vis2 Projekt nicht mehr öffnen kann.</p>
]]></description><link>https://forum.iobroker.net/post/966445</link><guid isPermaLink="true">https://forum.iobroker.net/post/966445</guid><dc:creator><![CDATA[Feuersturm]]></dc:creator><pubDate>Tue, 21 Mar 2023 14:27:32 GMT</pubDate></item><item><title><![CDATA[Reply to Neueinsteiger - Vis2 Installation on Tue, 21 Mar 2023 14:09:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> danke erstmal für eure Antworten. Ich möchte gerne Vis2 benutzen, da ich keine Lust habe für x Geräte eine eigene passende visu zu basteln:D vis1 ist ja meines Wissens nach nicht Responsiv</p>
]]></description><link>https://forum.iobroker.net/post/966442</link><guid isPermaLink="true">https://forum.iobroker.net/post/966442</guid><dc:creator><![CDATA[s.esders]]></dc:creator><pubDate>Tue, 21 Mar 2023 14:09:01 GMT</pubDate></item><item><title><![CDATA[Reply to Neueinsteiger - Vis2 Installation on Mon, 20 Mar 2023 07:13:40 GMT]]></title><description><![CDATA[<p dir="auto">@s-esders wenn du frisch von xxx kommst dann bleib bei stable ..</p>
<p dir="auto">die vis2 ist im test phase.. und du holst dir noch melh probleme mit rein</p>
<p dir="auto">ausserdem lass mal den</p>
<pre><code>iob fix
</code></pre>
<p dir="auto">über deine installation laufen</p>
]]></description><link>https://forum.iobroker.net/post/965794</link><guid isPermaLink="true">https://forum.iobroker.net/post/965794</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Mon, 20 Mar 2023 07:13:40 GMT</pubDate></item><item><title><![CDATA[Reply to Neueinsteiger - Vis2 Installation on Sun, 19 Mar 2023 17:37:16 GMT]]></title><description><![CDATA[<p dir="auto">@s-esders sagte in <a href="/post/965686">Neueinsteiger - Vis2 Installation</a>:</p>
<blockquote>
<p dir="auto">versuche gerade Vis2 zu installieren</p>
</blockquote>
<p dir="auto">warum?</p>
<blockquote>
<p dir="auto">Die Anleitung, die ich gefunden habe funktioniert nur leider nicht.<br />
<a href="https://forum.iobroker.net/topic/60398/test-adapter-vis-2-0-%25(#ff0000)%5B**alpha**%5D">https://forum.iobroker.net/topic/60398/test-adapter-vis-2-0-<span style="color:#ff0000">**alpha**</span></a></p>
</blockquote>
<p dir="auto">Die ist noch lange nicht fertig.</p>
<p dir="auto">wobei dein Problem aber wahrscheinlich in verbogenen Rechten im System zu suchen ist.</p>
]]></description><link>https://forum.iobroker.net/post/965702</link><guid isPermaLink="true">https://forum.iobroker.net/post/965702</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 19 Mar 2023 17:37:16 GMT</pubDate></item></channel></rss>
