<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehler bei Installation Node-Red]]></title><description><![CDATA[<p dir="auto">Hallo ich bekomme Node Red nicht installiert.<br />
Ich bekomme diesen Fehlercode. Was mache ich Falsch?</p>
<pre><code>
2023-02-28 17:32:03.881 - info: admin.0 (1293) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 17:32:26.152 - info: admin.0 (1293) terminating http server on port 8081
2023-02-28 17:32:26.150 - info: host.raspberrypi received SIGTERM
2023-02-28 17:32:26.155 - info: backitup.0 (1379) cleaned everything up...
2023-02-28 17:32:26.161 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
2023-02-28 17:32:26.162 - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
2023-02-28 17:32:26.163 - info: host.raspberrypi stopInstance system.adapter.openknx.0 (force=false, process=true)
2023-02-28 17:32:26.164 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
2023-02-28 17:32:26.175 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
2023-02-28 17:32:26.176 - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
2023-02-28 17:32:26.237 - info: admin.0 (1293) Got terminate signal TERMINATE_YOURSELF
2023-02-28 17:32:26.238 - info: javascript.0 (1320) Got terminate signal TERMINATE_YOURSELF
2023-02-28 17:32:26.242 - info: discovery.0 (1358) Got terminate signal TERMINATE_YOURSELF
2023-02-28 17:32:26.243 - info: openknx.0 (1335) Got terminate signal TERMINATE_YOURSELF
2023-02-28 17:32:26.246 - info: backitup.0 (1379) Got terminate signal TERMINATE_YOURSELF
2023-02-28 17:32:26.248 - info: openknx.0 (1335) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 17:32:26.252 - info: backitup.0 (1379) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 17:32:26.253 - info: javascript.0 (1320) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 17:32:26.257 - info: discovery.0 (1358) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 17:32:26.292 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
2023-02-28 17:32:26.294 - info: admin.0 (1293) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 17:32:26.296 - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
2023-02-28 17:32:26.297 - info: host.raspberrypi stopInstance system.adapter.openknx.0 send kill signal
2023-02-28 17:32:26.297 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
2023-02-28 17:32:26.298 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
2023-02-28 17:32:26.856 - info: host.raspberrypi instance system.adapter.openknx.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 17:32:26.918 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 17:32:26.920 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 17:32:26.921 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 17:32:26.938 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 17:32:26.938 - info: host.raspberrypi All instances are stopped.
2023-02-28 17:32:27.420 - info: host.raspberrypi terminated
2023-02-28 17:32:41.953 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
2023-02-28 17:32:41.959 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2023-02-28 17:32:41.960 - info: host.raspberrypi hostname: raspberrypi, node: v16.19.1
2023-02-28 17:32:41.961 - info: host.raspberrypi ip addresses: fe80::dc:81dd:69ae:b02c
2023-02-28 17:32:42.741 - info: host.raspberrypi connected to Objects and States
2023-02-28 17:32:42.795 - info: host.raspberrypi added notifications configuration of host
2023-02-28 17:32:43.284 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
2023-02-28 17:32:43.290 - info: host.raspberrypi 6 instances found
2023-02-28 17:32:43.303 - info: host.raspberrypi starting 5 instances
2023-02-28 17:32:43.395 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
2023-02-28 17:32:43.408 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
2023-02-28 17:32:43.425 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 604
2023-02-28 17:32:43.439 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
2023-02-28 17:32:43.453 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
2023-02-28 17:32:43.519 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
2023-02-28 17:32:43.534 - info: host.raspberrypi Some obsolete host states deleted.
2023-02-28 17:32:46.107 - info: admin.0 (604) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
2023-02-28 17:32:46.157 - info: admin.0 (604) requesting all states
2023-02-28 17:32:46.158 - info: admin.0 (604) requesting all objects
2023-02-28 17:32:46.781 - info: admin.0 (604) received all objects
2023-02-28 17:32:47.343 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 740
2023-02-28 17:32:47.402 - info: admin.0 (604) http server listening on port 8081
2023-02-28 17:32:47.403 - info: admin.0 (604) Use link "http://localhost:8081" to configure.
2023-02-28 17:32:47.414 - info: admin.0 (604) socket.io server listening on port 8081
2023-02-28 17:32:51.343 - info: host.raspberrypi instance system.adapter.openknx.0 started with pid 756
2023-02-28 17:32:51.411 - info: javascript.0 (740) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.1, js-controller: 4.0.24
2023-02-28 17:32:51.797 - info: javascript.0 (740) requesting all states
2023-02-28 17:32:51.798 - info: javascript.0 (740) requesting all objects
2023-02-28 17:32:52.196 - info: javascript.0 (740) received all states
2023-02-28 17:32:52.201 - info: javascript.0 (740) received all objects
2023-02-28 17:32:53.828 - info: openknx.0 (756) starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.openknx, node: v16.19.1, js-controller: 4.0.24
2023-02-28 17:32:53.860 - warn: openknx.0 (756) Gateway IP is missing please enter Gateway IP in the instance settings.
2023-02-28 17:32:55.382 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 834
2023-02-28 17:32:57.268 - info: discovery.0 (834) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
2023-02-28 17:32:59.375 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 849
2023-02-28 17:33:01.550 - info: backitup.0 (849) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
2023-02-28 17:33:01.711 - info: backitup.0 (849) [iobroker] backup was activated at 02:40 every 1 day(s)
2023-02-28 18:13:21.858 - info: admin.0 (604) failed connection to socket.io from ::ffff:192.168.9.50: Passport was not initialized
2023-02-28 18:13:22.027 - info: admin.0 (604) failed connection to socket.io from ::ffff:192.168.9.50: Passport was not initialized
2023-02-28 18:13:25.883 - info: admin.0 (604) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 18:13:53.019 - info: host.raspberrypi iobroker add node-red --host raspberrypi
2023-02-28 18:13:56.653 - info: host.raspberrypi iobroker NPM version: 8.19.3
2023-02-28 18:13:56.655 - info: host.raspberrypi iobroker Installing iobroker.node-red@4.0.0... (System call)
2023-02-28 18:14:30.218 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
2023-02-28 18:14:31.266 - info: host.raspberrypi iobroker exit 25
2023-02-28 18:17:24.483 - info: admin.0 (604) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 18:17:26.381 - info: admin.0 (604) &lt;== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
2023-02-28 18:18:06.911 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
2023-02-28 18:18:06.966 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
2023-02-28 18:18:07.002 - info: admin.0 (604) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:18:07.008 - info: admin.0 (604) terminating http server on port 8081
2023-02-28 18:18:07.013 - info: admin.0 (604) terminating
2023-02-28 18:18:07.015 - info: admin.0 (604) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2023-02-28 18:18:07.117 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
2023-02-28 18:18:07.125 - info: backitup.0 (849) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:18:07.127 - info: backitup.0 (849) cleaned everything up...
2023-02-28 18:18:07.129 - info: backitup.0 (849) terminating
2023-02-28 18:18:07.131 - info: backitup.0 (849) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2023-02-28 18:18:07.170 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
2023-02-28 18:18:07.193 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
2023-02-28 18:18:07.198 - info: discovery.0 (834) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:18:07.199 - info: discovery.0 (834) terminating
2023-02-28 18:18:07.201 - info: discovery.0 (834) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2023-02-28 18:18:07.246 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
2023-02-28 18:18:07.433 - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
2023-02-28 18:18:07.457 - info: javascript.0 (740) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:18:07.461 - info: javascript.0 (740) terminating
2023-02-28 18:18:07.463 - info: javascript.0 (740) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2023-02-28 18:18:07.487 - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
2023-02-28 18:18:07.558 - info: host.raspberrypi stopInstance system.adapter.openknx.0 (force=false, process=true)
2023-02-28 18:18:07.569 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2023-02-28 18:18:07.573 - info: openknx.0 (756) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:18:07.575 - info: openknx.0 (756) terminating
2023-02-28 18:18:07.576 - info: openknx.0 (756) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2023-02-28 18:18:07.620 - info: host.raspberrypi stopInstance system.adapter.openknx.0 send kill signal
2023-02-28 18:18:07.694 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2023-02-28 18:18:07.750 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2023-02-28 18:18:08.267 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2023-02-28 18:18:08.306 - info: host.raspberrypi instance system.adapter.openknx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2023-02-28 18:18:10.033 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 932
2023-02-28 18:18:10.198 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 939
2023-02-28 18:18:10.376 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 946
2023-02-28 18:18:10.542 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 953
2023-02-28 18:18:10.672 - info: host.raspberrypi instance system.adapter.openknx.0 started with pid 960
2023-02-28 18:18:13.641 - info: backitup.0 (939) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:18:13.890 - info: backitup.0 (939) [iobroker] backup was activated at 02:40 every 1 day(s)
2023-02-28 18:18:13.995 - info: admin.0 (932) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:18:14.110 - info: admin.0 (932) requesting all states
2023-02-28 18:18:14.186 - info: discovery.0 (946) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:18:14.111 - info: admin.0 (932) requesting all objects
2023-02-28 18:18:14.912 - info: admin.0 (932) received all objects
2023-02-28 18:18:15.320 - info: openknx.0 (960) starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.openknx, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:18:15.371 - warn: openknx.0 (960) Gateway IP is missing please enter Gateway IP in the instance settings.
2023-02-28 18:18:15.455 - info: admin.0 (932) http server listening on port 8081
2023-02-28 18:18:15.456 - info: admin.0 (932) Use link "http://localhost:8081" to configure.
2023-02-28 18:18:15.466 - info: admin.0 (932) socket.io server listening on port 8081
2023-02-28 18:18:16.054 - info: javascript.0 (953) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:18:16.267 - info: admin.0 (932) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 18:18:16.350 - info: javascript.0 (953) requesting all states
2023-02-28 18:18:16.352 - info: javascript.0 (953) requesting all objects
2023-02-28 18:18:16.682 - info: javascript.0 (953) received all objects
2023-02-28 18:18:16.686 - info: javascript.0 (953) received all states
2023-02-28 18:18:48.521 - info: admin.0 (932) &lt;== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
2023-02-28 18:18:48.683 - info: admin.0 (932) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 18:18:48.696 - info: admin.0 (932) &lt;== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
2023-02-28 18:18:49.263 - info: admin.0 (932) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 18:19:50.907 - info: backitup.0 (939) cleaned everything up...
2023-02-28 18:19:50.908 - info: admin.0 (932) terminating http server on port 8081
2023-02-28 18:19:50.923 - info: host.raspberrypi received SIGTERM
2023-02-28 18:19:50.928 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
2023-02-28 18:19:50.929 - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
2023-02-28 18:19:50.929 - info: host.raspberrypi stopInstance system.adapter.openknx.0 (force=false, process=true)
2023-02-28 18:19:50.930 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
2023-02-28 18:19:50.930 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
2023-02-28 18:19:50.931 - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
2023-02-28 18:19:50.968 - info: javascript.0 (953) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:19:50.968 - info: openknx.0 (960) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:19:50.972 - info: admin.0 (932) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:19:50.974 - info: javascript.0 (953) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:19:50.976 - info: openknx.0 (960) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:19:50.979 - info: discovery.0 (946) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:19:50.982 - info: backitup.0 (939) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:19:50.985 - info: admin.0 (932) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:19:50.987 - info: discovery.0 (946) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:19:50.994 - info: backitup.0 (939) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:19:51.010 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
2023-02-28 18:19:51.012 - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
2023-02-28 18:19:51.012 - info: host.raspberrypi stopInstance system.adapter.openknx.0 send kill signal
2023-02-28 18:19:51.013 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
2023-02-28 18:19:51.013 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
2023-02-28 18:19:51.578 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:19:51.579 - info: host.raspberrypi instance system.adapter.openknx.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:19:51.598 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:19:51.599 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:19:51.612 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:19:51.616 - info: host.raspberrypi All instances are stopped.
2023-02-28 18:19:51.777 - info: host.raspberrypi terminated
2023-02-28 18:21:38.516 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
2023-02-28 18:21:38.522 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2023-02-28 18:21:38.522 - info: host.raspberrypi hostname: raspberrypi, node: v16.19.1
2023-02-28 18:21:38.524 - info: host.raspberrypi ip addresses: 192.168.9.167 2003:e1:ef09:3800:498:e052:2966:ad48 fe80::dc:81dd:69ae:b02c
2023-02-28 18:21:39.142 - info: host.raspberrypi connected to Objects and States
2023-02-28 18:21:39.165 - info: host.raspberrypi added notifications configuration of host
2023-02-28 18:21:39.500 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
2023-02-28 18:21:39.506 - info: host.raspberrypi 6 instances found
2023-02-28 18:21:39.519 - info: host.raspberrypi starting 5 instances
2023-02-28 18:21:39.564 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
2023-02-28 18:21:39.579 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
2023-02-28 18:21:39.598 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1745
2023-02-28 18:21:39.610 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
2023-02-28 18:21:39.624 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
2023-02-28 18:21:39.687 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
2023-02-28 18:21:39.699 - info: host.raspberrypi Some obsolete host states deleted.
2023-02-28 18:21:41.826 - info: admin.0 (1745) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:21:41.875 - info: admin.0 (1745) requesting all states
2023-02-28 18:21:41.876 - info: admin.0 (1745) requesting all objects
2023-02-28 18:21:42.511 - info: admin.0 (1745) received all objects
2023-02-28 18:21:42.830 - info: admin.0 (1745) http server listening on port 8081
2023-02-28 18:21:42.831 - info: admin.0 (1745) Use link "http://localhost:8081" to configure.
2023-02-28 18:21:42.840 - info: admin.0 (1745) socket.io server listening on port 8081
2023-02-28 18:21:43.555 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 1772
2023-02-28 18:21:46.502 - info: javascript.0 (1772) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:21:46.717 - info: javascript.0 (1772) requesting all states
2023-02-28 18:21:46.719 - info: javascript.0 (1772) requesting all objects
2023-02-28 18:21:47.038 - info: javascript.0 (1772) received all objects
2023-02-28 18:21:47.041 - info: javascript.0 (1772) received all states
2023-02-28 18:21:47.598 - info: host.raspberrypi instance system.adapter.openknx.0 started with pid 1787
2023-02-28 18:21:49.702 - info: openknx.0 (1787) starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.openknx, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:21:49.734 - warn: openknx.0 (1787) Gateway IP is missing please enter Gateway IP in the instance settings.
2023-02-28 18:21:51.583 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 1802
2023-02-28 18:21:55.572 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1810
2023-02-28 18:21:55.808 - info: admin.0 (1745) failed connection to socket.io from ::ffff:192.168.9.50: Passport was not initialized
2023-02-28 18:22:00.897 - info: admin.0 (1745) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 18:22:02.521 - info: discovery.0 (1802) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:22:02.644 - info: backitup.0 (1810) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:22:03.680 - info: backitup.0 (1810) [iobroker] backup was activated at 02:40 every 1 day(s)
2023-02-28 18:22:18.844 - info: host.raspberrypi iobroker add node-red --host raspberrypi
2023-02-28 18:22:22.234 - info: host.raspberrypi iobroker NPM version: 8.19.3
2023-02-28 18:22:22.236 - info: host.raspberrypi iobroker Installing iobroker.node-red@4.0.0... (System call)
2023-02-28 18:22:56.795 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
2023-02-28 18:22:57.849 - info: host.raspberrypi iobroker exit 25
2023-02-28 18:23:36.123 - info: host.raspberrypi received SIGTERM
2023-02-28 18:23:36.131 - info: backitup.0 (1810) cleaned everything up...
2023-02-28 18:23:36.127 - info: admin.0 (1745) terminating http server on port 8081
2023-02-28 18:23:36.131 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
2023-02-28 18:23:36.132 - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
2023-02-28 18:23:36.133 - info: host.raspberrypi stopInstance system.adapter.openknx.0 (force=false, process=true)
2023-02-28 18:23:36.135 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
2023-02-28 18:23:36.136 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
2023-02-28 18:23:36.137 - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
2023-02-28 18:23:36.176 - info: admin.0 (1745) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:23:36.177 - info: javascript.0 (1772) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:23:36.180 - info: openknx.0 (1787) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:23:36.183 - info: discovery.0 (1802) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:23:36.186 - info: backitup.0 (1810) Got terminate signal TERMINATE_YOURSELF
2023-02-28 18:23:36.192 - info: openknx.0 (1787) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:23:36.192 - info: backitup.0 (1810) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:23:36.193 - info: discovery.0 (1802) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:23:36.199 - info: javascript.0 (1772) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:23:36.200 - info: admin.0 (1745) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2023-02-28 18:23:36.206 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
2023-02-28 18:23:36.208 - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
2023-02-28 18:23:36.208 - info: host.raspberrypi stopInstance system.adapter.openknx.0 send kill signal
2023-02-28 18:23:36.209 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
2023-02-28 18:23:36.209 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
2023-02-28 18:23:36.815 - info: host.raspberrypi instance system.adapter.openknx.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:23:36.816 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:23:36.817 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:23:36.866 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:23:36.908 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2023-02-28 18:23:36.909 - info: host.raspberrypi All instances are stopped.
2023-02-28 18:23:36.986 - info: host.raspberrypi terminated
2023-02-28 18:28:12.151 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
2023-02-28 18:28:12.157 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2023-02-28 18:28:12.158 - info: host.raspberrypi hostname: raspberrypi, node: v16.19.1
2023-02-28 18:28:12.159 - info: host.raspberrypi ip addresses: 192.168.9.167 2003:e1:ef09:3800:498:e052:2966:ad48 fe80::dc:81dd:69ae:b02c
2023-02-28 18:28:12.794 - info: host.raspberrypi connected to Objects and States
2023-02-28 18:28:12.816 - info: host.raspberrypi added notifications configuration of host
2023-02-28 18:28:13.151 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
2023-02-28 18:28:13.156 - info: host.raspberrypi 6 instances found
2023-02-28 18:28:13.171 - info: host.raspberrypi starting 5 instances
2023-02-28 18:28:13.217 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
2023-02-28 18:28:13.232 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
2023-02-28 18:28:13.252 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1989
2023-02-28 18:28:13.263 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
2023-02-28 18:28:13.278 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
2023-02-28 18:28:13.335 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
2023-02-28 18:28:13.346 - info: host.raspberrypi Some obsolete host states deleted.
2023-02-28 18:28:15.435 - info: admin.0 (1989) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:28:15.488 - info: admin.0 (1989) requesting all states
2023-02-28 18:28:15.488 - info: admin.0 (1989) requesting all objects
2023-02-28 18:28:16.065 - info: admin.0 (1989) received all objects
2023-02-28 18:28:16.335 - info: admin.0 (1989) http server listening on port 8081
2023-02-28 18:28:16.336 - info: admin.0 (1989) Use link "http://localhost:8081" to configure.
2023-02-28 18:28:16.344 - info: admin.0 (1989) socket.io server listening on port 8081
2023-02-28 18:28:16.591 - info: admin.0 (1989) failed connection to socket.io from ::ffff:192.168.9.50: Passport was not initialized
2023-02-28 18:28:16.628 - info: admin.0 (1989) failed connection to socket.io from ::ffff:192.168.9.50: Passport was not initialized
2023-02-28 18:28:17.240 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 2012
2023-02-28 18:28:20.297 - info: javascript.0 (2012) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:28:20.524 - info: javascript.0 (2012) requesting all states
2023-02-28 18:28:20.525 - info: javascript.0 (2012) requesting all objects
2023-02-28 18:28:20.876 - info: javascript.0 (2012) received all objects
2023-02-28 18:28:20.880 - info: javascript.0 (2012) received all states
2023-02-28 18:28:21.201 - info: host.raspberrypi instance system.adapter.openknx.0 started with pid 2031
2023-02-28 18:28:21.341 - info: admin.0 (1989) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 18:28:24.973 - info: openknx.0 (2031) starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.openknx, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:28:25.042 - warn: openknx.0 (2031) Gateway IP is missing please enter Gateway IP in the instance settings.
2023-02-28 18:28:25.225 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 2049
2023-02-28 18:28:28.906 - info: discovery.0 (2049) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:28:29.213 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 2080
2023-02-28 18:28:31.260 - info: backitup.0 (2080) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
2023-02-28 18:28:31.358 - info: backitup.0 (2080) [iobroker] backup was activated at 02:40 every 1 day(s)
2023-02-28 18:29:31.425 - info: host.raspberrypi iobroker url ioBroker/ioBroker.node-red --host raspberrypi --debug
2023-02-28 18:29:33.317 - info: host.raspberrypi iobroker install ioBroker/ioBroker.node-red
2023-02-28 18:29:34.369 - info: host.raspberrypi iobroker NPM version: 8.19.3
2023-02-28 18:29:34.371 - info: host.raspberrypi iobroker Installing ioBroker/ioBroker.node-red... (System call)
2023-02-28 18:30:03.041 - info: host.raspberrypi iobroker npm ERR! code ENOTEMPTYnpm ERR! syscall rename
2023-02-28 18:30:03.043 - info: host.raspberrypi iobroker npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2mnpm ERR! errno -39
2023-02-28 18:30:03.048 - info: host.raspberrypi iobroker npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -&gt; '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
2023-02-28 18:30:03.052 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-02-28T17_29_35_365Z-debug-0.log
2023-02-28 18:30:03.081 - error: host.raspberrypi iobroker host.raspberrypi Cannot install ioBroker/ioBroker.node-red: 217
2023-02-28 18:30:04.127 - info: host.raspberrypi iobroker exit 25
2023-02-28 18:30:14.842 - info: host.raspberrypi iobroker url https://github.com/node-red/node-red.git --host raspberrypi --debug
2023-02-28 18:30:17.726 - info: host.raspberrypi iobroker install node-red/node-red#604487143886cd5a5150f269e5d244934df29fcc
2023-02-28 18:30:19.057 - info: host.raspberrypi iobroker NPM version: 8.19.3
2023-02-28 18:30:19.060 - info: host.raspberrypi iobroker Installing node-red/node-red#604487143886cd5a5150f269e5d244934df29fcc... (System call)
2023-02-28 18:32:54.163 - info: admin.0 (1989) ==&gt; Connected system.user.admin from ::ffff:192.168.9.50
2023-02-28 18:34:03.012 - info: admin.0 (1989) &lt;== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
2023-02-28 18:45:10.918 - info: host.raspberrypi iobroker npm ERR! code ENOTEMPTY
2023-02-28 18:45:10.921 - info: host.raspberrypi iobroker npm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2mnpm ERR! errno -39
2023-02-28 18:45:10.926 - info: host.raspberrypi iobroker npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -&gt; '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
2023-02-28 18:45:10.930 - info: host.raspberrypi iobroker
2023-02-28 18:45:10.934 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:
2023-02-28 18:45:10.937 - info: host.raspberrypi iobroker npm ERR! /home/iobroker/.npm/_logs/2023-02-28T17_30_20_094Z-debug-0.log
2023-02-28 18:45:10.969 - error: host.raspberrypi iobroker host.raspberrypi Cannot install node-red/node-red#604487143886cd5a5150f269e5d244934df29fcc: 217
2023-02-28 18:45:12.010 - info: host.raspberrypi iobroker exit 25
2023-02-28 19:24:16.888 - info: admin.0 (1989) failed connection to socket.io from ::ffff:192.168.9.203: Passport was not initialized
2023-02-28 19:24:26.392 - info: admin.0 (1989) ==&gt; Connected system.user.admin from ::ffff:192.168.9.203
2023-02-28 19:25:17.034 - error: host.raspberrypi Invalid request getRepository. "callback" or "from" is null
2023-02-28 19:25:45.965 - info: host.raspberrypi iobroker add node-red --host raspberrypi
2023-02-28 19:25:49.372 - info: host.raspberrypi iobroker NPM version: 8.19.3
2023-02-28 19:25:49.374 - info: host.raspberrypi iobroker Installing iobroker.node-red@4.0.0... (System call)
2023-02-28 19:26:16.980 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
2023-02-28 19:26:18.025 - info: host.raspberrypi iobroker exit 25
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/63452/fehler-bei-installation-node-red</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 13:05:39 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/63452.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Feb 2023 18:28:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehler bei Installation Node-Red on Tue, 28 Feb 2023 18:30:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timowald" aria-label="Profile: timowald">@<bdi>timowald</bdi></a></p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update">https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update</a></p>
]]></description><link>https://forum.iobroker.net/post/955407</link><guid isPermaLink="true">https://forum.iobroker.net/post/955407</guid><dc:creator><![CDATA[DJMarc75]]></dc:creator><pubDate>Tue, 28 Feb 2023 18:30:32 GMT</pubDate></item></channel></rss>
