<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Socket Error: UNKNOWN]]></title><description><![CDATA[<p dir="auto">Sowohl im VIS als auch im echarts Fenster kommt immer wieder diese Meldung:</p>
<p dir="auto"><img src="/assets/uploads/files/1675361476104-socketerror.jpg" alt="socketerror.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Wenn man ein oder manchmal auch mehrmals auf OK drückt geht alles normal weiter.<br />
Was bedeutet dieser Fehler?</p>
]]></description><link>https://forum.iobroker.net/topic/62624/socket-error-unknown</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 12:59:38 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/62624.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Feb 2023 18:13:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Socket Error: UNKNOWN on Fri, 03 Feb 2023 12:02:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a></p>
<p dir="auto">Hallo</p>
<p dir="auto">iob diag liefert</p>
<pre><code>pi@raspberrypi:~ $ iob diag
iobroker [command]
Commands:
  iobroker setup                                               Setup ioBroker
  iobroker start [all|&lt;adapter&gt;.&lt;instance&gt;]                    Starts the js-controller or a specified adapter instance
  iobroker stop [&lt;adapter&gt;.&lt;instance&gt;]                         stops the js-controller or a specified adapter instance
  iobroker restart [&lt;adapter&gt;.&lt;instance&gt;]                      Restarts js-controller or a specified adapter instance  [aliases: r]
  iobroker debug &lt;adapter&gt;[.&lt;instance&gt;]                        Starts a Node.js debugging session for the adapter instance
  iobroker info                                                Shows the host info
  iobroker logs [&lt;adapter&gt;]                                    Monitor log
  iobroker add &lt;adapter&gt; [desiredNumber]                       Add instance of adapter  [aliases: a]
  iobroker install &lt;adapter&gt;                                   Installs a specified adapter  [aliases: i]
  iobroker rebuild [&lt;module&gt;]                                  Rebuild all native modules or path
  iobroker url &lt;url&gt; [&lt;name&gt;]                                  Install adapter from specified url, e.g. GitHub
  iobroker del &lt;adapter&gt;                                       Remove adapter and all instances from this host  [aliases: delete]
  iobroker del &lt;adapter&gt;.&lt;instance&gt;                            Remove adapter instance  [aliases: delete]
  iobroker update [&lt;repositoryUrl&gt;]                            Update repository and list adapters
  iobroker upgrade                                             Upgrade management
  iobroker upload [all|&lt;adapter&gt;]                              Upload management  [aliases: u]
  iobroker object                                              Object management  [aliases: o]
  iobroker state                                               State management  [aliases: s]
  iobroker message &lt;adapter&gt;[.instance] &lt;command&gt; [&lt;message&gt;]  Send message to adapter instance/s
  iobroker list &lt;type&gt; [&lt;filter&gt;]                              List all entries, like objects
  iobroker chmod &lt;mode&gt; &lt;file&gt;                                 Change file rights
  iobroker chown &lt;user&gt; &lt;group&gt; &lt;file&gt;                         Change file ownership
  iobroker touch &lt;file&gt;                                        Touch file
  iobroker rm &lt;file&gt;                                           Remove file
  iobroker file                                                File management
  iobroker user                                                User commands
  iobroker group                                               group management
  iobroker host &lt;hostname&gt;                                     Set host to given hostname
  iobroker set &lt;adapter&gt;.&lt;instance&gt;                            Change settings of adapter config
  iobroker license &lt;license.file or license.text&gt;              Update license by given file
  iobroker cert                                                Certificate management
  iobroker clean &lt;yes&gt;                                         Clears all objects and states
  iobroker backup                                              Create backup
  iobroker restore &lt;backup name or path&gt;                       Restore a specified backup
  iobroker validate &lt;backup name or path&gt;                      Validate a specified backup
  iobroker status [all|&lt;adapter&gt;.&lt;instance&gt;]                   Status of ioBroker or adapter instance  [aliases: isrun]
  iobroker repo [&lt;name&gt;]                                       Show repo information
  iobroker uuid                                                Show uuid of the installation  [aliases: id]
  iobroker unsetup                                             Reset license, installation secret and language
  iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
  iobroker multihost                                           Multihost management
  iobroker compact                                             compact group management
  iobroker plugin                                              Plugin management
  iobroker version [&lt;adapter&gt;]                                 Show version of js-controller or specified adapter  [aliases: v]
Options:
  --help  Show help  [boolean]
</code></pre>
<p dir="auto">Ich glaube aber, dass ein Problem meines lokalen Netzwerkes schuld sein könnte.<br />
Ich habe gerade folgendes beobachtet:<br />
Auf meinem (Windows) Rechner waren 2 Firefox Fenster mit IO-Broker Vis sichtbar, in einer virtuellen Maschine eine Win 7 Instanz und über VNC ein Desktop eines Win 10 Rechners der gerade eine große Datei von der lokalen Festplatte auf ein NAS kopiert hat. Dann hatte ich in Ultraedit eine Datei geöffnet, die auf dem IO-Broker Raspberry liegt und per SMB ins lokale Netz eingebunden ist.<br />
Jetzt habe ich in das UltraaEdit Fenster geklickt und dieses hat dann erstmal die darin geladene Datei aktualisiert. In dem Moment sind auf beiden VIS Fenstern die Fenster "Socket Errror: UNKNOWN" aufgepoppt, im VNC Fenster hat das Kopieren der Datei auf das NAS mit der Meldung "... abgebrochen, überprüfen Sie die Schreibrechte" agebrochen und  die vituelle Maschine hat komplett den Netzwerkzugang verloren. (Kein Ping mehr ins lokale Netz möglich, Netzwerkadapter sagt, dass kein Kabel angeschlossen ist, wenn ich die virtuelle Maschine schlafen lege "Zustand der virtuellen Maschine speichern" und wieder aufwecke ist das Netzwerk wieder da).<br />
Ich glaube ich habe ein tieferes Netzwerkproblem hier :-(</p>
]]></description><link>https://forum.iobroker.net/post/940054</link><guid isPermaLink="true">https://forum.iobroker.net/post/940054</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Fri, 03 Feb 2023 12:02:25 GMT</pubDate></item><item><title><![CDATA[Reply to Socket Error: UNKNOWN on Thu, 02 Feb 2023 18:39:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/939674">Socket Error: UNKNOWN</a>:</p>
<blockquote>
<p dir="auto">kommt immer wieder diese Meldung:</p>
</blockquote>
<blockquote>
<p dir="auto">VIS als auch im echarts Fenster</p>
</blockquote>
<p dir="auto">in kombination nur mit Echart ... oder allgemein .</p>
<p dir="auto">Auch nach einem</p>
<pre><code>sudo reboot
</code></pre>
<p dir="auto">noch vorhanden oder .. sporalisch oder ...</p>
<p dir="auto">Zeige mal alles von</p>
<pre><code>iob diag
</code></pre>
<p dir="auto">sonst wird das ein raten ....</p>
]]></description><link>https://forum.iobroker.net/post/939682</link><guid isPermaLink="true">https://forum.iobroker.net/post/939682</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Thu, 02 Feb 2023 18:39:03 GMT</pubDate></item></channel></rss>
