<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ioBroker startet nach Bullseye update nicht mehr]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,<br />
ich bin nach der Anleitung von <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> vorgegangen und hab meinen PI4 von Buster auf Bullseye upgedatet, nun startet ioBroker nicht mehr.<br />
Die Ausgabe von iobroker diag</p>
<pre><code>*** ioBroker Diagnosis ***
Please stretch the window of your terminal programm (puTTY) as wide as possible        or switch to full screen
The following checks may give hints to potential malconfigurations or errors, pl        ease post them in our forum:
https://forum.iobroker.net
Just copy and paste the Summary Page, including the ``` characters at start and        end.
It helps us to help you!
Press any key to continue
======== Start marking the full check here =========
Skript v.2022-12-13
*** BASE SYSTEM ***
Model           : Raspberry Pi 3 Model B Rev 1.2
Architecture:   armv7l
Docker:         false
Virtualization: none
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 11 (bullseye)
Release:        11
Codename:       bullseye
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Systemuptime and Load:
 15:37:06 up 20 min,  1 user,  load average: 0.00, 0.13, 0.24
CPU threads: 4
*** Time and Time Zones ***
Tue Dec 27 14:37:06 UTC 2022
Tue Dec 27 15:37:06 CET 2022
CET +0100
Europe/Berlin
*** User and Groups ***
pi
/home/pi
pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
*** X-Server-Setup ***
X-Server:       false
Desktop:
Terminal:       tty
*** MEMORY ***
Mem:            922M        145M        295M        0.0K        481M        737M
Swap:            99M          0B         99M
Total:          1.0G        145M        395M
          922 M total memory
          145 M used memory
          236 M active memory
          271 M inactive memory
          295 M free memory
          118 M buffer memory
          363 M swap cache
           99 M total swap
            0 M used swap
           99 M free swap
*** FILESYSTEM ***
/dev/root      ext4       29G  7.4G   21G  27% /
devtmpfs       devtmpfs  429M     0  429M   0% /dev
tmpfs          tmpfs     462M     0  462M   0% /dev/shm
tmpfs          tmpfs     185M  620K  184M   1% /run
/dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
Show mounted filesystems (real ones only):
TARGET  SOURCE         FSTYPE OPTIONS
/       /dev/mmcblk0p2 ext4   rw,noatime
`-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
/var:
723M    /var/
444M    /var/log
377M    /var/log/journal/6a4fb0bc59ea42fabbaf7f900b09cc5d
125M    /var/lib
/opt/iobroker/backups:
2.9G    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
270M    /opt/iobroker/iobroker-data/
191M    /opt/iobroker/iobroker-data/files
72M     /opt/iobroker/iobroker-data/files/telegram.admin
61M     /opt/iobroker/iobroker-data/backup-objects
51M     /opt/iobroker/iobroker-data/files/javascript.admin
15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
6.5M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js.map
*** NodeJS-Installation ***
/usr/bin/nodejs         v16.19.0
/usr/bin/node           v16.19.0
/usr/bin/npm            8.19.3
nodejs:
  Installed: 16.19.0-deb-1nodesource1
  Candidate: 16.19.0-deb-1nodesource1
  Version table:
 *** 16.19.0-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
        100 /var/lib/dpkg/status
     14.21.1-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
     12.22.12~dfsg-1~deb11u1 500
        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
*** ioBroker-Installation ***
ioBroker Status
node:internal/modules/cjs/loader:998
  throw err;
Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
    at Function.Module._load (node:internal/modules/cjs/loader:841:27)
    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    at node:internal/main/run_main_module:22:47 {
  code: 'MODULE_NOT_FOUND',
  requireStack: []
Core adapters versions
  throw err;
  requireStack: []
js-controller:
  throw err;
  requireStack: []
admin:
npm ERR! code ELSPROBLEMS
npm ERR! extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
npm ERR! extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/jsonl-db
npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
npm ERR! extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alcalzone/proper-lockfile
npm ERR! extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
npm ERR! extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
npm ERR! extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
npm ERR! extraneous: @googleapis/drive@4.0.1 /opt/iobroker/node_modules/@googleapis/drive
npm ERR! extraneous: @greenlock/manager@3.1.0 /opt/iobroker/node_modules/@greenlock/manager
npm ERR! extraneous: @iobroker/adapter-core@1.0.3 /opt/iobroker/node_modules/@iobroker/adapter-core
npm ERR! extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
npm ERR! extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
npm ERR! extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
npm ERR! extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
npm ERR! extraneous: @iobroker/db-states-file@4.0.23 /opt/iobroker/node_modules/@iobroker/db-states-file
npm ERR! extraneous: @iobroker/db-states-jsonl@4.0.23 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
npm ERR! extraneous: @iobroker/db-states-redis@4.0.23 /opt/iobroker/node_modules/@iobroker/db-states-redis
npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
npm ERR! extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
npm ERR! extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
npm ERR! extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
npm ERR! extraneous: @iobroker/plugin-sentry@1.2.0 /opt/iobroker/node_modules/@iobroker/plugin-sentry
npm ERR! extraneous: @iobroker/socket-classes@1.0.2 /opt/iobroker/node_modules/@iobroker/socket-classes
npm ERR! extraneous: @iobroker/ws-server@2.1.0 /opt/iobroker/node_modules/@iobroker/ws-server
npm ERR! extraneous: @root/acme@ /opt/iobroker/node_modules/@root/acme
npm ERR! extraneous: @root/asn1@1.0.0 /opt/iobroker/node_modules/@root/asn1
npm ERR! extraneous: @root/csr@0.8.1 /opt/iobroker/node_modules/@root/csr
npm ERR! extraneous: @root/encoding@1.0.1 /opt/iobroker/node_modules/@root/encoding
npm ERR! extraneous: @root/greenlock-express@4.0.4 /opt/iobroker/node_modules/@root/greenlock-express
npm ERR! extraneous: @root/greenlock@ /opt/iobroker/node_modules/@root/greenlock
npm ERR! extraneous: @root/keypairs@0.9.0 /opt/iobroker/node_modules/@root/keypairs
npm ERR! extraneous: @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
npm ERR! extraneous: @root/pem@1.0.4 /opt/iobroker/node_modules/@root/pem
npm ERR! extraneous: @root/request@1.8.2 /opt/iobroker/node_modules/@root/request
npm ERR! extraneous: @root/x509@0.7.2 /opt/iobroker/node_modules/@root/x509
npm ERR! extraneous: @sentry/core@6.19.7 /opt/iobroker/node_modules/@sentry/core
npm ERR! extraneous: @sentry/hub@6.19.7 /opt/iobroker/node_modules/@sentry/hub
npm ERR! extraneous: @sentry/integrations@6.19.7 /opt/iobroker/node_modules/@sentry/integrations
npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal
npm ERR! extraneous: @sentry/node@6.19.7 /opt/iobroker/node_modules/@sentry/node
npm ERR! extraneous: @sentry/types@6.19.7 /opt/iobroker/node_modules/@sentry/types
npm ERR! extraneous: @sentry/utils@6.19.7 /opt/iobroker/node_modules/@sentry/utils
npm ERR! extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@serialport/binding-mock
npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
npm ERR! extraneous: @serialport/bindings@ /opt/iobroker/node_modules/@serialport/bindings
npm ERR! extraneous: @serialport/parser-byte-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-byte-length
npm ERR! extraneous: @serialport/parser-cctalk@10.5.0 /opt/iobroker/node_modules/@serialport/parser-cctalk
npm ERR! extraneous: @serialport/parser-delimiter@10.5.0 /opt/iobroker/node_modules/@serialport/parser-delimiter
npm ERR! extraneous: @serialport/parser-inter-byte-timeout@10.5.0 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
npm ERR! extraneous: @serialport/parser-packet-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-packet-length
npm ERR! extraneous: @serialport/parser-readline@10.5.0 /opt/iobroker/node_modules/@serialport/parser-readline
npm ERR! extraneous: @serialport/parser-ready@10.5.0 /opt/iobroker/node_modules/@serialport/parser-ready
npm ERR! extraneous: @serialport/parser-regex@10.5.0 /opt/iobroker/node_modules/@serialport/parser-regex
npm ERR! extraneous: @serialport/parser-slip-encoder@10.5.0 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
npm ERR! extraneous: @serialport/parser-spacepacket@10.5.0 /opt/iobroker/node_modules/@serialport/parser-spacepacket
npm ERR! extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/stream
npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/@socket.io/component-emitter
npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
npm ERR! extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
npm ERR! extraneous: @types/cors@2.8.12 /opt/iobroker/node_modules/@types/cors
npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
npm ERR! extraneous: @types/iobroker@1.4.12 /opt/iobroker/node_modules/@types/iobroker
npm ERR! extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
npm ERR! extraneous: @types/request@ /opt/iobroker/node_modules/@types/request
npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types/responselike
npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
npm ERR! extraneous: accepts@1.3.7 /opt/iobroker/node_modules/accepts
npm ERR! extraneous: acme-http-01-standalone@3.0.5 /opt/iobroker/node_modules/acme-http-01-standalone
npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
npm ERR! extraneous: ajv@6.10.2 /opt/iobroker/node_modules/ajv
npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/ansi-styles
npm ERR! extraneous: anymatch@3.1.2 /opt/iobroker/node_modules/anymatch
npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
npm ERR! extraneous: array.prototype.findindex@2.2.1 /opt/iobroker/node_modules/array.prototype.findindex
npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
npm ERR! extraneous: asn1@0.2.4 /opt/iobroker/node_modules/asn1
npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/assert-plus
npm ERR! extraneous: async@2.6.4 /opt/iobroker/node_modules/async
npm ERR! extraneous: at-least-node@1.0.0 /opt/iobroker/node_modules/at-least-node
npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/aws-sign2
npm ERR! extraneous: aws4@1.8.0 /opt/iobroker/node_modules/aws4
npm ERR! extraneous: axios@0.26.1 /opt/iobroker/node_modules/axios
npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
npm ERR! extraneous: balanced-match@1.0.0 /opt/iobroker/node_modules/balanced-match
npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
npm ERR! extraneous: base64-arraybuffer@0.1.5 /opt/iobroker/node_modules/base64-arraybuffer
npm ERR! extraneous: base64-js@1.3.1 /opt/iobroker/node_modules/base64-js
npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
npm ERR! extraneous: bignumber.js@9.1.1 /opt/iobroker/node_modules/bignumber.js
npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/binary-extensions
npm ERR! extraneous: bl@ /opt/iobroker/node_modules/bl
npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
npm ERR! extraneous: bluebird@3.7.1 /opt/iobroker/node_modules/bluebird
npm ERR! extraneous: body-parser@1.20.0 /opt/iobroker/node_modules/body-parser
npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/braces
npm ERR! extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/buffer-from
npm ERR! extraneous: buffer@5.6.0 /opt/iobroker/node_modules/buffer
npm ERR! extraneous: busboy@ /opt/iobroker/node_modules/busboy
npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheable-request
npm ERR! extraneous: call-bind@1.0.0 /opt/iobroker/node_modules/call-bind
npm ERR! extraneous: callsite@1.0.0 /opt/iobroker/node_modules/callsite
npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/caseless
npm ERR! extraneous: cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/chokidar
npm ERR! extraneous: chownr@1.1.4 /opt/iobroker/node_modules/chownr
npm ERR! extraneous: ci-info@3.3.2 /opt/iobroker/node_modules/ci-info
npm ERR! extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
npm ERR! extraneous: cluster-key-slot@1.1.0 /opt/iobroker/node_modules/cluster-key-slot
npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
npm ERR! extraneous: color-convert@1.9.3 /opt/iobroker/node_modules/color-convert
npm ERR! extraneous: color-name@1.1.3 /opt/iobroker/node_modules/color-name
npm ERR! extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
npm ERR! extraneous: color@3.2.1 /opt/iobroker/node_modules/color
npm ERR! extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/component-emitter
npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
npm ERR! extraneous: compression@ /opt/iobroker/node_modules/compression
npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
npm ERR! extraneous: content-disposition@ /opt/iobroker/node_modules/content-disposition
npm ERR! extraneous: content-type@1.0.4 /opt/iobroker/node_modules/content-type
npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser
npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/cookie-signature
npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie
npm ERR! extraneous: core-util-is@1.0.2 /opt/iobroker/node_modules/core-util-is
npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
npm ERR! extraneous: cron-parser@3.5.0 /opt/iobroker/node_modules/cron-parser
npm ERR! extraneous: cron@1.7.2 /opt/iobroker/node_modules/cron
npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/cross-spawn
npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
npm ERR! extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
npm ERR! extraneous: daemonize2@0.4.2 /opt/iobroker/node_modules/daemonize2
npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
npm ERR! extraneous: date-fns@ /opt/iobroker/node_modules/date-fns
npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/debug
npm ERR! extraneous: decache@4.6.1 /opt/iobroker/node_modules/decache
npm ERR! extraneous: decompress-response@ /opt/iobroker/node_modules/decompress-response
npm ERR! extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
npm ERR! extraneous: define-properties@1.1.3 /opt/iobroker/node_modules/define-properties
npm ERR! extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/depd
npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
npm ERR! extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
npm ERR! extraneous: dgram@1.0.1 /opt/iobroker/node_modules/dgram
npm ERR! extraneous: diskusage@1.1.3 /opt/iobroker/node_modules/diskusage
npm ERR! extraneous: dns-packet@1.3.4 /opt/iobroker/node_modules/dns-packet
npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
npm ERR! extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
npm ERR! extraneous: eckles@1.4.1 /opt/iobroker/node_modules/eckles
npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/emoji-regex
npm ERR! extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
npm ERR! extraneous: engine.io-parser@2.2.0 /opt/iobroker/node_modules/engine.io-parser
npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
npm ERR! extraneous: es-abstract@1.20.5 /opt/iobroker/node_modules/es-abstract
npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
npm ERR! extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
npm ERR! extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/escalade
npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
npm ERR! extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
npm ERR! extraneous: eventemitter3@3.1.2 /opt/iobroker/node_modules/eventemitter3
npm ERR! extraneous: execa@ /opt/iobroker/node_modules/execa
npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-fileupload
npm ERR! extraneous: express-session@ /opt/iobroker/node_modules/express-session
npm ERR! extraneous: express@ /opt/iobroker/node_modules/express
npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/extend
npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/extsprintf
npm ERR! extraneous: eyes@0.1.8 /opt/iobroker/node_modules/eyes
npm ERR! extraneous: fast-deep-equal@2.0.1 /opt/iobroker/node_modules/fast-deep-equal
npm ERR! extraneous: fast-json-stable-stringify@2.0.0 /opt/iobroker/node_modules/fast-json-stable-stringify
npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
npm ERR! extraneous: fast-xml-parser@3.21.1 /opt/iobroker/node_modules/fast-xml-parser
npm ERR! extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
npm ERR! extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
npm ERR! extraneous: file-type@3.9.0 /opt/iobroker/node_modules/file-type
npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/fill-range
npm ERR! extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
npm ERR! extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/forever-agent
npm ERR! extraneous: form-data@2.3.3 /opt/iobroker/node_modules/form-data
npm ERR! extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
npm ERR! extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
npm ERR! extraneous: from@0.1.7 /opt/iobroker/node_modules/from
npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
npm ERR! extraneous: function-bind@1.1.1 /opt/iobroker/node_modules/function-bind
npm ERR! extraneous: function.prototype.name@1.1.5 /opt/iobroker/node_modules/function.prototype.name
npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
npm ERR! extraneous: gaxios@5.0.2 /opt/iobroker/node_modules/gaxios
npm ERR! extraneous: gcp-metadata@ /opt/iobroker/node_modules/gcp-metadata
npm ERR! extraneous: get-intrinsic@1.0.1 /opt/iobroker/node_modules/get-intrinsic
npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
npm ERR! extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-common
npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
npm ERR! extraneous: got@11.8.5 /opt/iobroker/node_modules/got
npm ERR! extraneous: greenlock-express@4.0.3 /opt/iobroker/node_modules/greenlock-express
npm ERR! extraneous: greenlock-manager-fs@3.1.1 /opt/iobroker/node_modules/greenlock-manager-fs
npm ERR! extraneous: greenlock-store-fs@3.2.2 /opt/iobroker/node_modules/greenlock-store-fs
npm ERR! extraneous: greenlock@4.0.4 /opt/iobroker/node_modules/greenlock
npm ERR! extraneous: gtoken@ /opt/iobroker/node_modules/gtoken
npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/har-schema
npm ERR! extraneous: har-validator@5.1.3 /opt/iobroker/node_modules/har-validator
npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
npm ERR! extraneous: has-binary2@ /opt/iobroker/node_modules/has-binary2
npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
npm ERR! extraneous: has-property-descriptors@1.0.0 /opt/iobroker/node_modules/has-property-descriptors
npm ERR! extraneous: has-symbols@1.0.1 /opt/iobroker/node_modules/has-symbols
npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/has-tostringtag
npm ERR! extraneous: has@1.0.3 /opt/iobroker/node_modules/has
npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
npm ERR! extraneous: http-cache-semantics@4.1.0 /opt/iobroker/node_modules/http-cache-semantics
npm ERR! extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/http-signature
npm ERR! extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
npm ERR! extraneous: https-proxy-agent@ /opt/iobroker/node_modules/https-proxy-agent
npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/human-signals
npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
npm ERR! extraneous: ieee754@1.1.13 /opt/iobroker/node_modules/ieee754
npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
npm ERR! extraneous: internal-slot@1.0.4 /opt/iobroker/node_modules/internal-slot
npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
npm ERR! invalid: iobroker.fullybrowser@ /opt/iobroker/node_modules/iobroker.fullybrowser
npm ERR! invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
npm ERR! invalid: iobroker.jarvis@ /opt/iobroker/node_modules/iobroker.jarvis
npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
npm ERR! invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
npm ERR! invalid: iobroker.socketio@ /opt/iobroker/node_modules/iobroker.socketio
npm ERR! invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
npm ERR! extraneous: iobroker.ws@ /opt/iobroker/node_modules/iobroker.ws
npm ERR! extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
npm ERR! extraneous: ip@1.1.5 /opt/iobroker/node_modules/ip
npm ERR! extraneous: ipaddr.js@1.9.1 /opt/iobroker/node_modules/ipaddr.js
npm ERR! extraneous: is-arrayish@0.2.1 /opt/iobroker/node_modules/is-arrayish
npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/is-core-module
npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
npm ERR! extraneous: is-nan@1.3.2 /opt/iobroker/node_modules/is-nan
npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
npm ERR! extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/is-stream
npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/is-typedarray
npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
npm ERR! extraneous: is@3.3.0 /opt/iobroker/node_modules/is
npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/isarray
npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/isexe
npm ERR! extraneous: isstream@0.1.2 /opt/iobroker/node_modules/isstream
npm ERR! extraneous: jsbn@0.1.1 /opt/iobroker/node_modules/jsbn
npm ERR! extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
npm ERR! extraneous: json-schema-traverse@0.4.1 /opt/iobroker/node_modules/json-schema-traverse
npm ERR! extraneous: json-schema@0.2.3 /opt/iobroker/node_modules/json-schema
npm ERR! extraneous: json-stringify-safe@5.0.1 /opt/iobroker/node_modules/json-stringify-safe
npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
npm ERR! extraneous: jsonc-parser@3.0.0 /opt/iobroker/node_modules/jsonc-parser
npm ERR! extraneous: jsonwebtoken@8.5.1 /opt/iobroker/node_modules/jsonwebtoken
npm ERR! extraneous: jsprim@1.4.1 /opt/iobroker/node_modules/jsprim
npm ERR! extraneous: jszip@ /opt/iobroker/node_modules/jszip
npm ERR! extraneous: jwa@1.4.1 /opt/iobroker/node_modules/jwa
npm ERR! extraneous: jws@3.2.2 /opt/iobroker/node_modules/jws
npm ERR! extraneous: keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
npm ERR! extraneous: keyv@4.5.2 /opt/iobroker/node_modules/keyv
npm ERR! extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
npm ERR! extraneous: le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
npm ERR! extraneous: le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
npm ERR! extraneous: le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
npm ERR! extraneous: lie@3.1.1 /opt/iobroker/node_modules/lie
npm ERR! extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
npm ERR! extraneous: localforage@ /opt/iobroker/node_modules/localforage
npm ERR! extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
npm ERR! extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
npm ERR! extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
npm ERR! extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
npm ERR! extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
npm ERR! extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
npm ERR! extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
npm ERR! extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
npm ERR! extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
npm ERR! extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
npm ERR! extraneous: logform@ /opt/iobroker/node_modules/logform
npm ERR! extraneous: loglevel@1.8.0 /opt/iobroker/node_modules/loglevel
npm ERR! extraneous: long-timeout@0.1.1 /opt/iobroker/node_modules/long-timeout
npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
npm ERR! extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
npm ERR! extraneous: luxon@1.28.0 /opt/iobroker/node_modules/luxon
npm ERR! extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
npm ERR! extraneous: md5@ /opt/iobroker/node_modules/md5
npm ERR! extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
npm ERR! extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/merge-stream
npm ERR! extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
npm ERR! extraneous: mime@1.6.0 /opt/iobroker/node_modules/mime
npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/mimic-fn
npm ERR! extraneous: mimic-response@ /opt/iobroker/node_modules/mimic-response
npm ERR! extraneous: minimatch@5.1.0 /opt/iobroker/node_modules/minimatch
npm ERR! extraneous: moment-timezone@0.5.27 /opt/iobroker/node_modules/moment-timezone
npm ERR! extraneous: moment@2.24.0 /opt/iobroker/node_modules/moment
npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/ms
npm ERR! extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
npm ERR! extraneous: negotiator@0.6.2 /opt/iobroker/node_modules/negotiator
npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
npm ERR! extraneous: node-abi@ /opt/iobroker/node_modules/node-abi
npm ERR! extraneous: node-addon-api@5.0.0 /opt/iobroker/node_modules/node-addon-api
npm ERR! extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
npm ERR! extraneous: node-fetch@2.6.7 /opt/iobroker/node_modules/node-fetch
npm ERR! extraneous: node-forge@1.3.1 /opt/iobroker/node_modules/node-forge
npm ERR! extraneous: node-gyp-build@4.5.0 /opt/iobroker/node_modules/node-gyp-build
npm ERR! extraneous: node-ical@ /opt/iobroker/node_modules/node-ical
npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
npm ERR! extraneous: node-schedule@2.1.0 /opt/iobroker/node_modules/node-schedule
npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
npm ERR! extraneous: node.extend@2.0.2 /opt/iobroker/node_modules/node.extend
npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/npm-run-path
npm ERR! extraneous: npm@6.14.18 /opt/iobroker/node_modules/npm
npm ERR! extraneous: oauth-sign@0.9.0 /opt/iobroker/node_modules/oauth-sign
npm ERR! extraneous: object-hash@2.2.0 /opt/iobroker/node_modules/object-hash
npm ERR! extraneous: object-inspect@1.11.0 /opt/iobroker/node_modules/object-inspect
npm ERR! extraneous: object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
npm ERR! extraneous: object.assign@4.1.4 /opt/iobroker/node_modules/object.assign
npm ERR! extraneous: ohash@ /opt/iobroker/node_modules/ohash
npm ERR! extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
npm ERR! extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/onetime
npm ERR! extraneous: opencollective-postinstall@2.0.2 /opt/iobroker/node_modules/opencollective-postinstall
npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
npm ERR! extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
npm ERR! extraneous: pako@1.0.11 /opt/iobroker/node_modules/pako
npm ERR! extraneous: parseqs@ /opt/iobroker/node_modules/parseqs
npm ERR! extraneous: parseuri@ /opt/iobroker/node_modules/parseuri
npm ERR! extraneous: parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
npm ERR! extraneous: passport@ /opt/iobroker/node_modules/passport
npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/path-key
npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
npm ERR! extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
npm ERR! extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause
npm ERR! extraneous: performance-now@2.1.0 /opt/iobroker/node_modules/performance-now
npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
npm ERR! extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
npm ERR! extraneous: pidusage@ /opt/iobroker/node_modules/pidusage
npm ERR! extraneous: platform@1.3.6 /opt/iobroker/node_modules/platform
npm ERR! extraneous: prebuild-install@ /opt/iobroker/node_modules/prebuild-install
npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
npm ERR! extraneous: promisify-child-process@4.1.1 /opt/iobroker/node_modules/promisify-child-process
npm ERR! extraneous: prompt@ /opt/iobroker/node_modules/prompt
npm ERR! extraneous: proxy-addr@ /opt/iobroker/node_modules/proxy-addr
npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
npm ERR! extraneous: psl@1.4.0 /opt/iobroker/node_modules/psl
npm ERR! extraneous: pump@2.0.1 /opt/iobroker/node_modules/pump
npm ERR! extraneous: punycode@2.1.1 /opt/iobroker/node_modules/punycode
npm ERR! extraneous: qs@6.11.0 /opt/iobroker/node_modules/qs
npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
npm ERR! extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
npm ERR! extraneous: rasha@1.2.5 /opt/iobroker/node_modules/rasha
npm ERR! extraneous: raw-body@2.5.1 /opt/iobroker/node_modules/raw-body
npm ERR! extraneous: read@1.0.7 /opt/iobroker/node_modules/read
npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/readable-stream
npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
npm ERR! extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
npm ERR! extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
npm ERR! extraneous: redirect-https@1.3.1 /opt/iobroker/node_modules/redirect-https
npm ERR! extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
npm ERR! extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
npm ERR! extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
npm ERR! extraneous: regexp.prototype.flags@1.4.3 /opt/iobroker/node_modules/regexp.prototype.flags
npm ERR! extraneous: request-promise-core@1.1.4 /opt/iobroker/node_modules/request-promise-core
npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
npm ERR! extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
npm ERR! extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
npm ERR! extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
npm ERR! extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
npm ERR! extraneous: rfdc@ /opt/iobroker/node_modules/rfdc
npm ERR! extraneous: rrule@ /opt/iobroker/node_modules/rrule
npm ERR! extraneous: rsa-compat@ /opt/iobroker/node_modules/rsa-compat
npm ERR! extraneous: safe-regex-test@1.0.0 /opt/iobroker/node_modules/safe-regex-test
npm ERR! extraneous: safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
npm ERR! extraneous: safe-stable-stringify@2.3.1 /opt/iobroker/node_modules/safe-stable-stringify
npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
npm ERR! extraneous: send@ /opt/iobroker/node_modules/send
npm ERR! extraneous: seq-logging@1.1.1 /opt/iobroker/node_modules/seq-logging
npm ERR! extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
npm ERR! extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/shebang-command
npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/shebang-regex
npm ERR! extraneous: side-channel@1.0.4 /opt/iobroker/node_modules/side-channel
npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/signal-exit
npm ERR! extraneous: simple-get@ /opt/iobroker/node_modules/simple-get
npm ERR! extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/socket.io-client
npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/socket.io-parser
npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/socket.io
npm ERR! extraneous: sorted-array-functions@1.3.0 /opt/iobroker/node_modules/sorted-array-functions
npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/source-map-support
npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/source-map
npm ERR! extraneous: split@1.0.1 /opt/iobroker/node_modules/split
npm ERR! extraneous: sshpk@1.16.1 /opt/iobroker/node_modules/sshpk
npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
npm ERR! extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
npm ERR! extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
npm ERR! extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/stream-shift
npm ERR! extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/string_decoder
npm ERR! extraneous: string.prototype.trimend@1.0.6 /opt/iobroker/node_modules/string.prototype.trimend
npm ERR! extraneous: string.prototype.trimstart@1.0.6 /opt/iobroker/node_modules/string.prototype.trimstart
npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/strip-final-newline
npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/supports-preserve-symlinks-flag
npm ERR! extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
npm ERR! extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/through
npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
npm ERR! extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
npm ERR! extraneous: tough-cookie@2.4.3 /opt/iobroker/node_modules/tough-cookie
npm ERR! extraneous: tr46@0.0.3 /opt/iobroker/node_modules/tr46
npm ERR! extraneous: triple-beam@1.3.0 /opt/iobroker/node_modules/triple-beam
npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/tslib
npm ERR! extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
npm ERR! extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
npm ERR! extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
npm ERR! extraneous: unix-dgram@2.0.4 /opt/iobroker/node_modules/unix-dgram
npm ERR! extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
npm ERR! extraneous: uri-js@4.2.2 /opt/iobroker/node_modules/uri-js
npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
npm ERR! extraneous: ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/util-deprecate
npm ERR! extraneous: utils-merge@1.0.1 /opt/iobroker/node_modules/utils-merge
npm ERR! extraneous: uuid@3.3.3 /opt/iobroker/node_modules/uuid
npm ERR! extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
npm ERR! extraneous: verror@ /opt/iobroker/node_modules/verror
npm ERR! extraneous: virtual-tsc@ /opt/iobroker/node_modules/virtual-tsc
npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
npm ERR! extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
npm ERR! extraneous: webdav@4.11.2 /opt/iobroker/node_modules/webdav
npm ERR! extraneous: webidl-conversions@3.0.1 /opt/iobroker/node_modules/webidl-conversions
npm ERR! extraneous: whatwg-url@5.0.0 /opt/iobroker/node_modules/whatwg-url
npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/which
npm ERR! extraneous: winston-daily-rotate-file@ /opt/iobroker/node_modules/winston-daily-rotate-file
npm ERR! extraneous: winston-seq-updated@ /opt/iobroker/node_modules/winston-seq-updated
npm ERR! extraneous: winston-syslog@2.6.0 /opt/iobroker/node_modules/winston-syslog
npm ERR! extraneous: winston-transport@ /opt/iobroker/node_modules/winston-transport
npm ERR! extraneous: winston@ /opt/iobroker/node_modules/winston
npm ERR! extraneous: ws@7.4.6 /opt/iobroker/node_modules/ws
npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/xmlhttprequest-ssl
npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
npm ERR!     /home/pi/.npm/_logs/2022-12-27T14_37_18_594Z-debug-0.log
Adapters from github:   1
  throw err;
  requireStack: []
ioBroker-Repositories
  throw err;
  requireStack: []
ioBroker-Instances
  throw err;
  requireStack: []
Objects and States
Objects:        0
States:         0
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:3 https://repos.influxdata.com/debian bullseye InRelease
Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
Reading package lists...
Pending Updates: 0
*** Listening Ports ***
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11662      500/sshd: /usr/sbin
tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13152      609/influxd
tcp6       0      0 :::22                   :::*                    LISTEN      0          11664      500/sshd: /usr/sbin
tcp6       0      0 :::3000                 :::*                    LISTEN      109        13171      604/grafana-server
tcp6       0      0 :::8086                 :::*                    LISTEN      999        11928      609/influxd
udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          11780      -
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13422      339/avahi-daemon: r
udp        0      0 0.0.0.0:55140           0.0.0.0:*                           108        13424      339/avahi-daemon: r
udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13505      603/dhcpcd
udp6       0      0 :::51820                :::*                                0          11781      -
udp6       0      0 :::5353                 :::*                                108        13423      339/avahi-daemon: r
udp6       0      0 :::50523                :::*                                108        13425      339/avahi-daemon: r
</code></pre>
<p dir="auto">============ Mark until here for C&amp;P =============</p>
<p dir="auto">iob diag has finished.</p>
<p dir="auto">Press any key for a summary</p>
<pre><code></code></pre>
]]></description><link>https://forum.iobroker.net/topic/61417/iobroker-startet-nach-bullseye-update-nicht-mehr</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 09:09:06 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/61417.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Dec 2022 14:39:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ioBroker startet nach Bullseye update nicht mehr on Tue, 27 Dec 2022 18:15:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uncleb" aria-label="Profile: uncleb">@<bdi>uncleb</bdi></a></p>
<p dir="auto">Du musst dich auch zuerst in das richtige Verzeichnis stellen. Und bitte immer komplette Ein- und Ausgaben posten, dann sieht man sowas auch viel schneller.</p>
<p dir="auto">Die Zeile davor ist nicht aus dekorativen Gründen da.</p>
]]></description><link>https://forum.iobroker.net/post/917137</link><guid isPermaLink="true">https://forum.iobroker.net/post/917137</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 27 Dec 2022 18:15:26 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker startet nach Bullseye update nicht mehr on Tue, 27 Dec 2022 17:57:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/917015">ioBroker startet nach Bullseye update nicht mehr</a>:</p>
<blockquote>
<p dir="auto">sudo -H -u iobroker npm install iobroker.js-controller</p>
</blockquote>
<p dir="auto">Klappt leider auch nicht :/</p>
<pre><code>npm notice
npm notice New major version of npm available! 8.19.3 -&gt; 9.2.0
npm notice Changelog: https://github.com/npm/cli/releases/tag/v9.2.0
npm notice Run npm install -g npm@9.2.0 to update!
npm notice
npm ERR! code EACCES
npm ERR! syscall mkdir
npm ERR! path /home/pi/node_modules
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, mkdir '/home/pi/node_modules'
npm ERR!  [Error: EACCES: permission denied, mkdir '/home/pi/node_modules'] {
npm ERR!   errno: -13,
npm ERR!   code: 'EACCES',
npm ERR!   syscall: 'mkdir',
npm ERR!   path: '/home/pi/node_modules'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the        current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check t        he
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR!     /home/iobroker/.npm/_logs/2022-12-27T17_54_19_377Z-debug-0.log
</code></pre>
]]></description><link>https://forum.iobroker.net/post/917129</link><guid isPermaLink="true">https://forum.iobroker.net/post/917129</guid><dc:creator><![CDATA[UncleB]]></dc:creator><pubDate>Tue, 27 Dec 2022 17:57:09 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker startet nach Bullseye update nicht mehr on Tue, 27 Dec 2022 14:48:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uncleb" aria-label="Profile: uncleb">@<bdi>uncleb</bdi></a> sagte in <a href="/post/917012">ioBroker startet nach Bullseye update nicht mehr</a>:</p>
<pre><code>curl -sL https://iobroker.net/fix.sh | bash -
</code></pre>
<p dir="auto">danach</p>
<pre><code>cd /opt/iobroker
</code></pre>
]]></description><link>https://forum.iobroker.net/post/917015</link><guid isPermaLink="true">https://forum.iobroker.net/post/917015</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 27 Dec 2022 14:48:12 GMT</pubDate></item></channel></rss>
