<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[iobroker error]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
der ioBroker am Raspi4 läuft nicht sauber durch<br />
läuft und läuft und dann plötzlich das:</p>
<pre><code>2022-11-01 18:00:28.128 - info: fuelpricemonitor.0 (103508) Started with JSON-Explorer version 0.1.9
2022-11-01 18:00:37.687 - info: fuelpricemonitor.0 (103508) Terminated (NO_ERROR): Without reason
2022-11-01 18:00:38.227 - info: fuelpricemonitor.0 (103508) cleaned everything up...
2022-11-01 18:00:38.386 - info: host.raspberrypi instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
2022-11-01 18:15:00.080 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 103641
2022-11-01 18:15:04.126 - info: daswetter.0 (103641) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.17.1, js-controller: 4.0.23
2022-11-01 18:15:04.202 - info: daswetter.0 (103641) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
2022-11-01 18:15:04.745 - info: daswetter.0 (103641) cleaned everything up...
2022-11-01 18:15:04.773 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2022-11-01 18:20:25.084 - info: host.raspberrypi instance system.adapter.fuelpricemonitor.0 started with pid 103708
2022-11-01 18:20:29.288 - info: fuelpricemonitor.0 (103708) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.17.1, js-controller: 4.0.23
2022-11-01 18:20:29.361 - info: fuelpricemonitor.0 (103708) Started with JSON-Explorer version 0.1.9
2022-11-01 18:20:42.984 - error: fuelpricemonitor.0 (103708) States database error: read ECONNRESET
2022-11-01 18:20:42.986 - error: kecontact.0 (97533) States database error: read ECONNRESET
2022-11-01 18:20:42.977 - error: fritzdect.0 (97517) States database error: write ECONNRESET
2022-11-01 18:20:42.942 - info: hs100.0 (97544) cleaned everything up...
2022-11-01 18:20:42.996 - error: shelly.0 (97225) States database error: read ECONNRESET
2022-11-01 18:20:42.961 - error: life360.0 (97597) Objects database error: read ECONNRESET
2022-11-01 18:20:42.956 - info: time-switch.0 (97571) cleaning everything up...
2022-11-01 18:20:42.968 - info: vis-inventwo.0 (97435) cleaned everything up...
2022-11-01 18:20:42.997 - info: fuelpricemonitor.0 (103708) cleaned everything up...
2022-11-01 18:20:43.022 - info: life360.0 (97597) Disabled polling.
2022-11-01 18:20:43.024 - info: life360.0 (97597) cleaned everything up...
2022-11-01 18:20:42.967 - info: zigbee.0 (97082) cleaned everything up...
2022-11-01 18:20:43.133 - info: cloud.0 (97361) Connection changed: disconnect
2022-11-01 18:20:43.234 - info: fritzdect.0 (97517) cleaned everything up...
2022-11-01 18:20:43.327 - info: iot.0 (97339) Connection changed: disconnect
2022-11-01 18:20:43.341 - info: iot.0 (97339) Connection lost
2022-11-01 18:20:43.137 - error: modbus.1 (97134) States database error: read ECONNRESET
2022-11-01 18:20:43.128 - error: modbus.0 (97104) Objects database error: read ECONNRESET
2022-11-01 18:20:43.191 - info: zigbee.0 (97082) Zigbee: disabling joining new devices.
2022-11-01 18:20:43.373 - error: backitup.0 (97251) States database error: write EPIPE
2022-11-01 18:20:43.389 - info: backitup.0 (97251) cleaned everything up...
2022-11-01 18:20:43.378 - error: mqtt.0 (97164) States database error: write EPIPE
2022-11-01 18:20:44.400 - error: javascript.0 (97034) States database error: write EPIPE
2022-11-01 18:20:44.433 - info: javascript.0 (97034) Stop script script.js.common.AMIS_Fronius
2022-11-01 18:20:44.444 - info: renault.0 (97501) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.437 - info: fronius.0 (97390) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.440 - info: echarts.0 (97551) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.463 - info: go-e.0 (97471) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.477 - info: iot.0 (97339) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.502 - info: kecontact.0 (97533) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.502 - info: fuelpricemonitor.0 (103708) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.519 - info: vis-inventwo.0 (97435) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.521 - info: hs100.0 (97544) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.524 - info: time-switch.0 (97571) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.529 - info: shelly.0 (97225) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.529 - info: life360.0 (97597) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.616 - info: zigbee.0 (97082) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.435 - info: javascript.0 (97034) Stop script script.js.common.AMIS_Home
2022-11-01 18:20:44.436 - info: javascript.0 (97034) Stop script script.js.common.C35
2022-11-01 18:20:44.481 - info: javascript.0 (97034) Stop script script.js.common.SE_Power
2022-11-01 18:20:44.482 - info: javascript.0 (97034) Stop script script.js.common.ZOE_Ladung_Ziel
2022-11-01 18:20:44.484 - info: javascript.0 (97034) Stop script script.js.common.ZOE_MIN_Ladung
2022-11-01 18:20:44.485 - info: javascript.0 (97034) Stop script script.js.common.go-E_Error
2022-11-01 18:20:44.486 - info: javascript.0 (97034) Stop script script.js.common.go-E_Limits
2022-11-01 18:20:44.486 - info: javascript.0 (97034) Stop script script.js.common.go-E_Verriegelung
2022-11-01 18:20:44.487 - info: javascript.0 (97034) Stop script script.js.common.ZOE_GridOffset
2022-11-01 18:20:44.488 - info: javascript.0 (97034) Stop script script.js.common.ZOE_MinMax
2022-11-01 18:20:44.489 - info: javascript.0 (97034) Stop script script.js.common.go-E_Control
2022-11-01 18:20:44.489 - info: javascript.0 (97034) Stop script script.js.common.go-E_GridOffset
2022-11-01 18:20:44.490 - info: javascript.0 (97034) Stop script script.js.common.Pool_Steuerung
2022-11-01 18:20:44.491 - info: javascript.0 (97034) Stop script script.js.common.ZOE_Init
2022-11-01 18:20:44.492 - info: javascript.0 (97034) Stop script script.js.common.ZOE_Phasen
2022-11-01 18:20:44.492 - info: javascript.0 (97034) Stop script script.js.common.go-E_Init
2022-11-01 18:20:44.492 - info: javascript.0 (97034) Stop script script.js.common.go-E_Überschuss
2022-11-01 18:20:44.492 - info: javascript.0 (97034) Stop script script.js.common.go-E_Überwachung
2022-11-01 18:20:44.494 - info: javascript.0 (97034) Stop script script.js.common.Grid-PV
2022-11-01 18:20:44.517 - info: javascript.0 (97034) Stop script script.js.common.Grid-PVFronius
2022-11-01 18:20:44.518 - info: javascript.0 (97034) Stop script script.js.common.ZOE_Debug
2022-11-01 18:20:44.526 - info: javascript.0 (97034) Stop script script.js.common.go-E_Phasen
2022-11-01 18:20:44.527 - info: javascript.0 (97034) Stop script script.js.common.ZOE_Regelung
2022-11-01 18:20:44.528 - info: javascript.0 (97034) Stop script script.js.common.Pool
2022-11-01 18:20:44.528 - info: javascript.0 (97034) Stop script script.js.common.ZOE_Steuerung
2022-11-01 18:20:44.529 - info: javascript.0 (97034) Stop script script.js.common.go-E_Charger
2022-11-01 18:20:44.530 - info: javascript.0 (97034) Stop script script.js.common.Garage
2022-11-01 18:20:44.532 - info: javascript.0 (97034) Stop script script.js.common.Adapter
2022-11-01 18:20:44.647 - info: cloud.0 (97361) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.739 - info: fritzdect.0 (97517) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:44.894 - info: backitup.0 (97251) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:45.237 - info: s7.0 (97195) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:45.937 - info: javascript.0 (97034) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:20:47.963 - error: echarts.0 (97551) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:47.966 - error: web.0 (97269) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:47.976 - error: fronius.0 (97390) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:47.986 - warn: fronius.0 (97390) get state error: Connection is closed.
2022-11-01 18:20:47.991 - error: go-e.0 (97471) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:47.972 - error: ws.0 (97578) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.003 - error: ws.0 (97578) States database error: connect ECONNREFUSED 127.0.0.1:9000
2022-11-01 18:20:48.019 - error: fuelpricemonitor.0 (103708) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.021 - error: kecontact.0 (97533) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.039 - error: hs100.0 (97544) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.058 - error: life360.0 (97597) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.060 - error: renault.0 (97501) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.059 - error: vis-inventwo.0 (97435) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.067 - error: shelly.0 (97225) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.065 - error: time-switch.0 (97571) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.149 - warn: renault.0 (97501) get state error: Connection is closed.
2022-11-01 18:20:48.161 - warn: renault.0 (97501) get state error: DB closed
2022-11-01 18:20:48.206 - error: cloud.0 (97361) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.188 - error: admin.0 (96966) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.088 - warn: shelly.0 (97225) get state error: Connection is closed.
2022-11-01 18:20:48.092 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.095 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.096 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.097 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.098 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.102 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.126 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.127 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.183 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.184 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.185 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.186 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.223 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.224 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.225 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.226 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.227 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.247 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.248 - warn: shelly.0 (97225) get state error: DB closed
2022-11-01 18:20:48.269 - error: fritzdect.0 (97517) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.289 - error: iot.0 (97339) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.314 - error: telegram.0 (97052) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.414 - error: zigbee.0 (97082) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.427 - error: backitup.0 (97251) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.472 - error: modbus.0 (97104) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.596 - error: modbus.1 (97134) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:48.956 - error: s7.0 (97195) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:49.570 - warn: javascript.0 (97034) get state error: Connection is closed.
2022-11-01 18:20:49.571 - warn: javascript.0 (97034) get state error: DB closed
2022-11-01 18:20:49.572 - warn: javascript.0 (97034) get state error: DB closed
2022-11-01 18:20:49.573 - warn: javascript.0 (97034) get state error: DB closed
2022-11-01 18:20:49.574 - warn: javascript.0 (97034) get state error: DB closed
2022-11-01 18:20:49.579 - warn: javascript.0 (97034) get state error: DB closed
2022-11-01 18:20:49.619 - error: javascript.0 (97034) script.js.common.Grid-PV: setForeignState: Error: DB closed
2022-11-01 18:20:49.619 - error: javascript.0 (97034) script.js.common.Grid-PVFronius: setForeignState: Error: DB closed
2022-11-01 18:20:49.620 - error: javascript.0 (97034) script.js.common.go-E_Phasen: setForeignState: Error: DB closed
2022-11-01 18:20:49.621 - error: javascript.0 (97034) script.js.common.go-E_Phasen: setForeignState: Error: DB closed
2022-11-01 18:20:49.621 - error: javascript.0 (97034) script.js.common.ZOE_Regelung: setForeignState: Error: DB closed
2022-11-01 18:20:49.621 - error: javascript.0 (97034) script.js.common.go-E_Charger: setForeignState: Error: DB closed
2022-11-01 18:20:52.997 - error: ws.0 (97578) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:53.086 - error: shelly.0 (97225) Cannot find view "system" for search "device" : Connection is closed.
2022-11-01 18:20:56.797 - error: history.0 (96993) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:20:56.810 - error: history.0 (96993) States database error: connect ECONNREFUSED 127.0.0.1:9000
2022-11-01 18:21:01.819 - error: history.0 (96993) States database error: connect ECONNREFUSED 127.0.0.1:9000
2022-11-01 18:21:01.826 - error: history.0 (96993) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-11-01 18:21:02.746 - info: history.0 (96993) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-11-01 18:21:06.840 - warn: history.0 (96993) get state error: Connection is closed.
2022-11-01 18:21:06.841 - warn: history.0 (96993) get state error: DB closed
2022-11-01 18:21:12.603 - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
2022-11-01 18:21:12.610 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
2022-11-01 18:21:12.611 - info: host.raspberrypi hostname: raspberrypi, node: v16.17.1
2022-11-01 18:21:12.612 - info: host.raspberrypi ip addresses: 192.168.0.92 fe80::8511:91de:53a6:d2db 192.168.0.93 fe80::4e06:c2e7:21eb:13ec
2022-11-01 18:21:14.850 - info: host.raspberrypi connected to Objects and States
2022-11-01 18:21:14.907 - info: host.raspberrypi added notifications configuration of host
2022-11-01 18:21:15.817 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
2022-11-01 18:21:15.819 - info: host.raspberrypi 35 instances found
2022-11-01 18:21:15.894 - info: host.raspberrypi starting 30 instances
2022-11-01 18:21:16.018 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
2022-11-01 18:21:16.091 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 103747
2022-11-01 18:21:16.106 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
2022-11-01 18:21:16.164 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
2022-11-01 18:21:16.223 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
2022-11-01 18:21:16.281 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
2022-11-01 18:21:16.340 - info: host.raspberrypi Some obsolete host states deleted.
2022-11-01 18:21:18.102 - error: admin.0 (103747) admin.0 already running
2022-11-01 18:21:18.697 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:18.698 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
2022-11-01 18:21:19.965 - info: host.raspberrypi instance system.adapter.history.0 started with pid 103758
2022-11-01 18:21:21.429 - error: history.0 (103758) history.0 already running
2022-11-01 18:21:21.434 - warn: history.0 (103758) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-11-01 18:21:22.010 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:22.012 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
2022-11-01 18:21:23.972 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 103769
2022-11-01 18:21:27.285 - error: javascript.0 (103769) javascript.0 already running
2022-11-01 18:21:27.290 - warn: javascript.0 (103769) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-11-01 18:21:27.885 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:27.886 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
2022-11-01 18:21:27.977 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 103780
2022-11-01 18:21:30.417 - error: telegram.0 (103780) telegram.0 already running
2022-11-01 18:21:31.011 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:31.012 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
2022-11-01 18:21:32.031 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 103791
2022-11-01 18:21:35.989 - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 103802
2022-11-01 18:21:35.992 - error: zigbee.0 (103791) zigbee.0 already running
2022-11-01 18:21:35.998 - warn: zigbee.0 (103791) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-11-01 18:21:36.600 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:36.601 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
2022-11-01 18:21:37.484 - error: modbus.0 (103802) modbus.0 already running
2022-11-01 18:21:38.063 - error: host.raspberrypi instance system.adapter.modbus.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:38.063 - info: host.raspberrypi Restart adapter system.adapter.modbus.0 because enabled
2022-11-01 18:21:39.972 - info: host.raspberrypi instance system.adapter.modbus.1 started with pid 103813
2022-11-01 18:21:41.441 - error: modbus.1 (103813) modbus.1 already running
2022-11-01 18:21:42.031 - error: host.raspberrypi instance system.adapter.modbus.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:42.032 - info: host.raspberrypi Restart adapter system.adapter.modbus.1 because enabled
2022-11-01 18:21:44.013 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 103824
2022-11-01 18:21:45.433 - error: mqtt.0 (103824) mqtt.0 already running
2022-11-01 18:21:46.014 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:46.015 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
2022-11-01 18:21:47.977 - info: host.raspberrypi instance system.adapter.s7.0 started with pid 103835
2022-11-01 18:21:48.769 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 103842
2022-11-01 18:21:49.666 - error: s7.0 (103835) s7.0 already running
2022-11-01 18:21:49.672 - warn: s7.0 (103835) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-11-01 18:21:50.256 - error: host.raspberrypi instance system.adapter.s7.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:50.257 - info: host.raspberrypi Restart adapter system.adapter.s7.0 because enabled
2022-11-01 18:21:52.322 - info: host.raspberrypi instance system.adapter.history.0 started with pid 103869
2022-11-01 18:21:52.358 - info: host.raspberrypi instance system.adapter.shelly.0 started with pid 103875
2022-11-01 18:21:54.326 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
2022-11-01 18:21:55.575 - info: history.0 (103869) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.history, node: v16.17.1, js-controller: 4.0.23
2022-11-01 18:21:55.588 - error: shelly.0 (103875) shelly.0 already running
2022-11-01 18:21:55.596 - warn: shelly.0 (103875) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-11-01 18:21:56.418 - info: history.0 (103869) enabled logging of fronius.0.inverter.1.PAC (Count=1), Alias=false
2022-11-01 18:21:56.421 - info: history.0 (103869) enabled logging of go-e.0.amperePV (Count=2), Alias=false
2022-11-01 18:21:56.423 - info: history.0 (103869) enabled logging of go-e.0.allow_charging (Count=3), Alias=false
2022-11-01 18:21:56.424 - info: history.0 (103869) enabled logging of fuelpricemonitor.0.0_Home_Diesel.0.prices.0.amount (Count=4), Alias=false
2022-11-01 18:21:56.425 - info: history.0 (103869) enabled logging of fuelpricemonitor.0.zuHome_Diesel.0.prices.0.amount (Count=5), Alias=false
2022-11-01 18:21:56.426 - info: history.0 (103869) enabled logging of kecontact.0.state (Count=6), Alias=false
2022-11-01 18:21:56.427 - info: history.0 (103869) enabled logging of kecontact.0.plug (Count=7), Alias=false
2022-11-01 18:21:56.428 - info: history.0 (103869) enabled logging of kecontact.0.enableUser (Count=8), Alias=false
2022-11-01 18:21:56.430 - info: history.0 (103869) enabled logging of kecontact.0.currentUser (Count=9), Alias=false
2022-11-01 18:21:56.431 - info: history.0 (103869) enabled logging of kecontact.0.output (Count=10), Alias=false
2022-11-01 18:21:56.434 - info: history.0 (103869) enabled logging of kecontact.0.u1 (Count=11), Alias=false
2022-11-01 18:21:56.436 - info: history.0 (103869) enabled logging of kecontact.0.u2 (Count=12), Alias=false
2022-11-01 18:21:56.438 - info: history.0 (103869) enabled logging of kecontact.0.u3 (Count=13), Alias=false
2022-11-01 18:21:56.440 - info: history.0 (103869) enabled logging of kecontact.0.i1 (Count=14), Alias=false
2022-11-01 18:21:56.442 - info: history.0 (103869) enabled logging of kecontact.0.i2 (Count=15), Alias=false
2022-11-01 18:21:56.444 - info: history.0 (103869) enabled logging of kecontact.0.i3 (Count=16), Alias=false
2022-11-01 18:21:56.450 - info: history.0 (103869) enabled logging of kecontact.0.p (Count=17), Alias=false
2022-11-01 18:21:56.453 - info: history.0 (103869) enabled logging of kecontact.0.start (Count=18), Alias=false
2022-11-01 18:21:56.455 - info: history.0 (103869) enabled logging of hs100.0.192_168_0_176.state (Count=19), Alias=false
2022-11-01 18:21:56.456 - info: history.0 (103869) enabled logging of alias.0.Humidity (Count=20), Alias=false
2022-11-01 18:21:56.457 - info: history.0 (103869) enabled logging of alias.0.Humidity_2 (Count=21), Alias=false
2022-11-01 18:21:56.458 - info: history.0 (103869) enabled logging of alias.0.KebaP30c.p (Count=22), Alias=false
2022-11-01 18:21:56.459 - info: history.0 (103869) enabled logging of alias.0.go-E.power (Count=23), Alias=false
2022-11-01 18:21:56.459 - info: history.0 (103869) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell (Count=24), Alias=false
2022-11-01 18:21:56.460 - info: history.0 (103869) enabled logging of javascript.0.Wolken-PV_Caddy.Wolkenzaehler_PVCaddy (Count=25), Alias=false
2022-11-01 18:21:56.461 - info: history.0 (103869) enabled logging of javascript.0.Wolken-PV_Home.Wolkenzaehler_Home (Count=26), Alias=false
2022-11-01 18:21:56.461 - info: history.0 (103869) enabled logging of 0_userdata.0.Zoe.ZoeGridOffset (Count=27), Alias=false
2022-11-01 18:21:56.462 - info: history.0 (103869) enabled logging of 0_userdata.0.Zoe.ZoeStateLadung (Count=28), Alias=false
2022-11-01 18:21:56.462 - info: history.0 (103869) enabled logging of javascript.0.Zoe.1P (Count=29), Alias=false
2022-11-01 18:21:56.463 - info: history.0 (103869) enabled logging of javascript.0.Zoe.3P (Count=30), Alias=false
2022-11-01 18:21:56.463 - info: history.0 (103869) enabled logging of javascript.0.Zoe.Regelzeit (Count=31), Alias=false
2022-11-01 18:21:56.464 - info: history.0 (103869) enabled logging of javascript.0.Zoe.MaxStromMitPool (Count=32), Alias=false
2022-11-01 18:21:56.464 - info: history.0 (103869) enabled logging of 0_userdata.0.go-e.LADUNG (Count=33), Alias=false
2022-11-01 18:21:56.465 - info: history.0 (103869) enabled logging of 0_userdata.0.go-e.1P (Count=34), Alias=false
2022-11-01 18:21:56.466 - info: history.0 (103869) enabled logging of 0_userdata.0.go-e.3P (Count=35), Alias=false
2022-11-01 18:21:56.466 - info: history.0 (103869) enabled logging of javascript.0.go-e.0.psm (Count=36), Alias=false
2022-11-01 18:21:56.467 - info: history.0 (103869) enabled logging of 0_userdata.0.go-e-phases.Phasenumschaltung (Count=37), Alias=false
2022-11-01 18:21:56.468 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.170 (Count=38), Alias=false
2022-11-01 18:21:56.469 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.180 (Count=39), Alias=false
2022-11-01 18:21:56.469 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.270 (Count=40), Alias=false
2022-11-01 18:21:56.470 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.280 (Count=41), Alias=false
2022-11-01 18:21:56.470 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.PVPower (Count=42), Alias=false
2022-11-01 18:21:56.471 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.Power (Count=43), Alias=false
2022-11-01 18:21:56.472 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.PVÜberschuss (Count=44), Alias=false
2022-11-01 18:21:56.472 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.Grid_Überwachung (Count=45), Alias=false
2022-11-01 18:21:56.473 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.Verbrauch (Count=46), Alias=false
2022-11-01 18:21:56.474 - info: history.0 (103869) enabled logging of 0_userdata.0.AMIS.Grid_Wolkenzähler (Count=47), Alias=false
2022-11-01 18:21:56.475 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.170 (Count=48), Alias=false
2022-11-01 18:21:56.475 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.180 (Count=49), Alias=false
2022-11-01 18:21:56.476 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.270 (Count=50), Alias=false
2022-11-01 18:21:56.477 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.280 (Count=51), Alias=false
2022-11-01 18:21:56.477 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.PowerFronius (Count=52), Alias=false
2022-11-01 18:21:56.478 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.PVPowerFronius (Count=53), Alias=false
2022-11-01 18:21:56.479 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.PVÜberschussFronius (Count=54), Alias=false
2022-11-01 18:21:56.480 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.Grid_Caddy_Überwachung (Count=55), Alias=false
2022-11-01 18:21:56.480 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.Verbrauch (Count=56), Alias=false
2022-11-01 18:21:56.481 - info: history.0 (103869) enabled logging of 0_userdata.0.AMISFronius.Grid_Caddy_Wolkenzähler (Count=57), Alias=false
2022-11-01 18:21:56.481 - info: history.0 (103869) enabled logging of 0_userdata.0.Bewässerung.BewässerungAktiv (Count=58), Alias=false
2022-11-01 18:21:56.482 - info: history.0 (103869) enabled logging of 0_userdata.0.Bewässerung.Intervall (Count=59), Alias=false
2022-11-01 18:21:56.482 - info: history.0 (103869) enabled logging of 0_userdata.0.Bewässerung.Grunddauer (Count=60), Alias=false
2022-11-01 18:21:56.483 - info: history.0 (103869) enabled logging of 0_userdata.0.Bewässerung.Dauer (Count=61), Alias=false
2022-11-01 18:21:56.484 - info: history.0 (103869) enabled logging of 0_userdata.0.Bewässerung.Timer (Count=62), Alias=false
2022-11-01 18:21:56.484 - info: history.0 (103869) enabled logging of javascript.0.Pool.VL (Count=63), Alias=false
2022-11-01 18:21:56.485 - info: history.0 (103869) enabled logging of javascript.0.Pool.RL (Count=64), Alias=false
2022-11-01 18:21:56.485 - info: history.0 (103869) enabled logging of s7.0.Inputs.0.I1 (Count=65), Alias=false
2022-11-01 18:21:56.486 - info: history.0 (103869) enabled logging of s7.0.Outputs.0.Q1 (Count=66), Alias=false
2022-11-01 18:21:56.486 - info: history.0 (103869) enabled logging of s7.0.Outputs.0.Q2 (Count=67), Alias=false
2022-11-01 18:21:56.487 - info: history.0 (103869) enabled logging of s7.0.Outputs.0.Q3 (Count=68), Alias=false
2022-11-01 18:21:56.487 - info: history.0 (103869) enabled logging of s7.0.Outputs.0.Q4 (Count=69), Alias=false
2022-11-01 18:21:56.488 - info: history.0 (103869) enabled logging of s7.0.DBs.DB1.VW2 (Count=70), Alias=false
2022-11-01 18:21:56.488 - info: history.0 (103869) enabled logging of s7.0.DBs.DB1.VW4 (Count=71), Alias=false
2022-11-01 18:21:56.489 - info: history.0 (103869) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuellSMA (Count=72), Alias=false
2022-11-01 18:21:56.489 - info: history.0 (103869) enabled logging of shelly.0.SHSW-25#483FDA8241A8#1.Relay0.Switch (Count=73), Alias=false
2022-11-01 18:21:56.489 - info: history.0 (103869) enabled logging of shelly.0.SHSW-25#483FDA8241A8#1.Relay0.Power (Count=74), Alias=false
2022-11-01 18:21:56.490 - info: history.0 (103869) enabled logging of shelly.0.SHSW-25#483FDA8241A8#1.Relay1.Switch (Count=75), Alias=false
2022-11-01 18:21:56.490 - info: history.0 (103869) enabled logging of shelly.0.SHSW-25#483FDA8241A8#1.Relay1.Power (Count=76), Alias=false
2022-11-01 18:21:56.491 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch (Count=77), Alias=false
2022-11-01 18:21:56.491 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power (Count=78), Alias=false
2022-11-01 18:21:56.493 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Energy (Count=79), Alias=false
2022-11-01 18:21:56.494 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#BC6DEB#1.Relay0.Switch (Count=80), Alias=false
2022-11-01 18:21:56.495 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#BC6DEB#1.Relay0.Power (Count=81), Alias=false
2022-11-01 18:21:56.496 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#BC6DEB#1.Relay0.Energy (Count=82), Alias=false
2022-11-01 18:21:56.496 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#DCCD03#1.Relay0.Switch (Count=83), Alias=false
2022-11-01 18:21:56.497 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#DCCD03#1.Relay0.Power (Count=84), Alias=false
2022-11-01 18:21:56.498 - info: history.0 (103869) enabled logging of shelly.0.SHPLG-S#DCCD03#1.Relay0.Energy (Count=85), Alias=false
2022-11-01 18:21:56.499 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_087610456373.state (Count=86), Alias=false
2022-11-01 18:21:56.499 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_116300118701.state (Count=87), Alias=false
2022-11-01 18:21:56.500 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_087610456373.power (Count=88), Alias=false
2022-11-01 18:21:56.501 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_087610456373.energy (Count=89), Alias=false
2022-11-01 18:21:56.501 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_116300118701.power (Count=90), Alias=false
2022-11-01 18:21:56.502 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_116300118701.energy (Count=91), Alias=false
2022-11-01 18:21:56.502 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_grp1B416E-3D27D6EE1.state (Count=92), Alias=false
2022-11-01 18:21:56.503 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_grp1B416E-3D27D6EE1.power (Count=93), Alias=false
2022-11-01 18:21:56.503 - info: history.0 (103869) enabled logging of fritzdect.0.DECT_grp1B416E-3D27D6EE1.energy (Count=94), Alias=false
2022-11-01 18:21:58.580 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 103899
2022-11-01 18:21:58.600 - error: host.raspberrypi instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:21:58.601 - info: host.raspberrypi Restart adapter system.adapter.shelly.0 because enabled
2022-11-01 18:21:58.755 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 103906
2022-11-01 18:22:00.148 - info: host.raspberrypi instance system.adapter.web.0 started with pid 103913
2022-11-01 18:22:01.355 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 103924
2022-11-01 18:22:01.536 - error: backitup.0 (103899) backitup.0 already running
2022-11-01 18:22:01.544 - warn: backitup.0 (103899) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-11-01 18:22:02.541 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:22:02.543 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
2022-11-01 18:22:03.588 - error: web.0 (103913) web.0 already running
2022-11-01 18:22:04.341 - error: host.raspberrypi instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2022-11-01 18:22:04.343 - info: host.raspberrypi Restart adapter system.adapter.web.0 because enabled
2022-11-01 18:22:04.521 - info: javascript.0 (103906) starting. Version 6.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.17.1, js-controller: 4.0.23
2022-11-01 18:22:05.995 - info: javascript.0 (103906) requesting all states
2022-11-01 18:22:05.997 - info: javascript.0 (103906) requesting all objects
2022-11-01 18:22:06.821 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 103960
2022-11-01 18:22:07.268 - info: javascript.0 (103906) received all objects
2022-11-01 18:22:07.272 - info: vis.0 (103941) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.17.1, js-controller: 4.0.23
2022-11-01 18:22:07.733 - info: javascript.0 (103906) received all states
2022-11-01 18:22:07.827 - info: vis.0 (103941) vis license is OK.
2022-11-01 18:22:08.056 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 103975
2022-11-01 18:22:08.139 - info: javascript.0 (103906) Start javascript script.js.common.AMIS_Fronius
2022-11-01 18:22:08.292 - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 103982
2022-11-01 18:22:08.329 - info: javascript.0 (103906) script.js.common.AMIS_Fronius: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.332 - info: javascript.0 (103906) Start javascript script.js.common.AMIS_Home
2022-11-01 18:22:08.351 - info: javascript.0 (103906) script.js.common.AMIS_Home: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.359 - info: javascript.0 (103906) Start javascript script.js.common.C35
2022-11-01 18:22:08.380 - info: javascript.0 (103906) script.js.common.C35: registered 0 subscriptions, 3 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.382 - info: javascript.0 (103906) Start javascript script.js.common.SE_Power
2022-11-01 18:22:08.391 - info: javascript.0 (103906) script.js.common.SE_Power: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.393 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_Ladung_Ziel
2022-11-01 18:22:08.471 - info: javascript.0 (103906) script.js.common.ZOE_Ladung_Ziel: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.472 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_MIN_Ladung
2022-11-01 18:22:08.487 - info: javascript.0 (103906) script.js.common.ZOE_MIN_Ladung: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.488 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Error
2022-11-01 18:22:08.495 - info: javascript.0 (103906) script.js.common.go-E_Error: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.496 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Limits
2022-11-01 18:22:08.506 - info: javascript.0 (103906) script.js.common.go-E_Limits: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.509 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Verriegelung
2022-11-01 18:22:08.516 - info: javascript.0 (103906) script.js.common.go-E_Verriegelung: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.551 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_GridOffset
2022-11-01 18:22:08.573 - info: javascript.0 (103906) script.js.common.ZOE_GridOffset: registered 5 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.576 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_MinMax
2022-11-01 18:22:08.595 - info: javascript.0 (103906) script.js.common.ZOE_MinMax: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.596 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Control
2022-11-01 18:22:08.610 - info: javascript.0 (103906) script.js.common.go-E_Control: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.612 - info: javascript.0 (103906) Start javascript script.js.common.go-E_GridOffset
2022-11-01 18:22:08.621 - info: javascript.0 (103906) script.js.common.go-E_GridOffset: registered 5 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.622 - info: javascript.0 (103906) Start javascript script.js.common.Pool_Steuerung
2022-11-01 18:22:08.635 - info: javascript.0 (103906) script.js.common.Pool_Steuerung: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.637 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_Init
2022-11-01 18:22:08.650 - info: javascript.0 (103906) script.js.common.ZOE_Init: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.651 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_Phasen
2022-11-01 18:22:08.659 - info: javascript.0 (103906) script.js.common.ZOE_Phasen: registered 5 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.661 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Init
2022-11-01 18:22:08.676 - info: javascript.0 (103906) script.js.common.go-E_Init: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.677 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Überschuss
2022-11-01 18:22:08.697 - info: javascript.0 (103906) script.js.common.go-E_Überschuss: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.698 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Überwachung
2022-11-01 18:22:08.707 - info: javascript.0 (103906) script.js.common.go-E_Überwachung: registered 5 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.709 - info: javascript.0 (103906) Start javascript script.js.common.Grid-PV
2022-11-01 18:22:08.723 - info: javascript.0 (103906) script.js.common.Grid-PV: registered 17 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.724 - info: javascript.0 (103906) Start javascript script.js.common.Grid-PVFronius
2022-11-01 18:22:08.738 - info: javascript.0 (103906) script.js.common.Grid-PVFronius: registered 16 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.741 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_Debug
2022-11-01 18:22:08.750 - info: javascript.0 (103906) script.js.common.ZOE_Debug: registered 28 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.750 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Phasen
2022-11-01 18:22:08.780 - info: javascript.0 (103906) script.js.common.go-E_Phasen: registered 1 subscription, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.781 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_Regelung
2022-11-01 18:22:08.791 - info: javascript.0 (103906) script.js.common.ZOE_Regelung: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.792 - info: javascript.0 (103906) Start javascript script.js.common.Pool
2022-11-01 18:22:08.805 - info: javascript.0 (103906) script.js.common.Pool: registered 6 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.805 - info: javascript.0 (103906) Start javascript script.js.common.ZOE_Steuerung
2022-11-01 18:22:08.817 - info: javascript.0 (103906) script.js.common.ZOE_Steuerung: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.818 - info: javascript.0 (103906) Start javascript script.js.common.go-E_Charger
2022-11-01 18:22:08.827 - info: javascript.0 (103906) script.js.common.go-E_Charger: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.828 - info: javascript.0 (103906) Start javascript script.js.common.Garage
2022-11-01 18:22:08.870 - info: javascript.0 (103906) script.js.common.Garage: registered 26 subscriptions, 4 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:08.871 - info: javascript.0 (103906) Start javascript script.js.common.Adapter
2022-11-01 18:22:08.891 - info: javascript.0 (103906) script.js.common.Adapter: registered 0 subscriptions, 4 schedules, 0 messages, 0 logs and 0 file subscriptions
2022-11-01 18:22:09.448 - info: javascript.0 (103906) script.js.common.go-E_GridOffset: go-E Wolkenzähler hat GridOffset angepasst auf: 4500
2022-11-01 18:22:10.044 - warn: javascript.0 (103906) script.js.common.Pool: telegram: POOL - STOP Alive Toggle Fail
2022-11-01 18:22:10.769 - info: vis.0 (103941) Terminated (NO_ERROR): Without reason
2022-11-01 18:22:11.411 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
2022-11-01 18:22:11.890 - error: iot.0 (103975) iot.0 already running
2022-11-01 18:22:11.898 - warn: iot.0 (103975) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2022-11-01 18:22:12.013 - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 103997
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/59558/iobroker-error</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 02:25:12 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/59558.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Nov 2022 17:29:38 GMT</pubDate><ttl>60</ttl></channel></rss>
