<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[mqtt: Error: listen EADDRINUSE: address already in use]]></title><description><![CDATA[<p dir="auto">Ich möchte mqtt über Port 1883 betreiben, habe ich so auch eingestellt.<br />
Beim start des Adapters kommt:</p>
<pre><code>starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.mqtt, node: v16.17.1, js-controller: 4.0.23
Starting MQTT server on 0.0.0.0:1883
uncaught exception: listen EADDRINUSE: address already in use 0.0.0.0:1884
Error: listen EADDRINUSE: address already in use 0.0.0.0:1884 at Server.setupListenHandle [as _listen2] (node:net:1432:16) at listenInCluster (node:net:1480:12) at doListen (node:net:1629:7) at processTicksAndRejections (node:internal/process/task_queues:84:21) at runNextTicks (node:internal/process/task_queues:65:3) at processImmediate (node:internal/timers:437:9)
Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use 0.0.0.0:1884
</code></pre>
<p dir="auto">Was kann ich tun um das zu beheben?</p>
]]></description><link>https://forum.iobroker.net/topic/59464/mqtt-error-listen-eaddrinuse-address-already-in-use</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 13:20:02 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/59464.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 29 Oct 2022 17:27:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to mqtt: Error: listen EADDRINUSE: address already in use on Sat, 29 Oct 2022 18:16:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a></p>
<p dir="auto">OK, jetzt habe ich alles neu gestartet und es kommen auch Werte an. Dass der Adapter gelb bleibt hat mich aber etwas irritiert.</p>
]]></description><link>https://forum.iobroker.net/post/882193</link><guid isPermaLink="true">https://forum.iobroker.net/post/882193</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sat, 29 Oct 2022 18:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt: Error: listen EADDRINUSE: address already in use on Sat, 29 Oct 2022 17:55:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> Wenn er gelb ist, heisst das nur, dass ich kein Client mit ihm verbunden hat. Und es ist Aufgabe eines Clients sich zu verbinden und nicht eine des Brokers.</p>
]]></description><link>https://forum.iobroker.net/post/882181</link><guid isPermaLink="true">https://forum.iobroker.net/post/882181</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Sat, 29 Oct 2022 17:55:11 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt: Error: listen EADDRINUSE: address already in use on Sat, 29 Oct 2022 17:53:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
Ich habe jetzt inzwischen den Adapter deinstalliert und neu installiert (dabei gleich ein Update gemacht). Die Meldung mit Port 1884 ist jetzt weg, aber der Adapter bleibt gelb (Keine Verbindung) und es kommen auch keine Daten an.</p>
]]></description><link>https://forum.iobroker.net/post/882179</link><guid isPermaLink="true">https://forum.iobroker.net/post/882179</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sat, 29 Oct 2022 17:53:10 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt: Error: listen EADDRINUSE: address already in use on Sat, 29 Oct 2022 17:43:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> laut Doku <a href="https://www.iobroker.net/#de/adapters/adapterref/iobroker.mqtt/README.md" rel="nofollow ugc">https://www.iobroker.net/#de/adapters/adapterref/iobroker.mqtt/README.md</a></p>
<blockquote>
<p dir="auto">Port - Der Port für die Verbindung über TCP (Standard ist 1883), ein WebSocket-Server (siehe <span style="color:#ff0000"><strong>Option</strong></span> oben) wird an Port +1 (Standard: 1884) ausgeführt.</p>
</blockquote>
<p dir="auto">also musst du ihn aktiviert haben.</p>
]]></description><link>https://forum.iobroker.net/post/882173</link><guid isPermaLink="true">https://forum.iobroker.net/post/882173</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 29 Oct 2022 17:43:36 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt: Error: listen EADDRINUSE: address already in use on Sat, 29 Oct 2022 17:39:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a></p>
<pre><code>pi@raspberrypi:~ $ iobroker list instances
+ system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
+ system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
  system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
+ system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
  system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
+ system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
+ system.adapter.enigma2.1                : enigma2               : raspberrypi                              -  enabled
+ system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
+ system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
+ system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
+ system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
  system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              - disabled
  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
+ system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
  system.adapter.info.0                   : info                  : raspberrypi                              - disabled
+ system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
+ system.adapter.kodi.0                   : kodi                  : raspberrypi                              -  enabled, port: 9090
+ system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
  system.adapter.modbus.0                 : modbus                : raspberrypi                              - disabled
+ system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              -  enabled
+ system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
+ system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
  system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
+ system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
+ system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
+ system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
  system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
+ system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
  system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
  system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
+ system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7aead84aacc9eb118e17914f1d69213e-if00-port0
+ instance is alive
pi@raspberrypi:~ $
</code></pre>
<p dir="auto">Port 1884 wird von Sonoff verwendet.<br />
Websockets ist nicht aktiviert.</p>
]]></description><link>https://forum.iobroker.net/post/882167</link><guid isPermaLink="true">https://forum.iobroker.net/post/882167</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sat, 29 Oct 2022 17:39:52 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt: Error: listen EADDRINUSE: address already in use on Sat, 29 Oct 2022 17:31:00 GMT]]></title><description><![CDATA[<p dir="auto">Wahrschienlich wieder websockets im mqtt Adapter aktiviert. Macht halt keine Haken, wenn ihr nicht wisst für was sie sind.</p>
]]></description><link>https://forum.iobroker.net/post/882165</link><guid isPermaLink="true">https://forum.iobroker.net/post/882165</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Sat, 29 Oct 2022 17:31:00 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt: Error: listen EADDRINUSE: address already in use on Sat, 29 Oct 2022 17:28:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/882162">mqtt: Error: listen EADDRINUSE: address already in use</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">erst mal <code>iobroker list instances</code> aufrufen und Ergebnis posten</p>
]]></description><link>https://forum.iobroker.net/post/882164</link><guid isPermaLink="true">https://forum.iobroker.net/post/882164</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 29 Oct 2022 17:28:20 GMT</pubDate></item></channel></rss>
