<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">ich habe folgendes Fehlerbild bei einem Adapterupdate aus Github bekommen.</p>
<p dir="auto">Kann da jemand etwas mit anfangen?</p>
<p dir="auto">Danke und Gruß</p>
<p dir="auto">Peter</p>
<pre><code>
$ iobroker url Zefau/ioBroker.jarvis --host iobroker --debug
install Zefau/ioBroker.jarvis
Installing Zefau/ioBroker.jarvis... (System call)
npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@types/component-emitternpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@types/json-buffernpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/compress-brotli
npm ERR! code ENOENTnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/@types/component-emitter
npm ERR! errno -2
npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/@types/component-emitter'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2022-10-05T11_50_52_749Z-debug.log
host.iobroker Cannot install Zefau/ioBroker.jarvis: 254
ERROR: Process exited with code 25
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/58652/problem-fehler-25-mit-npm-6-14-17-beim-adapterupdate</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 01:58:41 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/58652.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Oct 2022 12:14:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate on Thu, 06 Oct 2022 10:43:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schtallone" aria-label="Profile: schtallone">@<bdi>schtallone</bdi></a> sagte in <a href="/post/869071">[Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate</a>:</p>
<blockquote>
<p dir="auto">Gibt auch eine Anleitung hier wie das sauber geht mit einem neuen Container und Backup einspielen?</p>
</blockquote>
<p dir="auto">Was für eine Anleitung !?</p>
<p dir="auto">Ein Backup mit BackitUp auf deinem alten System erstellen ...<br />
dann :</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a> sagte in <a href="/post/869064">[Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate</a>:<br />
: neuen Container mit dem Image 7.0.1 erstellen ... Backup rein fertig !</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/869125</link><guid isPermaLink="true">https://forum.iobroker.net/post/869125</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Thu, 06 Oct 2022 10:43:09 GMT</pubDate></item><item><title><![CDATA[Reply to [Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate on Thu, 06 Oct 2022 09:20:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schtallone" aria-label="Profile: schtallone">@<bdi>schtallone</bdi></a> sagte in <a href="/post/869059">[Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate</a>:</p>
<blockquote>
<p dir="auto">Eine andere Frage: MAcht das unbedingt sinn, die Node.js zu aktualiesieren.</p>
</blockquote>
<p dir="auto">Es ist sinnvoll die jeweilig empfohlene Versionslinie mit aktuellem Stand im System zu haben.</p>
]]></description><link>https://forum.iobroker.net/post/869073</link><guid isPermaLink="true">https://forum.iobroker.net/post/869073</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 06 Oct 2022 09:20:49 GMT</pubDate></item><item><title><![CDATA[Reply to [Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate on Thu, 06 Oct 2022 09:18:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a> said in <a href="/post/869064">[Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate</a>:</p>
<blockquote>
<p dir="auto">Image 7.0.1 erstellen</p>
</blockquote>
<p dir="auto">danke für den Tipp. Ich bin ja froh das der bisherige Container eigentlich läuft. Gibt auch eine Anleitung hier wie das sauber geht mit einem neuen Container und Backup einspielen? Sorry, abewr ich bin nicht so erfahren...</p>
]]></description><link>https://forum.iobroker.net/post/869071</link><guid isPermaLink="true">https://forum.iobroker.net/post/869071</guid><dc:creator><![CDATA[Schtallone]]></dc:creator><pubDate>Thu, 06 Oct 2022 09:18:27 GMT</pubDate></item><item><title><![CDATA[Reply to [Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate on Thu, 06 Oct 2022 09:08:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schtallone" aria-label="Profile: schtallone">@<bdi>schtallone</bdi></a></p>
<p dir="auto">Empfehlung : neuen Container mit dem Image 7.0.1 erstellen ... Backup rein fertig !</p>
]]></description><link>https://forum.iobroker.net/post/869064</link><guid isPermaLink="true">https://forum.iobroker.net/post/869064</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Thu, 06 Oct 2022 09:08:23 GMT</pubDate></item><item><title><![CDATA[Reply to [Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate on Thu, 06 Oct 2022 09:05:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
habe ich so durchgeführt und konnte nun auch ohne Fehlermeldung die Beta Version von jarvis istallieren.</p>
<p dir="auto">Eine andere Frage: MAcht das unbedingt sinn, die Node.js zu aktualiesieren. So wie ich das in der Anleitung lese, ist das ja nicht ohne und da ich auf nem Docker unterwegs bin mit meine ioB ist ja das Thema "Root" nicht so einfach.</p>
]]></description><link>https://forum.iobroker.net/post/869059</link><guid isPermaLink="true">https://forum.iobroker.net/post/869059</guid><dc:creator><![CDATA[Schtallone]]></dc:creator><pubDate>Thu, 06 Oct 2022 09:05:20 GMT</pubDate></item><item><title><![CDATA[Reply to [Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate on Wed, 05 Oct 2022 12:59:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schtallone" aria-label="Profile: schtallone">@<bdi>schtallone</bdi></a></p>
<pre><code>iob stop
iob fix
iob start
</code></pre>
]]></description><link>https://forum.iobroker.net/post/868645</link><guid isPermaLink="true">https://forum.iobroker.net/post/868645</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 05 Oct 2022 12:59:42 GMT</pubDate></item><item><title><![CDATA[Reply to [Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate on Wed, 05 Oct 2022 12:43:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a><br />
Hallo,</p>
<p dir="auto">ich habe die Installation über die Adapterseite und die "Katze" gemacht im Expertenmpdus. Einen Link selber habe ich nicht eingegeben sondern nur "jarvis" suchen lassen.</p>
<p dir="auto">Gruß</p>
]]></description><link>https://forum.iobroker.net/post/868635</link><guid isPermaLink="true">https://forum.iobroker.net/post/868635</guid><dc:creator><![CDATA[Schtallone]]></dc:creator><pubDate>Wed, 05 Oct 2022 12:43:22 GMT</pubDate></item><item><title><![CDATA[Reply to [Problem] Fehler 25 mit NPM 6.14.17 beim Adapterupdate on Wed, 05 Oct 2022 12:40:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schtallone" aria-label="Profile: schtallone">@<bdi>schtallone</bdi></a></p>
<p dir="auto">EDIT:</p>
<p dir="auto">ist der link richtig</p>
<blockquote>
<p dir="auto">iobroker url Zefau/ioBroker.jarvis</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/868626</link><guid isPermaLink="true">https://forum.iobroker.net/post/868626</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Wed, 05 Oct 2022 12:40:51 GMT</pubDate></item></channel></rss>
